Erreur à 19:39
Rien dans les logs
0000|[2024-03-29 19:14:15]DEBUG : get file '/var/log/TheengsGateway.log' from 192.168.0.73
0001|[2024-03-29 19:18:17]DEBUG : get file '/var/log/TheengsGateway.log' from 192.168.0.73
0002|[2024-03-29 19:21:15]DEBUG : get file '/var/log/TheengsGateway.log' from 192.168.0.73
0003|[2024-03-29 19:24:15]DEBUG : get file '/var/log/TheengsGateway.log' from 192.168.0.73
0004|[2024-03-29 19:28:17]DEBUG : get file '/var/log/TheengsGateway.log' from 192.168.0.73
0005|[2024-03-29 19:32:48]DEBUG : get file '/var/log/TheengsGateway.log' from 192.168.0.73
0006|[2024-03-29 19:35:29]DEBUG : get file '/var/log/TheengsGateway.log' from 192.168.0.73
0007|[2024-03-29 19:39:14]DEBUG : get file '/var/log/TheengsGateway.log' from 192.168.0.73
0008|[2024-03-29 19:42:16]DEBUG : get file '/var/log/TheengsGateway.log' from 192.168.0.73
Les logs de l’antenne
58611|DEBUG:BLEGateway:C4:7C:8D:6C:79:F2:AdvertisementData(local_name='Flower care', service_data={'0000fe95-0000-1000-8000-00805f9b34fb': b'q \x98\x00(\xf2yl\x8d|\xc4\r\t\x10\x02\x00\x00'}, service_uuids=['0000fe95-0000-1000-8000-00805f9b34fb'], rssi=-42)
58612|DEBUG:BLEGateway:Already discovered or filtered: C47C8D6C79F2
58613|DEBUG:BLEGateway:Sent `{"name": "Flower care", "id": "C4:7C:8D:6C:79:F2", "rssi": -42, "servicedatauuid": "fe95", "servicedata": "7120980028f2796c8d7cc40d0910020000", "brand": "Xiaomi/VegTrug", "model": "MiFlora", "model_id": "HHCCJCY01HHCC", "type": "PLANT", "fer": 0, "mac": "C4:7C:8D:6C:79:F2"}` to topic `home/TGW_1980/BTtoMQTT/C47C8D6C79F2`
58614|DEBUG:BLEGateway:A8:42:E3:69:87:F6:AdvertisementData(local_name='Core200S', manufacturer_data={1744: b'\x01\xf6\x87i\xe3B\xa8\xc6&\x02\x02\x02'}, rssi=-86)
58615|DEBUG:BLEGateway:Sent `{"manufacturerdata": "d00601f68769e342a8c626020202", "name": "Core200S", "id": "A8:42:E3:69:87:F6", "rssi": -86, "mfr": "Etekcity Corporation"}` to topic `home/TGW_1980/BTtoMQTT/A842E36987F6`
58616|INFO:BLEGateway:Sent 18 messages to MQTT
58617|DEBUG:BLEGateway:A8:42:E3:69:87:F6:AdvertisementData(local_name='Core200S', manufacturer_data={1744: b'\x01\xf6\x87i\xe3B\xa8\xc6&\x02\x02\x02'}, rssi=-74)
58618|DEBUG:BLEGateway:Sent `{"manufacturerdata": "d00601f68769e342a8c626020202", "name": "Core200S", "id": "A8:42:E3:69:87:F6", "rssi": -74, "mfr": "Etekcity Corporation"}` to topic `home/TGW_1980/BTtoMQTT/A842E36987F6`
58619|DEBUG:BLEGateway:EF:D6:E5:E2:AB:F5:AdvertisementData(manufacturer_data={76: b'\x12\x02\x00\x00'}, rssi=-96)
