Jeedom 4.5 et erreurs sur vérification de 4 tables dans « backup.log »
Bonjour.
Contexte diy, debian 12, jeedom beta 4.5
Je constate la présence d’erreurs sur la vérification de 4 tables dans la log « backup »
[START BACKUP]
***************Start of Jeedom backup at 2024-11-13 11:35:47***************
Send begin backup event...
OK
Checking files rights...
OK
 Backing up plugin netatmoSecurity...OK
Checking  table aprescouchésoleil...Failed to SHOW CREATE TABLE `aprescouchésoleil`
Error: Table 'jeedom.aprescouchésoleil' doesn't exist
OK
Checking  table apreslevésoleil...Failed to SHOW CREATE TABLE `apreslevésoleil`
Error: Table 'jeedom.apreslevésoleil' doesn't exist
OK
Checking  table avantcouchésoleil...Failed to SHOW CREATE TABLE `avantcouchésoleil`
Error: Table 'jeedom.avantcouchésoleil' doesn't exist
OK
Checking  table avantlevésoleil...Failed to SHOW CREATE TABLE `avantlevésoleil`
Error: Table 'jeedom.avantlevésoleil' doesn't exist
OK
Checking  table cache...OK
Checking  table calendar_event...OK
Checking  table cmd...OK
Checking  table config...OK
Checking  table conso_abo...OK
Checking  table conso_current...OK
Checking  table conso_groupe...OK
Checking  table conso_jour...OK
Checking  table conso_periode...OK
Checking  table conso_periode_groupe...OK
Checking  table conso_price...OK
Checking  table conso_taxe...OK
Checking  table conso_teleinfo...OK
Checking  table conso_tmp...OK
Checking  table conso_tva...OK
Checking  table cron...OK
Checking  table dataStore...OK
Checking  table devolo_connection...OK
Checking  table devolo_cpl_rates...OK
Checking  table devolo_macinfo...OK
Checking  table eqLogic...OK
Checking  table eqReal...OK
Checking  table history...OK
Checking  table historyArch...OK
Checking  table interactDef...OK
Checking  table interactQuery...OK
Checking  table listener...OK
Checking  table message...OK
Checking  table note...OK
Checking  table object...OK
Checking  table plan...OK
Checking  table plan3d...OK
Checking  table plan3dHeader...OK
Checking  table planHeader...OK
Checking  table queue...OK
Checking  table scenario...OK
Checking  table scenarioElement...OK
Checking  table scenarioExpression...OK
Checking  table scenarioSubElement...OK
Checking  table timeline...OK
Checking  table update...OK
Checking  table user...OK
Checking  table view...OK
Checking  table viewData...OK
Checking  table viewZone...OK
Checking  table widgets...OK
Backing up database...
OK
Cache persistence:
OK
Creating archive...
Plugin MQTTDiscovery - Following subfolder will be excluded from the backup: resources/venv
Plugin meteofrance - Following subfolder will be excluded from the backup: data/*.json
OK
Cleaning old backup...OK
Send backup Samba...
OK
Limiting backup size to 500 Mb...
Delete: /var/www/html/core/php/../../backup/backup-DMJ_Jeedom_DEV-4.5-2024-11-13-03h37.tar.gz
OK
Backup name: /var/www/html/core/php/../../backup/backup-DMJ_Jeedom_DEV-4.5-2024-11-13-11h35.tar.gz
OK
Send end backup event...OK
Backup operation duration: 20s
***************Jeedom backup end***************
[END BACKUP SUCCESS]
Pour la même tâche dans la log « cron_execution », pas d’erreur :
***************Start of Jeedom backup at 2024-11-13 03:37:01***************
Send begin backup event...OK
Checking files rights... OK
Checking  table aprescouchésoleil...OK
Checking  table apreslevésoleil...OK
Checking  table avantcouchésoleil...OK
Checking  table avantlevésoleil...OK
Backing up database...OK
Cache persistence:
OK
Creating archive...
OK
Send backup Samba...Delete backup too old : {"filename":"backup-DMJ_Jeedom_DEV-4.4.19-2024-11-06-03h37.tar.gz","size":"191274765","datetime":"2024-11-06 03:37:19"}Delete backup too old : {"filename":"backup-DMJ_Jeedom_DEV-4.4.19-2024-11-05-03h37.tar.gz","size":"191240863","datetime":"2024-11-05 03:37:28"}OK
Delete: /var/www/html/core/php/../../backup/backup-DMJ_Jeedom_DEV-4.5-2024-11-11-03h37.tar.gz
OK
Backup name: /var/www/html/core/php/../../backup/backup-DMJ_Jeedom_DEV-4.5-2024-11-13-03h37.tar.gz
Checking files rights...OK
Backup operation duration: 21s
C’est table ne sont pas par défaut dans le core, vu le nom je dirais que ca appartient a un plugin qui fait des actions sur levée couché de soleil. Je pense qu’il faut voir avec le dev du plugin en question.
Bonjour.
Ok, c’est noté. Mais pourquoi un comportement différent entre « Backup » et « cron_execution » ? N’y aurait t’il pas un souci avec la présence de caractères accentués dans le nom de ces 4 tables ?
Je sais pas pour le comportement mais c’est pas important.
Pour les table j’sais jamai eu l’idée de mettre des accent donc peut etre
Y a un moyen de savoir quel plugin à créer ces tables ?
Non aucun moyen
Depuis la configuration générale Jeedom, onglet OS/DB > Administration système, tu peux essayer cette commande:
grep -r "aprescouchésoleil" /var/www/html/plugins/*/plugin_info/*.sql
ou plus générique:
Ok, je ferme le post. J’ai fait un grep sur toute l’arborescence et je n’ai paS trouvé trace du CREATE de ces 4 tables, peut-être le reste d’un plugin qui s’est mal désinstallé.
