je crois que depuis la dernière bêta avec la modif sur les CRON, je n’ai plus que la partie Tiles et Disque Dur qui ne mettent à jour…
En effet dans la log, je ne vois plus que le passage du refresh Token et Disque Dur :
3521|[2022-10-29 11:00:06][DEBUG] : ================= REFRESH TOKEN ==================
3522|[2022-10-29 11:00:06][DEBUG] : >───────── ARRET CRON FreeboxPUT
3523|[2022-10-29 11:00:06][DEBUG] : >───────── ARRET CRON FreeboxGET
3524|[2022-10-29 11:00:06][DEBUG] : >───────── ARRET CRON FreeboxAPI
3525|[2022-10-29 11:00:07][DEBUG] : │──────────> Close Session
3526|[2022-10-29 11:00:07][DEBUG] : [Freebox Close Session] : {"uid":"3fd12642ce2a7e2af7b640adb988ee39","success":false,"msg":"Vous devez vous connecter pour accéder à cette fonction","result":{"password_salt":"J9zcrrqHmYIJGeTsO+iLXss1aDUkvjEF","challenge":"xy\/lG74WfXv3J+L730010U0U7OsT0LP5"},"error_code":"invalid_session"}
3527|[2022-10-29 11:00:07][DEBUG] : [Freebox Password] : {"success":true,"result":{"logged_in":false,"challenge":"xy\/xxxxxxxxxxxxxxxx+L730010U0U7OsT0LP5","password_salt":"xxxxxxxxxxxxxxxxx+iLXss1aDUkvjEF","password_set":true}}
3528|[2022-10-29 11:00:07][DEBUG] : [Freebox Open Session] : {"result":{"session_token":"xxxxxxxxxxxxxxxxxxxxxxxx","challenge":"xy\/lG74WfXv3J+L730010U0U7OsT0LP5","password_salt":"xxxxxxxxxxxxxxxxxxxxxxxx+iLXss1aDUkvjEF","permissions":{"parental":true,"contacts":true,"explorer":true,"tv":true,"wdo":true,"downloader":true,"profile":true,"camera":true,"settings":true,"calls":true,"home":true,"pvr":true,"vm":true,"player":true},"password_set":true},"success":true}
3529|[2022-10-29 11:00:07][DEBUG] : [Freebox Etat Session] : OK / 1
3530|[2022-10-29 11:00:08][DEBUG] : >───────── REDEMARRAGE CRON FreeboxPUT
3531|[2022-10-29 11:00:08][DEBUG] : >───────── REDEMARRAGE CRON FreeboxGET
3532|[2022-10-29 11:00:09][DEBUG] : ================= FIN REFRESH TOKEN ==================
3533|[2022-10-29 11:01:14][DEBUG] : ================= CRON pour l'actualisation de : Disque Dur ==================
3534|[2022-10-29 11:01:14][DEBUG] : │ [Freebox Request Connexion] : GET sur la l'adresse mafreebox.freebox.fr/api/v9/storage/disk(null)
3535|[2022-10-29 11:01:14][DEBUG] : │ [Freebox Request Result] : {"success":true,"result":[{"idle_duration":0,"read_error_requests":0,"read_requests":2581642,"spinning":false,"table_type":"gpt","firmware":"M6CR054","type":"sata","idle":false,"connector":1,"id":1000,"write_error_requests":0,"state":"enabled","write_requests":24398944,"total_bytes":240050000000,"model":"CT240BX500SSD1","active_duration":0,"temp":55,"serial":"2131E5BCAD82","partitions":[{"fstype":"ext4","total_bytes":236090000000,"label":"Freebox_ssd","id":1001,"internal":false,"fsck_result":"no_run_yet","state":"mounted","disk_id":1000,"free_bytes":153860000000,"used_bytes":82210000000,"path":"L0ZyZWVib3hfc3Nk"}]},{"idle_duration":1240,"read_error_requests":0,"read_requests":5148530,"spinning":false,"table_type":"raid","firmware":"04.01A04","type":"sata","idle":true,"connector":3,"id":2000,"write_error_requests":0,"state":"disabled","write_requests":117,"total_bytes":1000000000000,"model":"WDC WD10SPZX-08Z10","active_duration":0,"temp":42,"serial":"WD-WXA1A981J4DT","partitions":[{"fstype":"raid","total_bytes":0,"label":"Volume 1000Go","id":2000,"internal":false,"fsck_result":"no_run_yet","state":"umounted","disk_id":2000,"free_bytes":0,"used_bytes":0,"path":"L1ZvbHVtZSAxMDAwR28="}]},{"idle_duration":1242,"read_error_requests":0,"read_requests":5226283,"spinning":false,"table_type":"raid","firmware":"02.01A02","type":"sata","idle":true,"connector":0,"id":3000,"write_error_requests":0,"state":"disabled","write_requests":165,"total_bytes":1000000000000,"model":"WDC WD10JUCX-56WPNY0","active_duration":0,"temp":50,"serial":"WD-WXC1A6813LS4","partitions":[{"fstype":"raid","total_bytes":0,"label":"Volume 1000Go 1","id":3000,"internal":false,"fsck_result":"no_run_yet","state":"umounted","disk_id":3000,"free_bytes":0,"used_bytes":0,"path":"L1ZvbHVtZSAxMDAwR28gMQ=="}]},{"idle_duration":1242,"read_error_requests":0,"read_requests":5108378,"spinning":false,"table_type":"raid","firmware":"04.01A04","type":"sata","idle":true,"connector":2,"id":4000,"write_error_requests":0,"state":"disabled","write_requests":157,"total_bytes":1000000000000,"model":"WDC