Oui et bien redémarrer le démon
Vider les logs oui
Pas besoin de supprimer l équipement
Faire une recherche directement dans l équipement
Et mettre les logs ici
[2023-11-12 20:06:34]DEBUG : │──────────> Close Session
[2023-11-12 20:06:34]DEBUG : [Freebox Close Session] : {"uid":"22eb98ea979b32fc6cd3bc5e810e59a0","success":false,"msg":"Vous devez vous connecter pour accéder à cette fonction","result":{"password_salt":"nU87VwiFiYK4LyWZyMRM5GHHvjkLtyIu","challenge":"\/zY55kBZavFap+V6Pqkv8BHPX3uWsmBT"},"error_code":"invalid_session"}
[2023-11-12 20:06:37]DEBUG : │──────────> Close Session
[2023-11-12 20:06:37]DEBUG : ================= REFRESH T**OK**EN ==================
[2023-11-12 20:06:37]DEBUG : >───────── ARRET CRON FreeboxPUT
[2023-11-12 20:06:37]DEBUG : >───────── ARRET CRON FreeboxGET
[2023-11-12 20:06:37]DEBUG : >───────── ARRET CRON FreeboxAPI
[2023-11-12 20:06:38]DEBUG : │──────────> Close Session
[2023-11-12 20:06:38]DEBUG : [Freebox Password] : {"success":true,"result":{"logged_in":false,"challenge":"\/zY55kBZavFap+V6Pqkv8BHPX3uWsmBT","password_salt":"nU87VwiFiYK4LyWZyMRM5GHHvjkLtyIu","password_set":true}}
[2023-11-12 20:06:38]DEBUG : [Freebox Open Session] : {"result":{"session_token":"SRCGL1sHF8Cdjx4cviYF5Wh5en\/sxpJCYXHsaUICEy7oybk\/1c2M41y+6CsBAD\/3","challenge":"\/zY55kBZavFap+V6Pqkv8BHPX3uWsmBT","password_salt":"nU87VwiFiYK4LyWZyMRM5GHHvjkLtyIu","permissions":{"parental":true,"contacts":true,"explorer":true,"tv":true,"wdo":true,"downloader":true,"profile":true,"camera":true,"settings":true,"calls":true,"home":true,"pvr":true,"vm":true,"player":true},"password_set":true},"success":true}
[2023-11-12 20:06:38]DEBUG : [Freebox Etat Session] : **OK** / 1
[2023-11-12 20:06:39]DEBUG : >───────── REDEMARRAGE CRON FreeboxPUT
[2023-11-12 20:06:39]DEBUG : >───────── REDEMARRAGE CRON FreeboxGET
[2023-11-12 20:06:39]DEBUG : ================= FIN REFRESH T**OK**EN ==================
[2023-11-12 20:07:02]DEBUG : └─────────
[2023-11-12 20:07:20]DEBUG : ┌───────── Ajout des commandes : Wifi
[2023-11-12 20:07:20]DEBUG : │ Application des Widgets ou Icônes pour le core V4
[2023-11-12 20:07:20]DEBUG : >> ================ >> Name : Wifi -- LogicalID : wifi -- catégorie : default -- Equipement Type : -- Logical ID Equip : -- Cron : */5 * * * * -- Objet :
[2023-11-12 20:07:20]DEBUG : >───────── Wifi : Update Liste Noire/Blanche
[2023-11-12 20:07:20]DEBUG : │ [Freebox Request Connexion] : sur la l'adresse mafreebox.freebox.fr/api/v10/wifi/mac_filter/(null)
[2023-11-12 20:07:20]DEBUG : │ [Freebox Request Result] : {"success":true}
[2023-11-12 20:07:20]DEBUG : >───────── Liste Noire/Blanche : Vide
[2023-11-12 20:07:20]DEBUG : │ [Freebox Request Connexion] : GET sur la l'adresse mafreebox.freebox.fr/api/v10/wifi/config(null)
[2023-11-12 20:07:20]DEBUG : │ [Freebox Request Result] : {"success":true,"result":{"enabled":true,"expected_phys":[{"band":"5g","phy_id":1,"detected":true},{"band":"2d4g","phy_id":0,"detected":true},{"band":"5g","phy_id":3,"detected":true}],"mac_filter_state":"disabled"}}
[2023-11-12 20:07:20]DEBUG : │ [Freebox Request Connexion] : GET sur la l'adresse mafreebox.freebox.fr/api/v10/wifi/planning(null)
[2023-11-12 20:07:20]DEBUG : │ [Freebox Request Result] : {"success":true,"result":{"use_planning":false,"resolution":48,"mapping":["on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on","on"]}}
[2023-11-12 20:07:20]DEBUG : │ [Freebox Request Connexion] : GET sur la l'adresse mafreebox.freebox.fr/api/v10/wifi/wps/config(null)
[2023-11-12 20:07:20]DEBUG : │ [Freebox Request Result] : {"success":true,"result":{"enabled":true}}
[2023-11-12 20:07:20]DEBUG : │ [Freebox Request Connexion] : GET sur la l'adresse mafreebox.freebox.fr/api/v10/wifi/ap/1(null)
[2023-11-12 20:07:20]DEBUG : │ [Freebox Request Result] : {"success":true,"result":{"capabilities":{"6g":{"shortgi20":false,"vht_rx_ldpc":false,"vht_sounding_dimensions_1":false,"ldpc":false,"ht_40":false,"smps_dynamic":false,"vht_shortgi80":false,"vht_rx_stbc_4":false,"vht_txops_ps":false,"vht_max_ampdu_len_exp4":false,"vht_max_ampdu_len_exp6":false,"smps_static":false,"vht_rx_antenna_consistency":false,"vht_shortgi160":false,"he_40":false,"vht_tx_stbc":false,"he_supported":false,"vht_ext_nss_bw_3":false,"delayed_ba":false,"ht_20":false,"vht_ext_nss_bw_2":false,"vht_ext_nss_bw_1":false,"vht_beamformee_sts_1":false,"vht_max_ampdu_len_exp3":false,"vht_su_beamformer":false,"vht_tx_antenna_consistency":false,"he_80":false,"vht_rx_stbc_3":false,"vht_max_ampdu_len_exp7":false,"vht_max_ampdu_len_exp1":false,"he_160":false,"vht_max_ampdu_len_exp5":false,"rx_stbc_3":false,"vht_htc":false,"vht_mpdu_len_11454":false,"vht_max_ampdu_len_exp2":false,"vht_rx_stbc_1":false,"rx_stbc_2":false,"vht_sounding_dimensions_3":false,"max_amsdu_7935":false,"vht_su_beamformee":false,"dsss_cck_40":false,"vht_80_80":false,"vht_160":false,"vht_sounding_dimensions_2":false,"psmp":false,"vht_80":false,"vht_beamformee_sts_3":false,"vht_beamformee_sts_2":false,"supported":false,"greenfield":false,"vht_rx_stbc_2":false,"rx_stbc_1":false,"vht_mu_beamformee":false,"vht_mpdu_len_7991":false,"tx_stbc":false,"shortgi40":false,"vht_mu_beamformer":false,"lsig_txop_prot":false},"5g":{"shortgi20":true,"vht_rx_ldpc":true,"vht_sounding_dimensions_1":true,"ldpc":true,"ht_40":true,"smps_dynamic":true,"vht_shortgi80":true,"vht_rx_stbc_4":false,"vht_txops_ps":false,"vht_max_ampdu_len_exp4":true,"vht_max_ampdu_len_exp6":true,"smps_static":false,"vht_rx_antenna_consistency":true,"vht_shortgi160":true,"he_40":false,"vht_tx_stbc":true,"he_supported":false,"vht_ext_nss_bw_3":false,"delayed_ba":false,"ht_20":true,"vht_ext_nss_bw_2":true,"vht_ext_nss_bw_1":false,"vht_beamformee_sts_1":true,"vht_max_ampdu_len_exp3":true,"vht_su_beamformer":true,"vht_tx_antenna_consistency":true,"he_80":false,"vht_rx_stbc_3":false,"vht_max_ampdu_len_exp7":true,"vht_max_ampdu_len_exp1":true,"he_160":false,"vht_max_ampdu_len_exp5":true,"rx_stbc_3":false,"vht_htc":false,"vht_mpdu_len_11454":true,"vht_max_ampdu_len_exp2":true,"vht_rx_stbc_1":true,"rx_stbc_2":false,"vht_sounding_dimensions_3":true,"max_amsdu_7935":true,"vht_su_beamformee":true,"dsss_cck_40":true,"vht_80_80":false,"vht_160":false,"vht_sounding_dimensions_2":true,"psmp":false,"vht_80":true,"vht_beamformee_sts_3":true,"vht_beamformee_sts_2":true,"supported":true,"greenfield":false,"vht_rx_stbc_2":false,"rx_stbc_1":true,"vht_mu_beamformee":true,"vht_mpdu_len_7991":true,"tx_stbc":true,"shortgi