Merci pour la proposition.
Cette installation s’est correctement déroulée :
root@JeedomAtlas:~# sudo python3 -m pip install --upgrade setuptools
Collecting setuptools
Using cached https://files.pythonhosted.org/packages/a4/53/bfc6409447ca024558b8b19d055de94c813c3e32c0296c48a0873a161cf5/setuptools-63.2.0-py3-none-any.whl
Installing collected packages: setuptools
Successfully installed setuptools-63.2.0
root@JeedomAtlas:~#
Par contre cela ne change rien pour les dépendances, elle se bloque toujours à 40%.
Quand je consulte la page de configuration du plugin, elle est longue à s’afficher.
Voici les nouveau log dependancy :
* Installation des dépendances *
***** Commande: sudo apt-get update **********
Hit:1 http://deb.debian.org/debian buster InRelease
Hit:2 http://deb.debian.org/debian buster-updates InRelease
Hit:3 http://deb.debian.org/debian buster-backports InRelease
Hit:4 http://security.debian.org buster/updates InRelease
Hit:5 http://armbian.systemonachip.net/apt buster InRelease
Reading package lists...
***** Commande: sudo apt-get install -y python3 python3-pip **********
Building dependency tree...
Reading state information...
python3-pip is already the newest version (18.1-5).
python3 is already the newest version (3.7.3-1).
0 upgraded, 0 newly installed, 0 to remove and 133 not upgraded.
***** Commande: sudo pip3 install requests **********
Collecting pyicloud
Using cached https://files.pythonhosted.org/packages/62/63/952666bd50c4af95e1d658e26843b41f18ea8f287163a97b629f4956b19b/pyicloud-1.0.0-py3-none-any.whl
Collecting requests>=2.24.0 (from pyicloud)
Using cached https://files.pythonhosted.org/packages/ca/91/6d9b8ccacd0412c08820f72cebaa4f0c0441b5cda699c90f618b6f8a1b42/requests-2.28.1-py3-none-any.whl
Collecting keyrings.alt>=3.5.2 (from pyicloud)
Using cached https://files.pythonhosted.org/packages/a0/af/b7a63dc71f8b61d1a0128c285bce59fd8f80791dedca0bf7c1f1aa581171/keyrings.alt-4.1.1-py3-none-any.whl
Collecting tzlocal>=4.0 (from pyicloud)
Using cached https://files.pythonhosted.org/packages/31/b7/3bc2c1868f27677139b772e4fde95265b93151912fd90eb874827943bfcf/tzlocal-4.2-py3-none-any.whl
Collecting click>=7.1.2 (from pyicloud)
Using cached https://files.pythonhosted.org/packages/c2/f1/df59e28c642d583f7dacffb1e0965d0e00b218e0186d7858ac5233dce840/click-8.1.3-py3-none-any.whl
Collecting keyring>=21.4.0 (from pyicloud)
Using cached https://files.pythonhosted.org/packages/4c/84/a327a91da22f03df2aa6e0202c15647f2fad9d9230aa7a472a0bb1cc9dce/keyring-23.7.0-py3-none-any.whl
Collecting certifi>=2020.6.20 (from pyicloud)
Using cached https://files.pythonhosted.org/packages/e9/06/d3d367b7af6305b16f0d28ae2aaeb86154fa91f144f036c2d5002a5a202b/certifi-2022.6.15-py3-none-any.whl
Collecting idna<4,>=2.5 (from requests>=2.24.0->pyicloud)
Using cached https://files.pythonhosted.org/packages/04/a2/d918dcd22354d8958fe113e1a3630137e0fc8b44859ade3063982eacd2a4/idna-3.3-py3-none-any.whl
Collecting charset-normalizer<3,>=2 (from requests>=2.24.0->pyicloud)
Using cached https://files.pythonhosted.org/packages/94/69/64b11e8c2fb21f08634468caef885112e682b0ebe2908e74d3616eb1c113/charset_normalizer-2.1.0-py3-none-any.whl
Collecting urllib3<1.27,>=1.21.1 (from requests>=2.24.0->pyicloud)
Using cached https://files.pythonhosted.org/packages/68/47/93d3d28e97c7577f563903907912f4b3804054e4877a5ba6651f7182c53b/urllib3-1.26.10-py2.py3-none-any.whl
Collecting backports.zoneinfo; python_version < "3.9" (from tzlocal>=4.0->pyicloud)
Using cached https://files.pythonhosted.org/packages/ad/85/475e514c3140937cf435954f78dedea1861aeab7662d11de232bdaa90655/backports.zoneinfo-0.2.1.tar.gz
Installing build dependencies: started
Installing build dependencies: finished with status 'done'
Collecting pytz-deprecation-shim (from tzlocal>=4.0->pyicloud)
Using cached https://files.pythonhosted.org/packages/eb/73/3eaab547ca809754e67e06871cff0fc962bafd4b604e15f31896a0f94431/pytz_deprecation_shim-0.1.0.post0-py2.py3-none-any.whl
Collecting importlib-metadata; python_version < "3.8" (from click>=7.1.2->pyicloud)
Using cached https://files.pythonhosted.org/packages/d2/a2/8c239dc898138f208dd14b441b196e7b3032b94d3137d9d8453e186967fc/importlib_metadata-4.12.0-py3-none-any.whl
Collecting jeepney>=0.4.2; sys_platform == "linux" (from keyring>=21.4.0->pyicloud)
Using cached https://files.pythonhosted.org/packages/ae/72/2a1e2290f1ab1e06f71f3d0f1646c9e4634e70e1d37491535e19266e8dc9/jeepney-0.8.0-py3-none-any.whl
Collecting SecretStorage>=3.2; sys_platform == "linux" (from keyring>=21.4.0->pyicloud)
Using cached https://files.pythonhosted.org/packages/54/42/7cf083c31a9739b40ed683fad17460d1db97ecd23c344df25e41fa9e85e2/SecretStorage-3.3.2-py3-none-any.whl
Collecting tzdata; python_version >= "3.6" (from pytz-deprecation-shim->tzlocal>=4.0->pyicloud)
Using cached https://files.pythonhosted.org/packages/89/2d/49329ebec33b14dae61ecc8c85abe596341832fa36c4bcd3d99fddda018b/tzdata-2022.1-py2.py3-none-any.whl
Collecting zipp>=0.5 (from importlib-metadata; python_version < "3.8"->click>=7.1.2->pyicloud)
Using cached https://files.pythonhosted.org/packages/f0/36/639d6742bcc3ffdce8b85c31d79fcfae7bb04b95f0e5c4c6f8b206a038cc/zipp-3.8.1-py3-none-any.whl
Collecting typing-extensions>=3.6.4; python_version < "3.8" (from importlib-metadata; python_version < "3.8"->click>=7.1.2->pyicloud)
Using cached https://files.pythonhosted.org/packages/ed/d6/2afc375a8d55b8be879d6b4986d4f69f01115e795e36827fd3a40166028b/typing_extensions-4.3.0-py3-none-any.whl
Collecting cryptography>=2.0 (from SecretStorage>=3.2; sys_platform == "linux"->keyring>=21.4.0->pyicloud)
Using cached https://files.pythonhosted.org/packages/89/d9/5fcd312d5cce0b4d7ee8b551a0ea99e4ea9db0fdbf6dd455a19042e3370b/cryptography-37.0.4.tar.gz
Installing build dependencies: finished with status 'error'
Complete output from command /usr/bin/python3 -m pip install --ignore-installed --no-user --prefix /tmp/pip-build-env-jc0qvxtd --no-warn-script-location --no-binary :none: --only-binary :none: -i https://pypi.org/simple -- setuptools>=40.6.0,!=60.9.0 wheel "cffi>=1.12; platform_python_implementation != 'PyPy'" setuptools-rust>=0.11.4:
Collecting setuptools!=60.9.0,>=40.6.0
Collecting wheel
Using cached https://files.pythonhosted.org/packages/27/d6/003e593296a85fd6ed616ed962795b2f87709c3eee2bca4f6d0fe55c6d00/wheel-0.37.1-py2.py3-none-any.whl
Collecting cffi>=1.12
Using cached https://files.pythonhosted.org/packages/2b/a8/050ab4f0c3d4c1b8aaa805f70e26e84d0e27004907c5b8ecc1d31815f92a/cffi-1.15.1.tar.gz
Collecting setuptools-rust>=0.11.4
Using cached https://files.pythonhosted.org/packages/c4/d3/b101f6af5d70988a89fa2b5d7f0d9bc92974014e3eb61ee3802966dc07a6/setuptools_rust-1.4.1-py3-none-any.whl
Collecting pycparser (from cffi>=1.12)
Using cached https://files.pythonhosted.org/packages/62/d5/5f610ebe421e85889f2e55e33b7f9a6795bd982198517d912eb1c76e1a53/pycparser-2.21-py2.py3-none-any.whl
Collecting semantic-version<3,>=2.8.2 (from setuptools-rust>=0.11.4)
Using cached https://files.pythonhosted.org/packages/6a/23/8146aad7d88f4fcb3a6218f41a60f6c2d4e3a72de72da1825dc7c8f7877c/semantic_version-2.10.0-py2.py3-none-any.whl
Collecting typing-extensions>=3.7.4.3 (from setuptools-rust>=0.11.4)
Building wheels for collected packages: cffi
Running setup.py bdist_wheel for cffi: started
Running setup.py bdist_wheel for cffi: finished with status 'error'
Complete output from command /usr/bin/python3 -u -c "import setuptools, tokenize;__file__='/tmp/pip-install-9bidotbz/cffi/setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('
');f.close();exec(compile(code, __file__, 'exec'))" bdist_wheel -d /tmp/pip-wheel-lktt_tcj --python-tag cp37:
Package libffi was not found in the pkg-config search path.
