alors, l’allumage de la led d’ambiance marche peu importe le canal, mais les commandes d’allumage de la lumière associée au canal ne marche plus.
Log cmd (test allumage depuis plugin lumière ambiance et lumière de chaque canal, et a la fin allumage depuis l’appli ewelink des lumières de chaque canal)
0436|[2023-11-25 13:01:39]DEBUG : Cmd : {"lightSwitch":"on"} - full Cmd : {"sequence":"4","deviceid":"1001f1089d","selfApikey":"00000000-0000-0000-0000-000000000000","iv":"OTA0ODgxODA0OTIyNzgwMw==","encrypt":true,"data":"ZgipsGs7NFjkC+4ECk0JfLUEdeGsNN0f8Edn/UT6QbU="} - Rec:{"sequence":"4","seq":160,"error":0,"encrypt":true}
0437|[2023-11-25 13:01:39]DEBUG : - Receive after decode :{"switches":[{"switch":"off","outlet":0},{"switch":"off","outlet":1}],"triggerType":2,"lightSwitch":"on","fwVersion":"1.2.0","rssi":-64,"ssid":"MWHOME","bssid":"B6:39:56:8D:3A:F6"}
0438|[2023-11-25 13:01:39]DEBUG : - Receive after decode :{"switches":[{"switch":"off","outlet":0},{"switch":"off","outlet":1}],"triggerType":2,"lightSwitch":"on","fwVersion":"1.2.0","rssi":-64,"ssid":"MWHOME","bssid":"B6:39:56:8D:3A:F6"}
0439|[2023-11-25 13:01:40]DEBUG : - Receive after decode :{"switches":[{"switch":"off","outlet":0},{"switch":"off","outlet":1}],"triggerType":2,"lightSwitch":"on","fwVersion":"1.2.0","rssi":-64,"ssid":"MWHOME","bssid":"B6:39:56:8D:3A:F6"}
0440|[2023-11-25 13:01:40]DEBUG : - Receive after decode :{"switches":[{"switch":"off","outlet":0},{"switch":"off","outlet":1}],"triggerType":2,"lightSwitch":"on","fwVersion":"1.2.0","rssi":-64,"ssid":"MWHOME","bssid":"B6:39:56:8D:3A:F6"}
0441|[2023-11-25 13:01:41]DEBUG : - Receive after decode :{"switches":[{"switch":"off","outlet":0},{"switch":"off","outlet":1}],"triggerType":2,"lightSwitch":"on","fwVersion":"1.2.0","rssi":-64,"ssid":"MWHOME","bssid":"B6:39:56:8D:3A:F6"}
0442|[2023-11-25 13:01:41]DEBUG : - Receive after decode :{"switches":[{"switch":"off","outlet":0},{"switch":"off","outlet":1}],"triggerType":2,"lightSwitch":"on","fwVersion":"1.2.0","rssi":-64,"ssid":"MWHOME","bssid":"B6:39:56:8D:3A:F6"}
0443|[2023-11-25 13:01:52]DEBUG : Cmd : {"lightSwitch":"off"} - full Cmd : {"sequence":"5","deviceid":"1001f1089d","selfApikey":"00000000-0000-0000-0000-000000000000","iv":"OTA0ODgxODA0OTIyNzgwMw==","encrypt":true,"data":"ZgipsGs7NFjkC+4ECk0JfKOeAJjsfDbndjho+k/Ow6g="} - Rec:{"sequence":"5","seq":161,"error":0,"encrypt":true}
0444|[2023-11-25 13:01:52]DEBUG : - Receive after decode :{"switches":[{"switch":"off","outlet":0},{"switch":"off","outlet":1}],"triggerType":2,"lightSwitch":"off","fwVersion":"1.2.0","rssi":-64,"ssid":"MWHOME","bssid":"B6:39:56:8D:3A:F6"}
0445|[2023-11-25 13:01:52]DEBUG : - Receive after decode :{"switches":[{"switch":"off","outlet":0},{"switch":"off","outlet":1}],"triggerType":2,"lightSwitch":"off","fwVersion":"1.2.0","rssi":-64,"ssid":"MWHOME","bssid":"B6:39:56:8D:3A:F6"}
0446|[2023-11-25 13:01:53]DEBUG : - Receive after decode :{"switches":[{"switch":"off","outlet":0},{"switch":"off","outlet":1}],"triggerType":2,"lightSwitch":"off","fwVersion":"1.2.0","rssi":-64,"ssid":"MWHOME","bssid":"B6:39:56:8D:3A:F6"}
