re après avoir bidouillé dans le boot, j(ai réussi a lancer le démarrage mais ça ne marche toujours pas voici ce que j’obtient sur la console
Loading Linux 4.19.0-21-arm64 ...
Loading initial ramdisk ...
EFI stub: Booting Linux Kernel...
EFI stub: Using DTB from configuration table
EFI stub: Exiting boot services and installing virtual address map...
[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd081]
[ 0.000000] Linux version 4.19.0-21-arm64 (debian-kernel@lists.debian.org) (gcc version 8.3.0 (Debian 8.3.0-6)) #1 SMP Debian 4.19.249-2 (2022-06-30)
[ 0.000000] efi: Getting EFI parameters from FDT:
[ 0.000000] efi: EFI v2.70 by EDK II
[ 0.000000] efi: SMBIOS 3.0=0x7b5c0000 MEMATTR=0x7a6e9018 ACPI 2.0=0x77f00000 RNG=0x7b67d298
[ 0.000000] efi: seeding entropy pool
[ 0.000000] secureboot: Secure boot disabled
[ 0.000000] cma: Reserved 64 MiB at 0x0000000073c00000
[ 0.000000] ACPI: Early table checksum verification disabled
[ 0.000000] ACPI: RSDP 0x0000000077F00000 000024 (v02 BOCHS )
[ 0.000000] ACPI: XSDT 0x0000000077EF0000 000054 (v01 BOCHS BXPCFACP 00000001 01000013)
[ 0.000000] ACPI: FACP 0x0000000077EB0000 00010C (v05 BOCHS BXPCFACP 00000001 BXPC 00000001)
[ 0.000000] ACPI: DSDT 0x0000000077EC0000 004848 (v02 BOCHS BXPCDSDT 00000001 BXPC 00000001)
[ 0.000000] ACPI: APIC 0x0000000077EA0000 0000F4 (v03 BOCHS BXPCAPIC 00000001 BXPC 00000001)
[ 0.000000] ACPI: GTDT 0x0000000077E90000 000060 (v02 BOCHS BXPCGTDT 00000001 BXPC 00000001)
[ 0.000000] ACPI: MCFG 0x0000000077E80000 00003C (v01 BOCHS BXPCMCFG 00000001 BXPC 00000001)
[ 0.000000] ACPI: SPCR 0x0000000077E70000 000050 (v02 BOCHS BXPCSPCR 00000001 BXPC 00000001)
[ 0.000000] ACPI: IORT 0x0000000077E60000 00007C (v00 BOCHS BXPCIORT 00000001 BXPC 00000001)
[ 0.000000] ACPI: SPCR: console: pl011,mmio,0x9000000,9600
[ 0.000000] ACPI: NUMA: Failed to initialise from firmware
[ 0.000000] NUMA: Faking a node at [mem 0x0000000040000000-0x000000007bcfffff]
[ 0.000000] NUMA: NODE_DATA [mem 0x7bced3c0-0x7bceefff]
[ 0.000000] Zone ranges:
[ 0.000000] DMA32 [mem 0x0000000040000000-0x000000007bcfffff]
[ 0.000000] Normal empty
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000040000000-0x0000000077f0ffff]
[ 0.000000] node 0: [mem 0x0000000077f10000-0x00000000781dffff]
[ 0.000000] node 0: [mem 0x00000000781e0000-0x000000007b4bffff]
[ 0.000000] node 0: [mem 0x000000007b4c0000-0x000000007b54ffff]
[ 0.000000] node 0: [mem 0x000000007b550000-0x000000007b55ffff]
[ 0.000000] node 0: [mem 0x000000007b560000-0x000000007b67ffff]
[ 0.000000] node 0: [mem 0x000000007b680000-0x000000007bcfffff]
[ 0.000000] Zeroed struct page in unavailable ranges: 800 pages
[ 0.000000] Initmem setup node 0 [mem 0x0000000040000000-0x000000007bcfffff]
[ 0.000000] psci: probing for conduit method from ACPI.
