tout est au vert côté homebridge, cependant, j’essaie d’ajouter un poele à pellet sur HB.
au démarrage l’équipement est détecté :
[2024-12-30T07:33:45.509Z] [DEBUG] eqLogic > {"id":"697","name":"Artemis","logicalId":"","generic_type":null,"object_id":"2","eqType_name":"jee4heat","isVisible":1,"isEnable":1,"order":"1","comment":"","tags":null,"status":{"lastCommunication":"2024-12-30 08:33:02","timeout":0,"enableDatime":"2024-05-31 07:53:44","warning":0,"danger":0},"pseudo":"","sendToHomebridge":1,"thermoModes":{"Chauf":"5695|ON","Clim":"NOT","Off":"5696|OFF"},"services":{"thermostat":[{"mode":{"id":"7197","logicalId":"jee4heat_auto","generic_type":"THERMOSTAT_MODE","eqType":"jee4heat","name":"Auto","order":"0","type":"action","subType":"other","eqLogic_id":"697","value":null,"isVisible":0}},{"state_name":{"id":"5670","logicalId":"jee4heat_30001","generic_type":"THERMOSTAT_STATE_NAME","eqType":"jee4heat","name":"Etat equipement","order":"2","type":"info","subType":"numeric","eqLogic_id":"697","isVisible":1,"currentValue":5,"display":{"invertBinary":0},"configuration":{"phpType":"double"}}},{"setpoint":{"id":"5676","logicalId":"jee4heat_50138","generic_type":"THERMOSTAT_SETPOINT","eqType":"jee4heat","name":"Thermostat Consigne","order":"3","type":"info","subType":"numeric","eqLogic_id":"697","unite":"°C","isVisible":1,"currentValue":19,"configuration":{"maxValue":25,"minValue":15,"phpType":"double"},"display":{"invertBinary":0}}},{"temperature":{"id":"5675","logicalId":"jee4heat_50006","generic_type":"THERMOSTAT_TEMPERATURE","eqType":"jee4heat","name":"Température ambiante","order":"4","type":"info","subType":"numeric","eqLogic_id":"697","unite":"°C","isVisible":1,"currentValue":17.7,"display":{"invertBinary":0},"configuration":{"phpType":"double"}}},{"set_mode":{"id":"5695","logicalId":"jee4heat_on","generic_type":"THERMOSTAT_SET_MODE","eqType":"jee4heat","name":"ON","order":"5","type":"action","subType":"other","eqLogic_id":"697","value":"5692","isVisible":1,"display":{"invertBinary":0}}},{"set_mode":{"id":"5696","logicalId":"jee4heat_off","generic_type":"THERMOSTAT_SET_MODE","eqType":"jee4heat","name":"OFF","order":"6","type":"action","subType":"other","eqLogic_id":"697","value":"5692","isVisible":1,"display":{"invertBinary":0}}},{"set_setpoint":{"id":"5701","logicalId":"jee4heat_slider","generic_type":"THERMOSTAT_SET_SETPOINT","eqType":"jee4heat","name":"Régler consigne","order":"7","type":"action","subType":"slider","eqLogic_id":"697","value":"5676","isVisible":1,"configuration":{"maxValue":25,"minValue":10},"display":{"invertBinary":0}}},{"state":{"id":"5692","logicalId":"jee4heat_stovestate","generic_type":"THERMOSTAT_STATE","eqType":"jee4heat","name":"Etat","order":"9","type":"info","subType":"binary","eqLogic_id":"697","isVisible":1,"currentValue":1,"display":{"invertBinary":0},"configuration":{"phpType":"integer"}}},{"mode":{"id":"7196","logicalId":"jee4heat_mode","generic_type":"THERMOSTAT_MODE","eqType":"jee4heat","name":"Mode","order":"25","type":"info","subType":"string","eqLogic_id":"697","isVisible":0,"currentValue":"heat","configuration":{"phpType":"string"}}}]},"numSwitches":0,"numDetector":0}
[2024-12-30T07:33:45.509Z] ┌──── Bureau > Artemis (697)
[2024-12-30T07:33:45.510Z] | [WARNING] Pas de config du mode Climatisation
[2024-12-30T07:33:45.510Z] | [DEBUG] Vérification d'existance de l'accessoire dans le cache Homebridge...