0447|[2023-11-25 13:01:53]DEBUG : - Receive after decode :{"switches":[{"switch":"off","outlet":0},{"switch":"off","outlet":1}],"triggerType":2,"lightSwitch":"off","fwVersion":"1.2.0","rssi":-64,"ssid":"MWHOME","bssid":"B6:39:56:8D:3A:F6"}
0448|[2023-11-25 13:01:54]DEBUG : - Receive after decode :{"switches":[{"switch":"off","outlet":0},{"switch":"off","outlet":1}],"triggerType":2,"lightSwitch":"off","fwVersion":"1.2.0","rssi":-64,"ssid":"MWHOME","bssid":"B6:39:56:8D:3A:F6"}
0449|[2023-11-25 13:01:54]DEBUG : - Receive after decode :{"switches":[{"switch":"off","outlet":0},{"switch":"off","outlet":1}],"triggerType":2,"lightSwitch":"off","fwVersion":"1.2.0","rssi":-64,"ssid":"MWHOME","bssid":"B6:39:56:8D:3A:F6"}
0450|[2023-11-25 13:03:00]DEBUG : Cmd : {"switch":"on"} - full Cmd : {"sequence":"6","deviceid":"1001f1089d","selfApikey":"00000000-0000-0000-0000-000000000000","iv":"OTA0ODgxODA0OTIyNzgwMw==","encrypt":true,"data":"U1X8QzUqzdK9B03MSoSQ6Q=="} - Rec:{"sequence":"6","seq":162,"error":400,"encrypt":true}
0451|[2023-11-25 13:03:00]DEBUG : - Receive after decode :{"switches":[{"switch":"off","outlet":0},{"switch":"off","outlet":1}],"triggerType":2,"fwVersion":"1.2.0","rssi":-62,"ssid":"MWHOME","bssid":"B6:39:56:8D:3A:F6"}
0452|[2023-11-25 13:03:00]DEBUG : - Receive after decode :{"switches":[{"switch":"off","outlet":0},{"switch":"off","outlet":1}],"triggerType":2,"fwVersion":"1.2.0","rssi":-62,"ssid":"MWHOME","bssid":"B6:39:56:8D:3A:F6"}
0453|[2023-11-25 13:03:01]DEBUG : - Receive after decode :{"switches":[{"switch":"off","outlet":0},{"switch":"off","outlet":1}],"triggerType":2,"fwVersion":"1.2.0","rssi":-62,"ssid":"MWHOME","bssid":"B6:39:56:8D:3A:F6"}
0454|[2023-11-25 13:03:01]DEBUG : - Receive after decode :{"switches":[{"switch":"off","outlet":0},{"switch":"off","outlet":1}],"triggerType":2,"fwVersion":"1.2.0","rssi":-62,"ssid":"MWHOME","bssid":"B6:39:56:8D:3A:F6"}
0455|[2023-11-25 13:03:02]DEBUG : - Receive after decode :{"switches":[{"switch":"off","outlet":0},{"switch":"off","outlet":1}],"triggerType":2,"fwVersion":"1.2.0","rssi":-62,"ssid":"MWHOME","bssid":"B6:39:56:8D:3A:F6"}
0456|[2023-11-25 13:03:02]DEBUG : - Receive after decode :{"switches":[{"switch":"off","outlet":0},{"switch":"off","outlet":1}],"triggerType":2,"fwVersion":"1.2.0","rssi":-62,"ssid":"MWHOME","bssid":"B6:39:56:8D:3A:F6"}
0457|[2023-11-25 13:03:11]DEBUG : Cmd : {"switch":"on"} - full Cmd : {"sequence":"2","deviceid":"1001f1089d","selfApikey":"00000000-0000-0000-0000-000000000000","iv":"OTA0ODgxODA0OTIyNzgwMw==","encrypt":true,"data":"U1X8QzUqzdK9B03MSoSQ6Q=="} - Rec:{"sequence":"2","seq":163,"error":400,"encrypt":true}
0458|[2023-11-25 13:03:11]DEBUG : - Receive after decode :{"switches":[{"switch":"off","outlet":0},{"switch":"off","outlet":1}],"triggerType":2,"fwVersion":"1.2.0","rssi":-61,"ssid":"MWHOME","bssid":"B6:39:56:8D:3A:F6"}
0459|[2023-11-25 13:03:11]DEBUG : - Receive after decode :{"switches":[{"switch":"off","outlet":0},{"switch":"off","outlet":1}],"triggerType":2,"fwVersion":"1.2.0","rssi":-61,"ssid":"MWHOME","bssid":"B6:39:56:8D:3A:F6"}
