[Jenkins] Updated translation
diff --git a/core/config/devices/enginko_MCFLW13IO/enginko_MCFLW13IO.png b/core/config/devices/enginko_MCFLW13IO/enginko_MCFLW13IO.png
index b7d81f8..028f0dd 100644
Binary files a/core/config/devices/enginko_MCFLW13IO/enginko_MCFLW13IO.png and b/core/config/devices/enginko_MCFLW13IO/enginko_MCFLW13IO.png differ
diff --git a/docs/de_DE/changelog.md b/docs/de_DE/changelog.md
index a87f26b..2f6b59c 100644
--- a/docs/de_DE/changelog.md
+++ b/docs/de_DE/changelog.md
@@ -30,6 +30,8 @@
- Ändern der Konfiguration *SIE MIO LORA V2* (bis zu 20 Temperaturfühler hinzufügen)
+- Konfiguration hinzufügen *Enginko MCF - LW13 IO*
# 29.04.2024
- Konfiguration hinzufügen *Dragino D23LBLS* (Eigenschaften : Batterie, Temperatur-Weiß, Temperatur-Rot, Temperatur-Schwarz, Alarm, PA8-Stufe, Modus)
diff --git a/docs/en_US/changelog.md b/docs/en_US/changelog.md
index c56bf7d..ff630f3 100644
--- a/docs/en_US/changelog.md
+++ b/docs/en_US/changelog.md
@@ -30,6 +30,8 @@
- Changing the configuration *SHE MIO LORA V2* (add up to 20 temperature probes)
+- Adding configuration *Enginko MCF - LW13 IO*
# 04/29/2024
- Adding configuration *Dragino D23LBLS* (properties : Battery, Temp-White, Temp-Red, Temp-Black, Alarm, PA8 Level, Mode)
diff --git a/docs/es_ES/changelog.md b/docs/es_ES/changelog.md
index 19951ad..b1c2164 100644
--- a/docs/es_ES/changelog.md
+++ b/docs/es_ES/changelog.md
@@ -30,6 +30,8 @@
- Cambiando la configuración *ELLA MIO LORA V2* (añadir hasta 20 sondas de temperatura)
+- Agregar configuración *Enginko MCF - LW13 IO*
# 29/04/2024
- Agregar configuración *Dragino D23LBLS* (propiedades : Batería, Temp-Blanco, Temp-Rojo, Temp-Negro, Alarma, Nivel PA8, Modo)
diff --git a/docs/i18n/de_DE.json b/docs/i18n/de_DE.json
index b958b30..a019cbc 100644
--- a/docs/i18n/de_DE.json
+++ b/docs/i18n/de_DE.json
@@ -21,6 +21,7 @@
"Thermokon 798228 - MCS Détecteur de mouvement, Capteur d'ambiance température, humidité relative, mouvement, présence": "Thermokon 798228 - MCS Bewegungsmelder, Raumsensor Temperatur, relative Luftfeuchtigkeit, Bewegung, Präsenz",
"SHE MIO LORA V2": "SIE MIO LORA V2",
"ajouter jusqu'à 20 sondes de températures": "bis zu 20 Temperaturfühler hinzufügen",
+ "Enginko MCF - LW13 IO": "Enginko MCF - LW13 IO",
"29\/04\/2024": "29.04.2024",
"Dragino D23LBLS": "Dragino D23LBLS",
"Batterie, Temp-White, Temp-Red, Temp-Black, Alarm, PA8 Level, Mode": "Batterie, Temperatur-Weiß, Temperatur-Rot, Temperatur-Schwarz, Alarm, PA8-Stufe, Modus",
diff --git a/docs/i18n/en_US.json b/docs/i18n/en_US.json
index 48117b5..0f64503 100644
--- a/docs/i18n/en_US.json
+++ b/docs/i18n/en_US.json
@@ -21,6 +21,7 @@
"Thermokon 798228 - MCS Détecteur de mouvement, Capteur d'ambiance température, humidité relative, mouvement, présence": "Thermokon 798228 - MCS Motion detector, Room sensor temperature, relative humidity, movement, presence",
