Appairage avec code PIN effectué
addTypeLabels: 0.566ms
addTypeLabels: 0.199ms
addTypeLabels: 0.911ms
[20-04-2024 22:06:03] INFO : Configuration de : sendLoglevel effectuée avec la valeur : debug
[20-04-2024 22:06:24] INFO : Event reçu de Presence-Sensor-FP2-E4C3 : occupancy-detected=0
[20-04-2024 22:06:25] INFO : Event reçu de Presence-Sensor-FP2-E4C3 : occupancy-detected=0
[20-04-2024 22:06:38] INFO : Recu de jeedom: Demande d'arret
[20-04-2024 22:06:38] DEBUG : Désouscription de Presence-Sensor-FP2-E4C3 sur 1.68,1.81,1.2674,1.2690,1.2694,1.2698,1.2702
[20-04-2024 22:06:38] INFO : Exit
/var/www/html/plugins/hkControl/resources/hkControl.js:43
const jsend = require('./utils/jeedom.js')('hkControl',conf.urlJeedom,conf.apiKey,conf.logLevel,'jsonrpc');
TypeError: require(...) is not a function
at Object.<anonymous> (/var/www/html/plugins/hkControl/resources/hkControl.js:43:43)
at Module._compile (node:internal/modules/cjs/loader:1364:14)
at Module._extensions..js (node:internal/modules/cjs/loader:1422:10)
at Module.load (node:internal/modules/cjs/loader:1203:32)
at Module._load (node:internal/modules/cjs/loader:1019:12)
at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12)
at node:internal/main/run_main_module:28:49
Node.js v18.20.2
[20-04-2024 22:10:07] INFO : Démarrage démon hkControl...
[20-04-2024 22:10:07] DEBUG : urlJeedom = http://192.168.0.49/core/api/jeeApi.php
[20-04-2024 22:10:07] DEBUG : apiKey = KdoIRrE6YWTx701QAXQ0GG2WING7uVO1Tz9t9eV3reC8SMCXQrSfXa3KOR3UQZ0r
[20-04-2024 22:10:07] DEBUG : serverPort = 63448
[20-04-2024 22:10:07] DEBUG : logLevel = debug
[20-04-2024 22:10:07] DEBUG : pairingFile = /var/www/html/plugins/hkControl/data/pairings.json
[20-04-2024 22:10:07] DEBUG : jeedom42 = 1
[20-04-2024 22:10:07] DEBUG : detectCam = false
[20-04-2024 22:10:07] DEBUG : pairings = {"A7:16:FA:8E:24:5A":{"name":"Presence-Sensor-FP2-E4C3","pin":"535-12-749","address":"192.168.0.37","port":"54526","type":"10","pairing":{"AccessoryPairingID":"41373a31363a46413a38453a32343a3541","AccessoryLTPK":"ffcbca7cb53ad23fc9bf5c8e17d07da50064a350ea404362a9e4ecd0f9021d6e","iOSDevicePairingID":"37313832636638362d303836652d346333662d396465332d316131343064376133653161","iOSDeviceLTSK":"a98bdc29f666eb46845bf0b19782a560adb46f683cbec3ffcd34408132179170f0277a4123b7f5dd5402bdf9011ae8408026165c0bdc67dc97956988564fe873","iOSDeviceLTPK":"f0277a4123b7f5dd5402bdf9011ae8408026165c0bdc67dc97956988564fe873"},"accessories":[{"aid":1,"services":[{"iid":1,"type":"0000003E-0000-1000-8000-0026BB765291","primary":false,"hidden":false,"characteristics":[{"iid":2,"type":"00000014-0000-1000-8000-0026BB765291","format":"bool","perms":["pw"],"typeLabel":"identify"},{"iid":3,"type":"00000020-0000-1000-8000-0026BB765291","format":"string","value":"Aqara","perms":["pr"],"ev":false,"enc":false,"typeLabel":"manufacturer"},{"iid":4,"type":"00000021-0000-1000-8000-0026BB765291","format":"string","value":"PS-S02E","perms":["pr"],"ev":false,"enc":false,"typeLabel":"model"},{"iid":5,"type":"00000023-0000-1000-8000-0026BB765291","format":"string","value":"Presence-Sensor-FP2-E4C3","perms":["pr"],"ev":false,"enc":false,"typeLabel":"name"},{"iid":6,