0460|[2023-11-25 13:03:12]DEBUG : - Receive after decode :{"switches":[{"switch":"off","outlet":0},{"switch":"off","outlet":1}],"triggerType":2,"fwVersion":"1.2.0","rssi":-61,"ssid":"MWHOME","bssid":"B6:39:56:8D:3A:F6"}
0461|[2023-11-25 13:03:12]DEBUG : - Receive after decode :{"switches":[{"switch":"off","outlet":0},{"switch":"off","outlet":1}],"triggerType":2,"fwVersion":"1.2.0","rssi":-61,"ssid":"MWHOME","bssid":"B6:39:56:8D:3A:F6"}
0462|[2023-11-25 13:03:13]DEBUG : - Receive after decode :{"switches":[{"switch":"off","outlet":0},{"switch":"off","outlet":1}],"triggerType":2,"fwVersion":"1.2.0","rssi":-61,"ssid":"MWHOME","bssid":"B6:39:56:8D:3A:F6"}
0463|[2023-11-25 13:03:13]DEBUG : - Receive after decode :{"switches":[{"switch":"off","outlet":0},{"switch":"off","outlet":1}],"triggerType":2,"fwVersion":"1.2.0","rssi":-61,"ssid":"MWHOME","bssid":"B6:39:56:8D:3A:F6"}
0464|[2023-11-25 13:03:31]DEBUG : Cmd : {"lightSwitch":"on"} - full Cmd : {"sequence":"7","deviceid":"1001f1089d","selfApikey":"00000000-0000-0000-0000-000000000000","iv":"OTA0ODgxODA0OTIyNzgwMw==","encrypt":true,"data":"ZgipsGs7NFjkC+4ECk0JfLUEdeGsNN0f8Edn/UT6QbU="} - Rec:{"sequence":"7","seq":164,"error":0,"encrypt":true}
0465|[2023-11-25 13:03:31]DEBUG : - Receive after decode :{"switches":[{"switch":"off","outlet":0},{"switch":"off","outlet":1}],"triggerType":2,"lightSwitch":"on","fwVersion":"1.2.0","rssi":-60,"ssid":"MWHOME","bssid":"B6:39:56:8D:3A:F6"}
0466|[2023-11-25 13:03:31]DEBUG : - Receive after decode :{"switches":[{"switch":"off","outlet":0},{"switch":"off","outlet":1}],"triggerType":2,"lightSwitch":"on","fwVersion":"1.2.0","rssi":-60,"ssid":"MWHOME","bssid":"B6:39:56:8D:3A:F6"}
0467|[2023-11-25 13:03:32]DEBUG : - Receive after decode :{"switches":[{"switch":"off","outlet":0},{"switch":"off","outlet":1}],"triggerType":2,"lightSwitch":"on","fwVersion":"1.2.0","rssi":-60,"ssid":"MWHOME","bssid":"B6:39:56:8D:3A:F6"}
0468|[2023-11-25 13:03:32]DEBUG : - Receive after decode :{"switches":[{"switch":"off","outlet":0},{"switch":"off","outlet":1}],"triggerType":2,"lightSwitch":"on","fwVersion":"1.2.0","rssi":-60,"ssid":"MWHOME","bssid":"B6:39:56:8D:3A:F6"}
0469|[2023-11-25 13:03:33]DEBUG : - Receive after decode :{"switches":[{"switch":"off","outlet":0},{"switch":"off","outlet":1}],"triggerType":2,"lightSwitch":"on","fwVersion":"1.2.0","rssi":-60,"ssid":"MWHOME","bssid":"B6:39:56:8D:3A:F6"}
0470|[2023-11-25 13:03:33]DEBUG : - Receive after decode :{"switches":[{"switch":"off","outlet":0},{"switch":"off","outlet":1}],"triggerType":2,"lightSwitch":"on","fwVersion":"1.2.0","rssi":-60,"ssid":"MWHOME","bssid":"B6:39:56:8D:3A:F6"}
0471|[2023-11-25 13:03:33]DEBUG : Cmd : {"lightSwitch":"off"} - full Cmd : {"sequence":"8","deviceid":"1001f1089d","selfApikey":"00000000-0000-0000-0000-000000000000","iv":"OTA0ODgxODA0OTIyNzgwMw==","encrypt":true,"data":"ZgipsGs7NFjkC+4ECk0JfKOeAJjsfDbndjho+k/Ow6g="} - Rec:{"sequence":"8","seq":165,"error":0,"encrypt":true}
