Partie 3 :
+ sleep 1
K3: Layer 4 [ 1:main 0.000] initialized
K3: I00000131: [ 1:main] 0.14.51: knxd -n K3 -B log -t 0xfffc -f 9 -e 4.3.0 -E 4.3.1:5 -B log -u/tmp/fileC6inuR -B log -b ipt:localhost:25673:25676
K3: Layer 4 [ 1:main 0.000] setting up
K3: Layer 0 [ 4:log/main 0.000] State setup
K3: Layer 0 [ 8:log/A.unix 0.000] State setup
K3: Layer 3 [ 5:A.unix/local 0.000] registerLink: 5:A.unix
K3: Layer 0 [12:log/B.ipt 0.000] State setup
K3: Layer 3 [10:B.ipt/Conn 0.000] registerLink: 10:B.ipt
K3: I00000129: [ 1:main] Connected: cfg:B.ipt.
K3: I00000129: [ 1:main] Connected: cfg:A.unix.
K3: Layer 4 [ 1:main 0.000] setup OK
K3: W00000125: [ 1:main] Consider using a config file.
K3: W00000126: [ 1:main] knxd should not run as root
K3: Layer 4 [ 1:main 0.000] trigger going up
K3: Layer 0 [ 4:log/main 0.000] State start
K3: Layer 3 [10:B.ipt/Conn 0.000] Start: cfg:B.ipt
K3: Layer 5 [10:B.ipt/Conn 0.000] down => >up
K3: Layer 5 [10:B.ipt/Conn 0.000] Starting
K3: Layer 0 [12:log/B.ipt 0.000] State start
K3: Layer 2 [11:B.ipt/ipt 0.000] Open
K3: Layer 2 [11:B.ipt/ipt 0.001] Opened
K3: Layer 4 [10:B.ipt/Conn 0.001] link state changed: >up
K3: Layer 3 [ 5:A.unix/local 0.001] Start: cfg:A.unix
K3: Layer 5 [ 5:A.unix/local 0.001] down => >up
K3: Layer 8 [ 5:A.unix/local 0.001] OpenLocalSocket /tmp/fileC6inuR
K3: Layer 8 [ 5:A.unix/local 0.001] LocalSocket opened
K3: Layer 5 [ 5:A.unix/local 0.001] >up => up
K3: Layer 4 [ 5:A.unix/local 0.001] link state changed: up
K3: Layer 5 [ 5:A.unix/local 0.001] Started
K3: Layer 4 [ 1:main 0.001] going up triggered
K3: Layer 4 [ 1:main 0.002] check start
K3: Layer 4 [10:B.ipt/Conn 0.002] state is >up
K3: Layer 4 [ 1:main 0.002] check end: want_up 1 some 1>1 all 0>0, going 1 up 1 down 0
K2: Layer 3 [ 5:server/Server 2.004] Allocate 4.2.1
K2: Layer 8 [ 5:server/Server 2.004] Tunnel CONNECTION_REQ with 4.2.1
K2: Layer 9 [29:tunnel/4.2.1 2.004] has 4.2.1
K2: Layer 0 [30:log/tunnel 2.005] State setup
K2: Layer 8 [29:tunnel/4.2.1 2.005] Start Conn 1
K2: Layer 3 [28:tunnel/ConnC 2.005] registerLink: 28:tunnel_28
K2: Layer 3 [28:tunnel/ConnC 2.005] Start: cfg:tunnel
K2: Layer 5 [28:tunnel/ConnC 2.005] down => >up
K2: Layer 5 [28:tunnel/ConnC 2.005] Starting
K2: Layer 0 [30:log/tunnel 2.005] State start
K2: Layer 0 [30:log/tunnel 2.005] State started
K2: Layer 5 [28:tunnel/ConnC 2.005] >up => up
K2: Layer 4 [28:tunnel/ConnC 2.005] link state changed: up
K2: Layer 5 [28:tunnel/ConnC 2.005] Started
K2: Layer 4 [ 1:main 2.005] check start
K2: Layer 4 [ 1:main 2.005] check end: want_up 1 some 1>1 all 0>1, going 0 up 4 down 0
K3: Layer 0 [12:log/B.ipt 0.002] State started
K3: Layer 5 [10:B.ipt/Conn 0.002] >up => up
K3: Layer 4 [10:B.ipt/Conn 0.002] link state changed: up
K3: Layer 5 [10:B.ipt/Conn 0.002] Started
K3: Layer 4 [ 1:main 0.003] check start
K3: Layer 4 [ 1:main 0.003] check end: want_up 1 some 1>1 all 0>1, going 0 up 2 down 0
K3: Layer 0 [ 4:log/main 0.003] State started
K3: Layer 4 [ 1:main 0.003] all drivers up
K3: Layer 4 [ 1:main 0.003] up
+ PL1=15768
+ knxtool vbusmonitor1 local:/tmp/fileqEi6OR
+ PL2=15769
+ knxtool vbusmonitor1 local:/tmp/file6I674Q
+ PL3=15770
+ PL5=15771
+ sleep 1
+ knxtool vbusmonitor1 local:/tmp/fileC6inuR