40":true,"vht_mu_beamformer":true,"lsig_txop_prot":false},"2d4g":{"shortgi20":false,"vht_rx_ldpc":false,"vht_sounding_dimensions_1":false,"ldpc":false,"ht_40":false,"smps_dynamic":false,"vht_shortgi80":false,"vht_rx_stbc_4":false,"vht_txops_ps":false,"vht_max_ampdu_len_exp4":false,"vht_max_ampdu_len_exp6":false,"smps_static":false,"vht_rx_antenna_consistency":false,"vht_shortgi160":false,"he_40":false,"vht_tx_stbc":false,"he_supported":false,"vht_ext_nss_bw_3":false,"delayed_ba":false,"ht_20":false,"vht_ext_nss_bw_2":false,"vht_ext_nss_bw_1":false,"vht_beamformee_sts_1":false,"vht_max_ampdu_len_exp3":false,"vht_su_beamformer":false,"vht_tx_antenna_consistency":false,"he_80":false,"vht_rx_stbc_3":false,"vht_max_ampdu_len_exp7":false,"vht_max_ampdu_len_exp1":false,"he_160":false,"vht_max_ampdu_len_exp5":false,"rx_stbc_3":false,"vht_htc":false,"vht_mpdu_len_11454":false,"vht_max_ampdu_len_exp2":false,"vht_rx_stbc_1":false,"rx_stbc_2":false,"vht_sounding_dimensions_3":false,"max_amsdu_7935":false,"vht_su_beamformee":false,"dsss_cck_40":false,"vht_80_80":false,"vht_160":false,"vht_sounding_dimensions_2":false,"psmp":false,"vht_80":false,"vht_beamformee_sts_3":false,"vht_beamformee_sts_2":false,"supported":false,"greenfield":false,"vht_rx_stbc_2":false,"rx_stbc_1":false,"vht_mu_beamformee":false,"vht_mpdu_len_7991":false,"tx_stbc":false,"shortgi40":false,"vht_mu_beamformer":false,"lsig_txop_prot":false},"60g":{"shortgi20":false,"vht_rx_ldpc":false,"vht_sounding_dimensions_1":false,"ldpc":false,"ht_40":false,"smps_dynamic":false,"vht_shortgi80":false,"vht_rx_stbc_4":false,"vht_txops_ps":false,"vht_max_ampdu_len_exp4":false,"vht_max_ampdu_len_exp6":false,"smps_static":false,"vht_rx_antenna_consistency":false,"vht_shortgi160":false,"he_40":false,"vht_tx_stbc":false,"he_supported":false,"vht_ext_nss_bw_3":false,"delayed_ba":false,"ht_20":false,"vht_ext_nss_bw_2":false,"vht_ext_nss_bw_1":false,"vht_beamformee_sts_1":false,"vht_max_ampdu_len_exp3":false,"vht_su_beamformer":false,"vht_tx_antenna_consistency":false,"he_80":false,"vht_rx_stbc_3":false,"vht_max_ampdu_len_exp7":false,"vht_max_ampdu_len_exp1":false,"he_160":false,"vht_max_ampdu_len_exp5":false,"rx_stbc_3":false,"vht_htc":false,"vht_mpdu_len_11454":false,"vht_max_ampdu_len_exp2":false,"vht_rx_stbc_1":false,"rx_stbc_2":false,"vht_sounding_dimensions_3":false,"max_amsdu_7935":false,"vht_su_beamformee":false,"dsss_cck_40":false,"vht_80_80":false,"vht_160":false,"vht_sounding_dimensions_2":false,"psmp":false,"vht_80":false,"vht_beamformee_sts_3":false,"vht_beamformee_sts_2":false,"supported":false,"greenfield":false,"vht_rx_stbc_2":false,"rx_stbc_1":false,"vht_mu_beamformee":false,"vht_mpdu_len_7991":false,"tx_stbc":false,"shortgi40":false,"vht_mu_beamformer":false,"lsig_txop_prot":false}},"name":"5G","id":1,"config":{"channel_width":"80","band":"5g","ht":{"greenfield":false,"shortgi20":true,"vht_rx_ldpc":true,"ldpc":true,"vht_rx_stbc":"1","vht_shortgi80":true,"vht_mu_beamformer":true,"vht_sounding_dimensions":"3","ht_enabled":true,"rx_stbc":"1","dsss_cck_40":true,"tx_stbc":true,"ac_enabled":true,"smps":"disabled","vht_shortgi160":true,"vht_beamformee_sts":"3","vht_tx_stbc":true,"vht_su_beamformee":true,"vht_su_beamformer":true,"delayed_ba":false,"vht_tx_antenna_consistency":true,"max_amsdu_7935":false,"vht_max_ampdu_len_exp":7,"vht_max_mpdu_len":"11454","psmp":false,"shortgi40":true,"vht_rx_antenna_consistency":true,"lsig_txop_prot":false},"dfs_enabled":false,"secondary_channel":0,"he":{"enabled":false,"su_beamformee":false,"twt_responder":false,"su_beamformer":false,"twt_required":false,"mu_beamformer":false},"primary_channel":0},"status":{"channel_width":"80","primary_channel":36,"dfs_disabled":true,"dfs_cac_remaining_time":0,"secondary_channel":40,"state":"active"}}}
[2023-11-12 20:07:20]DEBUG : >───────── Status Carte 5G / 1 : active
[2023-11-12 20:07:20]DEBUG : │ [Freebox Request Connexion] : GET sur la l'adresse mafreebox.freebox.fr/api/v10/wifi/ap/0(null)
[2023-11-12 20:07:20]DEBUG : │ [Freebox Request Result] : {"success":true,"result":{"capabilities":{"6g":{"shortgi20":false,"vht_rx_ldpc":false,"vht_sounding_dimensions_1":false,"ldpc":false,"ht_40":false,"smps_dynamic":false,"vht_shortgi80":false,"vht_rx_stbc_4":false,"vht_txops_ps":false,"vht_max_ampdu_len_exp4":false,"vht_max_ampdu_len_exp6":false,"smps_static":false,"vht_rx_antenna_consistency":false,"vht_shortgi160":false,"he_40":false,"vht_tx_stbc":false,"he_supported":false,"vht_ext_nss_bw_3":false,"delayed_ba":false,"ht_20":false,"vht_ext_nss_bw_2":false,"vht_ext_nss_bw_1":false,"vht_beamformee_sts_1":false,"vht_max_ampdu_len_exp3":false,"vht_su_beamformer":false,"vht_tx_antenna_consistency":false,"he_80":false,"vht_rx_stbc_3":false,"vht_max_ampdu_len_exp7":false,"vht_max_ampdu_len_exp1":false,"he_160":false,"vht_max_ampdu_len_exp5":false,"rx_stbc_3":false,"vht_htc":false,"vht_mpdu_len_11454":false,"vht_max_ampdu_len_exp2":false,"vht_rx_stbc_1":false,"rx_stbc_2":false,"vht_sounding_dimensions_3":false,"max_amsdu_7935":false,"vht_su_beamformee":false,"dsss_cck_40":false,"vht_80_80":false,"vht_160":false,"vht_sounding_dimensions_2":false,"psmp":false,"vht_80":false,"vht_beamformee_sts_3":false,"vht_beamformee_sts_2":false,"supported":false,"greenfield":false,"vht_rx_stbc_2":false,"rx_stbc_1":false,"vht_mu_beamformee":false,"vht_mpdu_len_7991":false,"tx_stbc":false,"shortgi40":false,"vht_mu_beamformer":false,"lsig_txop_prot":false},"5g":{"shortgi20":false,"vht_rx_ldpc":false,"vht_sounding_dimensions_1":false,"ldpc":false,"ht_40":false,"smps_dynamic":false,"vht_shortgi80":false,"vht_rx_stbc_4":false,"vht_txops_ps":false,"vht_max_ampdu_len_exp4":false,"vht_max_ampdu_len_exp6":false,"smps_static":false,"vht_rx_antenna_consistency":false,"vht_shortgi160":false,"he_40":false,"vht_tx_stbc":false,"he_supported":false,"vht_ext_nss_bw_3":false,"delayed_ba":false,"ht_20":false,"vht_ext_nss_bw_2":false,"vht_ext_nss_bw_1":false,"vht_beamformee_sts_1":false,"vht_max_ampdu_len_exp3":false,"vht_su_beamformer":false,"vht_tx_antenna_consistency":false,"he_80":false,"vht_rx_stbc_3":false,"vht_max_ampdu_len_exp7":false,"vht_max_ampdu_len_exp1":false,"he_160":false,"vht_max_ampdu_len_exp5":false,"rx_stbc_3":false,"vht_htc":false,"vht_mpdu_len_11454":false,"vht_max_ampdu_len_exp2":false,"vht_rx_stbc_1":false,"rx_stbc_2":false,"vht_sounding_dimensions_3":false,"max_amsdu_7935":false,"vht_su_beamformee":false,"dsss_cck_40":false,"vht_80_80":false,