0472|[2023-11-25 13:03:33]DEBUG : - Receive after decode :{"switches":[{"switch":"off","outlet":0},{"switch":"off","outlet":1}],"triggerType":2,"lightSwitch":"off","fwVersion":"1.2.0","rssi":-62,"ssid":"MWHOME","bssid":"B6:39:56:8D:3A:F6"}
0473|[2023-11-25 13:03:33]DEBUG : - Receive after decode :{"switches":[{"switch":"off","outlet":0},{"switch":"off","outlet":1}],"triggerType":2,"lightSwitch":"off","fwVersion":"1.2.0","rssi":-62,"ssid":"MWHOME","bssid":"B6:39:56:8D:3A:F6"}
0474|[2023-11-25 13:03:34]DEBUG : - Receive after decode :{"switches":[{"switch":"off","outlet":0},{"switch":"off","outlet":1}],"triggerType":2,"lightSwitch":"off","fwVersion":"1.2.0","rssi":-62,"ssid":"MWHOME","bssid":"B6:39:56:8D:3A:F6"}
0475|[2023-11-25 13:03:34]DEBUG : - Receive after decode :{"switches":[{"switch":"off","outlet":0},{"switch":"off","outlet":1}],"triggerType":2,"lightSwitch":"off","fwVersion":"1.2.0","rssi":-62,"ssid":"MWHOME","bssid":"B6:39:56:8D:3A:F6"}
0476|[2023-11-25 13:03:35]DEBUG : - Receive after decode :{"switches":[{"switch":"off","outlet":0},{"switch":"off","outlet":1}],"triggerType":2,"lightSwitch":"off","fwVersion":"1.2.0","rssi":-62,"ssid":"MWHOME","bssid":"B6:39:56:8D:3A:F6"}
0477|[2023-11-25 13:03:35]DEBUG : - Receive after decode :{"switches":[{"switch":"off","outlet":0},{"switch":"off","outlet":1}],"triggerType":2,"lightSwitch":"off","fwVersion":"1.2.0","rssi":-62,"ssid":"MWHOME","bssid":"B6:39:56:8D:3A:F6"}
0478|[2023-11-25 13:03:45]DEBUG : Cmd : {"switch":"on"} - full Cmd : {"sequence":"3","deviceid":"1001f1089d","selfApikey":"00000000-0000-0000-0000-000000000000","iv":"OTA0ODgxODA0OTIyNzgwMw==","encrypt":true,"data":"U1X8QzUqzdK9B03MSoSQ6Q=="} - Rec:{"sequence":"3","seq":166,"error":400,"encrypt":true}
0479|[2023-11-25 13:03:45]DEBUG : - Receive after decode :{"switches":[{"switch":"off","outlet":0},{"switch":"off","outlet":1}],"triggerType":2,"fwVersion":"1.2.0","rssi":-62,"ssid":"MWHOME","bssid":"B6:39:56:8D:3A:F6"}
0480|[2023-11-25 13:03:45]DEBUG : - Receive after decode :{"switches":[{"switch":"off","outlet":0},{"switch":"off","outlet":1}],"triggerType":2,"fwVersion":"1.2.0","rssi":-62,"ssid":"MWHOME","bssid":"B6:39:56:8D:3A:F6"}
0481|[2023-11-25 13:03:46]DEBUG : - Receive after decode :{"switches":[{"switch":"off","outlet":0},{"switch":"off","outlet":1}],"triggerType":2,"fwVersion":"1.2.0","rssi":-62,"ssid":"MWHOME","bssid":"B6:39:56:8D:3A:F6"}
0482|[2023-11-25 13:03:46]DEBUG : - Receive after decode :{"switches":[{"switch":"off","outlet":0},{"switch":"off","outlet":1}],"triggerType":2,"fwVersion":"1.2.0","rssi":-62,"ssid":"MWHOME","bssid":"B6:39:56:8D:3A:F6"}
0483|[2023-11-25 13:03:47]DEBUG : - Receive after decode :{"switches":[{"switch":"off","outlet":0},{"switch":"off","outlet":1}],"triggerType":2,"fwVersion":"1.2.0","rssi":-62,"ssid":"MWHOME","bssid":"B6:39:56:8D:3A:F6"}
0484|[2023-11-25 13:03:47]DEBUG : - Receive after decode :{"switches":[{"switch":"off","outlet":0},{"switch":"off","outlet":1}],"triggerType":2,"fwVersion":"1.2.0","rssi":-62,"ssid":"MWHOME","bssid":"B6:39:56:8D:3A:F6"}