58620|DEBUG:BLEGateway:DC:D1:12:8A:D6:1E:AdvertisementData(local_name='nut', manufacturer_data={89: b'\x00F'}, service_data={'0000180a-0000-1000-8000-00805f9b34fb': b'\xdc\xd1\x12\x8a\xd6\x1e'}, service_uuids=['00001803-0000-1000-8000-00805f9b34fb'], rssi=-37)
58621|DEBUG:BLEGateway:Discovered Trackers: {'6F:0C:47:5D:E7:64': 1711689541, 'CF:5F:E8:4A:B5:70': 1711689541, 'DC:D1:12:8A:D6:1E': 1711689550}
58622|DEBUG:BLEGateway:Already discovered or filtered: DCD1128AD61E
58623|DEBUG:BLEGateway:Sent `{"manufacturerdata": "59000046", "name": "nut", "id": "DC:D1:12:8A:D6:1E", "rssi": -37, "servicedatauuid": "180a", "servicedata": "dcd1128ad61e", "brand": "nut", "model": "Smart Tracker", "model_id": "NUT", "type": "TRACK", "cidc": false, "acts": true, "cont": true, "track": true, "device": "nut Tracker"}` to topic `home/TGW_1980/BTtoMQTT/DCD1128AD61E`
58624|DEBUG:BLEGateway:76:50:10:E4:58:72:AdvertisementData(manufacturer_data={76: b'\x10\x06\x06\x1a(g\xbc\x9a'}, tx_power=12, rssi=-98)
58625|DEBUG:BLEGateway:6F:0C:47:5D:E7:64:AdvertisementData(local_name='nut', manufacturer_data={210: b'\x003'}, service_data={'0000180a-0000-1000-8000-00805f9b34fb': b'o\x0cG]\xe7d'}, service_uuids=['00001803-0000-1000-8000-00805f9b34fb'], rssi=-64)
58626|DEBUG:BLEGateway:Discovered Trackers: {'6F:0C:47:5D:E7:64': 1711689551, 'CF:5F:E8:4A:B5:70': 1711689541, 'DC:D1:12:8A:D6:1E': 1711689550}
58627|DEBUG:BLEGateway:Already discovered or filtered: 6F0C475DE764
58628|DEBUG:BLEGateway:Sent `{"manufacturerdata": "d2000033", "name": "nut", "id": "6F:0C:47:5D:E7:64", "rssi": -64, "servicedatauuid": "180a", "servicedata": "6f0c475de764", "brand": "nut", "model": "Smart Tracker", "model_id": "NUT", "type": "TRACK", "cidc": false, "acts": true, "cont": true, "track": true, "device": "nut Tracker"}` to topic `home/TGW_1980/BTtoMQTT/6F0C475DE764`
58629|DEBUG:BLEGateway:A8:42:E3:69:87:F6:AdvertisementData(local_name='Core200S', manufacturer_data={1744: b'\x01\xf6\x87i\xe3B\xa8\xc6&\x02\x02\x02'}, rssi=-82)
58630|DEBUG:BLEGateway:Sent `{"manufacturerdata": "d00601f68769e342a8c626020202", "name": "Core200S", "id": "A8:42:E3:69:87:F6", "rssi": -82, "mfr": "Etekcity Corporation"}` to topic `home/TGW_1980/BTtoMQTT/A842E36987F6`
58631|DEBUG:BLEGateway:6B:A6:B7:67:9C:91:AdvertisementData(manufacturer_data={76: b'\x10\x05\x03\x18zp\xb6'}, tx_power=11, rssi=-95)
58632|DEBUG:BLEGateway:C4:7C:8D:6C:79:F2:AdvertisementData(local_name='Flower care', service_data={'0000fe95-0000-1000-8000-00805f9b34fb': b'q \x98\x00)\xf2yl\x8d|\xc4\r\x04\x10\x02\xc9\x00'}, service_uuids=['0000fe95-0000-1000-8000-00805f9b34fb'], rssi=-42)