"vht_160":false,"vht_sounding_dimensions_2":false,"psmp":false,"vht_80":false,"vht_beamformee_sts_3":false,"vht_beamformee_sts_2":false,"supported":false,"greenfield":false,"vht_rx_stbc_2":false,"rx_stbc_1":false,"vht_mu_beamformee":false,"vht_mpdu_len_7991":false,"tx_stbc":false,"shortgi40":false,"vht_mu_beamformer":false,"lsig_txop_prot":false},"2d4g":{"shortgi20":true,"vht_rx_ldpc":false,"vht_sounding_dimensions_1":false,"ldpc":true,"ht_40":true,"smps_dynamic":true,"vht_shortgi80":false,"vht_rx_stbc_4":false,"vht_txops_ps":false,"vht_max_ampdu_len_exp4":false,"vht_max_ampdu_len_exp6":false,"smps_static":false,"vht_rx_antenna_consistency":false,"vht_shortgi160":false,"he_40":false,"vht_tx_stbc":false,"he_supported":false,"vht_ext_nss_bw_3":false,"delayed_ba":false,"ht_20":true,"vht_ext_nss_bw_2":false,"vht_ext_nss_bw_1":false,"vht_beamformee_sts_1":false,"vht_max_ampdu_len_exp3":false,"vht_su_beamformer":false,"vht_tx_antenna_consistency":false,"he_80":false,"vht_rx_stbc_3":false,"vht_max_ampdu_len_exp7":false,"vht_max_ampdu_len_exp1":false,"he_160":false,"vht_max_ampdu_len_exp5":false,"rx_stbc_3":false,"vht_htc":false,"vht_mpdu_len_11454":false,"vht_max_ampdu_len_exp2":false,"vht_rx_stbc_1":false,"rx_stbc_2":false,"vht_sounding_dimensions_3":false,"max_amsdu_7935":true,"vht_su_beamformee":false,"dsss_cck_40":true,"vht_80_80":false,"vht_160":false,"vht_sounding_dimensions_2":false,"psmp":false,"vht_80":false,"vht_beamformee_sts_3":false,"vht_beamformee_sts_2":false,"supported":true,"greenfield":false,"vht_rx_stbc_2":false,"rx_stbc_1":true,"vht_mu_beamformee":false,"vht_mpdu_len_7991":false,"tx_stbc":true,"shortgi40":true,"vht_mu_beamformer":false,"lsig_txop_prot":false},"60g":{"shortgi20":false,"vht_rx_ldpc":false,"vht_sounding_dimensions_1":false,"ldpc":false,"ht_40":false,"smps_dynamic":false,"vht_shortgi80":false,"vht_rx_stbc_4":false,"vht_txops_ps":false,"vht_max_ampdu_len_exp4":false,"vht_max_ampdu_len_exp6":false,"smps_static":false,"vht_rx_antenna_consistency":false,"vht_shortgi160":false,"he_40":false,"vht_tx_stbc":false,"he_supported":false,"vht_ext_nss_bw_3":false,"delayed_ba":false,"ht_20":false,"vht_ext_nss_bw_2":false,"vht_ext_nss_bw_1":false,"vht_beamformee_sts_1":false,"vht_max_ampdu_len_exp3":false,"vht_su_beamformer":false,"vht_tx_antenna_consistency":false,"he_80":false,"vht_rx_stbc_3":false,"vht_max_ampdu_len_exp7":false,"vht_max_ampdu_len_exp1":false,"he_160":false,"vht_max_ampdu_len_exp5":false,"rx_stbc_3":false,"vht_htc":false,"vht_mpdu_len_11454":false,"vht_max_ampdu_len_exp2":false,"vht_rx_stbc_1":false,"rx_stbc_2":false,"vht_sounding_dimensions_3":false,"max_amsdu_7935":false,"vht_su_beamformee":false,"dsss_cck_40":false,"vht_80_80":false,"vht_160":false,"vht_sounding_dimensions_2":false,"psmp":false,"vht_80":false,"vht_beamformee_sts_3":false,"vht_beamformee_sts_2":false,"supported":false,"greenfield":false,"vht_rx_stbc_2":false,"rx_stbc_1":false,"vht_mu_beamformee":false,"vht_mpdu_len_7991":false,"tx_stbc":false,"shortgi40":false,"vht_mu_beamformer":false,"lsig_txop_prot":false}},"name":"2.4G","id":0,"config":{"channel_width":"20","band":"2d4g","ht":{"greenfield":false,"shortgi20":true,"vht_rx_ldpc":false,"ldpc":false,"vht_rx_stbc":"disabled","vht_shortgi80":false,"vht_mu_beamformer":false,"vht_sounding_dimensions":"disabled","ht_enabled":true,"rx_stbc":"1","dsss_cck_40":false,"tx_stbc":true,"ac_enabled":false,"smps":"disabled","vht_shortgi160":false,"vht_beamformee_sts":"disabled","vht_tx_stbc":false,"vht_su_beamformee":false,"vht_su_beamformer":false,"delayed_ba":false,"vht_tx_antenna_consistency":false,"max_amsdu_7935":false,"vht_max_ampdu_len_exp":0,"vht_max_mpdu_len":"default","psmp":false,"shortgi40":true,"vht_rx_antenna_consistency":false,"lsig_txop_prot":false},"dfs_enabled":false,"secondary_channel":0,"he":{"enabled":false,"su_beamformee":false,"twt_responder":false,"su_beamformer":false,"twt_required":false,"mu_beamformer":false},"primary_channel":0},"status":{"channel_width":"20","primary_channel":11,"dfs_disabled":false,"dfs_cac_remaining_time":0,"secondary_channel":0,"state":"active"}}}
[2023-11-12 20:07:20]DEBUG : >───────── Status Carte 2.4G / 0 : active
[2023-11-12 20:07:20]DEBUG : │ [Freebox Request Connexion] : GET sur la l'adresse mafreebox.freebox.fr/api/v10/wifi/ap/3(null)
[2023-11-12 20:07:20]DEBUG : │ [Freebox Request Result] : {"success":true,"result":{"capabilities":{"6g":{"shortgi20":false,"vht_rx_ldpc":false,"vht_sounding_dimensions_1":false,"ldpc":false,"ht_40":false,"smps_dynamic":false,"vht_shortgi80":false,"vht_rx_stbc_4":false,"vht_txops_ps":false,"vht_max_ampdu_len_exp4":false,"vht_max_ampdu_len_exp6":false,"smps_static":false,"vht_rx_antenna_consistency":false,"vht_shortgi160":false,"he_40":false,"vht_tx_stbc":false,"he_supported":false,"vht_ext_nss_bw_3":false,"delayed_ba":false,"ht_20":false,"vht_ext_nss_bw_2":false,"vht_ext_nss_bw_1":false,"vht_beamformee_sts_1":false,"vht_max_ampdu_len_exp3":false,"vht_su_beamformer":false,"vht_tx_antenna_consistency":false,"he_80":false,"vht_rx_stbc_3":false,"vht_max_ampdu_len_exp7":false,"vht_max_ampdu_len_exp1":false,"he_160":false,"vht_max_ampdu_len_exp5":false,"rx_stbc_3":false,"vht_htc":false,"vht_mpdu_len_11454":false,"vht_max_ampdu_len_exp2":false,"vht_rx_stbc_1":false,"rx_stbc_2":false,"vht_sounding_dimensions_3":false,"max_amsdu_7935":false,"vht_su_beamformee":false,"dsss_cck_40":false,"vht_80_80":false,"vht_160":false,"vht_sounding_dimensions_2":false,"psmp":false,"vht_80":false,"vht_beamformee_sts_3":false,"vht_beamformee_sts_2":false,"supported":false,"greenfield":false,"vht_rx_stbc_2":false,"rx_stbc_1":false,"vht_mu_beamformee":false,"vht_mpdu_len_7991":false,"tx_stbc":false,"shortgi40":false,"vht_mu_beamformer":false,"lsig_txop_prot":false},"5g":{"shortgi20":true,"vht_rx_ldpc":true,"vht_sounding_dimensions_1":true,"ldpc":true,"ht_40":true,"smps_dynamic":true,"vht_shortgi80":true,"vht_rx_stbc_4":false,"vht_txops_ps":false,"vht_max_ampdu_len_exp4":true,"vht_max_ampdu_len_exp6":true,"smps_static":false,"vht_rx_antenna_consistency":true,"vht_shortgi160":true,"he_40":false,"vht_tx_stbc":true,"he_supported":false,"vht_ext_nss_bw_3":false,"delayed_ba":false,"ht_20":true,"vht_ext_nss_bw_2":true,"vht_ext_nss_bw_1":false,"vht_beamformee_sts_1":true,"vht_max_ampdu_len_exp3":true,"vht_su_beamformer":true,"vht_tx_antenna_consistency":true,"he_80":false,"vht_rx_stbc_3":false,"vht_max_ampdu_len_exp7":true,"vht_max_ampdu_len_exp1":true