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: Trusted OS migration not required
[ 0.000000] psci: SMC Calling Convention v1.1
[ 0.000000] ACPI: SRAT not present
[ 0.000000] percpu: Embedded 25 pages/cpu s62296 r8192 d31912 u102400
[ 0.000000] Detected PIPT I-cache on CPU0
[ 0.000000] ARM_SMCCC_ARCH_WORKAROUND_1 missing from firmware
[ 0.000000] CPU features: enabling workaround for EL2 vector hardening
[ 0.000000] CPU features: enabling workaround for Spectre-BHB
[ 0.000000] CPU features: kernel page table isolation forced ON by KASLR
[ 0.000000] CPU features: detected: Kernel page table isolation (KPTI)
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 241164
[ 0.000000] Policy zone: DMA32
[ 0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-4.19.0-21-arm64 root=UUID=5bca12bc-64aa-494d-b443-f4d493b395cd ro single
[ 0.000000] Memory: 848064K/979968K available (9020K kernel code, 1612K rwdata, 2824K rodata, 4800K init, 537K bss, 66368K reserved, 65536K cma-reserved)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[ 0.000000] ftrace: allocating 33349 entries in 131 pages
[ 0.000000] rcu: Hierarchical RCU implementation.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=2.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] GICv2m: ACPI overriding V2M MSI_TYPER (base:80, num:64)
[ 0.000000] GICv2m: range[mem 0x08020000-0x08020fff], SPI[80:143]
[ 0.000000] arch_timer: cp15 timer(s) running at 25.00MHz (virt).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x5c40939b5, max_idle_ns: 440795202646 ns
[ 0.000001] sched_clock: 56 bits at 25MHz, resolution 40ns, wraps every 4398046511100ns
[ 0.000055] Console: colour dummy device 80x25
[ 0.000095] ACPI: Core revision 20180810
[ 0.000213] Calibrating delay loop (skipped), value calculated using timer frequency.. 50.00 BogoMIPS (lpj=100000)
[ 0.000218] pid_max: default: 32768 minimum: 301
[ 0.000321] Security Framework initialized
[ 0.000324] Yama: disabled by default; enable with sysctl kernel.yama.*
[ 0.000354] AppArmor: AppArmor initialized
[ 0.000589] Dentry cache hash table entries: 131072 (order: 8, 1048576 bytes)
[ 0.000710] Inode-cache hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.000742] Mount-cache hash table entries: 2048 (order: 2, 16384 bytes)
[ 0.000749] Mountpoint-cache hash table entries: 2048 (order: 2, 16384 bytes)
[ 0.001228] ACPI PPTT: No PPTT table found, cpu topology may be inaccurate
[ 0.001413] ASID allocator initialised with 32768 entries
[ 0.001461] rcu: Hierarchical SRCU implementation.
[ 0.002055] Remapping and enabling EFI services.
[ 0.002326] smp: Bringing up secondary CPUs ...
[ 0.026267] Detected PIPT I-cache on CPU1
[ 0.026337] CPU1: Booted secondary processor 0x0000000001 [0x410fd081]
[ 0.026449] smp: Brought up 1 node, 2 CPUs
[ 0.026456] SMP: Total of 2 processors activated.
[ 0.026461] CPU features: detected: 32-bit EL0 Support
[ 0.029882] CPU: All CPU(s) started at EL1
[ 0.029900] alternatives: patching kernel code
[ 0.030512] devtmpfs: initialized
[ 0.030839] Registered cp15_barrier emulation handler
[ 0.030856] Registered setend emulation handler
[ 0.030931] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.030944] futex hash table entries: 512 (order: 3, 32768 bytes)
[ 0.031579] pinctrl core: initialized pinctrl subsystem
[ 0.031844] SMBIOS 3.0.0 present.