K1: Layer 8 [ 8:B.unix/local 4.999] New Connection
K1: Layer 8 [30:B.unix/CConn 4.999] ClientConnection Init
K1: Layer 3 [30:B.unix/CConn 4.999] Allocate 4.1.1
K2: Layer 8 [14:A.unix/local 2.995] New Connection
K2: Layer 8 [32:A.unix/CConn 2.995] ClientConnection Init
K1: Layer 7 [32:B.unix/BusMon 4.999] Open A_Busmonitor
K2: Layer 3 [32:A.unix/CConn 2.995] Allocate 4.2.2
K1: Layer 3 [ 1:main 4.999] registerVBusmonitor
K2: Layer 7 [34:A.unix/BusMon 2.995] Open A_Busmonitor
K2: Layer 3 [ 1:main 2.995] registerVBusmonitor
+ knxtool grouplisten local:/tmp/file6I674Q 1/2/3
K3: Layer 8 [ 5:A.unix/local 0.995] New Connection
K3: Layer 8 [15:A.unix/CConn 0.995] ClientConnection Init
K3: Layer 3 [15:A.unix/CConn 0.995] Allocate 4.3.1
K3: Layer 7 [17:A.unix/BusMon 0.995] Open A_Busmonitor
K3: Layer 3 [ 1:main 0.995] registerVBusmonitor
K2: Layer 8 [14:A.unix/local 2.999] New Connection
K2: Layer 8 [35:A.unix/CConn 2.999] ClientConnection Init
K2: Layer 3 [35:A.unix/CConn 2.999] Allocate 4.2.3
K2: Layer 7 [36:A.unix@4.2.3/Group 2.999] OpenGroup
K2: Layer 4 [38:A.unix/TGr 2.999] OpenGroup 1/2/3 RW
K2: Layer 0 [39:log/A.unix 2.999] State setup
K2: Layer 7 [36:A.unix@4.2.3/Group 2.999] OpenGroup complete
K2: Layer 3 [37:A.unix/ConnS 2.999] registerLink: 37:A.unix_37
K2: Layer 3 [37:A.unix/ConnS 2.999] Start: cfg:A.unix
K2: Layer 5 [37:A.unix/ConnS 2.999] down => >up
K2: Layer 5 [37:A.unix/ConnS 2.999] Starting
K2: Layer 0 [39:log/A.unix 2.999] State start
K2: Layer 0 [39:log/A.unix 2.999] State started
K2: Layer 5 [37:A.unix/ConnS 2.999] >up => up
K2: Layer 4 [37:A.unix/ConnS 2.999] link state changed: up
K2: Layer 5 [37:A.unix/ConnS 2.999] Started
K2: Layer 4 [ 1:main 2.999] check start
K2: Layer 4 [ 1:main 2.999] check end: want_up 1 some 1>1 all 0>1, going 0 up 4 down 0
+ PL4=15785
+ knxtool groupcachereadsync local:/tmp/fileqEi6OR 1/2/3 3
+ sleep 2
K1: Layer 8 [ 8:B.unix/local 6.004] New Connection
K1: Layer 8 [33:B.unix/CConn 6.004] ClientConnection Init
K1: Layer 3 [33:B.unix/CConn 6.005] Allocate 4.1.2
K1: Layer 4 [ 5:A.cache/G 6.005] GroupCacheRead 1/2/3 75 3
K1: Layer 0 [ 6:log/A.cache 6.005] Recv L_Data low from 0.0.0 to 1/2/3 hops: 06 T_Data_Group A_GroupValue_Read
K1: Layer 0 [ 7:log/main 6.005] Recv L_Data low from 4.1.0 to 1/2/3 hops: 06 T_Data_Group A_GroupValue_Read
K1: Layer 0 [ 7:log/main 6.005] Send L_Data low from 4.1.0 to 1/2/3 hops: 05 T_Data_Group A_GroupValue_Read
K1: Layer 6 [26:router/ConnC 6.005] sending, send_more clear
K1: Layer 0 [28:log/router 6.005] Send L_Data low from 4.1.0 to 1/2/3 hops: 05 T_Data_Group A_GroupValue_Read
K1: Layer 2 [29:C.pace/router 6.005] out 1/2: delay for 0.202 sec
K1: Layer 6 [23:D.dummy/Conn 6.005] sending, send_more clear
K1: Layer 6 [23:D.dummy/Conn 6.005] sendNext called, send_more set
K1: Layer 6 [ 1:main 6.005] sending set
K1: Layer 6 [ 4:A.cache/Conn 6.005] sending, send_more clear
K1: Layer 0 [ 6:log/A.cache 6.005] Send L_Data low from 4.1.0 to 1/2/3 hops: 05 T_Data_Group A_GroupValue_Read
K1: Layer 6 [ 6:log/A.cache 6.005] send next
K1: Layer 6 [ 4:A.cache/Conn 6.005] sendNext called, send_more set
K1: Layer 6 [26:router/ConnC 6.005] still waiting
K1: Layer 6 [ 1:main 6.005] wait L
K2: Layer 0 [21:log/B.ip 4.001] Recv L_Data low from 4.1.0 to 1/2/3 hops: 05 T_Data_Group A_GroupValue_Read