,"he_160":false,"vht_max_ampdu_len_exp5":true,"rx_stbc_3":false,"vht_htc":false,"vht_mpdu_len_11454":true,"vht_max_ampdu_len_exp2":true,"vht_rx_stbc_1":true,"rx_stbc_2":false,"vht_sounding_dimensions_3":true,"max_amsdu_7935":true,"vht_su_beamformee":true,"dsss_cck_40":true,"vht_80_80":false,"vht_160":false,"vht_sounding_dimensions_2":true,"psmp":false,"vht_80":true,"vht_beamformee_sts_3":true,"vht_beamformee_sts_2":true,"supported":true,"greenfield":false,"vht_rx_stbc_2":false,"rx_stbc_1":true,"vht_mu_beamformee":true,"vht_mpdu_len_7991":true,"tx_stbc":true,"shortgi40":true,"vht_mu_beamformer":true,"lsig_txop_prot":false},"2d4g":{"shortgi20":false,"vht_rx_ldpc":false,"vht_sounding_dimensions_1":false,"ldpc":false,"ht_40":false,"smps_dynamic":false,"vht_shortgi80":false,"vht_rx_stbc_4":false,"vht_txops_ps":false,"vht_max_ampdu_len_exp4":false,"vht_max_ampdu_len_exp6":false,"smps_static":false,"vht_rx_antenna_consistency":false,"vht_shortgi160":false,"he_40":false,"vht_tx_stbc":false,"he_supported":false,"vht_ext_nss_bw_3":false,"delayed_ba":false,"ht_20":false,"vht_ext_nss_bw_2":false,"vht_ext_nss_bw_1":false,"vht_beamformee_sts_1":false,"vht_max_ampdu_len_exp3":false,"vht_su_beamformer":false,"vht_tx_antenna_consistency":false,"he_80":false,"vht_rx_stbc_3":false,"vht_max_ampdu_len_exp7":false,"vht_max_ampdu_len_exp1":false,"he_160":false,"vht_max_ampdu_len_exp5":false,"rx_stbc_3":false,"vht_htc":false,"vht_mpdu_len_11454":false,"vht_max_ampdu_len_exp2":false,"vht_rx_stbc_1":false,"rx_stbc_2":false,"vht_sounding_dimensions_3":false,"max_amsdu_7935":false,"vht_su_beamformee":false,"dsss_cck_40":false,"vht_80_80":false,"vht_160":false,"vht_sounding_dimensions_2":false,"psmp":false,"vht_80":false,"vht_beamformee_sts_3":false,"vht_beamformee_sts_2":false,"supported":false,"greenfield":false,"vht_rx_stbc_2":false,"rx_stbc_1":false,"vht_mu_beamformee":false,"vht_mpdu_len_7991":false,"tx_stbc":false,"shortgi40":false,"vht_mu_beamformer":false,"lsig_txop_prot":false},"60g":{"shortgi20":false,"vht_rx_ldpc":false,"vht_sounding_dimensions_1":false,"ldpc":false,"ht_40":false,"smps_dynamic":false,"vht_shortgi80":false,"vht_rx_stbc_4":false,"vht_txops_ps":false,"vht_max_ampdu_len_exp4":false,"vht_max_ampdu_len_exp6":false,"smps_static":false,"vht_rx_antenna_consistency":false,"vht_shortgi160":false,"he_40":false,"vht_tx_stbc":false,"he_supported":false,"vht_ext_nss_bw_3":false,"delayed_ba":false,"ht_20":false,"vht_ext_nss_bw_2":false,"vht_ext_nss_bw_1":false,"vht_beamformee_sts_1":false,"vht_max_ampdu_len_exp3":false,"vht_su_beamformer":false,"vht_tx_antenna_consistency":false,"he_80":false,"vht_rx_stbc_3":false,"vht_max_ampdu_len_exp7":false,"vht_max_ampdu_len_exp1":false,"he_160":false,"vht_max_ampdu_len_exp5":false,"rx_stbc_3":false,"vht_htc":false,"vht_mpdu_len_11454":false,"vht_max_ampdu_len_exp2":false,"vht_rx_stbc_1":false,"rx_stbc_2":false,"vht_sounding_dimensions_3":false,"max_amsdu_7935":false,"vht_su_beamformee":false,"dsss_cck_40":false,"vht_80_80":false,"vht_160":false,"vht_sounding_dimensions_2":false,"psmp":false,"vht_80":false,"vht_beamformee_sts_3":false,"vht_beamformee_sts_2":false,"supported":false,"greenfield":false,"vht_rx_stbc_2":false,"rx_stbc_1":false,"vht_mu_beamformee":false,"vht_mpdu_len_7991":false,"tx_stbc":false,"shortgi40":false,"vht_mu_beamformer":false,"lsig_txop_prot":false}},"name":"5G1","id":3,"config":{"channel_width":"80","band":"5g","ht":{"greenfield":false,"shortgi20":true,"vht_rx_ldpc":true,"ldpc":true,"vht_rx_stbc":"1","vht_shortgi80":true,"vht_mu_beamformer":true,"vht_sounding_dimensions":"3","ht_enabled":true,"rx_stbc":"1","dsss_cck_40":true,"tx_stbc":true,"ac_enabled":true,"smps":"disabled","vht_shortgi160":true,"vht_beamformee_sts":"3","vht_tx_stbc":true,"vht_su_beamformee":true,"vht_su_beamformer":true,"delayed_ba":false,"vht_tx_antenna_consistency":true,"max_amsdu_7935":false,"vht_max_ampdu_len_exp":7,"vht_max_mpdu_len":"11454","psmp":false,"shortgi40":true,"vht_rx_antenna_consistency":true,"lsig_txop_prot":false},"dfs_enabled":true,"secondary_channel":0,"he":{"enabled":false,"su_beamformee":false,"twt_responder":false,"su_beamformer":false,"twt_required":false,"mu_beamformer":false},"primary_channel":0},"status":{"channel_width":"80","primary_channel":116,"dfs_disabled":false,"dfs_cac_remaining_time":0,"secondary_channel":120,"state":"active"}}}
[2023-11-12 20:07:20]DEBUG : >───────── Status Carte 5G1 / 3 : active
[2023-11-12 20:07:20]DEBUG : │ Name : Etat Wifi -- Type : info -- LogicalID : wifiStatut -- Template Widget / Ligne : /0-- Type de générique : ENERGY_STATE -- Inverser : -- Icône : -- Min/Max : default/default -- Calcul/Arrondi : / -- Ordre : 1
[2023-11-12 20:07:20]DEBUG : │ Name : Wifi On -- Type : action -- LogicalID : wifiOn -- Template Widget / Ligne : Freebox_OS::Wifi/0-- Type de générique : ENERGY_ON -- Inverser : 0 -- Icône : fas fa-wifi icon_green -- Min/Max : default/default -- Calcul/Arrondi : / -- Ordre : 10
[2023-11-12 20:07:20]DEBUG : │ Name : Wifi Off -- Type : action -- LogicalID : wifiOff -- Template Widget / Ligne : Freebox_OS::Wifi/0-- Type de générique : ENERGY_OFF -- Inverser : 0 -- Icône : fas fa-times icon_red -- Min/Max : default/default -- Calcul/Arrondi : / -- Ordre : 11
[2023-11-12 20:07:20]DEBUG : │ Name : Etat Planning -- Type : info -- LogicalID : wifiPlanning -- Template Widget / Ligne : /0-- Type de générique : LIGHT_STATE -- Inverser : -- Icône : -- Min/Max : default/default -- Calcul/Arrondi : / -- Ordre : 0
[2023-11-12 20:07:20]DEBUG : │ Name : Wifi Planning On -- Type : action -- LogicalID : wifiPlanningOn -- Template Widget / Ligne : Freebox_OS::Planning Wifi/0-- Type de générique : LIGHT_ON -- Inverser : 0 -- Icône : fas fa-calendar-alt icon_green -- Min/Max : default/default -- Calcul/Arrondi : / -- Ordre : 12
[2023-11-12 20:07:20]DEBUG : │ Name : Wifi Planning Off -- Type : action -- LogicalID : wifiPlanningOff -- Template Widget / Ligne : Freebox_OS::Planning Wifi/0-- Type de générique : LIGHT_OFF -- Inverser : 0 -- Icône : fas fa-calendar-times icon_red -- Min/Max : default/default -- Calcul/Arrondi : / -- Ordre : 13
[2023-11-12 20:07:20]DEBUG : │ Name : Etat WPS -- Type : info -- LogicalID : wifiWPS -- Template Widget / Ligne : /0-- Type de générique : LIGHT_STATE -- Inverser : -- Icône : -- Min/Max : default/default -- Calcul/Arrondi : / -- Ordre : 0
[2023-11-12 20:07:20]DEBUG : └─────────
[2023-11-12 20:07:20]DEBUG : ┌───────── Création équipement spécifique : Wifi / Wifi WPS