58633|DEBUG:BLEGateway:Already discovered or filtered: C47C8D6C79F2
58634|DEBUG:BLEGateway:Sent `{"name": "Flower care", "id": "C4:7C:8D:6C:79:F2", "rssi": -42, "servicedatauuid": "fe95", "servicedata": "7120980029f2796c8d7cc40d041002c900", "brand": "Xiaomi/VegTrug", "model": "MiFlora", "model_id": "HHCCJCY01HHCC", "type": "PLANT", "tempc": 20.1, "tempf": 68.18, "mac": "C4:7C:8D:6C:79:F2"}` to topic `home/TGW_1980/BTtoMQTT/C47C8D6C79F2`
58635|DEBUG:BLEGateway:CF:5F:E8:4A:B5:70:AdvertisementData(local_name='nut', manufacturer_data={89: b'\x00P'}, service_data={'0000180a-0000-1000-8000-00805f9b34fb': b'\xcf_\xe8J\xb5p'}, service_uuids=['00001803-0000-1000-8000-00805f9b34fb'], rssi=-91)
58636|DEBUG:BLEGateway:Discovered Trackers: {'6F:0C:47:5D:E7:64': 1711689551, 'CF:5F:E8:4A:B5:70': 1711689552, 'DC:D1:12:8A:D6:1E': 1711689550}
58637|DEBUG:BLEGateway:Already discovered or filtered: CF5FE84AB570
58638|DEBUG:BLEGateway:Sent `{"manufacturerdata": "59000050", "name": "nut", "id": "CF:5F:E8:4A:B5:70", "rssi": -91, "servicedatauuid": "180a", "servicedata": "cf5fe84ab570", "brand": "nut", "model": "Smart Tracker", "model_id": "NUT", "type": "TRACK", "cidc": false, "acts": true, "cont": true, "track": true, "device": "nut Tracker"}` to topic `home/TGW_1980/BTtoMQTT/CF5FE84AB570`
58639|DEBUG:BLEGateway:A8:42:E3:69:87:F6:AdvertisementData(local_name='Core200S', manufacturer_data={1744: b'\x01\xf6\x87i\xe3B\xa8\xc6&\x02\x02\x02'}, rssi=-86)
58640|DEBUG:BLEGateway:Sent `{"manufacturerdata": "d00601f68769e342a8c626020202", "name": "Core200S", "id": "A8:42:E3:69:87:F6", "rssi": -86, "mfr": "Etekcity Corporation"}` to topic `home/TGW_1980/BTtoMQTT/A842E36987F6`
58641|DEBUG:BLEGateway:76:50:10:E4:58:72:AdvertisementData(manufacturer_data={76: b'\x10\x06\x06\x1a(g\xbc\x9a'}, tx_power=12, rssi=-82)
58642|DEBUG:BLEGateway:DC:D1:12:8A:D6:1E:AdvertisementData(local_name='nut', manufacturer_data={89: b'\x00F'}, service_data={'0000180a-0000-1000-8000-00805f9b34fb': b'\xdc\xd1\x12\x8a\xd6\x1e'}, service_uuids=['00001803-0000-1000-8000-00805f9b34fb'], rssi=-37)
58643|DEBUG:BLEGateway:Discovered Trackers: {'6F:0C:47:5D:E7:64': 1711689551, 'CF:5F:E8:4A:B5:70': 1711689552, 'DC:D1:12:8A:D6:1E': 1711689552}
58644|DEBUG:BLEGateway:Already discovered or filtered: DCD1128AD61E
58645|DEBUG:BLEGateway:Sent `{"manufacturerdata": "59000046", "name": "nut", "id": "DC:D1:12:8A:D6:1E", "rssi": -37, "servicedatauuid": "180a", "servicedata": "dcd1128ad61e", "brand": "nut", "model": "Smart Tracker", "model_id": "NUT", "type": "TRACK", "cidc": false, "acts": true, "cont": true, "track": true, "device": "nut Tracker"}` to topic `home/TGW_1980/BTtoMQTT/DCD1128AD61E`