[ 0.031851] DMI: QEMU KVM Virtual Machine, BIOS 0.0.0 02/06/2015
[ 0.032086] NET: Registered protocol family 16
[ 0.032228] audit: initializing netlink subsys (disabled)
[ 0.032363] audit: type=2000 audit(0.028:1): state=initialized audit_enabled=0 res=1
[ 0.032698] cpuidle: using governor ladder
[ 0.032721] cpuidle: using governor menu
[ 0.032791] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.034119] DMA: preallocated 256 KiB pool for atomic allocations
[ 0.034204] ACPI: bus type PCI registered
[ 0.034209] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[ 0.034283] Serial: AMBA PL011 UART driver
[ 0.036077] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.036637] ACPI: Added _OSI(Module Device)
[ 0.036641] ACPI: Added _OSI(Processor Device)
[ 0.036644] ACPI: Added _OSI(3.0 _SCP Extensions)
[ 0.036646] ACPI: Added _OSI(Processor Aggregator Device)
[ 0.036649] ACPI: Added _OSI(Linux-Dell-Video)
[ 0.036652] ACPI: Added _OSI(Linux-Lenovo-NV-HDMI-Audio)
[ 0.049179] ACPI: 1 ACPI AML tables successfully acquired and loaded
[ 0.050278] ACPI: Interpreter enabled
[ 0.050282] ACPI: Using GIC for interrupt routing
[ 0.050305] ACPI: MCFG table detected, 1 entries
[ 0.054060] ARMH0011:00: ttyAMA0 at MMIO 0x9000000 (irq = 4, base_baud = 0) is a SBSA
[ 0.408782] console [ttyAMA0] enabled
[ 0.412851] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
[ 0.416262] acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI]
[ 0.420374] acpi PNP0A08:00: _OSC: platform does not support [SHPCHotplug LTR]
[ 0.424393] acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug PME AER PCIeCapability]
[ 0.428991] acpi PNP0A08:00: ECAM area [mem 0x4010000000-0x401fffffff] reserved by PNP0C02:00
[ 0.433466] acpi PNP0A08:00: ECAM at [mem 0x4010000000-0x401fffffff] for [bus 00-ff]
[ 0.437554] Remapped I/O 0x000000003eff0000 to [io 0x0000-0xffff window]
[ 0.441168] PCI host bridge to bus 0000:00
[ 0.443253] pci_bus 0000:00: root bus resource [mem 0x10000000-0x3efeffff window]
[ 0.447454] pci_bus 0000:00: root bus resource [io 0x0000-0xffff window]
[ 0.451047] pci_bus 0000:00: root bus resource [mem 0x8000000000-0xffffffffff window]
[ 0.454872] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 0.494134] pci 0000:00:06.0: BAR 0: assigned [mem 0x10000000-0x10ffffff pref]
[ 0.497956] pci 0000:00:06.0: BAR 6: assigned [mem 0x11000000-0x1100ffff pref]
[ 0.501682] pci 0000:00:01.0: BAR 4: assigned [mem 0x8000000000-0x8000003fff 64bit pref]
[ 0.505706] pci 0000:00:02.0: BAR 4: assigned [mem 0x8000004000-0x8000007fff 64bit pref]
[ 0.509968] pci 0000:00:03.0: BAR 4: assigned [mem 0x8000008000-0x800000bfff 64bit pref]
[ 0.514212] pci 0000:00:04.0: BAR 4: assigned [mem 0x800000c000-0x800000ffff 64bit pref]
[ 0.518363] pci 0000:00:05.0: BAR 4: assigned [mem 0x8000010000-0x8000013fff 64bit pref]