[2024-12-30T07:33:45.510Z] | [DEBUG] Accessoire déjà existant dans le cache Homebridge
[2024-12-30T07:33:45.522Z] | [DEBUG] Suppression service :Artemis subtype:697-5676- UUID:0000004A-0000-1000-8000-0026BB765291
[2024-12-30T07:33:45.522Z] | [DEBUG] Caractéristique :Name valeur cache:Artemis
[2024-12-30T07:33:45.522Z] | [DEBUG] Caractéristique :Current Heating Cooling State valeur cache:0
[2024-12-30T07:33:45.522Z] | [DEBUG] Caractéristique :Target Heating Cooling State valeur cache:0
[2024-12-30T07:33:45.522Z] | [DEBUG] Caractéristique :Current Temperature valeur cache:17.700000000000003
[2024-12-30T07:33:45.522Z] | [DEBUG] Caractéristique :Target Temperature valeur cache:19
[2024-12-30T07:33:45.522Z] | [DEBUG] Caractéristique :Temperature Display Units valeur cache:0
[2024-12-30T07:33:45.523Z] | [DEBUG] Ajout service :Artemis subtype:697-5676- cmd_id:5676 UUID:0000004A-0000-1000-8000-0026BB765291
[2024-12-30T07:33:45.523Z] | [DEBUG] Caractéristique :Current Temperature valeur initiale:17.69999999999999
[2024-12-30T07:33:45.523Z] | [DEBUG] Caractéristique :Target Temperature valeur initiale:19
[2024-12-30T07:33:45.523Z] | [DEBUG] Caractéristique :Current Heating Cooling State valeur initiale:0
[2024-12-30T07:33:45.523Z] | [DEBUG] Caractéristique :Target Heating Cooling State valeur initiale:0
[2024-12-30T07:33:45.523Z] | [DEBUG] Caractéristique :Temperature Display Units valeur initiale:0
[2024-12-30T07:33:45.523Z] │ OK : Mise à jour de l'accessoire (Artemis)
[2024-12-30T07:33:45.533Z] └─────────
du côté des logs j’ai un message d’erreur récurrent à chaque changement d’état du poele :
[12/30/2024, 8:33:46 AM] [pdv] [DEBUG] ----Current State Thermo : 5
[12/30/2024, 8:33:46 AM] [pdv] [INFO] [Demande d'Homekit] Nom:Artemis>Current Heating Cooling State=0 (0) |||characteristic:{"_events":{},"_eventsCount":3,"iid":10,"value":0,"status":null,"statusCode":0,"subscriptions":0,"displayName":"Current Heating Cooling State","UUID":"0000000F-0000-1000-8000-0026BB765291","props":{"format":"uint8","perms":["ev","pr"],"minValue":0,"maxValue":2,"minStep":1,"validValues":[0,1,2],"needsBinding":true}}
[12/30/2024, 8:33:46 AM] [pdv] [ERROR] Erreur de la fonction getAccessoryValue : TypeError: Cannot read properties of undefined (reading 'toString')
at JeedomPlatform.getAccessoryValue (/var/www/html/plugins/homebridge/resources/node_modules/homebridge-jeedom/index.js:4446:83)
at TargetHeatingCoolingState.<anonymous> (/var/www/html/plugins/homebridge/resources/node_modules/homebridge-jeedom/index.js:3083:27)
at TargetHeatingCoolingState.emit (node:events:518:28)
at /var/www/html/plugins/homebridge/resources/node_modules/hap-nodejs/src/lib/Characteristic.ts:2468:14
at new Promise (<anonymous>)
at TargetHeatingCoolingState.<anonymous> (/var/www/html/plugins/homebridge/resources/node_modules/hap-nodejs/src/lib/Characteristic.ts:2466:12)
at step (/var/www/html/plugins/homebridge/resources/node_modules/tslib/tslib.js:196:27)
at Object.next (/var/www/html/plugins/homebridge/resources/node_modules/tslib/tslib.js:177:57)
at /var/www/html/plugins/homebridge/resources/node_modules/tslib/tslib.js:170:75
[12/30/2024, 8:33:46 AM] [@nebz/homebridge-jeedom] This plugin generated a warning from the characteristic 'Target Heating Cooling State': characteristic value expected valid finite number and received "undefined" (undefined). See https://homebridge.io/w/JtMGR for more info.