"type":"00000030-0000-1000-8000-0026BB765291","format":"string","value":"54EF4455E4C3","perms":["pr"],"ev":false,"enc":false,"typeLabel":"serial-number"},{"iid":7,"type":"00000052-0000-1000-8000-0026BB765291","format":"string","value":"1.2.6","perms":["pr"],"ev":false,"enc":false,"typeLabel":"firmware.revision"},{"iid":8,"type":"00000053-0000-1000-8000-0026BB765291","format":"string","value":"1.0.0","perms":["pr"],"ev":false,"enc":false,"typeLabel":"hardware.revision"},{"iid":9,"type":"34AB8811-AC7F-4340-BAC3-FD6A85F9943B","format":"string","value":"6.1;6.1","perms":["pr","hd"],"ev":false,"enc":false,"typeLabel":"34AB8811-AC7F-4340-BAC3-FD6A85F9943B"},{"iid":10,"type":"00000220-0000-1000-8000-0026BB765291","format":"data","value":"xDsGOzOmv1k=","perms":["pr"],"ev":false,"enc":false,"maxDataLen":8,"typeLabel":"product-data"}],"typeLabel":"accessory-information","serviceOriginalName":"Presence-Sensor-FP2-E4C3"},{"iid":16,"type":"000000A2-0000-1000-8000-0026BB765291","primary":false,"hidden":false,"characteristics":[{"iid":18,"type":"00000037-0000-1000-8000-0026BB765291","format":"string","value":"1.1.0","perms":["pr"],"ev":false,"enc":false,"typeLabel":"version"}],"typeLabel":"protocol.information.service"},{"iid":64,"type":"0000022A-0000-1000-8000-0026BB765291","primary":false,"hidden":false,"characteristics":[{"iid":66,"type":"0000022B-0000-1000-8000-0026BB765291","format":"bool","value":1,"perms":["pr"],"ev":false,"enc":false,"typeLabel":"current-transport"},{"iid":67,"type":"0000022C-0000-1000-8000-0026BB765291","format":"uint32","value":9,"perms":["pr"],"ev":false,"enc":false,"minValue":0,"maxValue":15,"minStep":1,"typeLabel":"wifi-capabilities"},{"iid":68,"type":"0000022D-0000-1000-8000-0026BB765291","format":"tlv8","value":"","perms":["pr","pw","ev","tw","wr"],"ev":false,"enc":false,"typeLabel":"wifi-configuration-control"}],"typeLabel":"wifi-transport"},{"iid":2560,"type":"00000239-0000-1000-8000-0026BB765291","primary":false,"hidden":false,"characteristics":[{"iid":2562,"type":"0000023C-0000-1000-8000-0026BB765291","format":"data","value":"","perms":["pr"],"ev":false,"enc":false,"maxDataLen":0,"typeLabel":"ping"}],"typeLabel":"accessory-runtime-information"},{"iid":80,"type":"9715BF53-AB63-4449-8DC7-2785D617390A","primary":false,"hidden":true,"characteristics":[{"iid":81,"type":"7D943F6A-E052-4E96-A176-D17BF00E32CB","format":"int","value":-1,"perms":["pr","ev","hd"],"ev":false,"enc":false,"description":"Firmware Update Status","minValue":-128,"maxValue":127,"minStep":1,"typeLabel":"Firmware Update Status"},{"iid":82,"type":"A45EFD52-0DB5-4C1A-9727-513FBCD8185F","format":"string","perms":["pw","hd"],"description":"Firmware Update URL","maxLen":256,"typeLabel":"Firmware Update URL"},{"iid":83,"type":"40F0124A-579D-40E4-865E-0EF6740EA64B","format":"string","perms":["pw","hd"],"description":"Firmware Update Checksum","typeLabel":"Firmware Update Checksum"},{"iid":85,"type":"96BF5F20-2996-4DB6-8D65-0E36314BCB6D","format":"string","value":"1.2.6","perms":["pr","hd"],"ev":false,"enc":false,"description":"Firmware Version","typeLabel":"Firmware