[2023-11-12 20:07:20]DEBUG : │ Name : Wifi Session WPS (toutes les sessions) Off -- Type : action -- LogicalID : wifiSessionWPSOff -- Template Widget / Ligne : /1-- Type de générique : LIGHT_OFF -- Inverser : 0 -- Icône : fas fa-link icon_red -- Min/Max : default/default -- Calcul/Arrondi : / -- Ordre : 30
[2023-11-12 20:07:20]DEBUG : │ [Freebox Request Connexion] : GET sur la l'adresse mafreebox.freebox.fr/api/v10/wifi/bss(null)
[2023-11-12 20:07:20]DEBUG : │ [Freebox Request Result] : {"success":true,"result":[{"config":{"enabled":true,"wps_enabled":true,"encryption":"wpa2_psk_ccmp","hide_ssid":false,"eapol_version":2,"key":"xxxxxxxxxxxxx","wps_uuid":"f77ee022-c6e3-4d3b-90c0-4515edb5bbaf","use_default_config":true,"ssid":"PHD"},"bss_params":{"enabled":true,"wps_uuid":"18fb7a52-3ea0-4c54-af05-977ea7043f10","ssid":"Freebox-6655D6","encryption":"wpa2_psk_ccmp","wps_enabled":true,"hide_ssid":false,"eapol_version":2,"key":"abundasse2-docendam-cumanos.@-tulerimus#"},"shared_bss_params":{"enabled":true,"wps_uuid":"f77ee022-c6e3-4d3b-90c0-4515edb5bbaf","ssid":"PHD","encryption":"wpa2_psk_ccmp","wps_enabled":true,"hide_ssid":false,"eapol_version":2,"key":"xxxxxxxxxxxxxx"},"id":"DC:00:B0:84:74:CB","use_shared_params":true,"phy_id":3,"status":{"state":"active","authorized_sta_count":0,"sta_count":0,"band":"5G","is_main_bss":false}},{"config":{"enabled":true,"wps_enabled":true,"encryption":"wpa2_psk_ccmp","hide_ssid":false,"eapol_version":2,"key":"xxxxxxxxxxxxxxxxxxx","wps_uuid":"f77ee022-c6e3-4d3b-90c0-4515edb5bbaf","use_default_config":true,"ssid":"PHD"},"bss_params":{"enabled":true,"wps_uuid":"f77ee022-c6e3-4d3b-90c0-4515edb5bbaf","ssid":"Freebox-6655D6","encryption":"wpa2_psk_ccmp","wps_enabled":true,"hide_ssid":false,"eapol_version":2,"key":"abundasse2-docendam-cumanos.@-tulerimus#"},"shared_bss_params":{"enabled":true,"wps_uuid":"f77ee022-c6e3-4d3b-90c0-4515edb5bbaf","ssid":"PHD","encryption":"wpa2_psk_ccmp","wps_enabled":true,"hide_ssid":false,"eapol_version":2,"key":"xxxxxxxxxxxxxxxxx"},"id":"DC:00:B0:84:74:C9","use_shared_params":true,"phy_id":0,"status":{"state":"active","authorized_sta_count":0,"sta_count":0,"band":"2G4","is_main_bss":false}},{"config":{"enabled":true,"wps_enabled":true,"encryption":"wpa2_psk_ccmp","hide_ssid":false,"eapol_version":2,"key":"xxxxxxxxxxxxxxxxx","wps_uuid":"66a14874-9511-4d06-a14d-c9e6a6081b36","use_default_config":false,"ssid":"PHD2"},"bss_params":{"enabled":true,"wps_uuid":"66a14874-9511-4d06-a14d-c9e6a6081b36","ssid":"PHD2","encryption":"wpa2_psk_ccmp","wps_enabled":true,"hide_ssid":false,"eapol_version":2,"key":"xxxxxxxxxxxxxxxxxx"},"shared_bss_params":{"enabled":true,"wps_uuid":"f77ee022-c6e3-4d3b-90c0-4515edb5bbaf","ssid":"PHD","encryption":"wpa2_psk_ccmp","wps_enabled":true,"hide_ssid":false,"eapol_version":2,"key":"xxxxxxxxxxxxxxx"},"id":"DC:00:B0:84:74:CA","use_shared_params":false,"phy_id":1,"status":{"state":"active","authorized_sta_count":3,"sta_count":3,"band":"5G","is_main_bss":false}}]}
[2023-11-12 20:07:20]DEBUG : │ Name : Wifi Session WPS (PHD) On -- Type : action -- LogicalID : DC:00:B0:84:74:CB -- Template Widget / Ligne : /1-- Type de générique : LIGHT_ON -- Inverser : 0 -- Icône : fas fa-link icon_orange -- Min/Max : default/default -- Calcul/Arrondi : / -- Ordre : 31
[2023-11-12 20:07:20]DEBUG : │──────────> Configuration Wifi commune pour l'ensemble des cartes
[2023-11-12 20:07:20]DEBUG : ┌───────── Création équipement : Wifi Filtrage Adresse Mac
[2023-11-12 20:07:20]DEBUG : │ Name : Liste Mac Blanche -- Type : info -- LogicalID : listwhite -- Template Widget / Ligne : /0-- Type de générique : -- Inverser : 0 -- Icône : fas fa-list-alt -- Min/Max : default/default -- Calcul/Arrondi : / -- Ordre : 41
[2023-11-12 20:07:20]DEBUG : │ Name : Liste MAC Noire -- Type : info -- LogicalID : listblack -- Template Widget / Ligne : /0-- Type de générique : -- Inverser : 0 -- Icône : far fa-list-alt -- Min/Max : default/default -- Calcul/Arrondi : / -- Ordre : 42
[2023-11-12 20:07:20]DEBUG : ┌───────── Création équipement spécifique : Wifi / Wifi Access Points
[2023-11-12 20:07:20]DEBUG : │ [Freebox Request Connexion] : GET sur la l'adresse mafreebox.freebox.fr/api/v10/wifi/ap(null)
[2023-11-12 20:07:20]DEBUG : │ [Freebox Request Result] : {"success":true,"result":[{"capabilities":{"6g":{"shortgi20":false,"vht_rx_ldpc":false,"vht_sounding_dimensions_1":false,"ldpc":false,"ht_40":false,"smps_dynamic":false,"vht_shortgi80":false,"vht_rx_stbc_4":false,"vht_txops_ps":false,"vht_max_ampdu_len_exp4":false,"vht_max_ampdu_len_exp6":false,"smps_static":false,"vht_rx_antenna_consistency":false,"vht_shortgi160":false,"he_40":false,"vht_tx_stbc":false,"he_supported":false,"vht_ext_nss_bw_3":false,"delayed_ba":false,"ht_20":false,"vht_ext_nss_bw_2":false,"vht_ext_nss_bw_1":false,"vht_beamformee_sts_1":false,"vht_max_ampdu_len_exp3":false,"vht_su_beamformer":false,"vht_tx_antenna_consistency":false,"he_80":false,"vht_rx_stbc_3":false,"vht_max_ampdu_len_exp7":false,"vht_max_ampdu_len_exp1":false,"he_160":false,"vht_max_ampdu_len_exp5":false,"rx_stbc_3":false,"vht_htc":false,"vht_mpdu_len_11454":false,"vht_max_ampdu_len_exp2":false,"vht_rx_stbc_1":false,"rx_stbc_2":false,"vht_sounding_dimensions_3":false,"max_amsdu_7935":false,"vht_su_beamformee":false,"dsss_cck_40":false,"vht_80_80":false,"vht_160":false,"vht_sounding_dimensions_2":false,"psmp":false,"vht_80":false,"vht_beamformee_sts_3":false,"vht_beamformee_sts_2":false,"supported":false,"greenfield":false,"vht_rx_stbc_2":false,"rx_stbc_1":false,"vht_mu_beamformee":false,"vht_mpdu_len_7991":false,"tx_stbc":false,"shortgi40":false,"vht_mu_beamformer":false,"lsig_txop_prot":false},"5g":{"shortgi20":true,"vht_rx_ldpc":true,"vht_sounding_dimensions_1":true,"ldpc":true,"ht_40":true,"smps_dynamic":true,"vht_shortgi80":true,"vht_rx_stbc_4":false,"vht_txops_ps":false,"vht_max_ampdu_len_exp4":true,"vht_max_ampdu_len_exp6":true,"smps_static":false,"vht_rx_antenna_consistency":true,"vht_shortgi160":true,"he_40":false,"vht_tx_stbc":true,"he_supported":false,"vht_ext_nss_bw_3":false,"delayed_ba":false,"ht_20":true,"vht_ext_nss_bw_2":true,"vht_ext_nss_bw_1":false,"vht_beamformee_sts_1":true,"vht_max_ampdu_len_exp3":true,"vht_su_beamformer":true,"vht_tx_antenna_consistency":true,"he_80":false,"vht_rx_stbc_3":false,"vht_max_ampdu_len_exp7":true,"vht_max_ampdu_len_exp1":true,"he_160":false,"vht_max_ampdu_len_exp5":true,"rx_stbc_3":false,"