0485|[2023-11-25 13:04:02]DEBUG : - Receive after decode :{"switches":[{"switch":"off","outlet":0},{"switch":"off","outlet":1}],"triggerType":2,"fwVersion":"1.2.0","rssi":-62,"ssid":"MWHOME","bssid":"B6:39:56:8D:3A:F6"}
0486|[2023-11-25 13:04:02]DEBUG : - Receive after decode :{"switches":[{"switch":"off","outlet":0},{"switch":"off","outlet":1}],"triggerType":2,"fwVersion":"1.2.0","rssi":-62,"ssid":"MWHOME","bssid":"B6:39:56:8D:3A:F6"}
0487|[2023-11-25 13:04:02]DEBUG : - Receive after decode :{"switches":[{"switch":"off","outlet":0},{"switch":"off","outlet":1}],"triggerType":2,"fwVersion":"1.2.0","rssi":-62,"ssid":"MWHOME","bssid":"B6:39:56:8D:3A:F6"}
0488|[2023-11-25 13:04:02]DEBUG : - Receive after decode :{"switches":[{"switch":"off","outlet":0},{"switch":"off","outlet":1}],"triggerType":2,"fwVersion":"1.2.0","rssi":-62,"ssid":"MWHOME","bssid":"B6:39:56:8D:3A:F6"}
0489|[2023-11-25 13:04:02]DEBUG : - Receive after decode :{"switches":[{"switch":"off","outlet":0},{"switch":"off","outlet":1}],"triggerType":2,"fwVersion":"1.2.0","rssi":-62,"ssid":"MWHOME","bssid":"B6:39:56:8D:3A:F6"}
0490|[2023-11-25 13:04:02]DEBUG : - Receive after decode :{"switches":[{"switch":"off","outlet":0},{"switch":"off","outlet":1}],"triggerType":2,"fwVersion":"1.2.0","rssi":-62,"ssid":"MWHOME","bssid":"B6:39:56:8D:3A:F6"}
0491|[2023-11-25 13:04:06]DEBUG : Cmd : {"switch":"on"} - full Cmd : {"sequence":"4","deviceid":"1001f1089d","selfApikey":"00000000-0000-0000-0000-000000000000","iv":"OTA0ODgxODA0OTIyNzgwMw==","encrypt":true,"data":"U1X8QzUqzdK9B03MSoSQ6Q=="} - Rec:{"sequence":"4","seq":167,"error":400,"encrypt":true}
0492|[2023-11-25 13:04:06]DEBUG : - Receive after decode :{"switches":[{"switch":"off","outlet":0},{"switch":"off","outlet":1}],"triggerType":2,"fwVersion":"1.2.0","rssi":-62,"ssid":"MWHOME","bssid":"B6:39:56:8D:3A:F6"}
0493|[2023-11-25 13:04:06]DEBUG : - Receive after decode :{"switches":[{"switch":"off","outlet":0},{"switch":"off","outlet":1}],"triggerType":2,"fwVersion":"1.2.0","rssi":-62,"ssid":"MWHOME","bssid":"B6:39:56:8D:3A:F6"}
0494|[2023-11-25 13:04:07]DEBUG : - Receive after decode :{"switches":[{"switch":"off","outlet":0},{"switch":"off","outlet":1}],"triggerType":2,"fwVersion":"1.2.0","rssi":-62,"ssid":"MWHOME","bssid":"B6:39:56:8D:3A:F6"}
0495|[2023-11-25 13:04:07]DEBUG : - Receive after decode :{"switches":[{"switch":"off","outlet":0},{"switch":"off","outlet":1}],"triggerType":2,"fwVersion":"1.2.0","rssi":-62,"ssid":"MWHOME","bssid":"B6:39:56:8D:3A:F6"}
0496|[2023-11-25 13:04:08]DEBUG : - Receive after decode :{"switches":[{"switch":"off","outlet":0},{"switch":"off","outlet":1}],"triggerType":2,"fwVersion":"1.2.0","rssi":-62,"ssid":"MWHOME","bssid":"B6:39:56:8D:3A:F6"}
0497|[2023-11-25 13:04:08]DEBUG : - Receive after decode :{"switches":[{"switch":"off","outlet":0},{"switch":"off","outlet":1}],"triggerType":2,"fwVersion":"1.2.0","rssi":-62,"ssid":"MWHOME","bssid":"B6:39:56:8D:3A:F6"}
