[Jenkins] Updated translation
diff --git a/docs/de_DE/changelog.md b/docs/de_DE/changelog.md
index 5192bde..a87f26b 100644
--- a/docs/de_DE/changelog.md
+++ b/docs/de_DE/changelog.md
@@ -28,6 +28,8 @@
 - Konfiguration hinzufügen *Thermokon 798228 - MCS Bewegungsmelder, Raumsensor Temperatur, relative Luftfeuchtigkeit, Bewegung, Präsenz*
+- Ändern der Konfiguration *SIE MIO LORA V2* (bis zu 20 Temperaturfühler hinzufügen)
 # 29.04.2024
 - Konfiguration hinzufügen *Dragino D23LBLS* (Eigenschaften : Batterie, Temperatur-Weiß, Temperatur-Rot, Temperatur-Schwarz, Alarm, PA8-Stufe, Modus)
diff --git a/docs/en_US/changelog.md b/docs/en_US/changelog.md
index 5a0bbdb..c56bf7d 100644
--- a/docs/en_US/changelog.md
+++ b/docs/en_US/changelog.md
@@ -28,6 +28,8 @@
 - Adding configuration *Thermokon 798228 - MCS Motion detector, Room sensor temperature, relative humidity, movement, presence*
+- Changing the configuration *SHE MIO LORA V2* (add up to 20 temperature probes)
 # 04/29/2024
 - Adding configuration *Dragino D23LBLS* (properties : Battery, Temp-White, Temp-Red, Temp-Black, Alarm, PA8 Level, Mode)
diff --git a/docs/es_ES/changelog.md b/docs/es_ES/changelog.md
index bdcfe64..19951ad 100644
--- a/docs/es_ES/changelog.md
+++ b/docs/es_ES/changelog.md
@@ -28,6 +28,8 @@
 - Agregar configuración *Thermokon 798228 - MCS Detector de movimiento, Sensor ambiente temperatura, humedad relativa, movimiento, presencia*
+- Cambiando la configuración *ELLA MIO LORA V2* (añadir hasta 20 sondas de temperatura)
 # 29/04/2024
 - Agregar configuración *Dragino D23LBLS* (propiedades : Batería, Temp-Blanco, Temp-Rojo, Temp-Negro, Alarma, Nivel PA8, Modo)
diff --git a/docs/i18n/de_DE.json b/docs/i18n/de_DE.json
index 2e2661a..b958b30 100644
--- a/docs/i18n/de_DE.json
+++ b/docs/i18n/de_DE.json
@@ -19,6 +19,8 @@
         "Mclimate Display CO2": "Mclimate CO2-Anzeige",
         "Milesight Smart Fan Coil WT301": "Milesight Smart Fan Coil WT301",
         "Thermokon 798228 - MCS Détecteur de mouvement, Capteur d'ambiance température, humidité relative, mouvement, présence": "Thermokon 798228 - MCS Bewegungsmelder, Raumsensor Temperatur, relative Luftfeuchtigkeit, Bewegung, Präsenz",
+        "SHE MIO LORA V2": "SIE MIO LORA V2",
+        "ajouter jusqu'à 20 sondes de températures": "bis zu 20 Temperaturfühler hinzufügen",
         "29\/04\/2024": "29.04.2024",
         "Dragino D23LBLS": "Dragino D23LBLS",
         "Batterie, Temp-White, Temp-Red, Temp-Black, Alarm, PA8 Level, Mode": "Batterie, Temperatur-Weiß, Temperatur-Rot, Temperatur-Schwarz, Alarm, PA8-Stufe, Modus",
@@ -62,7 +64,6 @@
         "Version, Voltage, Activer Power, Active Factor, Power Consumption, Current, Switch 1, Switch 2, Switch 3": "Version, Spannung, Aktivierungsleistung, Aktivfaktor, Stromverbrauch, Strom, Schalter 1, Schalter 2, Schalter 3",
         "Milesight WS51x": "Milesight WS51x",
         "Version, Voltage, Activer Power, Active Factor, Power Consumption, Current, State": "Version, Spannung, Aktivierungsleistung, Aktivfaktor, Stromverbrauch, Strom, Zustand",
-        "SHE MIO LORA V2": "SIE MIO LORA V2",
         "ON 1-2, OFF 1-2, ON 1-3, OFF 1-3": "EIN 1-2, AUS 1-2, EIN 1-3, AUS 1-3",
         "27\/03\/2023": "27.03.2023",
         "Ajout d'un bouton \"ChildLockDisable\" - Pour que le Child Lock soit automatiquement désactivé lorsque l'appareil est hors ligne": "Schaltfläche „ChildLockDisable“ hinzugefügt – Damit die Kindersicherung automatisch deaktiviert wird, wenn das Gerät offline ist",
diff --git a/docs/i18n/en_US.json b/docs/i18n/en_US.json
index 0269bde..48117b5 100644
--- a/docs/i18n/en_US.json
+++ b/docs/i18n/en_US.json
@@ -19,6 +19,8 @@
         "Mclimate Display CO2": "Mclimate Display CO2",