Version"},{"iid":84,"type":"36B7A28B-3200-4783-A3FB-6714F11B1417","format":"string","value":"lumi.motion.agl001","perms":["pr","hd"],"ev":false,"enc":false,"description":"Device Model","typeLabel":"Device Model"},{"iid":86,"type":"F5329CB1-A50B-4225-BA9B-331449E7F7A9","format":"uint8","value":1,"perms":["pr","hd"],"ev":false,"enc":false,"description":"Selected IoT Platform","minValue":0,"maxValue":4,"minStep":1,"typeLabel":"Selected IoT Platform"}],"typeLabel":"9715BF53-AB63-4449-8DC7-2785D617390A"},{"iid":96,"type":"F49132D1-12DF-4119-87D3-A93E8D68531E","primary":false,"hidden":true,"characteristics":[{"iid":101,"type":"00000023-0000-1000-8000-0026BB765291","format":"string","value":"AIOT","perms":["pr","hd"],"ev":false,"enc":false,"description":"Name","typeLabel":"name"},{"iid":97,"type":"25D889CB-7135-4A29-B5B4-C1FFD6D2DD5C","format":"string","value":"","perms":["pr","pw","hd"],"ev":false,"enc":false,"description":"Country Domain","typeLabel":"Country Domain"},{"iid":98,"type":"C7EECAA7-91D9-40EB-AD0C-FFDDE3143CB9","format":"string","value":"lumi1.54ef4455e4c3","perms":["pr","hd"],"ev":false,"enc":false,"description":"AIOT did","typeLabel":"AIOT did"},{"iid":99,"type":"80FA747E-CB45-45A4-B7BE-AA7D9964859E","format":"string","perms":["pw","hd"],"description":"AIOT bindkey","typeLabel":"AIOT bindkey"},{"iid":100,"type":"C3B8A329-EF0C-4739-B773-E5B7AEA52C71","format":"bool","value":1,"perms":["pr","hd"],"ev":false,"enc":false,"description":"AIOT bindstate","typeLabel":"AIOT bindstate"}],"typeLabel":"AIOT","serviceOriginalName":"AIOT"},{"iid":2672,"type":"00000084-0000-1000-8000-0026BB765291","primary":false,"hidden":false,"characteristics":[{"iid":2673,"type":"00000023-0000-1000-8000-0026BB765291","format":"string","value":"Light Sensor","perms":["pr"],"ev":false,"enc":false,"typeLabel":"name"},{"iid":2674,"type":"0000006B-0000-1000-8000-0026BB765291","format":"float","value":0,"perms":["pr","ev"],"ev":false,"enc":false,"unit":"lux","minValue":0,"maxValue":100000,"minStep":1,"typeLabel":"light-level.current"}],"typeLabel":"sensor.light","serviceOriginalName":"Light Sensor"},{"iid":2688,"type":"00000086-0000-1000-8000-0026BB765291","primary":true,"hidden":false,"characteristics":[{"iid":2689,"type":"00000023-0000-1000-8000-0026BB765291","format":"string","value":"Presence Sensor 1","perms":["pr"],"ev":false,"enc":false,"maxLen":20,"typeLabel":"name"},{"iid":2690,"type":"00000071-0000-1000-8000-0026BB765291","format":"uint8","value":1,"perms":["pr","ev"],"ev":false,"enc":false,"minValue":0,"maxValue":1,"minStep":1,"typeLabel":"occupancy-detected"},{"iid":2691,"type":"C8622A33-826A-4DD3-9BE9-D496361F29BB","format":"uint8","value":0,"perms":["pr","hd"],"ev":false,"enc":false,"description":"Sensor Index","minValue":0,"maxValue":30,"minStep":1,"typeLabel":"Sensor Index"}],"typeLabel":"sensor.occupancy","serviceOriginalName":"Presence Sensor 1"},{"iid":2692,"type":"00000086-0000-1000-8000-0026BB765291","primary":false,"hidden":false,"characteristics":[{"iid":2693,"type":"00000023-0000-1000-8000-0026BB765291","format":"string","value":"Presence Sensor 