0498|[2023-11-25 13:04:14]DEBUG : Cmd : {"switch":"off"} - full Cmd : {"sequence":"5","deviceid":"1001f1089d","selfApikey":"00000000-0000-0000-0000-000000000000","iv":"OTA0ODgxODA0OTIyNzgwMw==","encrypt":true,"data":"ujThh8dMj59Vox44EPHACx8TLbvWDwM93vwNuQD3OF8="} - Rec:{"sequence":"5","seq":168,"error":400,"encrypt":true}
0499|[2023-11-25 13:04:14]DEBUG : - Receive after decode :{"switches":[{"switch":"off","outlet":0},{"switch":"off","outlet":1}],"triggerType":2,"fwVersion":"1.2.0","rssi":-60,"ssid":"MWHOME","bssid":"B6:39:56:8D:3A:F6"}
0500|[2023-11-25 13:04:14]DEBUG : - Receive after decode :{"switches":[{"switch":"off","outlet":0},{"switch":"off","outlet":1}],"triggerType":2,"fwVersion":"1.2.0","rssi":-60,"ssid":"MWHOME","bssid":"B6:39:56:8D:3A:F6"}
0501|[2023-11-25 13:04:15]DEBUG : - Receive after decode :{"switches":[{"switch":"off","outlet":0},{"switch":"off","outlet":1}],"triggerType":2,"fwVersion":"1.2.0","rssi":-60,"ssid":"MWHOME","bssid":"B6:39:56:8D:3A:F6"}
0502|[2023-11-25 13:04:15]DEBUG : - Receive after decode :{"switches":[{"switch":"off","outlet":0},{"switch":"off","outlet":1}],"triggerType":2,"fwVersion":"1.2.0","rssi":-60,"ssid":"MWHOME","bssid":"B6:39:56:8D:3A:F6"}
0503|[2023-11-25 13:04:16]DEBUG : - Receive after decode :{"switches":[{"switch":"off","outlet":0},{"switch":"off","outlet":1}],"triggerType":2,"fwVersion":"1.2.0","rssi":-60,"ssid":"MWHOME","bssid":"B6:39:56:8D:3A:F6"}
0504|[2023-11-25 13:04:16]DEBUG : - Receive after decode :{"switches":[{"switch":"off","outlet":0},{"switch":"off","outlet":1}],"triggerType":2,"fwVersion":"1.2.0","rssi":-60,"ssid":"MWHOME","bssid":"B6:39:56:8D:3A:F6"}
0505|[2023-11-25 13:05:01]DEBUG : Cmd : {"switch":"on"} - full Cmd : {"sequence":"6","deviceid":"1001f1089d","selfApikey":"00000000-0000-0000-0000-000000000000","iv":"OTA0ODgxODA0OTIyNzgwMw==","encrypt":true,"data":"U1X8QzUqzdK9B03MSoSQ6Q=="} - Rec:{"sequence":"6","seq":169,"error":400,"encrypt":true}
0506|[2023-11-25 13:05:01]DEBUG : - Receive after decode :{"switches":[{"switch":"off","outlet":0},{"switch":"off","outlet":1}],"triggerType":2,"fwVersion":"1.2.0","rssi":-62,"ssid":"MWHOME","bssid":"B6:39:56:8D:3A:F6"}
0507|[2023-11-25 13:05:01]DEBUG : - Receive after decode :{"switches":[{"switch":"off","outlet":0},{"switch":"off","outlet":1}],"triggerType":2,"fwVersion":"1.2.0","rssi":-62,"ssid":"MWHOME","bssid":"B6:39:56:8D:3A:F6"}
0508|[2023-11-25 13:05:02]DEBUG : - Receive after decode :{"switches":[{"switch":"off","outlet":0},{"switch":"off","outlet":1}],"triggerType":2,"fwVersion":"1.2.0","rssi":-62,"ssid":"MWHOME","bssid":"B6:39:56:8D:3A:F6"}
0509|[2023-11-25 13:05:02]DEBUG : - Receive after decode :{"switches":[{"switch":"off","outlet":0},{"switch":"off","outlet":1}],"triggerType":2,"fwVersion":"1.2.0","rssi":-62,"ssid":"MWHOME","bssid":"B6:39:56:8D:3A:F6"}
0510|[2023-11-25 13:05:03]DEBUG : - Receive after decode :{"switches":[{"switch":"off","outlet":0},{"switch":"off","outlet":1}],"triggerType":2,"fwVersion":"1.2.0","rssi":-62,"ssid":"MWHOME","bssid":"B6:39:56:8D:3A:F6"}
0511|[2023-11-25 13:05:03]DEBUG : - Receive after decode :{"switches":[{"switch":"off","outlet":0},{"switch":"off","outlet":1}],"triggerType":2,"fwVersion":"1.2.0","rssi":-62,"ssid":"MWHOME","bssid":"B6:39:56:8D:3A:F6"}
