Hello
Je suis passé de zigbeelinker çà Jeezigbee vendredi a cause d’un blocage sans jamais avoir trouvé (rien dans le logs) , bref
J’ai une porte de garage avec un module réglé en impulsion, du au changement de plugin, je dois changer ma façon de faire .
Je créé un scenario avec en commande l’appui sur le bouton et juste une action pour le relais
Rien de plus simple sauf que le scenario ne se lance jamais
J’ai essayé
#[SAM - Salon - Cuisine][Bouton SF LEGRAND Porte du garage][Button]#
#[SAM - Salon - Cuisine][Bouton SF LEGRAND Porte du garage][Button]# == 'toggle'
Je n’ai pas d’idée , l’execution manuel fonctionne bien sur
C’est un bouton LEGRAND sans fil
"date_code": " \u000020171013\u0000\u0000\u0000\u0000\u0000",
"definition": {
"description": "Wireless remote switch",
"exposes": [
"access": 1,
"category": "diagnostic",
"description": "Remaining battery in %, can take up to 24 hours before reported",
"label": "Battery",
"name": "battery",
"property": "battery",
"type": "numeric",
"unit": "%",
"value_max": 100,
"value_min": 0
"access": 1,
"description": "Triggered action (e.g. a button click)",
"label": "Action",
"name": "action",
"property": "action",
"type": "enum",
"values": [
"identify",
"on",
"off",
"toggle",
"brightness_move_up",
"brightness_move_down",
"brightness_stop"
"access": 1,
"description": "Link quality (signal strength)",
"label": "Linkquality",
"name": "linkquality",
"property": "linkquality",
"type": "numeric",
"unit": "lqi",
"value_max": 255,
"value_min": 0
"model": "067773",
"options": [
"access": 2,
"description": "Set to false to disable the legacy integration (highly recommended), will change structure of the published payload (default true).",
"label": "Legacy",
"name": "legacy",
"property": "legacy",
"type": "binary",
"value_off": false,
"value_on": true
"access": 2,
"description": "Simulate a brightness value. If this device provides a brightness_move_up or brightness_move_down action it is possible to specify the update interval and delta. The action_brightness_delta indicates the delta for each interval. Note: will only work when legacy: false is set.",
"features": [
"access": 2,
"description": "Delta per interval, 20 by default",
"label": "Delta",
"name": "delta",
"property": "delta",
"type": "numeric",
"value_min": 0
"access": 2,
"description": "Interval duration",
"label": "Interval",
"name": "interval",
"property": "interval",
"type": "numeric",
"unit": "ms",
"value_min": 0
"label": "Simulated brightness",
"name": "simulated_brightness",
"property": "simulated_brightness",
"type": "composite"
"supports_ota": true,
"vendor": "Legrand"
"disabled": false,
"endpoints": {
"1": {
"bindings": [
"cluster": "genPollCtrl",
"target": {
"endpoint": 1,
"ieee_address": "0x804b50fffe77a064",
"type": "endpoint"
"cluster": "genPowerCfg",
"target": {
"endpoint": 1,
"type": "endpoint"
"cluster": "genOnOff",
"target": {
"endpoint": 1,
"type": "endpoint"
"cluster": "genLevelCtrl",
"target": {
"endpoint": 1,
"type": "endpoint"
"clusters": {
"input": [
"genBasic",
"genIdentify",
"genBinaryInput",
"genPollCtrl",
"genPowerCfg",
"manuSpecificLegrandDevices"
"output": [
"genIdentify",
"genOnOff",
"genLevelCtrl",
"genBasic",
"manuSpecificLegrandDevices",
"genOta"
"configured_reportings": [],
"scenes": []
"friendly_name": "Bouton LEGRAND Porte du garage",
"ieee_address": "0x0004740000795577",
"interview_completed": true,
"interviewing": false,
"manufacturer": " Legrand\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000",
"model_id": " Remote switch\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000",
"network_address": 770,
"power_source": "Battery",
"software_build_id": "0046",
"supported": true,
"type": "EndDevice"
Si vous avez une idée