[ 0.522707] pci 0000:00:07.0: BAR 4: assigned [mem 0x8000014000-0x8000017fff 64bit pref]
[ 0.528061] pci 0000:00:08.0: BAR 4: assigned [mem 0x8000018000-0x800001bfff 64bit pref]
[ 0.533460] pci 0000:00:09.0: BAR 0: assigned [mem 0x800001c000-0x800001ffff 64bit]
[ 0.537603] pci 0000:00:01.0: BAR 1: assigned [mem 0x11010000-0x11010fff]
[ 0.541067] pci 0000:00:02.0: BAR 1: assigned [mem 0x11011000-0x11011fff]
[ 0.544431] pci 0000:00:03.0: BAR 1: assigned [mem 0x11012000-0x11012fff]
[ 0.551246] pci 0000:00:06.0: BAR 2: assigned [mem 0x11013000-0x11013fff]
[ 0.554564] pci 0000:00:07.0: BAR 1: assigned [mem 0x11014000-0x11014fff]
[ 0.558434] pci 0000:00:08.0: BAR 1: assigned [mem 0x11015000-0x11015fff]
[ 0.562504] pci 0000:00:01.0: BAR 0: assigned [io 0x1000-0x107f]
[ 0.566413] pci 0000:00:02.0: BAR 0: assigned [io 0x1080-0x10bf]
[ 0.570309] pci 0000:00:03.0: BAR 0: assigned [io 0x10c0-0x10df]
[ 0.573925] pci 0000:00:04.0: BAR 0: assigned [io 0x10e0-0x10ff]
[ 0.577753] pci 0000:00:05.0: BAR 0: assigned [io 0x1100-0x111f]
[ 0.581640] ACPI: PCI Interrupt Link [GSI0] (IRQs *35)
[ 0.584222] ACPI: PCI Interrupt Link [GSI1] (IRQs *36)
[ 0.586887] ACPI: PCI Interrupt Link [GSI2] (IRQs *37)
[ 0.589556] ACPI: PCI Interrupt Link [GSI3] (IRQs *38)
[ 0.593016] pci 0000:00:06.0: vgaarb: VGA device added: decodes=io+mem,owns=none,locks=none
[ 0.597194] pci 0000:00:06.0: vgaarb: bridge control possible
[ 0.600321] pci 0000:00:06.0: vgaarb: setting as boot device (VGA legacy resources not available)
[ 0.604688] vgaarb: loaded
[ 0.606253] pps_core: LinuxPPS API ver. 1 registered
[ 0.609003] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.613765] PTP clock support registered
[ 0.615822] EDAC MC: Ver: 3.0.0
[ 0.617831] Registered efivars operations
[ 0.620692] clocksource: Switched to clocksource arch_sys_counter
[ 0.643889] VFS: Disk quotas dquot_6.6.0
[ 0.645865] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.658305] AppArmor: AppArmor Filesystem Enabled
[ 0.661020] pnp: PnP ACPI init
[ 0.663078] system 00:00: [mem 0x4010000000-0x401fffffff window] could not be reserved
[ 0.667562] pnp: PnP ACPI: found 1 devices
[ 0.673854] NET: Registered protocol family 2
[ 0.676469] IP idents hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.680512] tcp_listen_portaddr_hash hash table entries: 512 (order: 1, 8192 bytes)
[ 0.684685] TCP established hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.688494] TCP bind hash table entries: 8192 (order: 5, 131072 bytes)
[ 0.692118] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.695487] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 0.698784] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 0.702536] NET: Registered protocol family 1
[ 0.704952] NET: Registered protocol family 44
[ 0.707656] pci 0000:00:09.0: enabling device (0000 -> 0002)
[ 0.711335] Unpacking initramfs...