Perhaps you should add the directory containing `libffi.pc'
to the PKG_CONFIG_PATH environment variable
No package 'libffi' found
/usr/local/lib/python3.7/dist-packages/setuptools/config/setupcfg.py:463: SetuptoolsDeprecationWarning: The license_file parameter is deprecated, use license_files instead.
warnings.warn(msg, warning_class)
usage: -c [global_opts] cmd1 [cmd1_opts] [cmd2 [cmd2_opts] ...]
or: -c --help [cmd1 cmd2 ...]
or: -c --help-commands
or: -c cmd --help
error: invalid command 'bdist_wheel'
Failed building wheel for cffi
Running setup.py clean for cffi
Failed to build cffi
Installing collected packages: setuptools, wheel, pycparser, cffi, semantic-version, typing-extensions, setuptools-rust
Running setup.py install for cffi: started
Running setup.py install for cffi: finished with status 'error'
');f.close();exec(compile(code, __file__, 'exec'))" install --record /tmp/pip-record-4gwcecct/install-record.txt --single-version-externally-managed --prefix /tmp/pip-build-env-jc0qvxtd --compile:
running install
/usr/local/lib/python3.7/dist-packages/setuptools/command/install.py:37: SetuptoolsDeprecationWarning: setup.py install is deprecated. Use build and pip and other standards-based tools.
setuptools.SetuptoolsDeprecationWarning,
running build
running build_py
creating build
creating build/lib.linux-aarch64-cpython-37
creating build/lib.linux-aarch64-cpython-37/cffi
copying cffi/verifier.py -> build/lib.linux-aarch64-cpython-37/cffi
copying cffi/vengine_gen.py -> build/lib.linux-aarch64-cpython-37/cffi
copying cffi/vengine_cpy.py -> build/lib.linux-aarch64-cpython-37/cffi
copying cffi/setuptools_ext.py -> build/lib.linux-aarch64-cpython-37/cffi
copying cffi/recompiler.py -> build/lib.linux-aarch64-cpython-37/cffi
copying cffi/pkgconfig.py -> build/lib.linux-aarch64-cpython-37/cffi
copying cffi/model.py -> build/lib.linux-aarch64-cpython-37/cffi
copying cffi/lock.py -> build/lib.linux-aarch64-cpython-37/cffi
copying cffi/ffiplatform.py -> build/lib.linux-aarch64-cpython-37/cffi
copying cffi/error.py -> build/lib.linux-aarch64-cpython-37/cffi
copying cffi/cparser.py -> build/lib.linux-aarch64-cpython-37/cffi
copying cffi/commontypes.py -> build/lib.linux-aarch64-cpython-37/cffi
copying cffi/cffi_opcode.py -> build/lib.linux-aarch64-cpython-37/cffi
copying cffi/backend_ctypes.py -> build/lib.linux-aarch64-cpython-37/cffi
copying cffi/api.py -> build/lib.linux-aarch64-cpython-37/cffi
copying cffi/__init__.py -> build/lib.linux-aarch64-cpython-37/cffi
copying cffi/_cffi_include.h -> build/lib.linux-aarch64-cpython-37/cffi
copying cffi/parse_c_type.h -> build/lib.linux-aarch64-cpython-37/cffi
copying cffi/_embedding.h -> build/lib.linux-aarch64-cpython-37/cffi
copying cffi/_cffi_errors.h -> build/lib.linux-aarch64-cpython-37/cffi
running build_ext
building '_cffi_backend' extension
creating build/temp.linux-aarch64-cpython-37
creating build/temp.linux-aarch64-cpython-37/c
aarch64-linux-gnu-gcc -pthread -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O2 -Wall -g -fstack-protector-strong -Wformat -Werror=format-security -fPIC -DFFI_BUILDING=1 -DUSE__THREAD -DHAVE_SYNC_SYNCHRONIZE -I/usr/include/ffi -I/usr/include/libffi -I/usr/include/python3.7m -c c/_cffi_backend.c -o build/temp.linux-aarch64-cpython-37/c/_cffi_backend.o
c/_cffi_backend.c:2:10: fatal error: Python.h: No such file or directory
#include <Python.h>
compilation terminated.
error: command '/usr/bin/aarch64-linux-gnu-gcc' failed with exit code 1
Command "/usr/bin/python3 -u -c "import setuptools, tokenize;__file__='/tmp/pip-install-9bidotbz/cffi/setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('
');f.close();exec(compile(code, __file__, 'exec'))" install --record /tmp/pip-record-4gwcecct/install-record.txt --single-version-externally-managed --prefix /tmp/pip-build-env-jc0qvxtd --compile" failed with error code 1 in /tmp/pip-install-9bidotbz/cffi/
Command "/usr/bin/python3 -m pip install --ignore-installed --no-user --prefix /tmp/pip-build-env-jc0qvxtd --no-warn-script-location --no-binary :none: --only-binary :none: -i https://pypi.org/simple -- setuptools>=40.6.0,!=60.9.0 wheel "cffi>=1.12; platform_python_implementation != 'PyPy'" setuptools-rust>=0.11.4" failed with error code 1 in None
* Installation terminée *
Merci encore
