L’envoi des commandes vers le poêle ne fonctionnent pas
Voici les log de MCZremotre aprés redemarrage:
[2023-12-27 22:59:36]DEBUG : path:/var/www/html/plugins/mczremote/resources/mczremoted
[2023-12-27 22:59:36]DEBUG : Lancement démon MCZremote : /usr/bin/python3 /var/www/html/plugins/mczremote/resources/mczremoted/mczremoted.py --loglevel debug --mqttip 127.0.0.1 --mqttport 1883 --mqttauth 1 --mqttuser XXXXX --mqttpwd YYYYYYYYYYYYYYY --topicpub PUBmcz --topicsub SUBmcz --devserial SSSSSSSSSSS --devmac MMMMMMMMMMM --urlmcz http://app.mcz.it:9000 --socketport 55520 --sockethost 127.0.0.1 --callback http://127.0.0.1:80/plugins/mczremote/core/php/jeeMCZRemote.php --apikey AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA --pidfile /tmp/jeedom/mczremote/deamon.pid
[2023-12-27 22:59:15.094]DEBUG : Signal 15 caught, exiting...
[2023-12-27 22:59:15.095]DEBUG : Shutdown in progress...
[2023-12-27 22:59:15.096]DEBUG : Removing PID file /tmp/jeedom/mczremote/deamon.pid
[2023-12-27 22:59:38.680]INFO : Starting MCZ Remote Daemon (Version 0.2)
[2023-12-27 22:59:38.681]INFO : Log level: debug
[2023-12-27 22:59:38.682]DEBUG : Socket port: 55520
[2023-12-27 22:59:38.683]DEBUG : Socket host: 127.0.0.1
[2023-12-27 22:59:38.684]DEBUG : MQTT IP: 127.0.0.1
[2023-12-27 22:59:38.684]DEBUG : MQTT port: 1883
[2023-12-27 22:59:38.685]DEBUG : MQTT Authentication: 1
[2023-12-27 22:59:38.686]DEBUG : MQTT User: ********
[2023-12-27 22:59:38.686]DEBUG : MQTT Password: *********
[2023-12-27 22:59:38.687]DEBUG : MQTT Topic PUB: PUBmcz
[2023-12-27 22:59:38.687]DEBUG : MQTT Topic SUB: SUBmcz
[2023-12-27 22:59:38.688]DEBUG : MCZ Device Serial: ********
[2023-12-27 22:59:38.689]DEBUG : MCZ Device MAC: *********
[2023-12-27 22:59:38.690]DEBUG : MCZ Url: http://app.mcz.it:9000
[2023-12-27 22:59:38.691]DEBUG : PID file: /tmp/jeedom/mczremote/deamon.pid
[2023-12-27 22:59:38.692]DEBUG : Apikey: *******************************************************
[2023-12-27 22:59:38.693]DEBUG : Callback: http://127.0.0.1:80/plugins/mczremote/core/php/jeeMCZRemote.php
[2023-12-27 22:59:38.694]INFO : Connection en cours au broker MQTT (IP:127.0.0.1 PORT:1883)
[2023-12-27 22:59:38.701]INFO : Souscription au topic SUBmcz avec un Qos=1
[2023-12-27 22:59:38.703]DEBUG : Writing PID 15866 to /tmp/jeedom/mczremote/deamon.pid
[2023-12-27 22:59:38.707]DEBUG : Init request module v2.21.0
[2023-12-27 22:59:38.716]INFO : Connecté au broker MQTT avec le code : 0
[2023-12-27 22:59:38.730]DEBUG : Starting new HTTP connection (1): 127.0.0.1:80
[2023-12-27 22:59:38.757]DEBUG : http://127.0.0.1:80 "GET /plugins/mczremote/core/php/jeeMCZRemote.php?apikey=**************************************** HTTP/1.1" 200 1
[2023-12-27 22:59:38.763]DEBUG : request : http://127.0.0.1:80/plugins/mczremote/core/php/jeeMCZRemote.php?apikey=****************************************
[2023-12-27 22:59:38.764]DEBUG : Socket interface started
[2023-12-27 22:59:38.766]DEBUG : LoopNetServer Thread started
[2023-12-27 22:59:38.767]INFO : Start listening on: [127.0.0.1:55520]
[2023-12-27 22:59:38.767]DEBUG : Listening on: [127.0.0.1:55520]
[2023-12-27 22:59:38.769]DEBUG : start while read_socket
[2023-12-27 22:59:38.770]DEBUG : Read socket thread launched on: [127.0.0.1:55520]
[2023-12-27 22:59:43.782]DEBUG : Starting new HTTP connection (1): app.mcz.it:9000
[2023-12-27 22:59:43.882]DEBUG : http://app.mcz.it:9000 "GET /socket.io/?transport=polling&EIO=3&t=1703714383.7745655 HTTP/1.1" 200 121
[2023-12-27 22:59:44.047]INFO : Starting  link to mcz maestro
[2023-12-27 22:59:44.049]DEBUG : Link started to mcz maestro OK
[2023-12-27 22:59:44.085]INFO : Connected
[2023-12-27 22:59:44.086]DEBUG : SID is : PxsLCX47fRh6DvgHZgM4
