Intégration module temp + humidité du sol TZE200_myd45weu.TS0601
J’ai fait l’acquisition d’un de ces modules Tuya Zigbee Wireless Soil Moisture Meter Temperature Humidity Tester Plant Monitor IP67 Waterproof Detector for Garden Planting
Il est détecté mais non reconnu, voici le contenu des infos brutes :
    "ieee": "a4:c1:38:a4:6a:b0:23:8e",
    "nwk": 58662,
    "status": 2,
    "lqi": "184",
    "rssi": "-54",
    "last_seen": "1669207660.656588",
    "node_descriptor": "02:40:80:41:11:42:42:00:00:2a:42:00:00",
    "endpoints": [
            "id": 1,
            "status": 1,
            "device_type": 81,
            "profile_id": 260,
            "manufacturer": "_TZE200_myd45weu",
            "model": "TS0601",
            "output_clusters": [
                    "id": 25,
                    "name": "Ota",
                    "attributes": []
                    "id": 10,
                    "name": "Time",
                    "attributes": []
            "input_clusters": [
                    "id": 4,
                    "name": "Groups",
                    "attributes": []
                    "id": 5,
                    "name": "Scenes",
                    "attributes": []
                    "id": 61184,
                    "name": "Cluster",
                    "attributes": []
                    "id": 0,
                    "name": "Basic",
                    "attributes": [
                            "id": 0,
                            "name": "zcl_version",
                            "value": 3
                            "id": 1,
                            "name": "app_version",
                            "value": 72
                            "id": 2,
                            "name": "stack_version",
                            "value": 0
                            "id": 3,
                            "name": "hw_version",
                            "value": 1
                            "id": 4,
                            "name": "manufacturer",
                            "value": "_TZE200_myd45weu"
                            "id": 5,
                            "name": "model",
                            "value": "TS0601"
                            "id": 6,
                            "name": "date_code",
                            "value": ""
                            "id": 7,
                            "name": "power_source",
                            "value": 3
    "signature": {
        "model": "TS0601",
        "node_desc": {
            "logical_type": 2,
            "reserved": 0,
            "aps_flags": 0,
            "frequency_band": 8,
            "mac_capability_flags": 128,
            "manufacturer_code": 4417,
            "maximum_buffer_size": 66,
            "maximum_incoming_transfer_size": 66,
            "server_mask": 10752,
            "maximum_outgoing_transfer_size": 66,
        "endpoints": {
            "1": {
                "profile_id": 260,
                "device_type": 81,
                "input_clusters": [
                    4,
                    5,
                    61184,
                    0
                    25,
                    10
    "class": "zigpy.device"
Je n’ai plus accès ces jours à ce produit, j’attends une seconde livraison pour fournir le log si nécessaire.
salut
Depuis ce post,es tu en mesure d’utiliser cette sonde sur jeedom ?
car celle ci m’intéresse beaucoup ayant déjà un bon maillage zigbee
Je pense qu’il n’est toujours pas reconnu par Jeedom. Je le vois dans Jeedom via WifilightV2.
Par contre, j’ai des gros doutes sur les mesures. J’ai 2 capteurs, plantés à touche touche dans un pot de fleur, ils devraient remonter des valeurs très proches, ce n’est pas le cas. Idem, je les ai faits tremper dans de l’eau, je pensais qu’ils allaient de donner une humidité de 100%… Ben non :frowning:
Avez vous réussi à l 'intégrer dans Jeedom ou passez vous par une passerelle Tuya ?
Pour ma part pas de remontée dans Jeedom.
Bonne soirée
Je les ai dans Jeedom via le plugin Jeezigbee. En effet, ces équipements sont reconnus par Zigbee2Mqtt , ils remontent donc dans le nouveau plugin Zigbee (tjrs en beta).
Par contre, un gros bémol sur la fiabilité du produit.
J’en ai 2, je les ai positionnés côte à côte dans une jardinière pour les tester et j’ai eu des mesures différentes. Et maintenant qu’ils sont en place, j’en ai qui pense qu’il est sur un terrain volcanique :frowning: , il doit un peu transpirer.
Bonjour @JC38 ,
Merci pour votre réponse, j’ai une conbee2 et pas mal d’équipements sur le plugin Zigbee.
Savez-vous si on peut utiliser le même contrôleur pour les deux plugin ?
Bonne journée
Une clé ne peut être utilisée que part un seul plugin à la fois.
Merci pour votre réponse, je vais attendre alors…
Le plugin zigbee n’est pas la priorité actuelle, vous risquez d’attendre longtemps. Et au final vous passerez tout de même sur jeezigbee ou zigbeelinker, amha.
Je vais attendre que le plugin passe en stable, comme j’ai déjà prévu de passer du plugin Z-Wave à Z-waveJS au mois de mai, cela va me permettre de me faire la main, j’ai pas mal d’équipements en Zigbee, donc on va essayer de prioriser :slight_smile: cela va faire de l’occupation pour les mauvais jours de fin d’année :slight_smile:
Je fais un petit retour, dans un premier temps j’ai essayé avec Jeezigbee, les infos remontent bien, cependant je suis revenu au plugin zigbee, car Z2m est trop instable chez moi, et impossible de redémarrer Z2m lors d’un redémarrage de ma machine.
Donc j’ai essayé avec une passerelle tuya et WifilightV2, ça fonctionne bien, le taux d’humidité semble cohérent (je compare avec un detecteur non connecté).
Pour la température j’ai plus de doutes, la température est de 18 C dans la journée et 16 C la nuit. Le capteur est au sol, je vais historiser un autre thermomètre afin de me faire une Idée.
Pour info, j’ai 2 modules de ce type, achetés séparément chez 2 vendeurs différents.
Les remontées via Zigbee2mqtt étant fantaisistes (temp proches de 100°C) , je les ai repassés sous l’appli Tuya. Résultat, 1 temp à -30° C et l’autre à 54°C.
En plus, j’ai l’impression que les piles sont consommées à la vitesse grand V et que pour des capteurs, ils sont hyper bavards sur le réseau.
Je conseille donc la plus grande prudence aux éventuels acquéreurs :frowning_face:
