[Jenkins] Updated translation
diff --git a/docs/de_DE/changelog.md b/docs/de_DE/changelog.md
index 8cd0335..4d59f11 100644
--- a/docs/de_DE/changelog.md
+++ b/docs/de_DE/changelog.md
@@ -16,6 +16,9 @@
 - Konfiguration hinzufügen *MClimate-Gebläsekonvektor-Thermostat*
+- Konfiguration hinzufügen *WATTECO NETW'O Netzwerktester*
+- Konfiguration hinzufügen *Milesight EM300 DI*
 # 29.04.2024
diff --git a/docs/en_US/changelog.md b/docs/en_US/changelog.md
index 6b843ec..ce54472 100644
--- a/docs/en_US/changelog.md
+++ b/docs/en_US/changelog.md
@@ -16,6 +16,9 @@
 - Adding configuration *MClimate Fan Coil Thermostat*
+- Adding configuration *WATTECO NETW'O network tester*
+- Adding configuration *Milesight EM300 DI*
 # 04/29/2024
diff --git a/docs/es_ES/changelog.md b/docs/es_ES/changelog.md
index f5bb3a6..8c768f8 100644
--- a/docs/es_ES/changelog.md
+++ b/docs/es_ES/changelog.md
@@ -16,6 +16,9 @@
 - Agregar configuración *Termostato Fan Coil Mclimate*
+- Agregar configuración *Probador de red WATTECO NETW'O*
+- Agregar configuración *Milesight EM300 DI*
 # 29/04/2024
diff --git a/docs/i18n/de_DE.json b/docs/i18n/de_DE.json
index bad272b..f3f35cb 100644
--- a/docs/i18n/de_DE.json
+++ b/docs/i18n/de_DE.json
@@ -13,6 +13,8 @@
         "Vega SI-11 Rev2": "Vega SI-11 Rev2",
         "Communication period, Input Mode": "Kommunikationszeitraum, Eingabemodus",
         "MClimate Fan Coil Thermostat": "MClimate-Gebläsekonvektor-Thermostat",
+        "WATTECO Testeur de réseau NETW'O": "WATTECO NETW'O Netzwerktester",
+        "Milesight EM300 DI": "Milesight EM300 DI",
         "29\/04\/2024": "29.04.2024",
         "Dragino D23LBLS": "Dragino D23LBLS",
         "Batterie, Temp-White, Temp-Red, Temp-Black, Alarm, PA8 Level, Mode": "Batterie, Temperatur-Weiß, Temperatur-Rot, Temperatur-Schwarz, Alarm, PA8-Stufe, Modus",
diff --git a/docs/i18n/en_US.json b/docs/i18n/en_US.json
index cb92351..c85c7dc 100644
--- a/docs/i18n/en_US.json
+++ b/docs/i18n/en_US.json
@@ -13,6 +13,8 @@
         "Communication period, Input Mode": "Communication period, Input Mode",
         "MClimate Fan Coil Thermostat": "MClimate Fan Coil Thermostat",
+        "WATTECO Testeur de réseau NETW'O": "WATTECO NETW'O network tester",
         "29\/04\/2024": "04\/29\/2024",
         "Batterie, Temp-White, Temp-Red, Temp-Black, Alarm, PA8 Level, Mode": "Battery, Temp-White, Temp-Red, Temp-Black, Alarm, PA8 Level, Mode",
diff --git a/docs/i18n/es_ES.json b/docs/i18n/es_ES.json
index ada225d..03f79d8 100644
--- a/docs/i18n/es_ES.json
+++ b/docs/i18n/es_ES.json
@@ -13,6 +13,8 @@
         "Communication period, Input Mode": "Periodo de comunicación, modo de entrada",
         "MClimate Fan Coil Thermostat": "Termostato Fan Coil Mclimate",
+        "WATTECO Testeur de réseau NETW'O": "Probador de red WATTECO NETW'O",
         "29\/04\/2024": "29\/04\/2024",
         "Batterie, Temp-White, Temp-Red, Temp-Black, Alarm, PA8 Level, Mode": "Batería, Temp-Blanco, Temp-Rojo, Temp-Negro, Alarma, Nivel PA8, Modo",
diff --git a/docs/i18n/fr_FR.json b/docs/i18n/fr_FR.json
index 86f9f6a..f1cfe71 100644
--- a/docs/i18n/fr_FR.json
+++ b/docs/i18n/fr_FR.json
@@ -15,6 +15,8 @@
+        "WATTECO Testeur de réseau NETW'O": "WATTECO Testeur de réseau NETW'O",
         "Batterie, Temp-White, Temp-Red, Temp-Black, Alarm, PA8 Level, Mode": "Batterie, Temp-White, Temp-Red, Temp-Black, Alarm, PA8 Level, Mode",
diff --git a/docs/i18n/pt_PT.json b/docs/i18n/pt_PT.json
index fc76c8d..9574348 100644
--- a/docs/i18n/pt_PT.json
+++ b/docs/i18n/pt_PT.json
@@ -13,6 +13,8 @@
         "Communication period, Input Mode": "Período de comunicação, modo de entrada",
         "MClimate Fan Coil Thermostat": "Termostato de fan coil MClimate",
+        "WATTECO Testeur de réseau NETW'O": "Testador de rede WATTECO NETW'O",
         "Batterie, Temp-White, Temp-Red, Temp-Black, Alarm, PA8 Level, Mode": "Bateria, Temp-Branco, Temp-Vermelho, Temp-Preto, Alarme, Nível PA8, Modo",
diff --git a/docs/pt_PT/changelog.md b/docs/pt_PT/changelog.md
index 9880ecf..b569eae 100644
--- a/docs/pt_PT/changelog.md
+++ b/docs/pt_PT/changelog.md
@@ -16,6 +16,9 @@
 - Adicionando configuração *Termostato de fan coil MClimate*
+- Adicionando configuração *Testador de rede WATTECO NETW'O*
+- Adicionando configuração *Milesight EM300 DI*
 # 29/04/2024
GitHub
sha: 0ede4257b13d808611aac019178da07e83e83f7a