58646|DEBUG:BLEGateway:7A:9F:A2:14:DE:95:AdvertisementData(manufacturer_data={76: b'\x10\x05\x0f\x18Y\x80x'}, tx_power=12, rssi=-98)
58647|DEBUG:BLEGateway:A8:42:E3:69:87:F6:AdvertisementData(local_name='Core200S', manufacturer_data={1744: b'\x01\xf6\x87i\xe3B\xa8\xc6&\x02\x02\x02'}, rssi=-80)
58648|DEBUG:BLEGateway:Sent `{"manufacturerdata": "d00601f68769e342a8c626020202", "name": "Core200S", "id": "A8:42:E3:69:87:F6", "rssi": -80, "mfr": "Etekcity Corporation"}` to topic `home/TGW_1980/BTtoMQTT/A842E36987F6`
58649|DEBUG:BLEGateway:7A:9F:A2:14:DE:95:AdvertisementData(manufacturer_data={76: b'\x10\x05\x0f\x18Y\x80x'}, tx_power=12, rssi=-97)
58650|DEBUG:BLEGateway:C4:7C:8D:6C:79:F2:AdvertisementData(local_name='Flower care', service_data={'0000fe95-0000-1000-8000-00805f9b34fb': b'q \x98\x00)\xf2yl\x8d|\xc4\r\x04\x10\x02\xc9\x00'}, service_uuids=['0000fe95-0000-1000-8000-00805f9b34fb'], rssi=-44)
58651|DEBUG:BLEGateway:Already discovered or filtered: C47C8D6C79F2
58652|DEBUG:BLEGateway:Sent `{"name": "Flower care", "id": "C4:7C:8D:6C:79:F2", "rssi": -44, "servicedatauuid": "fe95", "servicedata": "7120980029f2796c8d7cc40d041002c900", "brand": "Xiaomi/VegTrug", "model": "MiFlora", "model_id": "HHCCJCY01HHCC", "type": "PLANT", "tempc": 20.1, "tempf": 68.18, "mac": "C4:7C:8D:6C:79:F2"}` to topic `home/TGW_1980/BTtoMQTT/C47C8D6C79F2`
58653|DEBUG:BLEGateway:A8:42:E3:69:87:F6:AdvertisementData(local_name='Core200S', manufacturer_data={1744: b'\x01\xf6\x87i\xe3B\xa8\xc6&\x02\x02\x02'}, rssi=-74)
58654|DEBUG:BLEGateway:Sent `{"manufacturerdata": "d00601f68769e342a8c626020202", "name": "Core200S", "id": "A8:42:E3:69:87:F6", "rssi": -74, "mfr": "Etekcity Corporation"}` to topic `home/TGW_1980/BTtoMQTT/A842E36987F6`
58655|DEBUG:BLEGateway:76:50:10:E4:58:72:AdvertisementData(manufacturer_data={76: b'\x10\x06\x06\x1a(g\xbc\x9a'}, tx_power=12, rssi=-88)
58656|DEBUG:BLEGateway:6B:A6:B7:67:9C:91:AdvertisementData(manufacturer_data={76: b'\x10\x05\x03\x18zp\xb6'}, tx_power=11, rssi=-95)
58657|DEBUG:BLEGateway:D1:FF:38:95:7C:32:AdvertisementData(manufacturer_data={76: b'\x12\x02\x00\x03'}, rssi=-91)
58658|DEBUG:BLEGateway:A8:42:E3:69:87:F6:AdvertisementData(local_name='Core200S', manufacturer_data={1744: b'\x01\xf6\x87i\xe3B\xa8\xc6&\x02\x02\x02'}, rssi=-74)
58659|DEBUG:BLEGateway:Sent `{"manufacturerdata": "d00601f68769e342a8c626020202", "name": "Core200S", "id": "A8:42:E3:69:87:F6", "rssi": -74, "mfr": "Etekcity Corporation"}` to topic `home/TGW_1980/BTtoMQTT/A842E36987F6`