2","perms":["pr"],"ev":false,"enc":false,"maxLen":20,"typeLabel":"name"},{"iid":2694,"type":"00000071-0000-1000-8000-0026BB765291","format":"uint8","value":1,"perms":["pr","ev"],"ev":false,"enc":false,"minValue":0,"maxValue":1,"minStep":1,"typeLabel":"occupancy-detected"},{"iid":2695,"type":"C8622A33-826A-4DD3-9BE9-D496361F29BB","format":"uint8","value":1,"perms":["pr","hd"],"ev":false,"enc":false,"description":"Sensor Index","minValue":0,"maxValue":30,"minStep":1,"typeLabel":"Sensor Index"}],"typeLabel":"sensor.occupancy","serviceOriginalName":"Presence Sensor 2"},{"iid":2696,"type":"00000086-0000-1000-8000-0026BB765291","primary":false,"hidden":false,"characteristics":[{"iid":2697,"type":"00000023-0000-1000-8000-0026BB765291","format":"string","value":"Presence Sensor 3","perms":["pr"],"ev":false,"enc":false,"maxLen":20,"typeLabel":"name"},{"iid":2698,"type":"00000071-0000-1000-8000-0026BB765291","format":"uint8","value":0,"perms":["pr","ev"],"ev":false,"enc":false,"minValue":0,"maxValue":1,"minStep":1,"typeLabel":"occupancy-detected"},{"iid":2699,"type":"C8622A33-826A-4DD3-9BE9-D496361F29BB","format":"uint8","value":2,"perms":["pr","hd"],"ev":false,"enc":false,"description":"Sensor Index","minValue":0,"maxValue":30,"minStep":1,"typeLabel":"Sensor Index"}],"typeLabel":"sensor.occupancy","serviceOriginalName":"Presence Sensor 3"},{"iid":2700,"type":"00000086-0000-1000-8000-0026BB765291","primary":false,"hidden":false,"characteristics":[{"iid":2701,"type":"00000023-0000-1000-8000-0026BB765291","format":"string","value":"Presence Sensor 4","perms":["pr"],"ev":false,"enc":false,"maxLen":20,"typeLabel":"name"},{"iid":2702,"type":"00000071-0000-1000-8000-0026BB765291","format":"uint8","value":0,"perms":["pr","ev"],"ev":false,"enc":false,"minValue":0,"maxValue":1,"minStep":1,"typeLabel":"occupancy-detected"},{"iid":2703,"type":"C8622A33-826A-4DD3-9BE9-D496361F29BB","format":"uint8","value":3,"perms":["pr","hd"],"ev":false,"enc":false,"description":"Sensor Index","minValue":0,"maxValue":30,"minStep":1,"typeLabel":"Sensor Index"}],"typeLabel":"sensor.occupancy","serviceOriginalName":"Presence Sensor 4"}]}],"client":null}}
[20-04-2024 22:10:07] INFO : Démon prêt et à l'écoute sur 63448 !
[20-04-2024 22:10:07] DEBUG : Bonjour reçu : {"name":"Presence-Sensor-FP2-E4C3","address":"192.168.0.37","allAddresses":["192.168.0.37","fe80::56ef:44ff:fe55:e4c3"],"port":54526,"c#":1,"ff":2,"id":"A7:16:FA:8E:24:5A","md":"PS-S02E","pv":"1.1","s#":2,"sf":0,"ci":10,"availableToPair":false}
[20-04-2024 22:10:07] INFO : Connexion à l'accessoire Presence-Sensor-FP2-E4C3(A7:16:FA:8E:24:5A) sur 192.168.0.37:54526 avec {"AccessoryPairingID":"41373a31363a46413a38453a32343a3541","AccessoryLTPK":"ffcbca7cb53ad23fc9bf5c8e17d07da50064a350ea404362a9e4ecd0f9021d6e","iOSDevicePairingID":"37313832636638362d303836652d346333662d396465332d316131343064376133653161","iOSDeviceLTSK":"a98bdc29f666eb46845bf0b19782a560adb46f683cbec3ffcd34408132179170f0277a4123b7f5dd5402bdf9011ae8408026165c0bdc67dc97956988564fe873","iOSDeviceLTPK":"f0277a4123b7f5dd5402bdf9011ae8408026165c0bdc67dc97956988564fe873"}
[20-04-2024 22:10:07] DEBUG : Ajout d'un écouteur d'évenements pour Presence-Sensor-FP2-E4C3
[20-04-2024 22:10:07] DEBUG : Analyse de l'accessoire Presence-Sensor-FP2-E4C3 ...