K2: Layer 8 [ 1:main 4.001] unknown addr 4.1.0
K2: Layer 0 [ 4:log/main 4.001] Recv L_Data low from 4.1.0 to 1/2/3 hops: 05 T_Data_Group A_GroupValue_Read
K2: Layer 0 [ 4:log/main 4.001] Send L_Data low from 4.1.0 to 1/2/3 hops: 04 T_Data_Group A_GroupValue_Read
K2: Layer 6 [37:A.unix/ConnS 4.001] sending, send_more clear
K2: Layer 0 [39:log/A.unix 4.001] Send L_Data low from 4.1.0 to 1/2/3 hops: 04 T_Data_Group A_GroupValue_Read
K2: Layer 7 [35:A.unix/CConn 4.001] Recv(002): 00 00
K2: Layer 6 [39:log/A.unix 4.001] send next
K2: Layer 6 [37:A.unix/ConnS 4.001] sendNext called, send_more set
K2: Layer 6 [ 1:main 4.001] sending set
K2: Layer 6 [24:router/ConnC 4.001] sending, send_more clear
K2: Layer 0 [26:log/router 4.001] Send L_Data low from 4.1.0 to 1/2/3 hops: 04 T_Data_Group A_GroupValue_Read
K2: Layer 2 [27:router.pace_/router 4.001] out 1/2: delay for 0.017 sec
K2: Layer 6 [28:tunnel/ConnC 4.001] sending, send_more clear
K2: Layer 6 [28:tunnel/ConnC 4.001] sendNext called, send_more set
K2: Layer 6 [37:A.unix/ConnS 4.001] is OK
K2: Layer 6 [24:router/ConnC 4.002] still waiting
K2: Layer 6 [ 1:main 4.002] wait L
K2: Layer 0 [30:log/tunnel 4.002] Send L_Data low from 4.1.0 to 1/2/3 hops: 04 T_Data_Group A_GroupValue_Read
K3: Layer 0 [12:log/B.ipt 1.999] Recv L_Data low from 4.1.0 to 1/2/3 hops: 04 T_Data_Group A_GroupValue_Read
K3: Layer 8 [ 1:main 1.999] unknown addr 4.1.0
K3: Layer 0 [ 4:log/main 1.999] Recv L_Data low from 4.1.0 to 1/2/3 hops: 04 T_Data_Group A_GroupValue_Read
K3: Layer 0 [ 4:log/main 1.999] Send L_Data low from 4.1.0 to 1/2/3 hops: 03 T_Data_Group A_GroupValue_Read
K3: Layer 6 [10:B.ipt/Conn 1.999] is OK
K3: Layer 6 [ 5:A.unix/local 1.999] is OK
K3: Layer 6 [ 1:main 1.999] OK
K3: Layer 6 [ 4:log/main 1.999] send next
K3: Layer 6 [ 2:main/L 1.999] OK L
K2: Layer 8 [29:tunnel/4.2.1 4.002] TUNNEL_ACK
K2: Layer 6 [30:log/tunnel 4.002] send next
K2: Layer 2 [27:router.pace_/router 4.018] delay done
K2: Layer 6 [26:log/router 4.018] send next
K2: Layer 6 [24:router/ConnC 4.018] sendNext called, send_more set
K2: Layer 6 [37:A.unix/ConnS 4.018] is OK
K2: Layer 6 [24:router/ConnC 4.018] is OK
K2: Layer 6 [19:B.ip/Conn 4.018] is OK
K2: Layer 6 [ 5:server/Server 4.018] is OK
K2: Layer 6 [28:tunnel/ConnC 4.018] is OK
K2: Layer 6 [14:A.unix/local 4.018] is OK
K2: Layer 6 [ 1:main 4.018] OK
K2: Layer 6 [ 4:log/main 4.018] send next
K2: Layer 6 [ 2:main/L 4.018] OK L
K1: Layer 4 [ 5:A.cache/G 6.080] GroupCache reread timeout
K1: Layer 8 [33:B.unix/CConn 6.080] ClientConnection 4.1.2 closing
K1: Layer 3 [ 1:main 6.080] Release 4.1.2
K1: Layer 2 [29:C.pace/router 6.207] delay done
K1: Layer 6 [28:log/router 6.207] send next
K1: Layer 6 [26:router/ConnC 6.207] sendNext called, send_more set
K1: Layer 6 [26:router/ConnC 6.207] is OK
K1: Layer 6 [23:D.dummy/Conn 6.207] is OK
K1: Layer 6 [13:server/Server 6.207] is OK
K1: Layer 6 [ 4:A.cache/Conn 6.207] is OK
K1: Layer 6 [ 8:B.unix/local 6.207] is OK
K1: Layer 6 [ 1:main 6.207] OK
K1: Layer 6 [ 7:log/main 6.207] send next
K1: Layer 6 [ 2:main/L 6.207] OK L
+ echo xmit 1
xmit 1
+ knxtool groupswrite local:/tmp/fileqEi6OR 1/2/3 4
K1: Layer 8 [ 8:B.unix/local 8.007] New Connection
