[JEEDORE] - Websocket connection has been closed with code:1015 reason:'An exception has occurred while connecting.'
bon stop arrete le daemon reboot du tydom et restart le daemon !!!
Toujours pareil en suivant la procédure stop demon / reboot jeedom ( alim+ pile +15s)/restart demon
J’ai même décider de réinstaller le plugin et de recommencer à zéro et toujours rien.
utilise tu ton appli tydom android en meme temps ?
Non je sais que je ne peux pas être connecter simultanément
Bonjour @Eli,
Visiblement le problème se représente depuis 2 jours :
3286|04/01/2025 13:27:29 - Connection to DeltaDore server has been closed...
3287|04/01/2025 13:27:59 - Websocket connection initialization....
3288|04/01/2025 13:27:59 - Connecting to '192.168.1.102'
3289|04/01/2025 13:27:59 - Websocket connection has been closed with code:1015 reason:'An exception has occurred while connecting.'
3290|04/01/2025 13:27:59 - Jeedore Daemon connection has been closed...
3291|04/01/2025 13:27:59 - Connection to DeltaDore server has been closed...
3292|04/01/2025 13:28:29 - Websocket connection initialization....
3293|04/01/2025 13:28:29 - Connecting to '192.168.1.102'
3294|04/01/2025 13:28:29 - Websocket connection has been closed with code:1015 reason:'An exception has occurred while connecting.'
3295|04/01/2025 13:28:29 - Jeedore Daemon connection has been closed...
3296|04/01/2025 13:28:29 - Connection to DeltaDore server has been closed...
3297|04/01/2025 13:28:59 - Websocket connection initialization....
3298|04/01/2025 13:28:59 - Connecting to '192.168.1.102'
3299|04/01/2025 13:28:59 - Websocket connection has been closed with code:1015 reason:'An exception has occurred while connecting.'
3300|04/01/2025 13:28:59 - Jeedore Daemon connection has been closed...
3301|04/01/2025 13:28:59 - Connection to DeltaDore server has been closed...
3302|04/01/2025 13:29:29 - Websocket connection initialization....
3303|04/01/2025 13:29:29 - Connecting to '192.168.1.102'
3304|04/01/2025 13:29:29 - Websocket connection has been closed with code:1015 reason:'An exception has occurred while connecting.'
3305|04/01/2025 13:29:29 - Jeedore Daemon connection has been closed...
je pense que le Dev a qui vous essayer de demander de l’aide n’est plus sur Jeedom et ne maintient plus depuis quelque temps deja le plugin jeedore (derniere maj 19/04/2020)
Vous avez créer un autre post avant de revenir sur ce fil qui date lui aussi.
donner plus d info sur l autre fil, avez vous fait des maj ? de jeedom ? de l os ? autres ?
Votre box tydom ne s’est elle pas mise à jour… automatiquement ?
avez vous juste essayer de débrancher votre box tydom ? Relancer votre box Jeedom ?
j’etais sous jeedore avant mais je suis passé au plugin tydom pour ma part car plus récent
Bonsoir @RGLD,
Merci pour la réponse
J’ai ouvert un autre post mais et je suis tombé après par hasard sur ce post.
Je n’ai fait aucun changement sur mon Jeedom (plugin ou système) sur l’os du raspberry ou sur Jeedore.
Delta dore m’a fait un mail pour une opération de maintenance sur les box tydom mais pour le 16 mars. Or elle bien fonctionner après le 16 mars.
J’ai également redémarré ma box tydom et Jeedom mais rien à faire.
Vous parler d’un autre plugin pour piloter une box tydom ? Car je n’ai trouvé aucun autre plugin sur le market…
ÉDIT : j’ai trouvé et installer le plugin Tydom en bêta . J’ai renseigné l’IP, l’adresse MAC et le mot de passe que j’avais réussi à trouvé avec Charle Proxy a l’époque (1 an) mais impossible de synchroniser.
J’ai vérifié avec Charle proxy et c’est bien le bon mot de passe
Voici les logs :
[2025-04-01 22:31:09] INFO  : Start demond
[2025-04-01 22:31:09] DEBUG  : Initializing TydomClient Class
[2025-04-01 22:31:09] INFO  : Configure local mode (192.168.1.102)
[2025-04-01 22:31:09] INFO  : Init request module v2.25.1
[2025-04-01 22:31:09] DEBUG  : Starting new HTTP connection (1): 127.0.0.1:80
[2025-04-01 22:31:09] DEBUG  : http://127.0.0.1:80 "GET /plugins/tydom/core/php/jeeTydom.php?apikey=snaOjkOzzVVbINmU72uHMRTGMG54OgwAANqLt1thhlCT6NV7pykVMRvPCbegBUX3 HTTP/1.1" 200 0
[2025-04-01 22:31:09] INFO  : Writing PID 424442 to /tmp/jeedom/tydom/deamon.pid
[2025-04-01 22:31:09] DEBUG  : Using selector: EpollSelector
[2025-04-01 22:31:09] INFO  : Connecting to tydom
[2025-04-01 22:31:09] ERROR  : Error: EOF occurred in violation of protocol (_ssl.c:1137)
