[Jenkins] Updated translation
diff --git a/core/config/devices/thermokon_798228/thermokon_798228.png b/core/config/devices/thermokon_798228/thermokon_798228.png
index a4a631b..2bf81d5 100644
Binary files a/core/config/devices/thermokon_798228/thermokon_798228.png and b/core/config/devices/thermokon_798228/thermokon_798228.png differ
diff --git a/core/i18n/en_US.json b/core/i18n/en_US.json
index 5e4cd67..243804c 100644
--- a/core/i18n/en_US.json
+++ b/core/i18n/en_US.json
@@ -29,7 +29,7 @@
         "Base64": "Base64",
         "Commande d'envoi": "Send command",
         "Avoir confirmation": "Have confirmation",
-        "Device EUI": "Device EUI",
+        "Device EUI": "EUI Device",
         "Application Key": "Application Key",
         "Ajouter une commande info": "Add order info",
         "Ajouter une commande action": "Add an action command",
diff --git a/docs/de_DE/changelog.md b/docs/de_DE/changelog.md
index 49e814d..5192bde 100644
--- a/docs/de_DE/changelog.md
+++ b/docs/de_DE/changelog.md
@@ -26,6 +26,8 @@
 - Konfiguration hinzufügen *Milesight Smart Fan Coil WT301*
+- Konfiguration hinzufügen *Thermokon 798228 - MCS Bewegungsmelder, Raumsensor Temperatur, relative Luftfeuchtigkeit, Bewegung, Präsenz*
 # 29.04.2024
 - Konfiguration hinzufügen *Dragino D23LBLS* (Eigenschaften : Batterie, Temperatur-Weiß, Temperatur-Rot, Temperatur-Schwarz, Alarm, PA8-Stufe, Modus)
diff --git a/docs/en_US/changelog.md b/docs/en_US/changelog.md
index 75a8fe4..5a0bbdb 100644
--- a/docs/en_US/changelog.md
+++ b/docs/en_US/changelog.md
@@ -26,6 +26,8 @@
 - Adding configuration *Milesight Smart Fan Coil WT301*
+- Adding configuration *Thermokon 798228 - MCS Motion detector, Room sensor temperature, relative humidity, movement, presence*
 # 04/29/2024
 - Adding configuration *Dragino D23LBLS* (properties : Battery, Temp-White, Temp-Red, Temp-Black, Alarm, PA8 Level, Mode)
diff --git a/docs/es_ES/changelog.md b/docs/es_ES/changelog.md
index f0b3308..bdcfe64 100644
--- a/docs/es_ES/changelog.md
+++ b/docs/es_ES/changelog.md
@@ -26,6 +26,8 @@
 - Agregar configuración *Fan Coil inteligente Milesight WT301*
+- Agregar configuración *Thermokon 798228 - MCS Detector de movimiento, Sensor ambiente temperatura, humedad relativa, movimiento, presencia*
 # 29/04/2024
 - Agregar configuración *Dragino D23LBLS* (propiedades : Batería, Temp-Blanco, Temp-Rojo, Temp-Negro, Alarma, Nivel PA8, Modo)
diff --git a/docs/i18n/de_DE.json b/docs/i18n/de_DE.json
index 763915f..2e2661a 100644
--- a/docs/i18n/de_DE.json
+++ b/docs/i18n/de_DE.json
@@ -18,6 +18,7 @@
         "Mclimate Display CO2 lite": "Mclimate Display CO2 Lite",
         "Mclimate Display CO2": "Mclimate CO2-Anzeige",
         "Milesight Smart Fan Coil WT301": "Milesight Smart Fan Coil WT301",
+        "Thermokon 798228 - MCS Détecteur de mouvement, Capteur d'ambiance température, humidité relative, mouvement, présence": "Thermokon 798228 - MCS Bewegungsmelder, Raumsensor Temperatur, relative Luftfeuchtigkeit, Bewegung, Präsenz",
         "29\/04\/2024": "29.04.2024",
         "Dragino D23LBLS": "Dragino D23LBLS",
         "Batterie, Temp-White, Temp-Red, Temp-Black, Alarm, PA8 Level, Mode": "Batterie, Temperatur-Weiß, Temperatur-Rot, Temperatur-Schwarz, Alarm, PA8-Stufe, Modus",
diff --git a/docs/i18n/en_US.json b/docs/i18n/en_US.json
index fc7cb8a..0269bde 100644