K1: Layer 8 [34:B.unix/CConn 8.007] ClientConnection Init
K1: Layer 3 [34:B.unix/CConn 8.007] Allocate 4.1.3
K1: Layer 7 [35:B.unix@4.1.3/Group 8.008] OpenGroup
K1: Layer 4 [37:B.unix/TGr 8.008] OpenGroup 1/2/3 WO
K1: Layer 0 [38:log/B.unix 8.008] State setup
K1: Layer 7 [35:B.unix@4.1.3/Group 8.008] OpenGroup complete
K1: Layer 3 [36:B.unix/ConnS 8.008] registerLink: 36:B.unix_36
K1: Layer 3 [36:B.unix/ConnS 8.008] Start: cfg:B.unix
K1: Layer 5 [36:B.unix/ConnS 8.008] down => >up
K1: Layer 5 [36:B.unix/ConnS 8.008] Starting
K1: Layer 0 [38:log/B.unix 8.008] State start
K1: Layer 0 [38:log/B.unix 8.008] State started
K1: Layer 5 [36:B.unix/ConnS 8.008] >up => up
K1: Layer 4 [36:B.unix/ConnS 8.008] link state changed: up
K1: Layer 5 [36:B.unix/ConnS 8.008] Started
K1: Layer 4 [ 1:main 8.008] check start
K1: Layer 4 [ 1:main 8.008] check end: want_up 1 some 1>1 all 0>1, going 0 up 5 down 0
K1: Layer 7 [34:B.unix/CConn 8.008] recv Group(002): 00 84
K1: Layer 4 [37:B.unix/TGr 8.008] Recv Group T_Data_Group A_GroupValue_Write (small) 04
K1: Layer 0 [38:log/B.unix 8.008] Recv L_Data low from 0.0.0 to 1/2/3 hops: 06 T_Data_Group A_GroupValue_Write (small) 04
K1: Layer 8 [36:B.unix/ConnS 8.008] found addr 4.1.3
K1: Layer 0 [ 7:log/main 8.008] Recv L_Data low from 4.1.3 to 1/2/3 hops: 06 T_Data_Group A_GroupValue_Write (small) 04
K1: Layer 0 [ 7:log/main 8.008] Send L_Data low from 4.1.3 to 1/2/3 hops: 05 T_Data_Group A_GroupValue_Write (small) 04
K1: Layer 6 [26:router/ConnC 8.008] sending, send_more clear
K1: Layer 0 [28:log/router 8.008] Send L_Data low from 4.1.3 to 1/2/3 hops: 05 T_Data_Group A_GroupValue_Write (small) 04
K1: Layer 2 [29:C.pace/router 8.008] out 1/2: delay for 0.202 sec
K1: Layer 6 [23:D.dummy/Conn 8.008] sending, send_more clear
K1: Layer 6 [23:D.dummy/Conn 8.008] sendNext called, send_more set
K1: Layer 6 [ 1:main 8.008] sending set
K1: Layer 6 [ 4:A.cache/Conn 8.008] sending, send_more clear
K1: Layer 0 [ 6:log/A.cache 8.008] Send L_Data low from 4.1.3 to 1/2/3 hops: 05 T_Data_Group A_GroupValue_Write (small) 04
K1: Layer 6 [ 6:log/A.cache 8.009] send next
K1: Layer 6 [ 4:A.cache/Conn 8.009] sendNext called, send_more set
K1: Layer 6 [ 1:main 8.009] sending set
K1: Layer 6 [26:router/ConnC 8.009] still waiting
K1: Layer 6 [ 1:main 8.009] wait L
Send request
K2: Layer 0 [21:log/B.ip 6.005] Recv L_Data low from 4.1.3 to 1/2/3 hops: 05 T_Data_Group A_GroupValue_Write (small) 04
K1: Layer 8 [34:B.unix/CConn 8.009] ClientConnection 4.1.3 closing
K2: Layer 8 [ 1:main 6.005] unknown addr 4.1.3
K1: Layer 3 [ 1:main 8.009] Release 4.1.3
K2: Layer 0 [ 4:log/main 6.005] Recv L_Data low from 4.1.3 to 1/2/3 hops: 05 T_Data_Group A_GroupValue_Write (small) 04
K1: Layer 3 [36:B.unix/ConnS 8.009] unregisterLink: B.unix_36
K1: Layer 8 [34:B.unix/CConn 8.009] Exiting
K1: Layer 7 [34:B.unix/CConn 8.009] CloseGroup
K1: Layer 4 [37:B.unix/TGr 8.009] CloseGroup
K2: Layer 0 [ 4:log/main 6.005] Send L_Data low from 4.1.3 to 1/2/3 hops: 04 T_Data_Group A_GroupValue_Write (small) 04
K2: Layer 6 [37:A.unix/ConnS 6.005] sending, send_more clear
K1: Layer 4 [ 1:main 8.009] check start
K2: Layer 0 [39:log/A.unix 6.005] Send L_Data low from 4.1.3 to 1/2/3 hops: 04 T_Data_Group A_GroupValue_Write (small) 04
