Je démarre dans le monde zigbee avec la clef POPP et je viens de remplacer un de mes thermostats zwave Stelpro par son équivalent zigbee du même fabricant : STZB402+.
Celui-ci est bien détecté par le clef mais aucune commande n’est crée puisque sa config semble non présente dans le plugin zigbee.
Puis-je l’ajouter moi-même? Comment faire?
Voici les infos brutes:
"ieee": "f8:f0:05:ff:ff:f7:81:3d",
"nwk": 16273,
"status": 2,
"lqi": "136",
"rssi": "-66",
"last_seen": "1631501176.170371",
"node_descriptor": "11:40:8e:85:11:59:3d:00:00:00:3d:00:00",
"endpoints": [
"id": 25,
"status": 1,
"device_type": 769,
"profile_id": 260,
"manufacturer": "Stelpro",
"model": "STZB402+",
"output_clusters": [
"id": 1026,
"name": "Temperature Measurement",
"attributes": []
"input_clusters": [
"id": 0,
"name": "Basic",
"attributes": [
"id": 0,
"name": "zcl_version",
"value": 1
"id": 1,
"name": "app_version",
"value": 104
"id": 2,
"name": "stack_version",
"value": 4
"id": 3,
"name": "hw_version",
"value": 1
"id": 4,
"name": "manufacturer",
"value": "Stelpro"
"id": 5,
"name": "model",
"value": "STZB402+"
"id": 6,
"name": "date_code",
"value": "20170307 00095"
"id": 7,
"name": "power_source",
"value": 1
"id": 3,
"name": "Identify",
"attributes": []
"id": 513,
"name": "Thermostat",
"attributes": [
"id": 0,
"name": "local_temp",
"value": 2200
"id": 8,
"name": "pi_heating_demand",
"value": 0
"id": 18,
"name": "occupied_heating_setpoint",
"value": 1200
"id": 28,
"name": "system_mode",
"value": 4
"id": 516,
"name": "Thermostat User Interface Configuration",
"attributes": []
"id": 4,
"name": "Groups",
"attributes": []
"signature": {
"node_desc": {
"logical_type": 1,
"user_descriptor_available": 1,
"reserved": 0,
"aps_flags": 0,
"frequency_band": 8,
"mac_capability_flags": 142,
"manufacturer_code": 4485,
"maximum_buffer_size": 89,
"maximum_incoming_transfer_size": 61,
"server_mask": 0,
"maximum_outgoing_transfer_size": 61,
"endpoints": {
"25": {
"profile_id": 260,
"device_type": 769,
"input_clusters": [
0,
3,
513,
516,
4
1026
"class": "zigpy.device"
J’ai trouvé aussi les infos suivantes :
Déclaration Zigbee Alliance
Compliance Document
Et peut-être d’autres infos à récupérer dans sa page d’intégration MQTT :
STZB402 dans zigbee2mqtt
Pour finir les liens constructeurs :
Fiche produit
Documentation