[ 1.298447] Freeing initrd memory: 24484K
[ 1.346408] hw perfevents: enabled with armv8_pmuv3_0 PMU driver, 7 counters available
[ 1.350893] kvm [1]: HYP mode not available
[ 1.354035] Initialise system trusted keyrings
[ 1.355736] Key type blacklist registered
[ 1.357973] workingset: timestamp_bits=42 max_order=18 bucket_order=0
[ 1.363260] zbud: loaded
[ 1.566110] Key type asymmetric registered
[ 1.568007] Asymmetric key parser 'x509' registered
[ 1.570534] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
[ 1.574205] io scheduler noop registered
[ 1.575959] io scheduler deadline registered
[ 1.578305] io scheduler cfq registered (default)
[ 1.580617] io scheduler mq-deadline registered
[ 1.584818] pl061_gpio ARMH0061:00: PL061 GPIO chip @0x0000000009030000 registered
[ 1.588786] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[ 1.592724] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0
[ 1.595848] ACPI: Power Button [PWRB]
[ 1.598877] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 1.603159] Serial: AMBA driver
[ 1.605099] msm_serial: driver initialized
[ 1.607530] ACPI PPTT: No PPTT table found, cache topology may be inaccurate
[ 1.611618] ACPI PPTT: No PPTT table found, cache topology may be inaccurate
[ 1.615574] cacheinfo: Unable to detect cache hierarchy for CPU 0
[ 1.619395] mousedev: PS/2 mouse device common for all mice
[ 1.623032] rtc-efi rtc-efi: rtc core: registered rtc-efi as rtc0
[ 1.627135] ledtrig-cpu: registered to indicate activity on CPUs
[ 1.631333] NET: Registered protocol family 10
[ 1.650684] Segment Routing with IPv6
[ 1.652406] mip6: Mobile IPv6
[ 1.654133] NET: Registered protocol family 17
[ 1.656157] mpls_gso: MPLS GSO support
[ 1.658847] registered taskstats version 1
[ 1.661066] Loading compiled-in X.509 certificates
[ 1.710763] Loaded X.509 cert 'Debian Secure Boot CA: 6ccece7e4c6c0d1f6149f3dd27dfcc5cbb419ea1'
[ 1.714834] Loaded X.509 cert 'Debian Secure Boot Signer 2021 - linux: 4b6ef5abca669825178e052c84667ccbc0531f8c'
[ 1.719827] zswap: loaded using pool lzo/zbud
[ 1.722257] AppArmor: AppArmor sha1 policy hashing enabled
[ 1.725408] rtc-efi rtc-efi: setting system clock to 2022-08-30 16:04:58 UTC (1661875498)
[ 1.732024] Freeing unused kernel memory: 4800K
[ 1.748847] Run /init as init process
Loading, please wait...
Starting version 241
[ 1.894983] PCI Interrupt Link [GSI1] enabled at IRQ 36
[ 1.918100] virtio-pci 0000:00:01.0: enabling device (0005 -> 0007)
[ 1.936578] ACPI: bus type USB registered
[ 1.940480] PCI Interrupt Link [GSI2] enabled at IRQ 37
[ 1.944086] usbcore: registered new interface driver usbfs
[ 1.948454] virtio-pci 0000:00:02.0: enabling device (0005 -> 0007)
[ 1.954262] usbcore: registered new interface driver hub
[ 1.958882] usbcore: registered new device driver usb
[ 1.966433] PCI Interrupt Link [GSI3] enabled at IRQ 38
[ 1.969086] virtio-pci 0000:00:03.0: enabling device (0005 -> 0007)
[ 1.979404] PCI Interrupt Link [GSI0] enabled at IRQ 35
[ 1.981809] virtio-pci 0000:00:04.0: enabling device (0005 -> 0007)
[ 1.986184] xhci_hcd 0000:00:09.0: xHCI Host Controller
[ 1.989913] xhci_hcd 0000:00:09.0: new USB bus registered, assigned bus number 1
[ 1.991264] virtio-pci 0000:00:05.0: enabling device (0005 -> 0007)
[ 1.998615] xhci_hcd 0000:00:09.0: hcc params 0x00080001 hci version 0x100 quirks 0x0000000000000010
[ 2.003646] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
[ 2.008205] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.012905] usb usb1: Product: xHCI Host Controller
[ 2.016516] virtio_blk virtio0: [vda] 88080392 512-byte logical blocks (45.1 GB/42.0 GiB)
[ 2.016660] usb usb1: Manufacturer: Linux 4.19.0-21-arm64 xhci-hcd