K1: Layer 4 [ 1:main 8.009] check end: want_up 1 some 1>1 all 1>1, going 0 up 5 down 0
K2: Layer 7 [35:A.unix/CConn 6.005] Recv(002): 00 84
K2: Layer 6 [39:log/A.unix 6.005] send next
K2: Layer 6 [37:A.unix/ConnS 6.005] sendNext called, send_more set
K2: Layer 6 [ 1:main 6.005] sending set
K2: Layer 6 [24:router/ConnC 6.005] sending, send_more clear
K2: Layer 0 [26:log/router 6.005] Send L_Data low from 4.1.3 to 1/2/3 hops: 04 T_Data_Group A_GroupValue_Write (small) 04
K2: Layer 2 [27:router.pace_/router 6.005] out 1/2: delay for 0.017 sec
K2: Layer 6 [28:tunnel/ConnC 6.005] sending, send_more clear
K2: Layer 6 [28:tunnel/ConnC 6.005] sendNext called, send_more set
K2: Layer 6 [37:A.unix/ConnS 6.005] is OK
K2: Layer 6 [24:router/ConnC 6.005] still waiting
K2: Layer 6 [ 1:main 6.005] wait L
K2: Layer 0 [30:log/tunnel 6.005] Send L_Data low from 4.1.3 to 1/2/3 hops: 04 T_Data_Group A_GroupValue_Write (small) 04
K3: Layer 0 [12:log/B.ipt 4.003] Recv L_Data low from 4.1.3 to 1/2/3 hops: 04 T_Data_Group A_GroupValue_Write (small) 04
K3: Layer 8 [ 1:main 4.003] unknown addr 4.1.3
K3: Layer 0 [ 4:log/main 4.003] Recv L_Data low from 4.1.3 to 1/2/3 hops: 04 T_Data_Group A_GroupValue_Write (small) 04
K3: Layer 0 [ 4:log/main 4.003] Send L_Data low from 4.1.3 to 1/2/3 hops: 03 T_Data_Group A_GroupValue_Write (small) 04
K3: Layer 6 [10:B.ipt/Conn 4.003] is OK
K3: Layer 6 [ 5:A.unix/local 4.003] is OK
K3: Layer 6 [ 1:main 4.003] OK
K3: Layer 6 [ 4:log/main 4.003] send next
K3: Layer 6 [ 2:main/L 4.003] OK L
K2: Layer 8 [29:tunnel/4.2.1 6.006] TUNNEL_ACK
K2: Layer 6 [30:log/tunnel 6.006] send next
+ sleep 1
K2: Layer 2 [27:router.pace_/router 6.022] delay done
K2: Layer 6 [26:log/router 6.022] send next
K2: Layer 6 [24:router/ConnC 6.022] sendNext called, send_more set
K2: Layer 6 [37:A.unix/ConnS 6.022] is OK
K2: Layer 6 [24:router/ConnC 6.022] is OK
K2: Layer 6 [19:B.ip/Conn 6.022] is OK
K2: Layer 6 [ 5:server/Server 6.022] is OK
K2: Layer 6 [28:tunnel/ConnC 6.022] is OK
K2: Layer 6 [14:A.unix/local 6.022] is OK
K2: Layer 6 [ 1:main 6.022] OK
K2: Layer 6 [ 4:log/main 6.022] send next
K2: Layer 6 [ 2:main/L 6.022] OK L
K1: Layer 2 [29:C.pace/router 8.210] delay done
K1: Layer 6 [28:log/router 8.211] send next
K1: Layer 6 [26:router/ConnC 8.211] sendNext called, send_more set
K1: Layer 6 [26:router/ConnC 8.211] is OK
K1: Layer 6 [23:D.dummy/Conn 8.211] is OK
K1: Layer 6 [13:server/Server 8.211] is OK
K1: Layer 6 [ 4:A.cache/Conn 8.211] is OK
K1: Layer 6 [ 8:B.unix/local 8.211] is OK
K1: Layer 6 [ 1:main 8.211] OK
K1: Layer 6 [ 7:log/main 8.211] send next
K1: Layer 6 [ 2:main/L 8.211] OK L
+ echo xmit 2
xmit 2
+ knxtool groupswrite local:/tmp/file6I674Q 1/2/3 5
K2: Layer 8 [14:A.unix/local 7.011] New Connection
K2: Layer 8 [40:A.unix/CConn 7.011] ClientConnection Init
K2: Layer 3 [40:A.unix/CConn 7.011] Allocate 4.2.4
K2: Layer 7 [41:A.unix@4.2.4/Group 7.011] OpenGroup
K2: Layer 4 [43:A.unix/TGr 7.012] OpenGroup 1/2/3 WO
K2: Layer 0 [44:log/A.unix 7.012] State setup
K2: Layer 7 [41:A.unix@4.2.4/Group 7.012] OpenGroup complete
K2: Layer 3 [42:A.unix/ConnS 7.012] registerLink: 42:A.unix_42
K2: Layer 3 [42:A.unix/ConnS 7.012] Start: cfg:A.unix
K2: Layer 5 [42:A.unix/ConnS 7.012] down => >up