58660|DEBUG:BLEGateway:DC:D1:12:8A:D6:1E:AdvertisementData(local_name='nut', manufacturer_data={89: b'\x00F'}, service_data={'0000180a-0000-1000-8000-00805f9b34fb': b'\xdc\xd1\x12\x8a\xd6\x1e'}, service_uuids=['00001803-0000-1000-8000-00805f9b34fb'], rssi=-40)
58661|DEBUG:BLEGateway:Discovered Trackers: {'6F:0C:47:5D:E7:64': 1711689551, 'CF:5F:E8:4A:B5:70': 1711689552, 'DC:D1:12:8A:D6:1E': 1711689553}
58662|DEBUG:BLEGateway:Already discovered or filtered: DCD1128AD61E
58663|DEBUG:BLEGateway:Sent `{"manufacturerdata": "59000046", "name": "nut", "id": "DC:D1:12:8A:D6:1E", "rssi": -40, "servicedatauuid": "180a", "servicedata": "dcd1128ad61e", "brand": "nut", "model": "Smart Tracker", "model_id": "NUT", "type": "TRACK", "cidc": false, "acts": true, "cont": true, "track": true, "device": "nut Tracker"}` to topic `home/TGW_1980/BTtoMQTT/DCD1128AD61E`
58664|DEBUG:BLEGateway:A8:42:E3:69:87:F6:AdvertisementData(local_name='Core200S', manufacturer_data={1744: b'\x01\xf6\x87i\xe3B\xa8\xc6&\x02\x02\x02'}, rssi=-81)
58665|DEBUG:BLEGateway:Sent `{"manufacturerdata": "d00601f68769e342a8c626020202", "name": "Core200S", "id": "A8:42:E3:69:87:F6", "rssi": -81, "mfr": "Etekcity Corporation"}` to topic `home/TGW_1980/BTtoMQTT/A842E36987F6`
58666|DEBUG:BLEGateway:6B:A6:B7:67:9C:91:AdvertisementData(manufacturer_data={76: b'\x10\x05\x03\x18zp\xb6'}, tx_power=11, rssi=-95)
58667|DEBUG:BLEGateway:6F:0C:47:5D:E7:64:AdvertisementData(local_name='nut', manufacturer_data={210: b'\x003'}, service_data={'0000180a-0000-1000-8000-00805f9b34fb': b'o\x0cG]\xe7d'}, service_uuids=['00001803-0000-1000-8000-00805f9b34fb'], rssi=-69)
58668|DEBUG:BLEGateway:Discovered Trackers: {'6F:0C:47:5D:E7:64': 1711689554, 'CF:5F:E8:4A:B5:70': 1711689552, 'DC:D1:12:8A:D6:1E': 1711689553}
58669|DEBUG:BLEGateway:Already discovered or filtered: 6F0C475DE764
58670|DEBUG:BLEGateway:Sent `{"manufacturerdata": "d2000033", "name": "nut", "id": "6F:0C:47:5D:E7:64", "rssi": -69, "servicedatauuid": "180a", "servicedata": "6f0c475de764", "brand": "nut", "model": "Smart Tracker", "model_id": "NUT", "type": "TRACK", "cidc": false, "acts": true, "cont": true, "track": true, "device": "nut Tracker"}` to topic `home/TGW_1980/BTtoMQTT/6F0C475DE764`
58671|DEBUG:BLEGateway:7A:9F:A2:14:DE:95:AdvertisementData(manufacturer_data={76: b'\x10\x05\x0f\x18Y\x80x'}, tx_power=12, rssi=-98)
58672|DEBUG:BLEGateway:A8:42:E3:69:87:F6:AdvertisementData(local_name='Core200S', manufacturer_data={1744: b'\x01\xf6\x87i\xe3B\xa8\xc6&\x02\x02\x02'}, rssi=-64)