0512|[2023-11-25 13:05:03]DEBUG : Cmd : {"switch":"on"} - full Cmd : {"sequence":"7","deviceid":"1001f1089d","selfApikey":"00000000-0000-0000-0000-000000000000","iv":"OTA0ODgxODA0OTIyNzgwMw==","encrypt":true,"data":"U1X8QzUqzdK9B03MSoSQ6Q=="} - Rec:{"sequence":"7","seq":170,"error":400,"encrypt":true}
0513|[2023-11-25 13:05:03]DEBUG : - Receive after decode :{"switches":[{"switch":"off","outlet":0},{"switch":"off","outlet":1}],"triggerType":2,"fwVersion":"1.2.0","rssi":-61,"ssid":"MWHOME","bssid":"B6:39:56:8D:3A:F6"}
0514|[2023-11-25 13:05:03]DEBUG : - Receive after decode :{"switches":[{"switch":"off","outlet":0},{"switch":"off","outlet":1}],"triggerType":2,"fwVersion":"1.2.0","rssi":-61,"ssid":"MWHOME","bssid":"B6:39:56:8D:3A:F6"}
0515|[2023-11-25 13:05:04]DEBUG : - Receive after decode :{"switches":[{"switch":"off","outlet":0},{"switch":"off","outlet":1}],"triggerType":2,"fwVersion":"1.2.0","rssi":-61,"ssid":"MWHOME","bssid":"B6:39:56:8D:3A:F6"}
0516|[2023-11-25 13:05:04]DEBUG : - Receive after decode :{"switches":[{"switch":"off","outlet":0},{"switch":"off","outlet":1}],"triggerType":2,"fwVersion":"1.2.0","rssi":-61,"ssid":"MWHOME","bssid":"B6:39:56:8D:3A:F6"}
0517|[2023-11-25 13:05:06]DEBUG : - Receive after decode :{"switches":[{"switch":"off","outlet":0},{"switch":"off","outlet":1}],"triggerType":2,"fwVersion":"1.2.0","rssi":-61,"ssid":"MWHOME","bssid":"B6:39:56:8D:3A:F6"}
0518|[2023-11-25 13:05:06]DEBUG : - Receive after decode :{"switches":[{"switch":"off","outlet":0},{"switch":"off","outlet":1}],"triggerType":2,"fwVersion":"1.2.0","rssi":-61,"ssid":"MWHOME","bssid":"B6:39:56:8D:3A:F6"}
0519|[2023-11-25 13:05:08]DEBUG : - Receive after decode :{"switches":[{"switch":"on","outlet":0},{"switch":"off","outlet":1}],"triggerType":11,"fwVersion":"1.2.0","rssi":-61,"ssid":"MWHOME","bssid":"B6:39:56:8D:3A:F6"}
0520|[2023-11-25 13:05:08]DEBUG : - Receive after decode :{"switches":[{"switch":"on","outlet":0},{"switch":"off","outlet":1}],"triggerType":11,"fwVersion":"1.2.0","rssi":-61,"ssid":"MWHOME","bssid":"B6:39:56:8D:3A:F6"}
0521|[2023-11-25 13:05:09]DEBUG : - Receive after decode :{"switches":[{"switch":"on","outlet":0},{"switch":"off","outlet":1}],"triggerType":11,"fwVersion":"1.2.0","rssi":-61,"ssid":"MWHOME","bssid":"B6:39:56:8D:3A:F6"}
0522|[2023-11-25 13:05:09]DEBUG : - Receive after decode :{"switches":[{"switch":"on","outlet":0},{"switch":"off","outlet":1}],"triggerType":11,"fwVersion":"1.2.0","rssi":-61,"ssid":"MWHOME","bssid":"B6:39:56:8D:3A:F6"}
0523|[2023-11-25 13:05:10]DEBUG : - Receive after decode :{"switches":[{"switch":"on","outlet":0},{"switch":"off","outlet":1}],"triggerType":11,"fwVersion":"1.2.0","rssi":-61,"ssid":"MWHOME","bssid":"B6:39:56:8D:3A:F6"}
0524|[2023-11-25 13:05:10]DEBUG : - Receive after decode :{"switches":[{"switch":"on","outlet":0},{"switch":"off","outlet":1}],"triggerType":11,"fwVersion":"1.2.0","rssi":-61,"ssid":"MWHOME","bssid":"B6:39:56:8D:3A:F6"}