K2: Layer 5 [42:A.unix/ConnS 7.012] Starting
K2: Layer 0 [44:log/A.unix 7.012] State start
K2: Layer 0 [44:log/A.unix 7.012] State started
K2: Layer 5 [42:A.unix/ConnS 7.012] >up => up
K2: Layer 4 [42:A.unix/ConnS 7.012] link state changed: up
K2: Layer 5 [42:A.unix/ConnS 7.012] Started
K2: Layer 4 [ 1:main 7.012] check start
K2: Layer 4 [ 1:main 7.012] check end: want_up 1 some 1>1 all 0>1, going 0 up 4 down 0
K2: Layer 7 [40:A.unix/CConn 7.012] recv Group(002): 00 85
K2: Layer 4 [43:A.unix/TGr 7.012] Recv Group T_Data_Group A_GroupValue_Write (small) 05
K2: Layer 0 [44:log/A.unix 7.012] Recv L_Data low from 0.0.0 to 1/2/3 hops: 06 T_Data_Group A_GroupValue_Write (small) 05
K2: Layer 8 [42:A.unix/ConnS 7.012] found addr 4.2.4
K2: Layer 0 [ 4:log/main 7.012] Recv L_Data low from 4.2.4 to 1/2/3 hops: 06 T_Data_Group A_GroupValue_Write (small) 05
K2: Layer 0 [ 4:log/main 7.012] Send L_Data low from 4.2.4 to 1/2/3 hops: 05 T_Data_Group A_GroupValue_Write (small) 05
K2: Layer 6 [28:tunnel/ConnC 7.012] sending, send_more clear
K2: Layer 6 [28:tunnel/ConnC 7.012] sendNext called, send_more set
K2: Layer 6 [ 1:main 7.012] sending set
K2: Layer 6 [19:B.ip/Conn 7.012] sending, send_more clear
K2: Layer 0 [21:log/B.ip 7.012] Send L_Data low from 4.2.4 to 1/2/3 hops: 05 T_Data_Group A_GroupValue_Write (small) 05
K2: Layer 2 [22:ip.pace_/B.ip 7.012] out 1/2: delay for 0.017 sec
K2: Layer 6 [24:router/ConnC 7.012] sending, send_more clear
K2: Layer 0 [26:log/router 7.012] Send L_Data low from 4.2.4 to 1/2/3 hops: 05 T_Data_Group A_GroupValue_Write (small) 05
K2: Layer 2 [27:router.pace_/router 7.012] out 1/2: delay for 0.017 sec
K2: Layer 6 [37:A.unix/ConnS 7.012] sending, send_more clear
K2: Layer 0 [39:log/A.unix 7.012] Send L_Data low from 4.2.4 to 1/2/3 hops: 05 T_Data_Group A_GroupValue_Write (small) 05
K2: Layer 7 [35:A.unix/CConn 7.012] Recv(002): 00 85
K2: Layer 6 [39:log/A.unix 7.012] send next
K2: Layer 6 [37:A.unix/ConnS 7.012] sendNext called, send_more set
K2: Layer 6 [ 1:main 7.013] sending set
K2: Layer 6 [42:A.unix/ConnS 7.013] is OK
K2: Layer 6 [14:A.unix/local 7.013] is OK
K2: Layer 6 [28:tunnel/ConnC 7.013] is OK
K2: Layer 6 [ 5:server/Server 7.013] is OK
K2: Layer 6 [19:B.ip/Conn 7.013] still waiting
K2: Layer 6 [ 1:main 7.013] wait L
K2: Layer 0 [30:log/tunnel 7.013] Send L_Data low from 4.2.4 to 1/2/3 hops: 05 T_Data_Group A_GroupValue_Write (small) 05
K1: Layer 0 [28:log/router 9.017] Recv L_Data low from 4.2.4 to 1/2/3 hops: 05 T_Data_Group A_GroupValue_Write (small) 05
K1: Layer 8 [ 1:main 9.017] unknown addr 4.2.4
K1: Layer 0 [ 7:log/main 9.017] Recv L_Data low from 4.2.4 to 1/2/3 hops: 05 T_Data_Group A_GroupValue_Write (small) 05
K1: Layer 0 [ 7:log/main 9.017] Send L_Data low from 4.2.4 to 1/2/3 hops: 04 T_Data_Group A_GroupValue_Write (small) 05
K1: Layer 6 [23:D.dummy/Conn 9.017] sending, send_more clear
K1: Layer 6 [23:D.dummy/Conn 9.017] sendNext called, send_more set
K1: Layer 6 [ 1:main 9.017] sending set
K1: Layer 6 [ 4:A.cache/Conn 9.017] sending, send_more clear
K1: Layer 0 [ 6:log/A.cache 9.017] Send L_Data low from 4.2.4 to 1/2/3 hops: 04 T_Data_Group A_GroupValue_Write (small) 05
K1: Layer 6 [ 6:log/A.cache 9.017] send next
K1: Layer 6 [ 4:A.cache/Conn 9.017] sendNext called, send_more set