vht_htc":false,"vht_mpdu_len_11454":true,"vht_max_ampdu_len_exp2":true,"vht_rx_stbc_1":true,"rx_stbc_2":false,"vht_sounding_dimensions_3":true,"max_amsdu_7935":true,"vht_su_beamformee":true,"dsss_cck_40":true,"vht_80_80":false,"vht_160":false,"vht_sounding_dimensions_2":true,"psmp":false,"vht_80":true,"vht_beamformee_sts_3":true,"vht_beamformee_sts_2":true,"supported":true,"greenfield":false,"vht_rx_stbc_2":false,"rx_stbc_1":true,"vht_mu_beamformee":true,"vht_mpdu_len_7991":true,"tx_stbc":true,"shortgi40":true,"vht_mu_beamformer":true,"lsig_txop_prot":false},"2d4g":{"shortgi20":false,"vht_rx_ldpc":false,"vht_sounding_dimensions_1":false,"ldpc":false,"ht_40":false,"smps_dynamic":false,"vht_shortgi80":false,"vht_rx_stbc_4":false,"vht_txops_ps":false,"vht_max_ampdu_len_exp4":false,"vht_max_ampdu_len_exp6":false,"smps_static":false,"vht_rx_antenna_consistency":false,"vht_shortgi160":false,"he_40":false,"vht_tx_stbc":false,"he_supported":false,"vht_ext_nss_bw_3":false,"delayed_ba":false,"ht_20":false,"vht_ext_nss_bw_2":false,"vht_ext_nss_bw_1":false,"vht_beamformee_sts_1":false,"vht_max_ampdu_len_exp3":false,"vht_su_beamformer":false,"vht_tx_antenna_consistency":false,"he_80":false,"vht_rx_stbc_3":false,"vht_max_ampdu_len_exp7":false,"vht_max_ampdu_len_exp1":false,"he_160":false,"vht_max_ampdu_len_exp5":false,"rx_stbc_3":false,"vht_htc":false,"vht_mpdu_len_11454":false,"vht_max_ampdu_len_exp2":false,"vht_rx_stbc_1":false,"rx_stbc_2":false,"vht_sounding_dimensions_3":false,"max_amsdu_7935":false,"vht_su_beamformee":false,"dsss_cck_40":false,"vht_80_80":false,"vht_160":false,"vht_sounding_dimensions_2":false,"psmp":false,"vht_80":false,"vht_beamformee_sts_3":false,"vht_beamformee_sts_2":false,"supported":false,"greenfield":false,"vht_rx_stbc_2":false,"rx_stbc_1":false,"vht_mu_beamformee":false,"vht_mpdu_len_7991":false,"tx_stbc":false,"shortgi40":false,"vht_mu_beamformer":false,"lsig_txop_prot":false},"60g":{"shortgi20":false,"vht_rx_ldpc":false,"vht_sounding_dimensions_1":false,"ldpc":false,"ht_40":false,"smps_dynamic":false,"vht_shortgi80":false,"vht_rx_stbc_4":false,"vht_txops_ps":false,"vht_max_ampdu_len_exp4":false,"vht_max_ampdu_len_exp6":false,"smps_static":false,"vht_rx_antenna_consistency":false,"vht_shortgi160":false,"he_40":false,"vht_tx_stbc":false,"he_supported":false,"vht_ext_nss_bw_3":false,"delayed_ba":false,"ht_20":false,"vht_ext_nss_bw_2":false,"vht_ext_nss_bw_1":false,"vht_beamformee_sts_1":false,"vht_max_ampdu_len_exp3":false,"vht_su_beamformer":false,"vht_tx_antenna_consistency":false,"he_80":false,"vht_rx_stbc_3":false,"vht_max_ampdu_len_exp7":false,"vht_max_ampdu_len_exp1":false,"he_160":false,"vht_max_ampdu_len_exp5":false,"rx_stbc_3":false,"vht_htc":false,"vht_mpdu_len_11454":false,"vht_max_ampdu_len_exp2":false,"vht_rx_stbc_1":false,"rx_stbc_2":false,"vht_sounding_dimensions_3":false,"max_amsdu_7935":false,"vht_su_beamformee":false,"dsss_cck_40":false,"vht_80_80":false,"vht_160":false,"vht_sounding_dimensions_2":false,"psmp":false,"vht_80":false,"vht_beamformee_sts_3":false,"vht_beamformee_sts_2":false,"supported":false,"greenfield":false,"vht_rx_stbc_2":false,"rx_stbc_1":false,"vht_mu_beamformee":false,"vht_mpdu_len_7991":false,"tx_stbc":false,"shortgi40":false,"vht_mu_beamformer":false,"lsig_txop_prot":false}},"name":"5G","id":1,"config":{"channel_width":"80","band":"5g","ht":{"greenfield":false,"shortgi20":true,"vht_rx_ldpc":true,"ldpc":true,"vht_rx_stbc":"1","vht_shortgi80":true,"vht_mu_beamformer":true,"vht_sounding_dimensions":"3","ht_enabled":true,"rx_stbc":"1","dsss_cck_40":true,"tx_stbc":true,"ac_enabled":true,"smps":"disabled","vht_shortgi160":true,"vht_beamformee_sts":"3","vht_tx_stbc":true,"vht_su_beamformee":true,"vht_su_beamformer":true,"delayed_ba":false,"vht_tx_antenna_consistency":true,"max_amsdu_7935":false,"vht_max_ampdu_len_exp":7,"vht_max_mpdu_len":"11454","psmp":false,"shortgi40":true,"vht_rx_antenna_consistency":true,"lsig_txop_prot":false},"dfs_enabled":false,"secondary_channel":0,"he":{"enabled":false,"su_beamformee":false,"twt_responder":false,"su_beamformer":false,"twt_required":false,"mu_beamformer":false},"primary_channel":0},"status":{"channel_width":"80","primary_channel":36,"dfs_disabled":true,"dfs_cac_remaining_time":0,"secondary_channel":40,"state":"active"}},{"capabilities":{"6g":{"shortgi20":false,"vht_rx_ldpc":false,"vht_sounding_dimensions_1":false,"ldpc":false,"ht_40":false,"smps_dynamic":false,"vht_shortgi80":false,"vht_rx_stbc_4":false,"vht_txops_ps":false,"vht_max_ampdu_len_exp4":false,"vht_max_ampdu_len_exp6":false,"smps_static":false,"vht_rx_antenna_consistency":false,"vht_shortgi160":false,"he_40":false,"vht_tx_stbc":false,"he_supported":false,"vht_ext_nss_bw_3":false,"delayed_ba":false,"ht_20":false,"vht_ext_nss_bw_2":false,"vht_ext_nss_bw_1":false,"vht_beamformee_sts_1":false,"vht_max_ampdu_len_exp3":false,"vht_su_beamformer":false,"vht_tx_antenna_consistency":false,"he_80":false,"vht_rx_stbc_3":false,"vht_max_ampdu_len_exp7":false,"vht_max_ampdu_len_exp1":false,"he_160":false,"vht_max_ampdu_len_exp5":false,"rx_stbc_3":false,"vht_htc":false,"vht_mpdu_len_11454":false,"vht_max_ampdu_len_exp2":false,"vht_rx_stbc_1":false,"rx_stbc_2":false,"vht_sounding_dimensions_3":false,"max_amsdu_7935":false,"vht_su_beamformee":false,"dsss_cck_40":false,"vht_80_80":false,"vht_160":false,"vht_sounding_dimensions_2":false,"psmp":false,"vht_80":false,"vht_beamformee_sts_3":false,"vht_beamformee_sts_2":false,"supported":false,"greenfield":false,"vht_rx_stbc_2":false,"rx_stbc_1":false,"vht_mu_beamformee":false,"vht_mpdu_len_7991":false,"tx_stbc":false,"shortgi40":false,"vht_mu_beamformer":false,"lsig_txop_prot":false},"5g":{"shortgi20":false,"vht_rx_ldpc":false,"vht_sounding_dimensions_1":false,"ldpc":false,"ht_40":false,"smps_dynamic":false,"vht_shortgi80":false,"vht_rx_stbc_4":false,"vht_txops_ps":false,"vht_max_ampdu_len_exp4":false,"vht_max_ampdu_len_exp6":false,"smps_static":false,"vht_rx_antenna_consistency":false,"vht_shortgi160":false,"he_40":false,"vht_tx_stbc":false,"he_supported":false,"vht_ext_nss_bw_3":false,"delayed_ba":false,"ht_20":false,"vht_ext_nss_bw_2":false,"vht_ext_nss_bw_1":false,"vht_beamformee_sts_1":false,"vht_max_ampdu_len_exp3":false,"vht_su_beamformer":false,"vht_tx_antenna_consistency":false,"he_80":false,"vht_rx_stbc_3":false,"vht_max_ampdu_len_exp7":false,"vht_max_ampdu_len_exp1":false,"he_160":false,"vht_max_ampdu_len_exp5":false,"rx_stbc_3":false,"vht_htc