0525|[2023-11-25 13:05:14]DEBUG : - Receive after decode :{"switches":[{"switch":"off","outlet":0},{"switch":"off","outlet":1}],"triggerType":11,"fwVersion":"1.2.0","rssi":-62,"ssid":"MWHOME","bssid":"B6:39:56:8D:3A:F6"}
0526|[2023-11-25 13:05:14]DEBUG : - Receive after decode :{"switches":[{"switch":"off","outlet":0},{"switch":"off","outlet":1}],"triggerType":11,"fwVersion":"1.2.0","rssi":-62,"ssid":"MWHOME","bssid":"B6:39:56:8D:3A:F6"}
0527|[2023-11-25 13:05:15]DEBUG : - Receive after decode :{"switches":[{"switch":"off","outlet":0},{"switch":"off","outlet":1}],"triggerType":11,"fwVersion":"1.2.0","rssi":-62,"ssid":"MWHOME","bssid":"B6:39:56:8D:3A:F6"}
0528|[2023-11-25 13:05:15]DEBUG : - Receive after decode :{"switches":[{"switch":"off","outlet":0},{"switch":"off","outlet":1}],"triggerType":11,"fwVersion":"1.2.0","rssi":-62,"ssid":"MWHOME","bssid":"B6:39:56:8D:3A:F6"}
0529|[2023-11-25 13:05:16]DEBUG : - Receive after decode :{"switches":[{"switch":"off","outlet":0},{"switch":"on","outlet":1}],"triggerType":11,"fwVersion":"1.2.0","rssi":-64,"ssid":"MWHOME","bssid":"B6:39:56:8D:3A:F6"}
0530|[2023-11-25 13:05:16]DEBUG : - Receive after decode :{"switches":[{"switch":"off","outlet":0},{"switch":"on","outlet":1}],"triggerType":11,"fwVersion":"1.2.0","rssi":-64,"ssid":"MWHOME","bssid":"B6:39:56:8D:3A:F6"}
0531|[2023-11-25 13:05:17]DEBUG : - Receive after decode :{"switches":[{"switch":"off","outlet":0},{"switch":"on","outlet":1}],"triggerType":11,"fwVersion":"1.2.0","rssi":-64,"ssid":"MWHOME","bssid":"B6:39:56:8D:3A:F6"}
0532|[2023-11-25 13:05:17]DEBUG : - Receive after decode :{"switches":[{"switch":"off","outlet":0},{"switch":"on","outlet":1}],"triggerType":11,"fwVersion":"1.2.0","rssi":-64,"ssid":"MWHOME","bssid":"B6:39:56:8D:3A:F6"}
0533|[2023-11-25 13:05:18]DEBUG : - Receive after decode :{"switches":[{"switch":"off","outlet":0},{"switch":"off","outlet":1}],"triggerType":11,"fwVersion":"1.2.0","rssi":-64,"ssid":"MWHOME","bssid":"B6:39:56:8D:3A:F6"}
0534|[2023-11-25 13:05:18]DEBUG : - Receive after decode :{"switches":[{"switch":"off","outlet":0},{"switch":"off","outlet":1}],"triggerType":11,"fwVersion":"1.2.0","rssi":-64,"ssid":"MWHOME","bssid":"B6:39:56:8D:3A:F6"}
0535|[2023-11-25 13:05:19]DEBUG : - Receive after decode :{"switches":[{"switch":"off","outlet":0},{"switch":"off","outlet":1}],"triggerType":11,"fwVersion":"1.2.0","rssi":-64,"ssid":"MWHOME","bssid":"B6:39:56:8D:3A:F6"}
0536|[2023-11-25 13:05:19]DEBUG : - Receive after decode :{"switches":[{"switch":"off","outlet":0},{"switch":"off","outlet":1}],"triggerType":11,"fwVersion":"1.2.0","rssi":-64,"ssid":"MWHOME","bssid":"B6:39:56:8D:3A:F6"}
0537|[2023-11-25 13:05:20]DEBUG : - Receive after decode :{"switches":[{"switch":"off","outlet":0},{"switch":"off","outlet":1}],"triggerType":11,"fwVersion":"1.2.0","rssi":-64,"ssid":"MWHOME","bssid":"B6:39:56:8D:3A:F6"}
0538|[2023-11-25 13:05:20]DEBUG : - Receive after decode :{"switches":[{"switch":"off","outlet":0},{"switch":"off","outlet":1}],"triggerType":11,"fwVersion":"1.2.0","rssi":-64,"ssid":"MWHOME","bssid":"B6:39:56:8D:3A:F6"}