WD10SPZX-08Z10","active_duration":0,"temp":44,"serial":"WD-WXN1AA8283Z5","partitions":[{"fstype":"raid","total_bytes":0,"label":"Volume 1000Go 2","id":4000,"internal":false,"fsck_result":"no_run_yet","state":"umounted","disk_id":4000,"free_bytes":0,"used_bytes":0,"path":"L1ZvbHVtZSAxMDAwR28gMg=="}]},{"idle_duration":0,"read_error_requests":0,"read_requests":0,"spinning":false,"table_type":"superfloppy","firmware":"","type":"raid","idle":false,"connector":0,"id":5000,"write_error_requests":0,"state":"enabled","write_requests":0,"total_bytes":2000000000000,"model":"","active_duration":0,"temp":0,"serial":"","partitions":[{"fstype":"ext4","total_bytes":1960000000000,"label":"Freebox","id":5000,"internal":false,"fsck_result":"no_run_yet","state":"mounted","disk_id":5000,"free_bytes":1260000000000,"used_bytes":705230000000,"path":"L0ZyZWVib3g="}]}]}
3536|[2022-10-29 11:01:14][DEBUG] : >───────── Occupation de la partition Freebox_ssd : 0.34821466389936 - Pour le disque [sata] - 1000
3537|[2022-10-29 11:01:14][DEBUG] : >───────── Occupation de la partition Volume 1000Go : 0 - Pour le disque [sata] - 2000
3538|[2022-10-29 11:01:14][DEBUG] : >───────── Occupation de la partition Freebox : 0.3598112244898 - Pour le disque [raid] - 5000
3539|[2022-10-29 11:01:14][DEBUG] : >───────── Occupation de la partition Volume 1000Go 1 : 0 - Pour le disque [sata] - 3000
3540|[2022-10-29 11:01:14][DEBUG] : >───────── Occupation de la partition Volume 1000Go 2 : 0 - Pour le disque [sata] - 4000
3541|[2022-10-29 11:01:14][DEBUG] : │ [Freebox Request Connexion] : GET sur la l'adresse mafreebox.freebox.fr/api/v9/storage/raid(null)
3542|[2022-10-29 11:01:14][DEBUG] : │ [Freebox Request Result] : {"success":true,"result":[{"degraded":false,"raid_disks":3,"next_check":0,"sync_action":"idle","level":"raid5","uuid":"335457db-52e0-4f9a-d4b2-44d7dd6d88cd","sysfs_state":"clear","id":0,"sync_completed_pos":0,"members":[{"total_bytes":1000000000000,"active_device":2,"id":2000,"corrected_read_errors":0,"array_id":0,"disk":{"firmware":"04.01A04","temp":42,"serial":"WD-WXA1A981J4DT","model":"WDC WD10SPZX-08Z10"},"role":"active","sct_erc_supported":true,"sct_erc_enabled":true,"dev_uuid":"ffcccc36-9e0a-c9af-35c1-e3d76774fafe","device_location":"sata-internal-p3","set_name":"Freebox","set_uuid":"335457db-52e0-4f9a-d4b2-44d7dd6d88cd"},{"total_bytes":1000000000000,"active_device":0,"id":3000,"corrected_read_errors":0,"array_id":0,"disk":{"firmware":"02.01A02","temp":50,"serial":"WD-WXC1A6813LS4","model":"WDC WD10JUCX-56WPNY0"},"role":"active","sct_erc_supported":false,"sct_erc_enabled":false,"dev_uuid":"97b5dea6-878c-d968-042f-ef28ac923a8c","device_location":"sata-internal-p0","set_name":"Freebox","set_uuid":"335457db-52e0-4f9a-d4b2-44d7dd6d88cd"},{"total_bytes":1000000000000,"active_device":1,"id":4000,"corrected_read_errors":0,"array_id":0,"disk":{"firmware":"04.01A04","temp":44,"serial":"WD-WXN1AA8283Z5","model":"WDC WD10SPZX-08Z10"},"role":"active","sct_erc_supported":true,"sct_erc_enabled":true,"dev_uuid":"45e980bd-c29b-d8cf-217b-ee18a1249792","device_location":"sata-internal-p2","set_name":"Freebox","set_uuid":"335457db-52e0-4f9a-d4b2-44d7dd6d88cd"}],"array_size":2000000000000,"state":"running","sync_speed":0,"name":"Freebox","check_interval":0,"disk_id":5000,"last_check":1634993019,"sync_completed_end":0,"sync_completed_percent":0}]}
3543|[2022-10-29 11:30:05][DEBUG] : ================= REFRESH TOKEN ==================
3544|[2022-10-29 11:30:05][DEBUG] : >───────── ARRET CRON FreeboxPUT
3545|[2022-10-29 11:30:05][DEBUG] : >───────── ARRET CRON FreeboxGET
3546|[2022-10-29 11:30:05][DEBUG] : >───────── ARRET CRON FreeboxAPI
3547|[2022-10-29 11:30:06][DEBUG] : │──────────> Close Session
J’ai constaté ce pb depuis le 27/10, j’attendais un peu voir si qq’un d’autre allait se manifester.
Cependant, j’ai également eu le soucis remonté par certains avec AlexaAPI où Alexa bloquait les requêtes à cause du user agent (Plus de reponse des appareils - #4 par skillix)
Eh bien j’ai fait la modif, j’ai relancé le démon AlexaAPI et surprise, les crons se relancent bien toutes pour FreeboxOS !!!
J’ai un peu de mal à comprendre la relation avec les 2…
