Jeedom V4 et Demon BLEA local NOK alors que V3 + BLEA (clé BT identique) = OK?
lsusb
Bus 002 Device 002: ID 174c:0825 ASMedia Technology Inc.
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 004: ID 0a12:0001 Cambridge Silicon Radio, Ltd Bluetooth Dongle (HCI mode)
Bus 001 Device 003: ID 0658:0200 Sigma Designs, Inc. Aeotec Z-Stick Gen5 (ZW090) - UZB
Bus 001 Device 002: ID 2109:3431 VIA Labs, Inc. Hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
hciconfig -a hci0
hci0:   Type: Primary  Bus: USB
        BD Address: 00:1A:7D:DA:71:13  ACL MTU: 310:10  SCO MTU: 64:8
        UP RUNNING
        RX bytes:6811509 acl:0 sco:0 events:1134080 errors:0
        TX bytes:7095832 acl:0 sco:0 commands:1133851 errors:0
        Features: 0xff 0xff 0x8f 0xfe 0xdb 0xff 0x5b 0x87
        Packet type: DM1 DM3 DM5 DH1 DH3 DH5 HV1 HV2 HV3
        Link policy: RSWITCH HOLD SNIFF PARK
        Link mode: SLAVE ACCEPT
        Class: 0x480000
        Service Classes: Capturing, Telephony
        Device Class: Miscellaneous,
        HCI Version: 4.0 (0x6)  Revision: 0x22bb
        LMP Version: 4.0 (0x6)  Subversion: 0x22bb
        Manufacturer: Cambridge Silicon Radio (10)
systemctl status bluetooth
 bluetooth.service - Bluetooth service
   Loaded: loaded (/lib/systemd/system/bluetooth.service; enabled; vendor preset
   Active: active (running) since Fri 2020-11-06 15:36:45 CET; 1 day 8h ago
     Docs: man:bluetoothd(8)
 Main PID: 320 (bluetoothd)
   Status: "Running"
    Tasks: 1 (limit: 4915)
   CGroup: /system.slice/bluetooth.service
           └─320 /usr/lib/bluetooth/bluetoothd
Warning: Journal has been rotated since unit was started. Log output is incomple
sinon le démon est bien en statut OK, comme la « santé » du plugin BLEA dans l’onglet de jeedom
démon relancé il y a qq minutes pour passer le log en info comme demandé
*** quelle est la version OS installée ?**
la commande : cat /proc/version me donne
Linux version 5.4.51-v7l+ (dom@buildbot) (gcc version 4.9.3 (crosstool-NG crosstool-ng-1.22.0-88-g8460611)) #1333 SMP Mon Aug 10 16:51:40 BST 2020
et cat /etc/issue
Raspbian GNU/Linux 10 \n \l
  • as-tu rebooté après avoir modifié le /boot/config.txt ?
    Oui m’sieur :slight_smile:
Donc je suppose que le modèle de ta clé USB Bluetooth est une SENA UD100a.
Le service bluetooth est OK.
Mais un démon OK sans log blea et ble_local c’est comme tu dis zarb’
Ce serait moi je réinstallerais le plugin (et en stable).
et je donnerais une copie d’écran de la config réseau.
akenad :slight_smile:
oh que neni, c’est une clé BT compatible BLE (5.0 donc) plutôt premier 1er (genre 10€ sur site de vente en ligne :wink: )
mais bon, je ne la mets pas en cause car elle fonctionnait (et fonctionne toujours d’ailleurs) très bien.
si je réinstalle, je perds toute mes devices donc ?
obligés de tout recréer ?
sans log pas de diag possible …
Tu peux réinstaller la stable sans désinstaller la version précédente et tu ne perds rien.
Toujours pas de local blea ?
Bonjour @Mips, OK je tente ça après les devoirs des enfants :wink: A+
[EDIT] à rien n’y comprendre :frowning:
installée la stable, choisi log « info » juste pour voir, redémarrage démon et … tjs vide !! je craque !
Ton image montre que tu es en log defaut.
Passe en log info, sauvegarde, redémarre le démon et regarde dans le log « Blea_local ».
