Jeedom 4.4-->iPad Air 2-->plugin jaillbreak?
C’est les dépendances du plugins…
Si tu relances les dépendances, qu’indique les logs : Jailbreak_packages ?
Voici les logs
+ touch /tmp/jeedom_install_in_progress_Jailbreak
+ echo 1
+ echo 2
+ echo 3
+ php /var/www/html/core/class/../php/jeecli.php plugin dependancy_end Jailbreak
+ echo 4
+ rm /tmp/jeedom_install_in_progress_Jailbreak
Tu es bien sur la beta du plugin ?
Jeedom 4.4.X ?
L’installation est gérée par le core depuis la grosse mise à jour 3.000 du plugin.
Je ne reproduis pas ton problème.
+ echo 1
+ echo 2
+ sudo chmod +x /var/www/html/core/class/../../resources/install_composer.sh
+ sudo /var/www/html/core/class/../../resources/install_composer.sh
Begin installation of composer
--2024-05-19 13:28:20--  https://getcomposer.org/installer
Resolving getcomposer.org (getcomposer.org)... 54.36.53.46, 2001:41d0:302:1100::8:104f
Connecting to getcomposer.org (getcomposer.org)|54.36.53.46|:443... connected.
HTTP request sent, awaiting response... 200 OK
Length: 58444 (57K) [application/octet-stream]
Saving to: 'composer-setup.php'
0K .......... .......... .......... .......... .......... 87% 5.22M 0s
50K .......                                               100%  267M=0.009s
2024-05-19 13:28:25 (5.94 MB/s) - 'composer-setup.php' saved [58444/58444]
All settings correct for using Composer
Downloading...
Composer (version 2.7.6) successfully installed to: /var/www/html/core/ajax/composer.phar
Use it: php composer.phar
End installation of composer
+ echo 3
+ cd /var/www/html/core/class/../../plugins/Jailbreak/
+ rm -rf vendor
+ sudo composer install --no-ansi --no-dev --no-interaction --no-plugins --no-progress --no-scripts --optimize-autoloader
Do not run Composer as root/super user! See https://getcomposer.org/root for details
Composer could not detect the root package (jeedom/jailbreak) version, defaulting to '1.0.0'. See https://getcomposer.org/root-version
Installing dependencies from lock file
Verifying lock file contents can be installed on current platform.
Package operations: 3 installs, 0 updates, 0 removals
- Installing paragonie/random_compat (v9.99.100): Extracting archive
- Installing paragonie/constant_time_encoding (v2.7.0): Extracting archive
- Installing phpseclib/phpseclib (3.0.37): Extracting archive
Generating optimized autoload files
1 package you are using is looking for funding.
Use the `composer fund` command to find out more!
+ sudo chown -R www-data:www-data 3rdparty LICENSE README.md composer.json composer.lock core data desktop plugin_info ressources vendor
+ echo 4
+ echo 5
ah non je suis resté sur la version 4.3 de jeedom pour l’instant, ça doit être ça qui merde alors…
Ah oui, c’est pour ça.
composer doit être pris en charge qu’en 4.4 par le core
Je suis passé en 4.4 puis revenu en arrière vers la 4.3 justement a cause de ce soucis des design non pris en charge par les iOS inférieur à 15.
C’est pour ça que je me décarcasse à jailbreak un iPad Air 2 et faire tourner ce plugin.
De toute façon j’ai pas le choix va falloir passer en 4.4
Bon je suis passé sur jeedom 4.4 et c’est ok pour les dépendances.
Par contre toujours le même message d’erreur quand j’essais d’installer les paquets depuis le plugin, du coup je les installe manuellement depuis cydia sur l’iPad et ils remontent bien vers le plugin.
Il me manque les paquets libactivator et les tiens com.fiobul.XXX
Il faut rajouter quel source dans cydia pour les avoir?
Mon repo : Flobul