[20-04-2024 22:10:07] DEBUG : Récupération en cours de la description de l'accessoire...
addTypeLabels: 0.622ms
[20-04-2024 22:10:09] INFO : Description de l'accessoire reçue : {"accessories":[{"aid":1,"services":[{"iid":1,"type":"0000003E-0000-1000-8000-0026BB765291","primary":false,"hidden":false,"characteristics":[{"iid":2,"type":"00000014-0000-1000-8000-0026BB765291","format":"bool","perms":["pw"],"typeLabel":"identify"},{"iid":3,"type":"00000020-0000-1000-8000-0026BB765291","format":"string","value":"Aqara","perms":["pr"],"ev":false,"enc":false,"typeLabel":"manufacturer"},{"iid":4,"type":"00000021-0000-1000-8000-0026BB765291","format":"string","value":"PS-S02E","perms":["pr"],"ev":false,"enc":false,"typeLabel":"model"},{"iid":5,"type":"00000023-0000-1000-8000-0026BB765291","format":"string","value":"Presence-Sensor-FP2-E4C3","perms":["pr"],"ev":false,"enc":false,"typeLabel":"name"},{"iid":6,"type":"00000030-0000-1000-8000-0026BB765291","format":"string","value":"54EF4455E4C3","perms":["pr"],"ev":false,"enc":false,"typeLabel":"serial-number"},{"iid":7,"type":"00000052-0000-1000-8000-0026BB765291","format":"string","value":"1.2.6","perms":["pr"],"ev":false,"enc":false,"typeLabel":"firmware.revision"},{"iid":8,"type":"00000053-0000-1000-8000-0026BB765291","format":"string","value":"1.0.0","perms":["pr"],"ev":false,"enc":false,"typeLabel":"hardware.revision"},{"iid":9,"type":"34AB8811-AC7F-4340-BAC3-FD6A85F9943B","format":"string","value":"6.1;6.1","perms":["pr","hd"],"ev":false,"enc":false,"typeLabel":"34AB8811-AC7F-4340-BAC3-FD6A85F9943B"},{"iid":10,"type":"00000220-0000-1000-8000-0026BB765291","format":"data","value":"xDsGOzOmv1k=","perms":["pr"],"ev":false,"enc":false,"maxDataLen":8,"typeLabel":"product-data"}],"typeLabel":"accessory-information","serviceOriginalName":"Presence-Sensor-FP2-E4C3"},{"iid":16,"type":"000000A2-0000-1000-8000-0026BB765291","primary":false,"hidden":false,"characteristics":[{"iid":18,"type":"00000037-0000-1000-8000-0026BB765291","format":"string","value":"1.1.0","perms":["pr"],"ev":false,"enc":false,"typeLabel":"version"}],"typeLabel":"protocol.information.service"},{"iid":64,"type":"0000022A-0000-1000-8000-0026BB765291","primary":false,"hidden":false,"characteristics":[{"iid":66,"type":"0000022B-0000-1000-8000-0026BB765291","format":"bool","value":1,"perms":["pr"],"ev":false,"enc":false,"typeLabel":"current-transport"},{"iid":67,"type":"0000022C-0000-1000-8000-0026BB765291","format":"uint32","value":9,"perms":["pr"],"ev":false,"enc":false,"minValue":0,"maxValue":15,"minStep":1,"typeLabel":"wifi-capabilities"},{"iid":68,"type":"0000022D-0000-1000-8000-0026BB765291","format":"tlv8","value":"","perms":["pr","pw","ev","tw","wr"],"ev":false,"enc":false,"typeLabel":"wifi-configuration-control"}],"typeLabel":"wifi-transport"},{"iid":2560,"type":"00000239-0000-1000-8000-0026BB765291","primary":false,"hidden":false,"characteristics":[{"iid":2562,"type":"0000023C-0000-1000-8000-0026BB765291","format":"data","value":"","perms":["pr"],"ev":false,"enc":false,"maxDataLen":0,"typeLabel":"ping"}],"typeLabel":"accessory-runtime-information"},{"iid":80,"type":"9715BF53-AB63-4449-8DC7-2785D617390A","primary":false,"hidden":true,"characteristics":[{"iid":81,"type":"7D943F6A-E052-4E96-A176-D17BF00E32CB","format":"int","value":-1,"perms":["pr","ev","hd"],"ev":false,"enc":false,"description":"Firmware