Jeedom dans les choux
Petite surprise pour moi ce matin. Mon jeedom fonctionne a peut prês mais j’ai des truc qui sont HS (volet ouvert avant l’heure…).
Je me connecte et vois des truc pas très net dans le logs.
Log jeedom :
[2022-02-02 05:54:15][ERROR] : Erreur sur jeedom::backup() : Echec durant la sauvegarde de la base de données. Vérifiez que mysqldump est présent. Code retourné : 2
log http.errror:
2 /var/www/html/core/class/DB.class.php(82): DB::getConnection()
#3 /var/www/html/core/class/config.class.php(187): DB::Prepare('SELECT `key`,`v...', Array, 1)
#4 /var/www/html/core/class/translate.class.php(34): config::byKeys(Array)
#5 /var/www/html/core/class/translate.class.php(151): translate::getConfig('language', 'fr_FR')
#6 /var/www/html/core/class/translate.class.php(75): translate::getLanguage()
#7 /var/www/html/core/class/translate.class.php(54): translate::exec('{{Chauffage}}', '/var/www/html/c...', false)
#8 /var/www/html/core/class/translate.class.php(165): translate::sentence('Chauffage', '/var/www/html/c...', false)
#9 /var/www/html/core/config/jeedom.config.php(23): __('Chauffage', '/var in /var/www/html/core/class/DB.class.php on line 40
[Wed Feb 02 05:00:16.172891 2022] [php7:error] [pid 26925] [client 127.0.0.1:58854] PHP Fatal error:  Uncaught PDOException: SQLSTATE[HY000] [2002] Connection refused in /var/www/html/core/class/DB.class.php:40
Stack trace:
#0 /var/www/html/core/class/DB.class.php(40): PDO->__construct('mysql:host=loca...', 'jeedom', '3767e406548139f', Array)
#1 /var/www/html/core/class/DB.class.php(50): DB::initConnection()
#2 /var/www/html/core/class/DB.class.php(82): DB::getConnection()
[Wed Feb 02 05:00:19.429867 2022] [php7:error] [pid 29981] [client 127.0.0.1:58882] PHP Fatal error:  Uncaught PDOException: SQLSTATE[HY000] [2002] Connection refused in /var/www/html/core/class/DB.class.php:40
Stack trace:
[Wed Feb 02 05:00:19.432341 2022] [php7:error] [pid 12868] [client 127.0.0.1:58884] PHP Fatal error:  Uncaught PDOException: SQLSTATE[HY000] [2002] Connection refused in /var/www/html/core/class/DB.class.php:40
Stack trace:
[Wed Feb 02 05:00:19.434640 2022] [php7:error] [pid 23788] [client 127.0.0.1:58886] PHP Fatal error:  Uncaught PDOException: SQLSTATE[HY000] [2002] Connection refused in /var/www/html/core/class/DB.class.php:40
Stack trace:
[Wed Feb 02 05:54:17.048140 2022] [php7:error] [pid 8607] [client 127.0.0.1:35908] PHP Fatal error:  Uncaught PDOException: SQLSTATE[HY000] [2002] Connection refused in /var/www/html/core/class/DB.class.php:40
Stack trace:
[Wed Feb 02 05:54:17.050001 2022] [php7:error] [pid 23788] [client 127.0.0.1:35910] PHP Fatal error:  Uncaught PDOException: SQLSTATE[HY000] [2002] Connection refused in /var/www/html/core/class/DB.class.php:40
Stack trace:
[Wed Feb 02 05:54:17.051624 2022] [php7:error] [pid 4754] [client 127.0.0.1:35912] PHP Fatal error:  Uncaught PDOException: SQLSTATE[HY000] [2002] Connection refused in /var/www/html/core/class/DB.class.php:40
Stack trace:
[Wed Feb 02 05:54:17.068464 2022] [php7:error] [pid 26925] [client 127.0.0.1:35914] PHP Fatal error:  Uncaught PDOException: SQLSTATE[HY000] [2002] Connection refused in /var/www/html/core/class/DB.class.php:40
Stack trace:
[Wed Feb 02 05:54:17.070231 2022] [php7:error] [pid 29981] [client 127.0.0.1:35916] PHP Fatal error:  Uncaught PDOException: SQLSTATE[HY000] [2002] Connection refused in /var/www/html/core/class/DB.class.php:40
Stack trace:
[Wed Feb 02 05:54:17.071962 2022] [php7:error] [pid 5096] [client 127.0.0.1:35918] PHP Fatal error:  Uncaught PDOException: SQLSTATE[HY000] [2002] Connection refused in /var/www/html/core/class/DB.class.php:40
Stack trace:
[Wed Feb 02 05:54:18.960128 2022] [php7:error] [pid 6316] [client 192.168.1.112:36798] PHP Fatal error:  Uncaught PDOException: SQLSTATE[HY000] [2002] Connection refused in /var/www/html/core/class/DB.class.php:40
Stack trace:
[Wed Feb 02 05:54:18.962890 2022] [php7:error] [pid 12868] [client 192.168.1.112:36800] PHP Fatal error:  Uncaught PDOException: SQLSTATE[HY000] [2002] Connection refused in /var/www/html/core/class/DB.class.php:40