Si ce log est toujours vide, voir ici : [Présentation] akenad - #45 par akenad
euhhh … la honte sur moi, j’avais oublié de … sauvegarder mon choix de log, patapé patapé :rofl:,
bref voici donc mon log « info » (j’ai caché mon API key)
[2020-11-08 23:30:48.287][INFO] : GLOBAL------Start blead
[2020-11-08 23:30:48.287][INFO] : GLOBAL------Log level : info
[2020-11-08 23:30:48.287][INFO] : GLOBAL------Socket port : 55008
[2020-11-08 23:30:48.288][INFO] : GLOBAL------Socket host : 127.0.0.1
[2020-11-08 23:30:48.288][INFO] : GLOBAL------Device : hci0
[2020-11-08 23:30:48.288][INFO] : GLOBAL------PID file : /tmp/jeedom/blea/deamon.pid
[2020-11-08 23:30:48.288][INFO] : GLOBAL------Apikey :
[2020-11-08 23:30:48.288][INFO] : GLOBAL------Callback : http://127.0.0.1:80/plugins/blea/core/php/jeeBlea.php
[2020-11-08 23:30:48.288][INFO] : GLOBAL------Cycle : 0.3
[2020-11-08 23:30:48.288][INFO] : GLOBAL------Scan interval  : 29
[2020-11-08 23:30:48.288][INFO] : GLOBAL------Number for no seen : 4
[2020-11-08 23:30:48.289][INFO] : GLOBAL------Scan Mode : passive
[2020-11-08 23:30:48.293][INFO] : LOADER------Import de la configuration devices.amazfitgtr
[2020-11-08 23:30:48.294][INFO] : LOADER------Import de la configuration devices.aqualin
[2020-11-08 23:30:48.297][INFO] : LOADER------Import de la configuration devices.awoxmesh
[2020-11-08 23:30:48.303][INFO] : LOADER------Import de la configuration devices.beagle
[2020-11-08 23:30:48.307][INFO] : LOADER------Import de la configuration devices.beewismartdoor
[2020-11-08 23:30:48.309][INFO] : LOADER------Import de la configuration devices.beewismartlite
[2020-11-08 23:30:48.310][INFO] : LOADER------Import de la configuration devices.blpnr
[2020-11-08 23:30:48.311][INFO] : LOADER------Import de la configuration devices.divoompixoo
[2020-11-08 23:30:48.504][INFO] : LOADER------Import de la configuration devices.divoomtimeboxmini
[2020-11-08 23:30:48.511][INFO] : LOADER------Import de la configuration devices.dotti
[2020-11-08 23:30:48.512][INFO] : LOADER------Import de la configuration devices.dreamscreen
[2020-11-08 23:30:48.513][INFO] : LOADER------Import de la configuration devices.fitbit
[2020-11-08 23:30:48.514][INFO] : LOADER------Import de la configuration devices.gigaset
[2020-11-08 23:30:48.515][INFO] : LOADER------Import de la configuration devices.hector
[2020-11-08 23:30:48.516][INFO] : LOADER------Import de la configuration devices.ibbq4
[2020-11-08 23:30:48.517][INFO] : LOADER------Import de la configuration devices.ibbq6
[2020-11-08 23:30:48.518][INFO] : LOADER------Import de la configuration devices.itag
[2020-11-08 23:30:48.519][INFO] : LOADER------Import de la configuration devices.jinlin
[2020-11-08 23:30:48.520][INFO] : LOADER------Import de la configuration devices.kst1
[2020-11-08 23:30:48.521][INFO] : LOADER------Import de la configuration devices.logiswitch
[2020-11-08 23:30:48.522][INFO] : LOADER------Import de la configuration devices.lywsd02
[2020-11-08 23:30:48.523][INFO] : LOADER------Import de la configuration devices.lywsd03
[2020-11-08 23:30:48.524][INFO] : LOADER------Import de la configuration devices.meyerdom2analog
[2020-11-08 23:30:48.525][INFO] : LOADER------Import de la configuration devices.meyerdom4contacts
[2020-11-08 23:30:48.526][INFO] : LOADER------Import de la configuration devices.meyerdomcontactvocal
[2020-11-08 23:30:48.527][INFO] : LOADER------Import de la configuration devices.miband
[2020-11-08 23:30:48.528][INFO] : LOADER------Import de la configuration devices.miband2
[2020-11-08 23:30:48.530][INFO] : LOADER------Import de la configuration devices.miband3