58673|DEBUG:BLEGateway:Sent `{"manufacturerdata": "d00601f68769e342a8c626020202", "name": "Core200S", "id": "A8:42:E3:69:87:F6", "rssi": -64, "mfr": "Etekcity Corporation"}` to topic `home/TGW_1980/BTtoMQTT/A842E36987F6`
58674|DEBUG:BLEGateway:A8:42:E3:69:87:F6:AdvertisementData(local_name='Core200S', manufacturer_data={1744: b'\x01\xf6\x87i\xe3B\xa8\xc6&\x02\x02\x02'}, rssi=-74)
58675|DEBUG:BLEGateway:Sent `{"manufacturerdata": "d00601f68769e342a8c626020202", "name": "Core200S", "id": "A8:42:E3:69:87:F6", "rssi": -74, "mfr": "Etekcity Corporation"}` to topic `home/TGW_1980/BTtoMQTT/A842E36987F6`
58676|DEBUG:BLEGateway:C4:7C:8D:6C:79:F2:AdvertisementData(local_name='Flower care', service_data={'0000fe95-0000-1000-8000-00805f9b34fb': b'q \x98\x00)\xf2yl\x8d|\xc4\r\x04\x10\x02\xc9\x00'}, service_uuids=['0000fe95-0000-1000-8000-00805f9b34fb'], rssi=-44)
58677|DEBUG:BLEGateway:Already discovered or filtered: C47C8D6C79F2
58678|DEBUG:BLEGateway:Sent `{"name": "Flower care", "id": "C4:7C:8D:6C:79:F2", "rssi": -44, "servicedatauuid": "fe95", "servicedata": "7120980029f2796c8d7cc40d041002c900", "brand": "Xiaomi/VegTrug", "model": "MiFlora", "model_id": "HHCCJCY01HHCC", "type": "PLANT", "tempc": 20.1, "tempf": 68.18, "mac": "C4:7C:8D:6C:79:F2"}` to topic `home/TGW_1980/BTtoMQTT/C47C8D6C79F2`
58679|DEBUG:BLEGateway:A8:42:E3:69:87:F6:AdvertisementData(local_name='Core200S', manufacturer_data={1744: b'\x01\xf6\x87i\xe3B\xa8\xc6&\x02\x02\x02'}, rssi=-86)
58680|DEBUG:BLEGateway:Sent `{"manufacturerdata": "d00601f68769e342a8c626020202", "name": "Core200S", "id": "A8:42:E3:69:87:F6", "rssi": -86, "mfr": "Etekcity Corporation"}` to topic `home/TGW_1980/BTtoMQTT/A842E36987F6`
58681|INFO:BLEGateway:Sent 19 messages to MQTT
58682|DEBUG:BLEGateway:70:EA:8F:26:CC:30:AdvertisementData(manufacturer_data={76: b'\x02\x15\x1c\xa9.#\xf0\x87M\xf7\xb9\xa2\xfdKqjK\xf6\x00j\x00\x00\x03'}, rssi=-61)
58683|DEBUG:BLEGateway:Already discovered or filtered: 70EA8F26CC30
58684|DEBUG:BLEGateway:Sent `{"manufacturerdata": "4c0002151ca92e23f0874df7b9a2fd4b716a4bf6006a000003", "id": "70:EA:8F:26:CC:30", "rssi": -61, "brand": "GENERIC", "model": "iBeacon", "model_id": "IBEACON", "type": "BCON", "mfid": "4c00", "uuid": "1ca92e23f0874df7b9a2fd4b716a4bf6", "major": 106, "minor": 0, "volt": 0.3}` to topic `home/TGW_1980/BTtoMQTT/70EA8F26CC30`
58685|DEBUG:BLEGateway:A8:42:E3:69:87:F6:AdvertisementData(local_name='Core200S', manufacturer_data={1744: b'\x01\xf6\x87i\xe3B\xa8\xc6&\x02\x02\x02'}, rssi=-74)