Update Status","minValue":-128,"maxValue":127,"minStep":1,"typeLabel":"Firmware Update Status"},{"iid":82,"type":"A45EFD52-0DB5-4C1A-9727-513FBCD8185F","format":"string","perms":["pw","hd"],"description":"Firmware Update URL","maxLen":256,"typeLabel":"Firmware Update URL"},{"iid":83,"type":"40F0124A-579D-40E4-865E-0EF6740EA64B","format":"string","perms":["pw","hd"],"description":"Firmware Update Checksum","typeLabel":"Firmware Update Checksum"},{"iid":85,"type":"96BF5F20-2996-4DB6-8D65-0E36314BCB6D","format":"string","value":"1.2.6","perms":["pr","hd"],"ev":false,"enc":false,"description":"Firmware Version","typeLabel":"Firmware Version"},{"iid":84,"type":"36B7A28B-3200-4783-A3FB-6714F11B1417","format":"string","value":"lumi.motion.agl001","perms":["pr","hd"],"ev":false,"enc":false,"description":"Device Model","typeLabel":"Device Model"},{"iid":86,"type":"F5329CB1-A50B-4225-BA9B-331449E7F7A9","format":"uint8","value":1,"perms":["pr","hd"],"ev":false,"enc":false,"description":"Selected IoT Platform","minValue":0,"maxValue":4,"minStep":1,"typeLabel":"Selected IoT Platform"}],"typeLabel":"9715BF53-AB63-4449-8DC7-2785D617390A"},{"iid":96,"type":"F49132D1-12DF-4119-87D3-A93E8D68531E","primary":false,"hidden":true,"characteristics":[{"iid":101,"type":"00000023-0000-1000-8000-0026BB765291","format":"string","value":"AIOT","perms":["pr","hd"],"ev":false,"enc":false,"description":"Name","typeLabel":"name"},{"iid":97,"type":"25D889CB-7135-4A29-B5B4-C1FFD6D2DD5C","format":"string","value":"","perms":["pr","pw","hd"],"ev":false,"enc":false,"description":"Country Domain","typeLabel":"Country Domain"},{"iid":98,"type":"C7EECAA7-91D9-40EB-AD0C-FFDDE3143CB9","format":"string","value":"lumi1.54ef4455e4c3","perms":["pr","hd"],"ev":false,"enc":false,"description":"AIOT did","typeLabel":"AIOT did"},{"iid":99,"type":"80FA747E-CB45-45A4-B7BE-AA7D9964859E","format":"string","perms":["pw","hd"],"description":"AIOT bindkey","typeLabel":"AIOT bindkey"},{"iid":100,"type":"C3B8A329-EF0C-4739-B773-E5B7AEA52C71","format":"bool","value":1,"perms":["pr","hd"],"ev":false,"enc":false,"description":"AIOT bindstate","typeLabel":"AIOT bindstate"}],"typeLabel":"AIOT","serviceOriginalName":"AIOT"},{"iid":2672,"type":"00000084-0000-1000-8000-0026BB765291","primary":false,"hidden":false,"characteristics":[{"iid":2673,"type":"00000023-0000-1000-8000-0026BB765291","format":"string","value":"Light Sensor","perms":["pr"],"ev":false,"enc":false,"typeLabel":"name"},{"iid":2674,"type":"0000006B-0000-1000-8000-0026BB765291","format":"float","value":0,"perms":["pr","ev"],"ev":false,"enc":false,"unit":"lux","minValue":0,"maxValue":100000,"minStep":1,"typeLabel":"light-level.current"}],"typeLabel":"sensor.light","serviceOriginalName":"Light Sensor"},{"iid":2688,"type":"00000086-0000-1000-8000-0026BB765291","primary":true,"hidden":false,"characteristics":[{"iid":2689,"type":"00000023-0000-1000-8000-0026BB765291","format":"string","value":"Presence Sensor 1","perms":["pr"],"ev":false,"enc":false,"maxLen":20,"typeLabel":"name"},{"iid":2690,"type":"00000071-0000-1000-8000-0026BB765291","format":"uint8","value":1,"perms":["pr","ev"],"ev":false,"enc":false,"minValue":0,"maxValue":1,"minStep":1,"typeLabel":"occupancy-detected"},{"iid":2691,"type":"C8622A33-826A-4DD3-9BE9-D496361F29BB","format":"uint8","value":0,"perms":["pr","hd"],"ev":false,"enc":false,"description":"Sensor