[ 2.024863] usb usb1: SerialNumber: 0000:00:09.0
[ 2.028018] hub 1-0:1.0: USB hub found
[ 2.030133] hub 1-0:1.0: 8 ports detected
[ 2.040060] SCSI subsystem initialized
[ 2.042581] xhci_hcd 0000:00:09.0: xHCI Host Controller
[ 2.045342] xhci_hcd 0000:00:09.0: new USB bus registered, assigned bus number 2
[ 2.050156] xhci_hcd 0000:00:09.0: Host supports USB 3.0 SuperSpeed
[ 2.053381] scsi host0: Virtio SCSI HBA
[ 2.054780] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[ 2.062445] scsi 0:0:0:0: CD-ROM QEMU QEMU CD-ROM 2.5+ PQ: 0 ANSI: 5
[ 2.063720] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 4.19
[ 2.073404] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.077623] usb usb2: Product: xHCI Host Controller
[ 2.080934] usb usb2: Manufacturer: Linux 4.19.0-21-arm64 xhci-hcd
[ 2.084892] usb usb2: SerialNumber: 0000:00:09.0
[ 2.088077] vda: vda1 vda2
[ 2.089409] hub 2-0:1.0: USB hub found
[ 2.092205] hub 2-0:1.0: 8 ports detected
[ 2.445034] sr 0:0:0:0: Power-on or device reset occurred
[ 2.448684] sr 0:0:0:0: [sr0] scsi3-mmc drive: 16x/50x cd/rw xa/form2 cdda tray
[ 2.453118] cdrom: Uniform CD-ROM driver Revision: 3.20
[ 2.520741] usb 1-1: new full-speed USB device number 2 using xhci_hcd
[ 2.670261] usb 1-1: New USB device found, idVendor=0658, idProduct=0200, bcdDevice= 0.00
[ 2.674303] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
Begin: Loading essential drivers ... done.
Begin: Running /scripts/init-premount ... done.
Begin: Mounting root file system ... Begin: Running /scripts/local-top ... done.
Begin: Running /scripts/local-premount ... done.
Begin: Will now check root file system ... fsck from util-linux 2.33.1
[/sbin/fsck.ext4 (1) -- /dev/vda2] fsck.ext4 -a -C0 /dev/vda2
/dev/vda2: recovering journal
/dev/vda2: Clearing orphaned inode 437 (uid=33, gid=33, mode=0100666, size=0)
/dev/vda2: Clearing orphaned inode 410 (uid=33, gid=33, mode=0100666, size=0)
/dev/vda2: Clearing orphaned inode 39 (uid=33, gid=33, mode=0100666, size=0)
/dev/vda2: Clearing orphaned inode 359 (uid=0, gid=0, mode=0100666, size=0)
/dev/vda2: Clearing orphaned inode 341 (uid=111, gid=118, mode=0100600, size=0)
/dev/vda2: Clearing orphaned inode 121 (uid=111, gid=118, mode=0100600, size=0)
/dev/vda2: Clearing orphaned inode 66 (uid=111, gid=118, mode=0100600, size=0)
/dev/vda2: Clearing orphaned inode 64 (uid=111, gid=118, mode=0100600, size=0)
/dev/vda2: clean, 104255/2618112 files, 1460902/10983932 blocks
done.
[ 5.881625] EXT4-fs (vda2): mounted filesystem with ordered data mode. Opts: (null)
done.
Begin: Running /scripts/local-bottom ... done.
Begin: Running /scripts/init-bottom ... done.
[ 8.841193] systemd[1]: Inserted module 'autofs4'
[ 9.194656] random: crng init done
[ 9.343232] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[ 9.359350] systemd[1]: Detected virtualization kvm.
[ 9.363022] systemd[1]: Detected architecture arm64.
Welcome to Debian GNU/Linux 10 (buster)!
[ 9.409978] systemd[1]: Set hostname to <neodomo>.
[ 9.569870] systemd-system-update-generator[163]: Offline system update overridden by runlevel "single" on the kernel command line
[ 12.888800] systemd[1]: /lib/systemd/system/fail2ban.service:12: PIDFile= references path below legacy directory /var/run/, updating /var/run/fail2ban/fail2ban.pid → /run/fail2ban/fail2ban.pid; please update the unit file accordingly.
[ 13.300636] systemd[1]: Listening on udev Control Socket.
[ OK ] Listening on udev Control Socket.
[ 13.307237] systemd[1]: Listening on Journal Socket.
[ OK ] Listening on Journal Socket.
[ 13.314906] systemd[1]: Mounting Huge Pages File System...
[ 13.320845] systemd[1]: Starting Create list of required static device nodes for the current kernel...