58686|DEBUG:BLEGateway:Sent `{"manufacturerdata": "d00601f68769e342a8c626020202", "name": "Core200S", "id": "A8:42:E3:69:87:F6", "rssi": -74, "mfr": "Etekcity Corporation"}` to topic `home/TGW_1980/BTtoMQTT/A842E36987F6`
58687|DEBUG:BLEGateway:70:EA:8F:26:CC:30:AdvertisementData(manufacturer_data={76: b'\x02\x15\x1c\xa9.#\xf0\x87M\xf7\xb9\xa2\xfdKqjK\xf6\x00j\x00\x00\x03'}, rssi=-56)
58688|DEBUG:BLEGateway:Already discovered or filtered: 70EA8F26CC30
58689|DEBUG:BLEGateway:Sent `{"manufacturerdata": "4c0002151ca92e23f0874df7b9a2fd4b716a4bf6006a000003", "id": "70:EA:8F:26:CC:30", "rssi": -56, "brand": "GENERIC", "model": "iBeacon", "model_id": "IBEACON", "type": "BCON", "mfid": "4c00", "uuid": "1ca92e23f0874df7b9a2fd4b716a4bf6", "major": 106, "minor": 0, "volt": 0.3}` to topic `home/TGW_1980/BTtoMQTT/70EA8F26CC30`
58690|DEBUG:BLEGateway:76:50:10:E4:58:72:AdvertisementData(manufacturer_data={76: b'\x10\x06\x06\x1a(g\xbc\x9a'}, tx_power=12, rssi=-97)
58691|DEBUG:BLEGateway:C4:7C:8D:6C:79:F2:AdvertisementData(local_name='Flower care', service_data={'0000fe95-0000-1000-8000-00805f9b34fb': b'q \x98\x00*\xf2yl\x8d|\xc4\r\x07\x10\x03_\x00\x00'}, service_uuids=['0000fe95-0000-1000-8000-00805f9b34fb'], rssi=-42)
58692|DEBUG:BLEGateway:Already discovered or filtered: C47C8D6C79F2
58693|DEBUG:BLEGateway:Sent `{"name": "Flower care", "id": "C4:7C:8D:6C:79:F2", "rssi": -42, "servicedatauuid": "fe95", "servicedata": "712098002af2796c8d7cc40d0710035f0000", "brand": "Xiaomi/VegTrug", "model": "MiFlora", "model_id": "HHCCJCY01HHCC", "type": "PLANT", "lux": 95, "mac": "C4:7C:8D:6C:79:F2"}` to topic `home/TGW_1980/BTtoMQTT/C47C8D6C79F2`
58694|DEBUG:BLEGateway:70:EA:8F:26:CC:30:AdvertisementData(manufacturer_data={76: b'\x02\x15\x1c\xa9.#\xf0\x87M\xf7\xb9\xa2\xfdKqjK\xf6\x00j\x00\x00\x03'}, rssi=-63)
58695|DEBUG:BLEGateway:Already discovered or filtered: 70EA8F26CC30
58696|DEBUG:BLEGateway:Sent `{"manufacturerdata": "4c0002151ca92e23f0874df7b9a2fd4b716a4bf6006a000003", "id": "70:EA:8F:26:CC:30", "rssi": -63, "brand": "GENERIC", "model": "iBeacon", "model_id": "IBEACON", "type": "BCON", "mfid": "4c00", "uuid": "1ca92e23f0874df7b9a2fd4b716a4bf6", "major": 106, "minor": 0, "volt": 0.3}` to topic `home/TGW_1980/BTtoMQTT/70EA8F26CC30`
58697|DEBUG:BLEGateway:CF:5F:E8:4A:B5:70:AdvertisementData(local_name='nut', manufacturer_data={89: b'\x00P'}, service_data={'0000180a-0000-1000-8000-00805f9b34fb': b'\xcf_\xe8J\xb5p'}, service_uuids=['00001803-0000-1000-8000-00805f9b34fb'], rssi=-91)
58698|DEBUG:BLEGateway:Discovered Trackers: {'6F:0C:47:5D:E7:64': 1711689554, 'CF:5F:E8:4A:B5:70': 1711689561, 'DC:D1:12:8A:D6:1E': 1711689553}
