Je suis un peu coincé ce matin avec mon jeedom après avoir passé la maj 2.2.20 et les modules annexes : eibd,…Le demon KNX ne démarre plus.
Il semblerait que les logs eibd et eibd_updates soient ok (installation ok), mais pour l’eibd_packages…c’est pas la meme.
Je ne sais plus vraiment quoi faire et je crains un peu la réinstalle totale du jeedom.
Voici le msg du eibd_packages :
0 upgraded, 1 newly installed, 0 to remove and 205 not upgraded.
1 not fully installed or removed.
Need to get 47.4 kB of archives.
After this operation, 238 kB of additional disk space will be used.
Get:1 http://ftp.uk.debian.org/debian buster/main arm64 knxd-tools arm64 0.14.30-1 [47.4 kB]
debconf: unable to initialize frontend: Dialog
debconf: (Dialog frontend will not work on a dumb terminal, an emacs shell buffer, or without a controlling terminal.)
debconf: falling back to frontend: Readline
debconf: unable to initialize frontend: Readline
debconf: (This frontend requires a controlling tty.)
debconf: falling back to frontend: Teletype
dpkg-preconfigure: unable to re-open stdin:
Fetched 47.4 kB in 0s (352 kB/s)
Selecting previously unselected package knxd-tools.
(Reading database ...
(Reading database ... 5%
(Reading database ... 10%
(Reading database ... 15%
(Reading database ... 20%
(Reading database ... 25%
(Reading database ... 30%
(Reading database ... 35%
(Reading database ... 40%
(Reading database ... 45%
(Reading database ... 50%
(Reading database ... 55%
(Reading database ... 60%
(Reading database ... 65%
(Reading database ... 70%
(Reading database ... 75%
(Reading database ... 80%
(Reading database ... 85%
(Reading database ... 90%
(Reading database ... 95%
(Reading database ... 100%
(Reading database ... 75777 files and directories currently installed.)
Preparing to unpack .../knxd-tools_0.14.30-1_arm64.deb ...
Unpacking knxd-tools (0.14.30-1) ...
Setting up knxd (0.14.30-1) ...
addgroup: The group `knxd' already exists as a system group. Exiting.
Warning: The home dir /var/lib/knxd you specified already exists.
The system user `knxd' already exists. Exiting.
A dependency job for knxd.service failed. See 'journalctl -xe' for details.
Job for knxd.socket failed.
See "systemctl status knxd.socket" and "journalctl -xe" for details.
invoke-rc.d: initscript knxd, action "start" failed.
● knxd.service - KNX Daemon
Loaded: loaded (e]8;;file://Jeedom/lib/systemd/system/knxd.servicea/lib/systemd/system/knxd.servicee]8;;a; enabled; vendor preset: enabled)
Active: inactive (dead)
Jul 02 08:48:42 Jeedom systemd[1]: e[0;1;39me[0;1;31me[0;1;39mDependency failed for KNX Daemon.e[0m
Jul 02 08:48:42 Jeedom systemd[1]: e[0;1;39me[0;1;31me[0;1;39mknxd.service: Job knxd.service/start failed with result 'dependency'.e[0m
Jul 02 08:48:46 Jeedom systemd[1]: e[0;1;39me[0;1;31me[0;1;39mDependency failed for KNX Daemon.e[0m
Jul 02 08:48:46 Jeedom systemd[1]: e[0;1;39me[0;1;31me[0;1;39mknxd.service: Job knxd.service/start failed with result 'dependency'.e[0m
Jul 02 08:48:54 Jeedom systemd[1]: e[0;1;39me[0;1;31me[0;1;39mDependency failed for KNX Daemon.e[0m
Jul 02 08:48:54 Jeedom systemd[1]: e[0;1;39me[0;1;31me[0;1;39mknxd.service: Job knxd.service/start failed with result 'dependency'.e[0m
Jul 02 08:48:57 Jeedom systemd[1]: e[0;1;39me[0;1;31me[0;1;39mDependency failed for KNX Daemon.e[0m
Jul 02 08:48:57 Jeedom systemd[1]: e[0;1;39me[0;1;31me[0;1;39mknxd.service: Job knxd.service/start failed with result 'dependency'.e[0m
dpkg: error processing package knxd (--configure):
installed knxd package post-installation script subprocess returned error exit status 1
Setting up knxd-tools (0.14.30-1) ...
Processing triggers for libc-bin (2.28-10) ...
Errors were encountered while processing:
knxd
E: Sub-process /usr/bin/dpkg returned an error code (1)
+ echo 6
+ php /var/www/html/core/class/../php/jeecli.php plugin dependancy_end eibd
+ rm /tmp/jeedom_install_in_progress_eibd