         "Thermokon 798228 - MCS Détecteur de mouvement, Capteur d'ambiance température, humidité relative, mouvement, présence": "Thermokon 798228 - MCS Motion detector, Room sensor temperature, relative humidity, movement, presence",
+        "SHE MIO LORA V2": "SHE MIO LORA V2",
+        "ajouter jusqu'à 20 sondes de températures": "add up to 20 temperature probes",
         "29\/04\/2024": "04\/29\/2024",
         "Batterie, Temp-White, Temp-Red, Temp-Black, Alarm, PA8 Level, Mode": "Battery, Temp-White, Temp-Red, Temp-Black, Alarm, PA8 Level, Mode",
@@ -62,7 +64,6 @@
         "Version, Voltage, Activer Power, Active Factor, Power Consumption, Current, Switch 1, Switch 2, Switch 3": "Version, Voltage, Activate Power, Active Factor, Power Consumption, Current, Switch 1, Switch 2, Switch 3",
         "Version, Voltage, Activer Power, Active Factor, Power Consumption, Current, State": "Version, Voltage, Activate Power, Active Factor, Power Consumption, Current, State",
-        "SHE MIO LORA V2": "SHE MIO LORA V2",
         "ON 1-2, OFF 1-2, ON 1-3, OFF 1-3": "ON 1-2, OFF 1-2, ON 1-3, OFF 1-3",
         "27\/03\/2023": "03\/27\/2023",
         "Ajout d'un bouton \"ChildLockDisable\" - Pour que le Child Lock soit automatiquement désactivé lorsque l'appareil est hors ligne": "Added \"ChildLockDisable\" button - To have the Child Lock automatically disabled when the device is offline",
diff --git a/docs/i18n/es_ES.json b/docs/i18n/es_ES.json
index 948efab..fe5fd4b 100644
--- a/docs/i18n/es_ES.json
+++ b/docs/i18n/es_ES.json
@@ -19,6 +19,8 @@
         "Mclimate Display CO2": "Pantalla climática CO2",
         "Milesight Smart Fan Coil WT301": "Fan Coil inteligente Milesight WT301",
         "Thermokon 798228 - MCS Détecteur de mouvement, Capteur d'ambiance température, humidité relative, mouvement, présence": "Thermokon 798228 - MCS Detector de movimiento, Sensor ambiente temperatura, humedad relativa, movimiento, presencia",
+        "SHE MIO LORA V2": "ELLA MIO LORA V2",
+        "ajouter jusqu'à 20 sondes de températures": "añadir hasta 20 sondas de temperatura",
         "29\/04\/2024": "29\/04\/2024",
         "Batterie, Temp-White, Temp-Red, Temp-Black, Alarm, PA8 Level, Mode": "Batería, Temp-Blanco, Temp-Rojo, Temp-Negro, Alarma, Nivel PA8, Modo",
@@ -62,7 +64,6 @@
         "Version, Voltage, Activer Power, Active Factor, Power Consumption, Current, Switch 1, Switch 2, Switch 3": "Versión, voltaje, potencia de activación, factor activo, consumo de energía, corriente, interruptor 1, interruptor 2, interruptor 3",
         "Milesight WS51x": "Mira de millas WS51x",
         "Version, Voltage, Activer Power, Active Factor, Power Consumption, Current, State": "Versión, voltaje, potencia de activación, factor activo, consumo de energía, corriente, estado",
-        "SHE MIO LORA V2": "ELLA MIO LORA V2",
         "ON 1-2, OFF 1-2, ON 1-3, OFF 1-3": "ENCENDIDO 1-2, APAGADO 1-2, ENCENDIDO 1-3, APAGADO 1-3",
         "27\/03\/2023": "27\/03\/2023",
         "Ajout d'un bouton \"ChildLockDisable\" - Pour que le Child Lock soit automatiquement désactivé lorsque l'appareil est hors ligne": "Se agregó el botón \"ChildLockDisable\": para que Child Lock se deshabilite automáticamente cuando el dispositivo está fuera de línea",
diff --git a/docs/i18n/fr_FR.json b/docs/i18n/fr_FR.json
index c6db5ca..06f93b2 100644
--- a/docs/i18n/fr_FR.json
+++ b/docs/i18n/fr_FR.json
@@ -21,6 +21,8 @@
         "Thermokon 798228 - MCS Détecteur de mouvement, Capteur d'ambiance température, humidité relative, mouvement, présence": "Thermokon 798228 - MCS Détecteur de mouvement, Capteur d'ambiance température, humidité relative, mouvement, présence",
+        "ajouter jusqu'à 20 sondes de températures": "ajouter jusqu'à 20 sondes de températures",
[... diff too long, it was truncated ...]
GitHub
sha: 442dd9b132ce0645604719ebe0510e06d28aba0d