Starting Create list of re…odes for the current kernel...
[ 13.326899] systemd[1]: Listening on fsck to fsckd communication Socket.
[ OK ] Listening on fsck to fsckd communication Socket.
Starting Remount Root and Kernel File Systems...
Mounting POSIX Message Queue File System...
Starting Load Kernel Modules...
[ OK ] Started Dispatch Password …ts to Console Directory Watch.
[ OK ] Reached target Local Encrypted Volumes.
[ OK ] Listening on Journal Audit Socket.
[ OK ] Set up automount Arbitrary…s File System Automount Point.
[ OK ] Reached target Swap.
[ OK ] Listening on udev Kernel Socket.
Starting udev Coldplug all Devices...
Mounting Kernel Debug File System...
[ OK ] Listening on Journal Socket (/dev/log).
Starting Journal Service...
[ OK ] Mounted Huge Pages File System.
[ OK ] Started Create list of req… nodes for the current kernel.
[ OK ] Mounted POSIX Message Queue File System.
[ OK ] Started Load Kernel Modules.
[ OK ] Mounted Kernel Debug File System.
Starting Apply Kernel Variables...
[ 13.569534] EXT4-fs (vda2): re-mounted. Opts: errors=remount-ro
[ OK ] Started Remount Root and Kernel File Systems.
Starting Create System Users...
Starting Load/Save Random Seed...
[ OK ] Started Journal Service.
[ OK ] Started Apply Kernel Variables.
Starting Flush Journal to Persistent Storage...
[ OK ] Started Load/Save Random Seed.
[ 13.725969] systemd-journald[187]: Received request to flush runtime journal from PID 1
[ OK ] Started udev Coldplug all Devices.
[ OK ] Started Flush Journal to Persistent Storage.
[ OK ] Started Create System Users.
Starting Create Static Device Nodes in /dev...
[ OK ] Started Create Static Device Nodes in /dev.
[ OK ] Reached target Local File Systems (Pre).
Mounting /tmp/jeedom...
Starting udev Kernel Device Manager...
[ OK ] Mounted /tmp/jeedom.
[ OK ] Started udev Kernel Device Manager.
[ 14.839985] input: QEMU Virtio Keyboard as /devices/pci0000:00/0000:00:07.0/virtio5/input/input1
[ 14.854487] input: QEMU Virtio Tablet as /devices/pci0000:00/0000:00:08.0/virtio6/input/input2
[ OK ] Found device /dev/disk/by-uuid/4A5D-628A.
Mounting /boot/efi...
[ 14.967849] EFI Variables Facility v0.08 2004-May-17
[ 15.009953] pstore: Using compression: deflate
[ 15.012245] pstore: Registered efi as persistent store backend
[ 15.401161] sr 0:0:0:0: Attached scsi generic sg0 type 5
[ 15.705178] FAT-fs (vda1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[ OK ] Mounted /boot/efi.
[ OK ] Reached target Local File Systems.
[ 15.737960] cdc_acm 1-1:1.0: ttyACM0: USB ACM device
Starting Create Volatile Files and Directories...[ 15.751190] usbcore: registered new interface driver cdc_acm
[ 15.754317] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
Starting Load AppArmor profiles...
[ 15.844186] cryptd: max_cpu_qlen set to 1000
[ 15.923163] bochs-drm 0000:00:06.0: enabling device (0000 -> 0002)
[ 15.930177] [drm] Found bochs VGA, ID 0xb0c5.
[ 15.933531] [drm] Framebuffer size 16384 kB @ 0x10000000, mmio @ 0x11013000.
[ 15.938879] [TTM] Zone kernel: Available graphics memory: 471442 kiB
[ 15.943779] [TTM] Initializing pool allocator
[ 15.947041] [TTM] Initializing DMA pool allocator
[ 15.956371] Console: switching to colour frame buffer device 128x48
[ 15.963297] bochs-drm 0000:00:06.0: fb0: bochsdrmfb frame buffer device
[ OK ] Started Create Volatile Files and Directories.