K1: Layer 6 [26:router/ConnC 9.017] is OK
K1: Layer 6 [23:D.dummy/Conn 9.018] is OK
K1: Layer 6 [13:server/Server 9.018] is OK
K1: Layer 6 [ 4:A.cache/Conn 9.018] is OK
K1: Layer 6 [ 8:B.unix/local 9.018] is OK
K1: Layer 6 [ 1:main 9.018] OK
K1: Layer 6 [ 7:log/main 9.018] send next
K1: Layer 6 [ 2:main/L 9.018] OK L
K3: Layer 0 [12:log/B.ipt 5.011] Recv L_Data low from 4.2.4 to 1/2/3 hops: 05 T_Data_Group A_GroupValue_Write (small) 05
K3: Layer 8 [ 1:main 5.011] unknown addr 4.2.4
K3: Layer 0 [ 4:log/main 5.011] Recv L_Data low from 4.2.4 to 1/2/3 hops: 05 T_Data_Group A_GroupValue_Write (small) 05
K3: Layer 0 [ 4:log/main 5.011] Send L_Data low from 4.2.4 to 1/2/3 hops: 04 T_Data_Group A_GroupValue_Write (small) 05
K3: Layer 6 [10:B.ipt/Conn 5.011] is OK
K3: Layer 6 [ 5:A.unix/local 5.011] is OK
K3: Layer 6 [ 1:main 5.011] OK
K3: Layer 6 [ 4:log/main 5.011] send next
K3: Layer 6 [ 2:main/L 5.011] OK L
K2: Layer 8 [29:tunnel/4.2.1 7.014] TUNNEL_ACK
K2: Layer 6 [30:log/tunnel 7.014] send next
Send request
K2: Layer 8 [40:A.unix/CConn 7.014] ClientConnection 4.2.4 closing
K2: Layer 3 [ 1:main 7.014] Release 4.2.4
K2: Layer 3 [42:A.unix/ConnS 7.014] unregisterLink: A.unix_42
K2: Layer 8 [40:A.unix/CConn 7.014] Exiting
K2: Layer 7 [40:A.unix/CConn 7.014] CloseGroup
K2: Layer 4 [43:A.unix/TGr 7.014] CloseGroup
K2: Layer 4 [ 1:main 7.014] check start
K2: Layer 4 [ 1:main 7.014] check end: want_up 1 some 1>1 all 1>1, going 0 up 4 down 0
+ sleep 1
K2: Layer 2 [22:ip.pace_/B.ip 7.029] delay done
K2: Layer 6 [21:log/B.ip 7.029] send next
K2: Layer 6 [19:B.ip/Conn 7.029] sendNext called, send_more set
K2: Layer 6 [14:A.unix/local 7.029] is OK
K2: Layer 6 [28:tunnel/ConnC 7.029] is OK
K2: Layer 6 [ 5:server/Server 7.029] is OK
K2: Layer 6 [19:B.ip/Conn 7.029] is OK
K2: Layer 6 [24:router/ConnC 7.029] still waiting
K2: Layer 2 [27:router.pace_/router 7.029] delay done
K2: Layer 6 [26:log/router 7.029] send next
K2: Layer 6 [24:router/ConnC 7.029] sendNext called, send_more set
K2: Layer 6 [24:router/ConnC 7.029] is OK
K2: Layer 6 [37:A.unix/ConnS 7.029] is OK
K2: Layer 6 [ 1:main 7.029] OK
K2: Layer 6 [ 4:log/main 7.030] send next
K2: Layer 6 [ 2:main/L 7.030] OK L
+ echo xmit 3
xmit 3
+ knxtool groupswrite local:/tmp/fileC6inuR 1/2/3 6
K3: Layer 8 [ 5:A.unix/local 6.017] New Connection
K3: Layer 8 [18:A.unix/CConn 6.017] ClientConnection Init
K3: Layer 3 [18:A.unix/CConn 6.018] Allocate 4.3.2
K3: Layer 7 [19:A.unix@4.3.2/Group 6.018] OpenGroup
K3: Layer 4 [21:A.unix/TGr 6.018] OpenGroup 1/2/3 WO
K3: Layer 0 [22:log/A.unix 6.018] State setup
K3: Layer 7 [19:A.unix@4.3.2/Group 6.018] OpenGroup complete
K3: Layer 3 [20:A.unix/ConnS 6.018] registerLink: 20:A.unix_20
K3: Layer 3 [20:A.unix/ConnS 6.018] Start: cfg:A.unix
K3: Layer 5 [20:A.unix/ConnS 6.018] down => >up
K3: Layer 5 [20:A.unix/ConnS 6.018] Starting
K3: Layer 0 [22:log/A.unix 6.018] State start
K3: Layer 0 [22:log/A.unix 6.018] State started
K3: Layer 5 [20:A.unix/ConnS 6.018] >up => up
K3: Layer 4 [20:A.unix/ConnS 6.018] link state changed: up
K3: Layer 5 [20:A.unix/ConnS 6.018] Started
K3: Layer 4 [ 1:main 6.018] check start
K3: Layer 4 [ 1:main 6.018] check end: want_up 1 some 1>1 all 0>1, going 0 up 2 down 0