":false,"vht_mpdu_len_11454":false,"vht_max_ampdu_len_exp2":false,"vht_rx_stbc_1":false,"rx_stbc_2":false,"vht_sounding_dimensions_3":false,"max_amsdu_7935":false,"vht_su_beamformee":false,"dsss_cck_40":false,"vht_80_80":false,"vht_160":false,"vht_sounding_dimensions_2":false,"psmp":false,"vht_80":false,"vht_beamformee_sts_3":false,"vht_beamformee_sts_2":false,"supported":false,"greenfield":false,"vht_rx_stbc_2":false,"rx_stbc_1":false,"vht_mu_beamformee":false,"vht_mpdu_len_7991":false,"tx_stbc":false,"shortgi40":false,"vht_mu_beamformer":false,"lsig_txop_prot":false},"2d4g":{"shortgi20":true,"vht_rx_ldpc":false,"vht_sounding_dimensions_1":false,"ldpc":true,"ht_40":true,"smps_dynamic":true,"vht_shortgi80":false,"vht_rx_stbc_4":false,"vht_txops_ps":false,"vht_max_ampdu_len_exp4":false,"vht_max_ampdu_len_exp6":false,"smps_static":false,"vht_rx_antenna_consistency":false,"vht_shortgi160":false,"he_40":false,"vht_tx_stbc":false,"he_supported":false,"vht_ext_nss_bw_3":false,"delayed_ba":false,"ht_20":true,"vht_ext_nss_bw_2":false,"vht_ext_nss_bw_1":false,"vht_beamformee_sts_1":false,"vht_max_ampdu_len_exp3":false,"vht_su_beamformer":false,"vht_tx_antenna_consistency":false,"he_80":false,"vht_rx_stbc_3":false,"vht_max_ampdu_len_exp7":false,"vht_max_ampdu_len_exp1":false,"he_160":false,"vht_max_ampdu_len_exp5":false,"rx_stbc_3":false,"vht_htc":false,"vht_mpdu_len_11454":false,"vht_max_ampdu_len_exp2":false,"vht_rx_stbc_1":false,"rx_stbc_2":false,"vht_sounding_dimensions_3":false,"max_amsdu_7935":true,"vht_su_beamformee":false,"dsss_cck_40":true,"vht_80_80":false,"vht_160":false,"vht_sounding_dimensions_2":false,"psmp":false,"vht_80":false,"vht_beamformee_sts_3":false,"vht_beamformee_sts_2":false,"supported":true,"greenfield":false,"vht_rx_stbc_2":false,"rx_stbc_1":true,"vht_mu_beamformee":false,"vht_mpdu_len_7991":false,"tx_stbc":true,"shortgi40":true,"vht_mu_beamformer":false,"lsig_txop_prot":false},"60g":{"shortgi20":false,"vht_rx_ldpc":false,"vht_sounding_dimensions_1":false,"ldpc":false,"ht_40":false,"smps_dynamic":false,"vht_shortgi80":false,"vht_rx_stbc_4":false,"vht_txops_ps":false,"vht_max_ampdu_len_exp4":false,"vht_max_ampdu_len_exp6":false,"smps_static":false,"vht_rx_antenna_consistency":false,"vht_shortgi160":false,"he_40":false,"vht_tx_stbc":false,"he_supported":false,"vht_ext_nss_bw_3":false,"delayed_ba":false,"ht_20":false,"vht_ext_nss_bw_2":false,"vht_ext_nss_bw_1":false,"vht_beamformee_sts_1":false,"vht_max_ampdu_len_exp3":false,"vht_su_beamformer":false,"vht_tx_antenna_consistency":false,"he_80":false,"vht_rx_stbc_3":false,"vht_max_ampdu_len_exp7":false,"vht_max_ampdu_len_exp1":false,"he_160":false,"vht_max_ampdu_len_exp5":false,"rx_stbc_3":false,"vht_htc":false,"vht_mpdu_len_11454":false,"vht_max_ampdu_len_exp2":false,"vht_rx_stbc_1":false,"rx_stbc_2":false,"vht_sounding_dimensions_3":false,"max_amsdu_7935":false,"vht_su_beamformee":false,"dsss_cck_40":false,"vht_80_80":false,"vht_160":false,"vht_sounding_dimensions_2":false,"psmp":false,"vht_80":false,"vht_beamformee_sts_3":false,"vht_beamformee_sts_2":false,"supported":false,"greenfield":false,"vht_rx_stbc_2":false,"rx_stbc_1":false,"vht_mu_beamformee":false,"vht_mpdu_len_7991":false,"tx_stbc":false,"shortgi40":false,"vht_mu_beamformer":false,"lsig_txop_prot":false}},"name":"2.4G","id":0,"config":{"channel_width":"20","band":"2d4g","ht":{"greenfield":false,"shortgi20":true,"vht_rx_ldpc":false,"ldpc":false,"vht_rx_stbc":"disabled","vht_shortgi80":false,"vht_mu_beamformer":false,"vht_sounding_dimensions":"disabled","ht_enabled":true,"rx_stbc":"1","dsss_cck_40":false,"tx_stbc":true,"ac_enabled":false,"smps":"disabled","vht_shortgi160":false,"vht_beamformee_sts":"disabled","vht_tx_stbc":false,"vht_su_beamformee":false,"vht_su_beamformer":false,"delayed_ba":false,"vht_tx_antenna_consistency":false,"max_amsdu_7935":false,"vht_max_ampdu_len_exp":0,"vht_max_mpdu_len":"default","psmp":false,"shortgi40":true,"vht_rx_antenna_consistency":false,"lsig_txop_prot":false},"dfs_enabled":false,"secondary_channel":0,"he":{"enabled":false,"su_beamformee":false,"twt_responder":false,"su_beamformer":false,"twt_required":false,"mu_beamformer":false},"primary_channel":0},"status":{"channel_width":"20","primary_channel":11,"dfs_disabled":false,"dfs_cac_remaining_time":0,"secondary_channel":0,"state":"active"}},{"capabilities":{"6g":{"shortgi20":false,"vht_rx_ldpc":false,"vht_sounding_dimensions_1":false,"ldpc":false,"ht_40":false,"smps_dynamic":false,"vht_shortgi80":false,"vht_rx_stbc_4":false,"vht_txops_ps":false,"vht_max_ampdu_len_exp4":false,"vht_max_ampdu_len_exp6":false,"smps_static":false,"vht_rx_antenna_consistency":false,"vht_shortgi160":false,"he_40":false,"vht_tx_stbc":false,"he_supported":false,"vht_ext_nss_bw_3":false,"delayed_ba":false,"ht_20":false,"vht_ext_nss_bw_2":false,"vht_ext_nss_bw_1":false,"vht_beamformee_sts_1":false,"vht_max_ampdu_len_exp3":false,"vht_su_beamformer":false,"vht_tx_antenna_consistency":false,"he_80":false,"vht_rx_stbc_3":false,"vht_max_ampdu_len_exp7":false,"vht_max_ampdu_len_exp1":false,"he_160":false,"vht_max_ampdu_len_exp5":false,"rx_stbc_3":false,"vht_htc":false,"vht_mpdu_len_11454":false,"vht_max_ampdu_len_exp2":false,"vht_rx_stbc_1":false,"rx_stbc_2":false,"vht_sounding_dimensions_3":false,"max_amsdu_7935":false,"vht_su_beamformee":false,"dsss_cck_40":false,"vht_80_80":false,"vht_160":false,"vht_sounding_dimensions_2":false,"psmp":false,"vht_80":false,"vht_beamformee_sts_3":false,"vht_beamformee_sts_2":false,"supported":false,"greenfield":false,"vht_rx_stbc_2":false,"rx_stbc_1":false,"vht_mu_beamformee":false,"vht_mpdu_len_7991":false,"tx_stbc":false,"shortgi40":false,"vht_mu_beamformer":false,"lsig_txop_prot":false},"5g":{"shortgi20":true,"vht_rx_ldpc":true,"vht_sounding_dimensions_1":true,"ldpc":true,"ht_40":true,"smps_dynamic":true,"vht_shortgi80":true,"vht_rx_stbc_4":false,"vht_txops_ps":false,"vht_max_ampdu_len_exp4":true,"vht_max_ampdu_len_exp6":true,"smps_static":false,"vht_rx_antenna_consistency":true,"vht_shortgi160":true,"he_40":false,"vht_tx_stbc":true,"he_supported":false,"vht_ext_nss_bw_3":false,"delayed_ba":false,"ht_20":true,"vht_ext_nss_bw_2":true,"vht_ext_nss_bw_1":false,"vht_beamformee_sts_1":true,"vht_max_ampdu_len_exp3":true,"vht_su_beamformer":true,"vht_tx_antenna_consistency":true,"he_80":false,"vht_rx_stbc_3":false,"vht_max_ampdu_len_exp7":true,"vht_max_ampdu_len_exp1":true,"he_160":false,"vht_max_ampdu_len_exp5":true,"rx_stbc