[2023-12-27 22:59:44.227]INFO : Publication sur MQTT PUBmcz: {"Etat du poele": ["Code inconnu :", "91781347027523042834641894817091538412893000860324342555513324727753471042535878628896729616384"]}
[2023-12-27 22:59:44.497]INFO : Publication sur MQTT PUBmcz: {"Etat du poele": "Puissance 1", "Etat du ventilateur ambiance": "Automatique", "Etat du ventilateur canalise 1": "Niveau 1", "Etat du ventilateur canalise 2": "Desactive", "Temperature des fumees": 67.0, "Temperature ambiante": 22.0, "Puffer Temperature": 127.5, "Temperature chaudiere": 0.0, "Temperature NTC3": 127.5, "Etat de la bougie": "Ok", "ACTIVE - Set": 1000, "RPM - Ventilateur fummees": 999, "RPM - Vis sans fin - SET": 142, "RPM - Vis sans fin - LIVE": 137, "Brazero": ["Code inconnu :", "255"], "Profil": "Manuel", "Etat du mode Active": "Off", "ACTIVE - Live": 100, "Mode de regulation": "Dynamique", "Mode ECO": "Off", "Silence": "Off", "Mode Chronotermostato": "On", "TEMP - Consigne": 18.0, "TEMP - Boiler": 35.0, "TEMP - Carte mere": 35.0, "Puissance Active": "Puissance 1", "Heure du poele (0-23)": 23, "Minutes du poele (0-29)": 3, "Jour du poele (1-31)": 27, "Mois du poele (1-12)": 12, "Annee du poele": 2023, "Heures de fonctionnement total (s)": "44:0:34:46", "Heures de fonctionnement en puissance 1 (s)": "37:9:7:46", "Heures de fonctionnement en puissance 2 (s)": "0:14:17:58", "Heures de fonctionnement en puissance 3 (s)": "0:16:17:18", "Heures de fonctionnement en puissance 4 (s)": "1:17:16:50", "Heures de fonctionnement en puissance 5 (s)": "0:16:42:4", "Heures avant entretien": 943, "Minutes avant extinction": 0, "Nombre d'allumages": 133, "Sonde Pellets": "Sonde pas active", "Effet sonore": "Off", "Etat effets sonores": "On", "Sleep": "Off", "Mode": "Hiver", "Sonde wifi temperature 1": 127.5, "Sonde wifi temperature 2": 127.5, "Sonde wifi temperature 3": 127.5, "Inconnu": 255, "Set Puffer": 64, "Set Boiler": 50, "Set Health": 255, "Temperature retour": 127.5, "Antigel": "On"}
[2023-12-27 23:00:14.392]INFO : Publication sur MQTT PUBmcz: {"Etat du poele": "Puissance 1", "Etat du ventilateur ambiance": "Automatique", "Etat du ventilateur canalise 1": "Niveau 1", "Etat du ventilateur canalise 2": "Desactive", "Temperature des fumees": 66.0, "Temperature ambiante": 22.0, "Puffer Temperature": 127.5, "Temperature chaudiere": 0.0, "Temperature NTC3": 127.5, "Etat de la bougie": "Ok", "ACTIVE - Set": 1000, "RPM - Ventilateur fummees": 999, "RPM - Vis sans fin - SET": 142, "RPM - Vis sans fin - LIVE": 155, "Brazero": ["Code inconnu :", "255"], "Profil": "Manuel", "Etat du mode Active": "Off", "ACTIVE - Live": 99, "Mode de regulation": "Dynamique", "Mode ECO": "Off", "Silence": "Off", "Mode Chronotermostato": "On", "TEMP - Consigne": 18.0, "TEMP - Boiler": 35.0, "TEMP - Carte mere": 35.0, "Puissance Active": "Puissance 1", "Heure du poele (0-23)": 23, "Minutes du poele (0-29)": 3, "Jour du poele (1-31)": 27, "Mois du poele (1-12)": 12, "Annee du poele": 2023, "Heures de fonctionnement total (s)": "44:0:35:15", "Heures de fonctionnement en puissance 1 (s)": "37:9:8:15", "Heures de fonctionnement en puissance 2 (s)": "0:14:17:58", "Heures de fonctionnement en puissance 3 (s)": "0:16:17:18", "Heures de fonctionnement en puissance 4 (s)": "1:17:16:50", "Heures de fonctionnement en puissance 5 (s)": "0:16:42:4", "Heures avant entretien": 943, "Minutes avant extinction": 0, "Nombre d'allumages": 133, "Sonde Pellets": "Sonde pas active", "Effet sonore": "Off", "Etat effets sonores": "On", "Sleep": "Off", "Mode": "Hiver", "Sonde wifi temperature 1": 127.5, "Sonde wifi temperature 2": 127.5, "Sonde wifi temperature 3": 127.5, "Inconnu": 255, "Set Puffer": 64, "Set Boiler": 50, "Set Health": 255, "Temperature retour": 127.5, "Antigel": "On"}