K3: Layer 7 [18:A.unix/CConn 6.018] recv Group(002): 00 86
K3: Layer 4 [21:A.unix/TGr 6.018] Recv Group T_Data_Group A_GroupValue_Write (small) 06
K3: Layer 0 [22:log/A.unix 6.018] Recv L_Data low from 0.0.0 to 1/2/3 hops: 06 T_Data_Group A_GroupValue_Write (small) 06
K3: Layer 8 [20:A.unix/ConnS 6.018] found addr 4.3.2
K3: Layer 0 [ 4:log/main 6.018] Recv L_Data low from 4.3.2 to 1/2/3 hops: 06 T_Data_Group A_GroupValue_Write (small) 06
K3: Layer 0 [ 4:log/main 6.018] Send L_Data low from 4.3.2 to 1/2/3 hops: 05 T_Data_Group A_GroupValue_Write (small) 06
K3: Layer 6 [10:B.ipt/Conn 6.018] sending, send_more clear
K3: Layer 6 [10:B.ipt/Conn 6.018] sendNext called, send_more set
K3: Layer 6 [ 1:main 6.018] sending set
K3: Layer 6 [20:A.unix/ConnS 6.018] is OK
K3: Layer 6 [ 5:A.unix/local 6.018] is OK
K3: Layer 6 [10:B.ipt/Conn 6.018] is OK
K3: Layer 6 [ 1:main 6.018] OK
K3: Layer 6 [ 4:log/main 6.018] send next
K3: Layer 6 [ 2:main/L 6.018] OK L
K3: Layer 0 [12:log/B.ipt 6.018] Send L_Data low from 4.3.2 to 1/2/3 hops: 05 T_Data_Group A_GroupValue_Write (small) 06
K2: Layer 8 [29:tunnel/4.2.1 8.021] TUNNEL_REQ
K2: Layer 0 [30:log/tunnel 8.021] Recv L_Data low from 4.3.2 to 1/2/3 hops: 05 T_Data_Group A_GroupValue_Write (small) 06
K2: Layer 8 [ 1:main 8.021] unknown addr 4.3.2
K2: Layer 0 [ 4:log/main 8.021] Recv L_Data low from 4.3.2 to 1/2/3 hops: 05 T_Data_Group A_GroupValue_Write (small) 06
K2: Layer 0 [ 4:log/main 8.021] Send L_Data low from 4.3.2 to 1/2/3 hops: 04 T_Data_Group A_GroupValue_Write (small) 06
K2: Layer 6 [19:B.ip/Conn 8.021] sending, send_more clear
K2: Layer 0 [21:log/B.ip 8.021] Send L_Data low from 4.3.2 to 1/2/3 hops: 04 T_Data_Group A_GroupValue_Write (small) 06
K2: Layer 2 [22:ip.pace_/B.ip 8.021] out 1/2: delay for 0.017 sec
Send request
K2: Layer 6 [24:router/ConnC 8.022] sending, send_more clear
K2: Layer 0 [26:log/router 8.022] Send L_Data low from 4.3.2 to 1/2/3 hops: 04 T_Data_Group A_GroupValue_Write (small) 06
K2: Layer 2 [27:router.pace_/router 8.022] out 1/2: delay for 0.017 sec
K2: Layer 6 [37:A.unix/ConnS 8.022] sending, send_more clear
K2: Layer 0 [39:log/A.unix 8.022] Send L_Data low from 4.3.2 to 1/2/3 hops: 04 T_Data_Group A_GroupValue_Write (small) 06
K2: Layer 7 [35:A.unix/CConn 8.022] Recv(002): 00 86
K2: Layer 6 [39:log/A.unix 8.022] send next
K2: Layer 6 [37:A.unix/ConnS 8.022] sendNext called, send_more set
K2: Layer 6 [ 1:main 8.022] sending set
K2: Layer 6 [14:A.unix/local 8.022] is OK
K2: Layer 6 [28:tunnel/ConnC 8.022] is OK
K2: Layer 6 [ 5:server/Server 8.022] is OK
K2: Layer 6 [19:B.ip/Conn 8.022] still waiting
K2: Layer 6 [ 1:main 8.022] wait L
K1: Layer 0 [28:log/router 10.026] Recv L_Data low from 4.3.2 to 1/2/3 hops: 04 T_Data_Group A_GroupValue_Write (small) 06
K1: Layer 8 [ 1:main 10.026] unknown addr 4.3.2
K1: Layer 0 [ 7:log/main 10.026] Recv L_Data low from 4.3.2 to 1/2/3 hops: 04 T_Data_Group A_GroupValue_Write (small) 06
K1: Layer 0 [ 7:log/main 10.027] Send L_Data low from 4.3.2 to 1/2/3 hops: 03 T_Data_Group A_GroupValue_Write (small) 06
K1: Layer 6 [23:D.dummy/Conn 10.027] sending, send_more clear
K1: Layer 6 [23:D.dummy/Conn 10.027] sendNext called, send_more set
K1: Layer 6 [ 1:main 10.027] sending set
+ sleep 1
