Intégration capteur température tuya
Je viens d’acquérir ce module tuya de température, il est détecté, mais non reconnu par jeedom.
Pouvez-vous l’ajouter svp
Modèle TH01Z white
€ 8,60 65%de réduction | Capteur de température et d’humidité intelligent Tuya Zigbee, écran LCD, affichage numérique, sans fil, Therye.com, fonctionne avec Alexa, Google
https://a.aliexpress.com/_EQCMGhb
    "ieee": "a4:c1:38:07:47:d7:8e:b6",
    "nwk": 23884,
    "status": 2,
    "lqi": "160",
    "rssi": "-60",
    "last_seen": "1684134093.264973",
    "node_descriptor": "02:40:80:41:11:42:42:00:00:2a:42:00:00",
    "endpoints": [
            "id": 1,
            "status": 1,
            "device_type": 81,
            "profile_id": 260,
            "manufacturer": "_TZE200_locansqn",
            "model": "TS0601",
            "output_clusters": [
                    "id": 25,
                    "name": "Ota",
                    "attributes": []
                    "id": 10,
                    "name": "Time",
                    "attributes": []
            "input_clusters": [
                    "id": 4,
                    "name": "Groups",
                    "attributes": []
                    "id": 5,
                    "name": "Scenes",
                    "attributes": []
                    "id": 61184,
                    "name": "Cluster",
                    "attributes": []
                    "id": 0,
                    "name": "Basic",
                    "attributes": [
                            "id": 0,
                            "name": "zcl_version",
                            "value": 3
                            "id": 1,
                            "name": "app_version",
                            "value": 72
                            "id": 2,
                            "name": "stack_version",
                            "value": 0
                            "id": 3,
                            "name": "hw_version",
                            "value": 1
                            "id": 4,
                            "name": "manufacturer",
                            "value": "_TZE200_locansqn"
                            "id": 5,
                            "name": "model",
                            "value": "TS0601"
                            "id": 6,
                            "name": "date_code",
                            "value": ""
                            "id": 7,
                            "name": "power_source",
                            "value": 3
    "signature": {
        "model": "TS0601",
        "node_desc": {
            "logical_type": 2,
            "reserved": 0,
            "aps_flags": 0,
            "frequency_band": 8,
            "mac_capability_flags": 128,
            "manufacturer_code": 4417,
            "maximum_buffer_size": 66,
            "maximum_incoming_transfer_size": 66,
            "server_mask": 10752,
            "maximum_outgoing_transfer_size": 66,
        "endpoints": {
            "1": {
                "profile_id": 260,
                "device_type": 81,
                "input_clusters": [
                    4,
                    5,
                    61184,
                    0
                    25,
                    10
    "class": "zigpy.device"
Pour info, il est pris en charge par Zigbee2MQTT
Par contre, dans la description il n’est pas indiqué la précision des mesures. As tu d’autres capteurs style AQARA pour pouvoir comparer ?
Je suis intéressé par un retour d’expérience !
Voir ce post qui peut être ici intéressant.
en claire jeedom n’a plus le temps pour intégrer de nouveaux modules…
Ce n’est pas très encourageant
Il faut passer à jeezigbee.
Le problème j’utilise le plugin officiel, il faut payer et tout reinclure pas tres motivé
J’utilise le plugin officiel
Pas top surtout quand on a payé un pack, de pire en pire jeedom
Ou passer à Zigbee2MQTT !
Jeezigbee est le future plugin offici. Je ne sais pas comment faire mais si tu as le plugin zigbee, tu n’aurais pas à payer jeezigbee.
Je vois souvent jeezigbee, mais dans le market il n’existe pas, sauf erreur de ma part. Est il opérationnel ou en projet ou en beta ?
Il faut autoriser les versions bêta.
Zigbeelinker a la même base.
Je vois !!
Je viens de l’installer avec mqtt manager, je savais pas qu’il y avait un nouveau plugin, par contre peut on ajouter la sauvegarde du plug-in zigbee officiel, poir éviter de tout reinclure ? Merci
Non, c’est un des défauts du zigbee.