[2023-12-27 23:00:44.222]INFO : Publication sur MQTT PUBmcz: {"Etat du poele": "Puissance 1", "Etat du ventilateur ambiance": "Automatique", "Etat du ventilateur canalise 1": "Niveau 1", "Etat du ventilateur canalise 2": "Desactive", "Temperature des fumees": 66.5, "Temperature ambiante": 22.0, "Puffer Temperature": 127.5, "Temperature chaudiere": 0.0, "Temperature NTC3": 127.5, "Etat de la bougie": "Ok", "ACTIVE - Set": 1000, "RPM - Ventilateur fummees": 998, "RPM - Vis sans fin - SET": 142, "RPM - Vis sans fin - LIVE": 180, "Brazero": ["Code inconnu :", "255"], "Profil": "Manuel", "Etat du mode Active": "Off", "ACTIVE - Live": 99, "Mode de regulation": "Dynamique", "Mode ECO": "Off", "Silence": "Off", "Mode Chronotermostato": "On", "TEMP - Consigne": 18.0, "TEMP - Boiler": 35.0, "TEMP - Carte mere": 35.0, "Puissance Active": "Puissance 1", "Heure du poele (0-23)": 23, "Minutes du poele (0-29)": 4, "Jour du poele (1-31)": 27, "Mois du poele (1-12)": 12, "Annee du poele": 2023, "Heures de fonctionnement total (s)": "44:0:35:45", "Heures de fonctionnement en puissance 1 (s)": "37:9:8:45", "Heures de fonctionnement en puissance 2 (s)": "0:14:17:58", "Heures de fonctionnement en puissance 3 (s)": "0:16:17:18", "Heures de fonctionnement en puissance 4 (s)": "1:17:16:50", "Heures de fonctionnement en puissance 5 (s)": "0:16:42:4", "Heures avant entretien": 943, "Minutes avant extinction": 0, "Nombre d'allumages": 133, "Sonde Pellets": "Sonde pas active", "Effet sonore": "Off", "Etat effets sonores": "On", "Sleep": "Off", "Mode": "Hiver", "Sonde wifi temperature 1": 127.5, "Sonde wifi temperature 2": 127.5, "Sonde wifi temperature 3": 127.5, "Inconnu": 255, "Set Puffer": 64, "Set Boiler": 50, "Set Health": 255, "Temperature retour": 127.5, "Antigel": "On"}
[2023-12-27 23:01:14.193]INFO : Publication sur MQTT PUBmcz: {"Etat du poele": "Puissance 1", "Etat du ventilateur ambiance": "Automatique", "Etat du ventilateur canalise 1": "Niveau 1", "Etat du ventilateur canalise 2": "Desactive", "Temperature des fumees": 66.5, "Temperature ambiante": 22.0, "Puffer Temperature": 127.5, "Temperature chaudiere": 0.0, "Temperature NTC3": 127.5, "Etat de la bougie": "Ok", "ACTIVE - Set": 1000, "RPM - Ventilateur fummees": 998, "RPM - Vis sans fin - SET": 142, "RPM - Vis sans fin - LIVE": 241, "Brazero": ["Code inconnu :", "255"], "Profil": "Manuel", "Etat du mode Active": "Off", "ACTIVE - Live": 100, "Mode de regulation": "Dynamique", "Mode ECO": "Off", "Silence": "Off", "Mode Chronotermostato": "On", "TEMP - Consigne": 18.0, "TEMP - Boiler": 35.0, "TEMP - Carte mere": 35.0, "Puissance Active": "Puissance 1", "Heure du poele (0-23)": 23, "Minutes du poele (0-29)": 4, "Jour du poele (1-31)": 27, "Mois du poele (1-12)": 12, "Annee du poele": 2023, "Heures de fonctionnement total (s)": "44:0:36:15", "Heures de fonctionnement en puissance 1 (s)": "37:9:9:15", "Heures de fonctionnement en puissance 2 (s)": "0:14:17:58", "Heures de fonctionnement en puissance 3 (s)": "0:16:17:18", "Heures de fonctionnement en puissance 4 (s)": "1:17:16:50", "Heures de fonctionnement en puissance 5 (s)": "0:16:42:4", "Heures avant entretien": 943, "Minutes avant extinction": 0, "Nombre d'allumages": 133, "Sonde Pellets": "Sonde pas active", "Effet sonore": "Off", "Etat effets sonores": "On", "Sleep": "Off", "Mode": "Hiver", "Sonde wifi temperature 1": 127.5, "Sonde wifi temperature 2": 127.5, "Sonde wifi temperature 3": 127.5, "Inconnu": 255, "Set Puffer": 64, "Set Boiler": 50, "Set Health": 255, "Temperature retour": 127.5, "Antigel": "On"}
Merci pour ton aide.