Stack trace:
[Wed Feb 02 05:54:18.965366 2022] [php7:error] [pid 24610] [client 192.168.1.112:36802] PHP Fatal error:  Uncaught PDOException: SQLSTATE[HY000] [2002] Connection refused in /var/www/html/core/class/DB.class.php:40
Stack trace:
[Wed Feb 02 05:54:20.962789 2022] [php7:error] [pid 18101] [client 127.0.0.1:35954] PHP Fatal error:  Uncaught PDOException: SQLSTATE[HY000] [2002] Connection refused in /var/www/html/core/class/DB.class.php:40
Stack trace:
[Wed Feb 02 05:54:20.964858 2022] [php7:error] [pid 8607] [client 127.0.0.1:35956] PHP Fatal error:  Uncaught PDOException: SQLSTATE[HY000] [2002] Connection refused in /var/www/html/core/class/DB.class.php:40
Stack trace:
[Wed Feb 02 05:54:20.966810 2022] [php7:error] [pid 23788] [client 127.0.0.1:35958] PHP Fatal error:  Uncaught PDOException: SQLSTATE[HY000] [2002] Connection refused in /var/www/html/core/class/DB.class.php:40
Stack trace:
La page santé est OK
en revanche tout les cron sont arrêtés.
Quest-ce que vous me conseiller de faire ?
Tu peux essayer de te connecter avec rescue=1 et aller vérifier la bdd
J’ai une erreur le site est inaccessible. Mais je suis pas sûr de l’adresse :
http://192.168.0.107/index.php?v=d&rescue=1
Après ça a l’air moins important que je le pensais au départ car beaucoup d’automatisme fonctionne et tout mes périphérique sont ok
Tu as accès au menu configuration onglet os/sb?
Si oui lance le check-up de la base par la
Tout est ok. Idem pour la vérification de la bdd et des packages
Marrant on dirait que le mot chauffage lui pose souci
La seul Loic ou Kiboost peuvent analyser et voir si souci
J’ai envoyé un ticket au support je verrais bien. Merci
C’est un soucis DB qui été dans les choux. Redémarre ça devrait rentrer dans l’ordre. Si ça se reproduit c’est soit un jeedom trop chargé pour sa puissance soit un soucis avec le stockage en général.
Ok je reboot et je vois merci.
C’est l’erreur typique avec un problème db.
C’est juste que c’est dans les première ligne de code d’initialisation :wink:
Il y a d’autres posts sur community avec le même problème.
J’ai reboot mais toujours le même message quand je tente une sauvegarde :
[START BACKUP]
***************Start of Jeedom backup at 2022-02-02 08:55:09***************
Envoi l'évènement de début de sauvegarde...
OK
Vérification des droits sur les fichiers...OK
Backup plugin deconz...OK
Vérification de la base de données...
mysqlcheck: Got error: 2013: Lost connection to MySQL server during query when executing 'CHECK TABLE ... '
OK
Sauvegarde la base de données...mysqldump: Got error: 2002: "Can't connect to local MySQL server through socket '/var/run/mysqld/mysqld.sock' (111)" when trying to connect
Erreur durant la sauvegarde : Echec durant la sauvegarde de la base de données. Vérifiez que mysqldump est présent. Code retourné : 2Détails : Array
[END BACKUP ERROR]
PHP Fatal error:  Uncaught Exception: Echec durant la sauvegarde de la base de données. Vérifiez que mysqldump est présent. Code retourné : 2 in /var/www/html/install/backup.php:104
Stack trace:
#0 {main}
thrown in /var/www/html/install/backup.php on line 104
Tu as vérifié ?
Tu dois avoir un problème avec l’une des tables dans la bdd @Idaho947.
Fait une recherche tu devrais trouver un post qui explique ce qui a été fait pour vérifier les tables et s’en sortir.
C’était la même chose, un problème à chaque backup donc reproductible en le lançant à la main.
@Bison tu parles de ce post Restauration d'une table de base de données corrompue à partir d'une sauvegarde (partage d'expériences) ?
mysqldump Ver 10.19 Distrib 10.3.31-MariaDB, for debian-linux-gnu (x86_64)
oui il est là
Bon j’ai fais une semi boulette…
J’ai voulu rapatrier une sauvegarde (celle d’hier) de mon NAS vers le jeedom. Sauf que j’avais oublié que ce bouton rapatrie et installe… Donc j’ai restaurer la sauvegarde d’hier.
A voir si ça résolut le soucis, je pense que oui. Et surtout si ça va replanter cette nuit. En tout cas la sauvegarde remarche.