[2020-11-08 23:30:48.530][INFO] : LOADER------Import de la configuration devices.miband4
[2020-11-08 23:30:48.531][INFO] : LOADER------Import de la configuration devices.miflora
[2020-11-08 23:30:48.533][INFO] : LOADER------Import de la configuration devices.miscale
[2020-11-08 23:30:48.534][INFO] : LOADER------Import de la configuration devices.miscale2
[2020-11-08 23:30:48.536][INFO] : LOADER------Import de la configuration devices.myfox
[2020-11-08 23:30:48.537][INFO] : LOADER------Import de la configuration devices.niu
[2020-11-08 23:30:48.538][INFO] : LOADER------Import de la configuration devices.noke
[2020-11-08 23:30:48.539][INFO] : LOADER------Import de la configuration devices.nut
[2020-11-08 23:30:48.540][INFO] : LOADER------Import de la configuration devices.parrotplant
[2020-11-08 23:30:48.541][INFO] : LOADER------Import de la configuration devices.pixoo
[2020-11-08 23:30:48.541][INFO] : LOADER------Import de la configuration devices.pixoo.divoom_image
[2020-11-08 23:30:48.542][INFO] : LOADER------Import de la configuration devices.pixoo.messages
[2020-11-08 23:30:48.542][INFO] : LOADER------Import de la configuration devices.pixoo.timebox
[2020-11-08 23:30:48.542][INFO] : LOADER------Import de la configuration devices.pixoo.timeboximage
[2020-11-08 23:30:48.542][INFO] : LOADER------Import de la configuration devices.playbulb
[2020-11-08 23:30:48.543][INFO] : LOADER------Import de la configuration devices.ropot
[2020-11-08 23:30:48.544][INFO] : LOADER------Import de la configuration devices.ruuvi
[2020-11-08 23:30:48.545][INFO] : LOADER------Import de la configuration devices.smartplug
[2020-11-08 23:30:48.546][INFO] : LOADER------Import de la configuration devices.tb05
[2020-11-08 23:30:48.547][INFO] : LOADER------Import de la configuration devices.ticatag
[2020-11-08 23:30:48.548][INFO] : LOADER------Import de la configuration devices.tile
[2020-11-08 23:30:48.548][INFO] : LOADER------Import de la configuration devices.timebox
[2020-11-08 23:30:48.549][INFO] : LOADER------Import de la configuration devices.timebox.divoom_image
[2020-11-08 23:30:48.550][INFO] : LOADER------Import de la configuration devices.timebox.messages
[2020-11-08 23:30:48.550][INFO] : LOADER------Import de la configuration devices.timebox.timebox
[2020-11-08 23:30:48.550][INFO] : LOADER------Import de la configuration devices.timebox.timeboximage
[2020-11-08 23:30:48.550][INFO] : LOADER------Import de la configuration devices.wistiki
[2020-11-08 23:30:48.551][INFO] : LOADER------Import de la configuration devices.xiaomiht
[2020-11-08 23:30:48.552][INFO] : LOADER------Import de la configuration devices.yeelight
[2020-11-08 23:30:48.552][INFO] : LOADER------Import de la configuration devices.yeelightcandela
[2020-11-08 23:30:48.704][INFO] : GLOBAL------Start listening...
[2020-11-08 23:30:48.704][INFO] : GLOBAL------Preparing Scanner...
Donc au niveau système et jeedom c’est Ok.
Je te conseille d’investir dans une clé SENA UD100a.
Ou pas vu qu’il a déjà deux antennes qui fonctionnent bien aussi et que ces devices sont vus.
Bref… Tout va bien en fait… La clé est juste hors portée
Edit : c’était ce que je disais déjà dans le 4eme message déjà…
j’aurais pu penser ça aussi excepté que …
la clé est sur mon jeedom qui est à 3-4m max de mon premier thermo-hygro dans le salon qui lui est + loin de ma … 1ère antenne dans la cuisine :sweat_smile:
à devenir fou cette histoire.
je sens que ça va finir en suppression plugin puis réinstall, tant pis je ferai un ré appairage :wink: global et je retoucherai qq scénarios