Index","minValue":0,"maxValue":30,"minStep":1,"typeLabel":"Sensor Index"}],"typeLabel":"sensor.occupancy","serviceOriginalName":"Presence Sensor 1"},{"iid":2692,"type":"00000086-0000-1000-8000-0026BB765291","primary":false,"hidden":false,"characteristics":[{"iid":2693,"type":"00000023-0000-1000-8000-0026BB765291","format":"string","value":"Presence Sensor 2","perms":["pr"],"ev":false,"enc":false,"maxLen":20,"typeLabel":"name"},{"iid":2694,"type":"00000071-0000-1000-8000-0026BB765291","format":"uint8","value":1,"perms":["pr","ev"],"ev":false,"enc":false,"minValue":0,"maxValue":1,"minStep":1,"typeLabel":"occupancy-detected"},{"iid":2695,"type":"C8622A33-826A-4DD3-9BE9-D496361F29BB","format":"uint8","value":1,"perms":["pr","hd"],"ev":false,"enc":false,"description":"Sensor Index","minValue":0,"maxValue":30,"minStep":1,"typeLabel":"Sensor Index"}],"typeLabel":"sensor.occupancy","serviceOriginalName":"Presence Sensor 2"},{"iid":2696,"type":"00000086-0000-1000-8000-0026BB765291","primary":false,"hidden":false,"characteristics":[{"iid":2697,"type":"00000023-0000-1000-8000-0026BB765291","format":"string","value":"Presence Sensor 3","perms":["pr"],"ev":false,"enc":false,"maxLen":20,"typeLabel":"name"},{"iid":2698,"type":"00000071-0000-1000-8000-0026BB765291","format":"uint8","value":0,"perms":["pr","ev"],"ev":false,"enc":false,"minValue":0,"maxValue":1,"minStep":1,"typeLabel":"occupancy-detected"},{"iid":2699,"type":"C8622A33-826A-4DD3-9BE9-D496361F29BB","format":"uint8","value":2,"perms":["pr","hd"],"ev":false,"enc":false,"description":"Sensor Index","minValue":0,"maxValue":30,"minStep":1,"typeLabel":"Sensor Index"}],"typeLabel":"sensor.occupancy","serviceOriginalName":"Presence Sensor 3"},{"iid":2700,"type":"00000086-0000-1000-8000-0026BB765291","primary":false,"hidden":false,"characteristics":[{"iid":2701,"type":"00000023-0000-1000-8000-0026BB765291","format":"string","value":"Presence Sensor 4","perms":["pr"],"ev":false,"enc":false,"maxLen":20,"typeLabel":"name"},{"iid":2702,"type":"00000071-0000-1000-8000-0026BB765291","format":"uint8","value":0,"perms":["pr","ev"],"ev":false,"enc":false,"minValue":0,"maxValue":1,"minStep":1,"typeLabel":"occupancy-detected"},{"iid":2703,"type":"C8622A33-826A-4DD3-9BE9-D496361F29BB","format":"uint8","value":3,"perms":["pr","hd"],"ev":false,"enc":false,"description":"Sensor Index","minValue":0,"maxValue":30,"minStep":1,"typeLabel":"Sensor Index"}],"typeLabel":"sensor.occupancy","serviceOriginalName":"Presence Sensor 4"}]}]}
[20-04-2024 22:10:09] DEBUG : Envoi de l'Accessory brut : {"eventType":"getAccessories","id":"A7:16:FA:8E:24:5A","refresh":false}
[20-04-2024 22:10:09] DEBUG : Souscription pour Presence-Sensor-FP2-E4C3
[20-04-2024 22:10:09] DEBUG : Souscription en cours à Presence-Sensor-FP2-E4C3 sur 1.68,1.81,1.2674,1.2690,1.2694,1.2698,1.2702...
[20-04-2024 22:10:10] DEBUG : Souscrit à Presence-Sensor-FP2-E4C3 sur 1.68,1.81,1.2674,1.2690,1.2694,1.2698,1.2702 !
[20-04-2024 22:10:20] INFO : Event reçu de Presence-Sensor-FP2-E4C3 : occupancy-detected=0
[20-04-2024 22:10:21] INFO : Event reçu de Presence-Sensor-FP2-E4C3 : occupancy-detected=0
Je suis pas sure ad’avoir fait la bonne manip pour les logs!!!