"SHE MIO LORA V2": "SHE MIO LORA V2",
"ajouter jusqu'à 20 sondes de températures": "add up to 20 temperature probes",
"29\/04\/2024": "04\/29\/2024",
"Batterie, Temp-White, Temp-Red, Temp-Black, Alarm, PA8 Level, Mode": "Battery, Temp-White, Temp-Red, Temp-Black, Alarm, PA8 Level, Mode",
diff --git a/docs/i18n/es_ES.json b/docs/i18n/es_ES.json
index fe5fd4b..b312f56 100644
--- a/docs/i18n/es_ES.json
+++ b/docs/i18n/es_ES.json
@@ -21,6 +21,7 @@
"Thermokon 798228 - MCS Détecteur de mouvement, Capteur d'ambiance température, humidité relative, mouvement, présence": "Thermokon 798228 - MCS Detector de movimiento, Sensor ambiente temperatura, humedad relativa, movimiento, presencia",
"SHE MIO LORA V2": "ELLA MIO LORA V2",
"ajouter jusqu'à 20 sondes de températures": "añadir hasta 20 sondas de temperatura",
"29\/04\/2024": "29\/04\/2024",
"Batterie, Temp-White, Temp-Red, Temp-Black, Alarm, PA8 Level, Mode": "Batería, Temp-Blanco, Temp-Rojo, Temp-Negro, Alarma, Nivel PA8, Modo",
diff --git a/docs/i18n/fr_FR.json b/docs/i18n/fr_FR.json
index 06f93b2..e05e9d5 100644
--- a/docs/i18n/fr_FR.json
+++ b/docs/i18n/fr_FR.json
@@ -23,6 +23,7 @@
"Thermokon 798228 - MCS Détecteur de mouvement, Capteur d'ambiance température, humidité relative, mouvement, présence": "Thermokon 798228 - MCS Détecteur de mouvement, Capteur d'ambiance température, humidité relative, mouvement, présence",
"ajouter jusqu'à 20 sondes de températures": "ajouter jusqu'à 20 sondes de températures",
"Batterie, Temp-White, Temp-Red, Temp-Black, Alarm, PA8 Level, Mode": "Batterie, Temp-White, Temp-Red, Temp-Black, Alarm, PA8 Level, Mode",
diff --git a/docs/i18n/pt_PT.json b/docs/i18n/pt_PT.json
index 35a5e89..9e3fa3b 100644
--- a/docs/i18n/pt_PT.json
+++ b/docs/i18n/pt_PT.json
@@ -21,6 +21,7 @@
"Thermokon 798228 - MCS Détecteur de mouvement, Capteur d'ambiance température, humidité relative, mouvement, présence": "Thermokon 798228 - Detector de movimento MCS, sensor de temperatura ambiente, umidade relativa, movimento, presença",
"SHE MIO LORA V2": "ELA MIO LORA V2",
"ajouter jusqu'à 20 sondes de températures": "adicione até 20 sondas de temperatura",
"Batterie, Temp-White, Temp-Red, Temp-Black, Alarm, PA8 Level, Mode": "Bateria, Temp-Branco, Temp-Vermelho, Temp-Preto, Alarme, Nível PA8, Modo",
diff --git a/docs/pt_PT/changelog.md b/docs/pt_PT/changelog.md
index af1921e..075ee3a 100644
--- a/docs/pt_PT/changelog.md
+++ b/docs/pt_PT/changelog.md
@@ -30,6 +30,8 @@
- Alterando a configuração *ELA MIO LORA V2* (adicione até 20 sondas de temperatura)
+- Adicionando configuração *Enginko MCF - LW13 IO*
# 29/04/2024
- Adicionando configuração *Dragino D23LBLS* (propriedades : Bateria, Temp-Branco, Temp-Vermelho, Temp-Preto, Alarme, Nível PA8, Modo)
GitHub
sha: d1e25b0c86e40882c4efcf8a41de34f0302de729