[12/30/2024, 8:33:46 AM] [pdv] [INFO] [Demande d'Homekit] Nom:Artemis>Current Temperature=17.69999999999999 (17.7) |||characteristic:{"_events":{},"_eventsCount":3,"iid":12,"value":17.69999999999999,"status":null,"statusCode":0,"subscriptions":0,"displayName":"Current Temperature","UUID":"00000011-0000-1000-8000-0026BB765291","props":{"format":"float","perms":["ev","pr"],"unit":"celsius","minValue":-50,"maxValue":300,"minStep":0.01,"needsBinding":true}}
[12/30/2024, 8:33:46 AM] [pdv] [INFO] [Demande d'Homekit] Nom:Artemis>Target Temperature=19 (19) |||characteristic:{"_events":{},"_eventsCount":4,"iid":13,"value":19,"status":null,"statusCode":0,"subscriptions":0,"displayName":"Target Temperature","UUID":"00000035-0000-1000-8000-0026BB765291","props":{"format":"float","perms":["ev","pr","pw"],"unit":"celsius","minValue":10,"maxValue":25,"minStep":0.1,"needsBinding":true}}
[12/30/2024, 8:33:46 AM] [pdv] [INFO] [Demande d'Homekit] Nom:Artemis>Temperature Display Units=0 (0) |||characteristic:{"_events":{},"_eventsCount":4,"iid":14,"value":0,"status":null,"statusCode":0,"subscriptions":0,"displayName":"Temperature Display Units","UUID":"00000036-0000-1000-8000-0026BB765291","props":{"format":"uint8","perms":["ev","pr","pw"],"minValue":0,"maxValue":1,"minStep":1,"validValues":[0,1],"needsBinding":true}}
[12/30/2024, 8:34:14 AM] [pdv] [INFO] [Maj reçue de Jeedom] commande:5692 value:1
[12/30/2024, 8:34:14 AM] [pdv] [INFO] [[Modification Cache Jeedom: Artemis>Etat(THERMOSTAT_STATE) de 1 vers 1 dans {"id":"5692","logicalId":"jee4heat_stovestate","generic_type":"THERMOSTAT_STATE","eqType":"jee4heat","name":"Etat","order":"9","type":"info","subType":"binary","eqLogic_id":"697","isVisible":1,"currentValue":1,"display":{"invertBinary":0},"configuration":{"phpType":"integer"}}
[12/30/2024, 8:34:14 AM] [pdv] [INFO] [Commande envoyée à HomeKit] Cause de modif: "Etat" (5692) Envoi valeur:17.7 dans Current Temperature
[12/30/2024, 8:34:14 AM] [pdv] [INFO] [Commande envoyée à HomeKit] Cause de modif: "Etat" (5692) Envoi valeur:19 dans Target Temperature
[12/30/2024, 8:34:14 AM] [pdv] [DEBUG] ----Current State Thermo : 5
[12/30/2024, 8:34:14 AM] [pdv] [INFO] [Commande envoyée à HomeKit] Cause de modif: "Etat" (5692) Envoi valeur:0 dans Current Heating Cooling State
[12/30/2024, 8:34:14 AM] [pdv] [ERROR] Erreur de la fonction getAccessoryValue : TypeError: Cannot read properties of undefined (reading 'toString')
at JeedomPlatform.updateSubscribers (/var/www/html/plugins/homebridge/resources/node_modules/homebridge-jeedom/index.js:5740:27)
at /var/www/html/plugins/homebridge/resources/node_modules/homebridge-jeedom/index.js:5686:12
at Array.map (<anonymous>)
at /var/www/html/plugins/homebridge/resources/node_modules/homebridge-jeedom/index.js:5680:19
at processTicksAndRejections (node:internal/process/task_queues:95:5)
[12/30/2024, 8:34:14 AM] [pdv] [INFO] [Maj reçue de Jeedom] commande:5670 value:5
[12/30/2024, 8:34:14 AM] [pdv] [INFO] [[Modification Cache Jeedom: Artemis>Etat equipement(THERMOSTAT_STATE_NAME) de 5 vers 5 dans {"id":"5670","logicalId":"jee4heat_30001","generic_type":"THERMOSTAT_STATE_NAME","eqType":"jee4heat","name":"Etat equipement","order":"2","type":"info","subType":"numeric","eqLogic_id":"697","isVisible":1,"currentValue":5,"display":{"invertBinary":0},"configuration":{"phpType":"double"}}
[12/30/2024, 8:34:14 AM] [pdv] [INFO] [Commande envoyée à HomeKit] Cause de modif: "Etat equipement" (5670) Envoi valeur:17.7 dans Current Temperature
[12/30/2024, 8:34:14 AM] [pdv] [INFO] [Commande envoyée à HomeKit] Cause de modif: "Etat equipement" (5670) Envoi valeur:19 dans Target Temperature
[12/30/2024, 8:34:14 AM] [pdv] [INFO] [Commande envoyée à HomeKit] Cause de modif: "Etat equipement" (5670) Envoi valeur:0 dans Current Heating Cooling State