--- a/docs/i18n/en_US.json
+++ b/docs/i18n/en_US.json
@@ -18,6 +18,7 @@
         "Mclimate Display CO2 lite": "Mclimate Display CO2 lite",
         "Mclimate Display CO2": "Mclimate Display CO2",
+        "Thermokon 798228 - MCS Détecteur de mouvement, Capteur d'ambiance température, humidité relative, mouvement, présence": "Thermokon 798228 - MCS Motion detector, Room sensor temperature, relative humidity, movement, presence",
         "29\/04\/2024": "04\/29\/2024",
         "Batterie, Temp-White, Temp-Red, Temp-Black, Alarm, PA8 Level, Mode": "Battery, Temp-White, Temp-Red, Temp-Black, Alarm, PA8 Level, Mode",
diff --git a/docs/i18n/es_ES.json b/docs/i18n/es_ES.json
index 70ae6cf..948efab 100644
--- a/docs/i18n/es_ES.json
+++ b/docs/i18n/es_ES.json
@@ -18,6 +18,7 @@
         "Mclimate Display CO2 lite": "Mclimate Pantalla CO2 lite",
         "Mclimate Display CO2": "Pantalla climática CO2",
         "Milesight Smart Fan Coil WT301": "Fan Coil inteligente Milesight WT301",
+        "Thermokon 798228 - MCS Détecteur de mouvement, Capteur d'ambiance température, humidité relative, mouvement, présence": "Thermokon 798228 - MCS Detector de movimiento, Sensor ambiente temperatura, humedad relativa, movimiento, presencia",
         "29\/04\/2024": "29\/04\/2024",
         "Batterie, Temp-White, Temp-Red, Temp-Black, Alarm, PA8 Level, Mode": "Batería, Temp-Blanco, Temp-Rojo, Temp-Negro, Alarma, Nivel PA8, Modo",
diff --git a/docs/i18n/fr_FR.json b/docs/i18n/fr_FR.json
index b7318c8..c6db5ca 100644
--- a/docs/i18n/fr_FR.json
+++ b/docs/i18n/fr_FR.json
@@ -20,6 +20,7 @@
+        "Thermokon 798228 - MCS Détecteur de mouvement, Capteur d'ambiance température, humidité relative, mouvement, présence": "Thermokon 798228 - MCS Détecteur de mouvement, Capteur d'ambiance température, humidité relative, mouvement, présence",
         "Batterie, Temp-White, Temp-Red, Temp-Black, Alarm, PA8 Level, Mode": "Batterie, Temp-White, Temp-Red, Temp-Black, Alarm, PA8 Level, Mode",
diff --git a/docs/i18n/pt_PT.json b/docs/i18n/pt_PT.json
index 9cc3eab..394797a 100644
--- a/docs/i18n/pt_PT.json
+++ b/docs/i18n/pt_PT.json
@@ -18,6 +18,7 @@
         "Mclimate Display CO2 lite": "Exibição Mclimate CO2 Lite",
         "Mclimate Display CO2": "Exibição Mclimate CO2",
         "Milesight Smart Fan Coil WT301": "Ventilador inteligente Milesight WT301",
+        "Thermokon 798228 - MCS Détecteur de mouvement, Capteur d'ambiance température, humidité relative, mouvement, présence": "Thermokon 798228 - Detector de movimento MCS, sensor de temperatura ambiente, umidade relativa, movimento, presença",
         "Batterie, Temp-White, Temp-Red, Temp-Black, Alarm, PA8 Level, Mode": "Bateria, Temp-Branco, Temp-Vermelho, Temp-Preto, Alarme, Nível PA8, Modo",
diff --git a/docs/pt_PT/changelog.md b/docs/pt_PT/changelog.md
index c79e1ac..df8fb9b 100644
--- a/docs/pt_PT/changelog.md
+++ b/docs/pt_PT/changelog.md
@@ -26,6 +26,8 @@
 - Adicionando configuração *Ventilador inteligente Milesight WT301*
+- Adicionando configuração *Thermokon 798228 - Detector de movimento MCS, sensor de temperatura ambiente, umidade relativa, movimento, presença*
 # 29/04/2024
 - Adicionando configuração *Dragino D23LBLS* (propriedades : Bateria, Temp-Branco, Temp-Vermelho, Temp-Preto, Alarme, Nível PA8, Modo)
GitHub
sha: 2c390b9153d4763e39a80446884c2b63851d3b67