_3":false,"vht_htc":false,"vht_mpdu_len_11454":true,"vht_max_ampdu_len_exp2":true,"vht_rx_stbc_1":true,"rx_stbc_2":false,"vht_sounding_dimensions_3":true,"max_amsdu_7935":true,"vht_su_beamformee":true,"dsss_cck_40":true,"vht_80_80":false,"vht_160":false,"vht_sounding_dimensions_2":true,"psmp":false,"vht_80":true,"vht_beamformee_sts_3":true,"vht_beamformee_sts_2":true,"supported":true,"greenfield":false,"vht_rx_stbc_2":false,"rx_stbc_1":true,"vht_mu_beamformee":true,"vht_mpdu_len_7991":true,"tx_stbc":true,"shortgi40":true,"vht_mu_beamformer":true,"lsig_txop_prot":false},"2d4g":{"shortgi20":false,"vht_rx_ldpc":false,"vht_sounding_dimensions_1":false,"ldpc":false,"ht_40":false,"smps_dynamic":false,"vht_shortgi80":false,"vht_rx_stbc_4":false,"vht_txops_ps":false,"vht_max_ampdu_len_exp4":false,"vht_max_ampdu_len_exp6":false,"smps_static":false,"vht_rx_antenna_consistency":false,"vht_shortgi160":false,"he_40":false,"vht_tx_stbc":false,"he_supported":false,"vht_ext_nss_bw_3":false,"delayed_ba":false,"ht_20":false,"vht_ext_nss_bw_2":false,"vht_ext_nss_bw_1":false,"vht_beamformee_sts_1":false,"vht_max_ampdu_len_exp3":false,"vht_su_beamformer":false,"vht_tx_antenna_consistency":false,"he_80":false,"vht_rx_stbc_3":false,"vht_max_ampdu_len_exp7":false,"vht_max_ampdu_len_exp1":false,"he_160":false,"vht_max_ampdu_len_exp5":false,"rx_stbc_3":false,"vht_htc":false,"vht_mpdu_len_11454":false,"vht_max_ampdu_len_exp2":false,"vht_rx_stbc_1":false,"rx_stbc_2":false,"vht_sounding_dimensions_3":false,"max_amsdu_7935":false,"vht_su_beamformee":false,"dsss_cck_40":false,"vht_80_80":false,"vht_160":false,"vht_sounding_dimensions_2":false,"psmp":false,"vht_80":false,"vht_beamformee_sts_3":false,"vht_beamformee_sts_2":false,"supported":false,"greenfield":false,"vht_rx_stbc_2":false,"rx_stbc_1":false,"vht_mu_beamformee":false,"vht_mpdu_len_7991":false,"tx_stbc":false,"shortgi40":false,"vht_mu_beamformer":false,"lsig_txop_prot":false},"60g":{"shortgi20":false,"vht_rx_ldpc":false,"vht_sounding_dimensions_1":false,"ldpc":false,"ht_40":false,"smps_dynamic":false,"vht_shortgi80":false,"vht_rx_stbc_4":false,"vht_txops_ps":false,"vht_max_ampdu_len_exp4":false,"vht_max_ampdu_len_exp6":false,"smps_static":false,"vht_rx_antenna_consistency":false,"vht_shortgi160":false,"he_40":false,"vht_tx_stbc":false,"he_supported":false,"vht_ext_nss_bw_3":false,"delayed_ba":false,"ht_20":false,"vht_ext_nss_bw_2":false,"vht_ext_nss_bw_1":false,"vht_beamformee_sts_1":false,"vht_max_ampdu_len_exp3":false,"vht_su_beamformer":false,"vht_tx_antenna_consistency":false,"he_80":false,"vht_rx_stbc_3":false,"vht_max_ampdu_len_exp7":false,"vht_max_ampdu_len_exp1":false,"he_160":false,"vht_max_ampdu_len_exp5":false,"rx_stbc_3":false,"vht_htc":false,"vht_mpdu_len_11454":false,"vht_max_ampdu_len_exp2":false,"vht_rx_stbc_1":false,"rx_stbc_2":false,"vht_sounding_dimensions_3":false,"max_amsdu_7935":false,"vht_su_beamformee":false,"dsss_cck_40":false,"vht_80_80":false,"vht_160":false,"vht_sounding_dimensions_2":false,"psmp":false,"vht_80":false,"vht_beamformee_sts_3":false,"vht_beamformee_sts_2":false,"supported":false,"greenfield":false,"vht_rx_stbc_2":false,"rx_stbc_1":false,"vht_mu_beamformee":false,"vht_mpdu_len_7991":false,"tx_stbc":false,"shortgi40":false,"vht_mu_beamformer":false,"lsig_txop_prot":false}},"name":"5G1","id":3,"config":{"channel_width":"80","band":"5g","ht":{"greenfield":false,"shortgi20":true,"vht_rx_ldpc":true,"ldpc":true,"vht_rx_stbc":"1","vht_shortgi80":true,"vht_mu_beamformer":true,"vht_sounding_dimensions":"3","ht_enabled":true,"rx_stbc":"1","dsss_cck_40":true,"tx_stbc":true,"ac_enabled":true,"smps":"disabled","vht_shortgi160":true,"vht_beamformee_sts":"3","vht_tx_stbc":true,"vht_su_beamformee":true,"vht_su_beamformer":true,"delayed_ba":false,"vht_tx_antenna_consistency":true,"max_amsdu_7935":false,"vht_max_ampdu_len_exp":7,"vht_max_mpdu_len":"11454","psmp":false,"shortgi40":true,"vht_rx_antenna_consistency":true,"lsig_txop_prot":false},"dfs_enabled":true,"secondary_channel":0,"he":{"enabled":false,"su_beamformee":false,"twt_responder":false,"su_beamformer":false,"twt_required":false,"mu_beamformer":false},"primary_channel":0},"status":{"channel_width":"80","primary_channel":116,"dfs_disabled":false,"dfs_cac_remaining_time":0,"secondary_channel":120,"state":"active"}}]}
[2023-11-12 20:07:20]DEBUG : │──────────> Nom de la carte 5G - Id : 1 - Status : active
[2023-11-12 20:07:20]DEBUG : │ Name : Etat carte Wifi 5G -- Type : info -- LogicalID : 1 -- Template Widget / Ligne : Freebox_OS::Wifi Statut carte/-- Type de générique : -- Inverser : 0 -- Icône : fas fa-wifi icon_blue -- Min/Max : default/default -- Calcul/Arrondi : / -- Ordre : 50
[2023-11-12 20:07:20]DEBUG : │──────────> Nom de la carte 2.4G - Id : 0 - Status : active
[2023-11-12 20:07:20]DEBUG : │ Name : Etat carte Wifi 2.4G -- Type : info -- LogicalID : 0 -- Template Widget / Ligne : Freebox_OS::Wifi Statut carte/-- Type de générique : -- Inverser : 0 -- Icône : fas fa-wifi icon_blue -- Min/Max : default/default -- Calcul/Arrondi : / -- Ordre : 51
[2023-11-12 20:07:20]DEBUG : │──────────> Nom de la carte 5G1 - Id : 3 - Status : active
[2023-11-12 20:07:20]DEBUG : │ Name : Etat carte Wifi 5G1 -- Type : info -- LogicalID : 3 -- Template Widget / Ligne : Freebox_OS::Wifi Statut carte/-- Type de générique : -- Inverser : 0 -- Icône : fas fa-wifi icon_blue -- Min/Max : default/default -- Calcul/Arrondi : / -- Ordre : 52
pour les logs, je vais regarder mais de suite car fin de week-end. Par contre tu as une box avec le wifi 6G ?
Est-il possible de mettre une copie d’écran de la liste des commandes dans le WIFI pour que je puisse comparer par rapport au log
Merci par avance
As-tu eu le temps de jeter un œil ?
Pour l’instant non
J’ai un autre soucis sur un autre plugin mais je ne t oubli pas
Ok pas de problème, je comprends
Hello
je n’ai pas oublié de regarder ton problème, je viens de m’apercevoir qu’il y avait beaucoup trop de différence entre la version stable et beta.
J’ai décidé de mettre a jour la stable avant de regarder ton problème
D’accord, j’ai fait une MAJ du plugin aujourd’hui
Je suis en train de regarder pour arrêter/démarrer une carte Wifi en particulier.
Cela n’est pas possible dans l’API (je n’ai rien vu qui le permet).
je peux redémarrer le point d’accès j’ai vu dans l’API. je n’ai rien trouvé pour faire ce que tu veux
Bonjour et meilleurs vœux,
D’accord, c’est dommage mais tant pis !
Merci d’avoir regardé.