[12/30/2024, 8:34:14 AM] [pdv] [INFO] [Maj reçue de Jeedom] commande:5675 value:17.7
[12/30/2024, 8:34:14 AM] [pdv] [INFO] [[Modification Cache Jeedom: Artemis>Température ambiante(THERMOSTAT_TEMPERATURE) de 17.7 vers 17.7 dans {"id":"5675","logicalId":"jee4heat_50006","generic_type":"THERMOSTAT_TEMPERATURE","eqType":"jee4heat","name":"Température ambiante","order":"4","type":"info","subType":"numeric","eqLogic_id":"697","unite":"°C","isVisible":1,"currentValue":17.7,"display":{"invertBinary":0},"configuration":{"phpType":"double"}}
[12/30/2024, 8:34:14 AM] [pdv] [INFO] [Commande envoyée à HomeKit] Cause de modif: "Température ambiante" (5675) Envoi valeur:17.7 dans Current Temperature
[12/30/2024, 8:34:14 AM] [pdv] [INFO] [Commande envoyée à HomeKit] Cause de modif: "Température ambiante" (5675) Envoi valeur:19 dans Target Temperature
[12/30/2024, 8:34:14 AM] [pdv] [INFO] [Commande envoyée à HomeKit] Cause de modif: "Température ambiante" (5675) Envoi valeur:0 dans Current Heating Cooling State
[12/30/2024, 8:34:14 AM] [pdv] [INFO] [Maj reçue de Jeedom] commande:5676 value:19
[12/30/2024, 8:34:14 AM] [pdv] [INFO] [[Modification Cache Jeedom: Artemis>Thermostat Consigne(THERMOSTAT_SETPOINT) de 19 vers 19 dans {"id":"5676","logicalId":"jee4heat_50138","generic_type":"THERMOSTAT_SETPOINT","eqType":"jee4heat","name":"Thermostat Consigne","order":"3","type":"info","subType":"numeric","eqLogic_id":"697","unite":"°C","isVisible":1,"currentValue":19,"configuration":{"maxValue":25,"minValue":15,"phpType":"double"},"display":{"invertBinary":0}}
[12/30/2024, 8:34:14 AM] [pdv] [INFO] [Commande envoyée à HomeKit] Cause de modif: "Thermostat Consigne" (5676) Envoi valeur:17.7 dans Current Temperature
[12/30/2024, 8:34:14 AM] [pdv] [INFO] [Commande envoyée à HomeKit] Cause de modif: "Thermostat Consigne" (5676) Envoi valeur:19 dans Target Temperature
[12/30/2024, 8:34:14 AM] [pdv] [INFO] [Commande envoyée à HomeKit] Cause de modif: "Thermostat Consigne" (5676) Envoi valeur:0 dans Current Heating Cooling State
[12/30/2024, 8:34:14 AM] [pdv] [INFO] [Maj reçue de Jeedom] commande:5799 value:17.9
[12/30/2024, 8:34:14 AM] [pdv] [INFO] [[Modification Cache Jeedom: VITOCAL 200S>Température(THERMOSTAT_TEMPERATURE) de 18 vers 17.9 dans {"id":"5799","logicalId":"","generic_type":"THERMOSTAT_TEMPERATURE","eqType":"virtual","name":"Température","order":"0","type":"info","subType":"numeric","eqLogic_id":"701","unite":"°C","value":"6904","isVisible":1,"currentValue":18,"display":{"invertBinary":0},"configuration":{"phpType":"double"}}
[12/30/2024, 8:34:14 AM] [pdv] [INFO] [Commande envoyée à HomeKit] Cause de modif: "Température" (5799) Envoi valeur:17.9 dans Current Temperature
[12/30/2024, 8:34:14 AM] [pdv] [INFO] [Commande envoyée à HomeKit] Cause de modif: "Température" (5799) Envoi valeur:16 dans Target Temperature
[12/30/2024, 8:34:14 AM] [pdv] [INFO] [Commande envoyée à HomeKit] Cause de modif: "Température" (5799) Envoi valeur:0 dans Current Heating Cooling State
[12/30/2024, 8:34:14 AM] [pdv] [DEBUG] TargetThermo : undefined chauffage :
[12/30/2024, 8:34:14 AM] [pdv] [INFO] [Commande envoyée à HomeKit] Cause de modif: "Température" (5799) Envoi valeur:3 dans Target Heating Cooling State
[12/30/2024, 8:34:14 AM] [pdv] [INFO] [Commande envoyée à HomeKit] Cause de modif: "Température" (5799) Envoi valeur:0 dans Temperature Display Units
il doit me manquer quelque chose quelque part et je ne vois pas trop où est l’erreur. a noter que côt jeedom le poele fonctionne bien :
mais l’état n’est pas bien reporté sur HB :
il voir bien la t) actuelle et le réglage de consigne, mais pas l’état on/off. j’ai du louper quelque chose ![]()