[ 15.980768] [drm] Initialized bochs-drm 1.0.0 20130925 for 0000:00:06.0 on minor 0
[ OK ] Reached target System Time Synchronized.
Starting Update UTMP about System Boot/Shutdown...
[ OK ] Started Update UTMP about System Boot/Shutdown.
[ OK ] Found device Virtio network device.
[ 16.638070] audit: type=1400 audit(1661875513.408:2): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/bin/man" pid=273 comm="apparmor_parser"
[ 16.652208] audit: type=1400 audit(1661875513.408:3): apparmor="STATUS" operation="profile_load" profile="unconfined" name="man_filter" pid=273 comm="apparmor_parser"
[ 16.663433] audit: type=1400 audit(1661875513.408:4): apparmor="STATUS" operation="profile_load" profile="unconfined" name="man_groff" pid=273 comm="apparmor_parser"
[ 16.675920] audit: type=1400 audit(1661875513.408:5): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe" pid=275 comm="apparmor_parser"
[ 16.688746] audit: type=1400 audit(1661875513.408:6): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe//kmod" pid=275 comm="apparmor_parser"
[ 16.688751] audit: type=1400 audit(1661875513.448:7): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/sbin/ntpd" pid=274 comm="apparmor_parser"
[ OK ] Started Load AppArmor profiles.
[ OK ] Reached target System Initialization.
[ OK ] Started Rescue Shell.
[ OK ] Reached target Rescue Mode.
Starting Update UTMP about System Runlevel Changes...
[ OK ] Started ifup for eth0.
[ OK ] Started Update UTMP about System Runlevel Changes.
[ 17.647288] print_req_error: I/O error, dev vda, sector 1859584
[ 17.650677] EXT4-fs warning (device vda2): ext4_end_bio:325: I/O error 10 writing to inode 5669 (offset 0 size 4096 starting block 232449)
[ 17.657187] Buffer I/O error on device vda2, logical block 206336
[ 17.663000] print_req_error: I/O error, dev vda, sector 285200
[ 17.666033] EXT4-fs warning (device vda2): htree_dirblock_to_tree:1011: inode #14054: lblock 0: comm run-parts: error -5 reading directory block
[ 18.916950] print_req_error: I/O error, dev vda, sector 1781760
[ 18.920058] Buffer I/O error on dev vda2, logical block 196608, lost sync page write
[ 18.924057] JBD2: Error -5 detected when updating journal superblock for vda2-8.
[ 18.927500] Aborting journal on device vda2-8.
[ 18.929667] print_req_error: I/O error, dev vda, sector 1781760
[ 18.932376] print_req_error: I/O error, dev vda, sector 1781760
[ 18.935080] Buffer I/O error on dev vda2, logical block 196608, lost sync page write
[ 18.938877] JBD2: Error -5 detected when updating journal superblock for vda2-8.
[ 44.004960] print_req_error: I/O error, dev vda, sector 208896
[ 44.010067] print_req_error: I/O error, dev vda, sector 208896
[ 44.014829] Buffer I/O error on dev vda2, logical block 0, lost sync page write
[ 44.020976] print_req_error: I/O error, dev vda, sector 473496
[ 44.025851] EXT4-fs warning (device vda2): ext4_end_bio:325: I/O error 10 writing to inode 298 (offset 0 size 0 starting block 59188)
[ 44.035827] Buffer I/O error on device vda2, logical block 33075
[ 44.040955] EXT4-fs (vda2): I/O error while writing superblock
[ 44.045384] EXT4-fs error (device vda2): ext4_journal_check_start:61: Detected aborted journal
[ 44.052189] EXT4-fs (vda2): Remounting filesystem read-only
[ 44.056542] print_req_error: I/O error, dev vda, sector 208896
[ 44.061271] print_req_error: I/O error, dev vda, sector 208896
[ 44.065924] Buffer I/O error on dev vda2, logical block 0, lost sync page write
[ 44.071797] EXT4-fs (vda2): I/O error while writing superblock
[ 44.074212] EXT4-fs (vda2): ext4_writepages: jbd2_start: 6143 pages, ino 298; err -30