58699|DEBUG:BLEGateway:Already discovered or filtered: CF5FE84AB570
58700|DEBUG:BLEGateway:Sent `{"manufacturerdata": "59000050", "name": "nut", "id": "CF:5F:E8:4A:B5:70", "rssi": -91, "servicedatauuid": "180a", "servicedata": "cf5fe84ab570", "brand": "nut", "model": "Smart Tracker", "model_id": "NUT", "type": "TRACK", "cidc": false, "acts": true, "cont": true, "track": true, "device": "nut Tracker"}` to topic `home/TGW_1980/BTtoMQTT/CF5FE84AB570`
58701|DEBUG:BLEGateway:A8:42:E3:69:87:F6:AdvertisementData(local_name='Core200S', manufacturer_data={1744: b'\x01\xf6\x87i\xe3B\xa8\xc6&\x02\x02\x02'}, rssi=-81)
58702|DEBUG:BLEGateway:Sent `{"manufacturerdata": "d00601f68769e342a8c626020202", "name": "Core200S", "id": "A8:42:E3:69:87:F6", "rssi": -81, "mfr": "Etekcity Corporation"}` to topic `home/TGW_1980/BTtoMQTT/A842E36987F6`
58703|DEBUG:BLEGateway:DC:D1:12:8A:D6:1E:AdvertisementData(local_name='nut', manufacturer_data={89: b'\x00F'}, service_data={'0000180a-0000-1000-8000-00805f9b34fb': b'\xdc\xd1\x12\x8a\xd6\x1e'}, service_uuids=['00001803-0000-1000-8000-00805f9b34fb'], rssi=-37)
58704|DEBUG:BLEGateway:Discovered Trackers: {'6F:0C:47:5D:E7:64': 1711689554, 'CF:5F:E8:4A:B5:70': 1711689561, 'DC:D1:12:8A:D6:1E': 1711689561}
58705|DEBUG:BLEGateway:Already discovered or filtered: DCD1128AD61E
58706|DEBUG:BLEGateway:Sent `{"manufacturerdata": "59000046", "name": "nut", "id": "DC:D1:12:8A:D6:1E", "rssi": -37, "servicedatauuid": "180a", "servicedata": "dcd1128ad61e", "brand": "nut", "model": "Smart Tracker", "model_id": "NUT", "type": "TRACK", "cidc": false, "acts": true, "cont": true, "track": true, "device": "nut Tracker"}` to topic `home/TGW_1980/BTtoMQTT/DCD1128AD61E`
58707|DEBUG:BLEGateway:70:EA:8F:26:CC:30:AdvertisementData(manufacturer_data={76: b'\x02\x15\x1c\xa9.#\xf0\x87M\xf7\xb9\xa2\xfdKqjK\xf6\x00j\x00\x00\x03'}, rssi=-57)
58708|DEBUG:BLEGateway:Already discovered or filtered: 70EA8F26CC30
58709|DEBUG:BLEGateway:Sent `{"manufacturerdata": "4c0002151ca92e23f0874df7b9a2fd4b716a4bf6006a000003", "id": "70:EA:8F:26:CC:30", "rssi": -57, "brand": "GENERIC", "model": "iBeacon", "model_id": "IBEACON", "type": "BCON", "mfid": "4c00", "uuid": "1ca92e23f0874df7b9a2fd4b716a4bf6", "major": 106, "minor": 0, "volt": 0.3}` to topic `home/TGW_1980/BTtoMQTT/70EA8F26CC30`
58710|DEBUG:BLEGateway:A8:42:E3:69:87:F6:AdvertisementData(local_name='Core200S', manufacturer_data={1744: b'\x01\xf6\x87i\xe3B\xa8\xc6&\x02\x02\x02'}, rssi=-87)
58711|DEBUG:BLEGateway:Sent `{"manufacturerdata": "d00601f68769e342a8c62602020
