Bonjour, je viens d’essayer par trois fois d’installer jeedom sur mon SSD plugé sur un Raspi3, et le processus se bloque toujours au même endroit (voir log joint)
Err:1 http://raspbian.raspberrypi.org/raspbian buster/main armhf mariadb-common all 1:10.3.22-0+deb10u1
404 Not Found [IP: 93.93.128.193 80]
Err:2 http://raspbian.raspberrypi.org/raspbian buster/main armhf libdbi-perl armhf 1.642-1+b1
Err:3 http://raspbian.raspberrypi.org/raspbian buster/main armhf mariadb-client-core-10.3 armhf 1:10.3.22-0+deb10u1
Err:4 http://raspbian.raspberrypi.org/raspbian buster/main armhf mariadb-client-10.3 armhf 1:10.3.22-0+deb10u1
Err:5 http://raspbian.raspberrypi.org/raspbian buster/main armhf mariadb-server-core-10.3 armhf 1:10.3.22-0+deb10u1
Err:6 http://raspbian.raspberrypi.org/raspbian buster/main armhf mariadb-server-10.3 armhf 1:10.3.22-0+deb10u1
Err:7 http://raspbian.raspberrypi.org/raspbian buster/main armhf libmariadb3 armhf 1:10.3.22-0+deb10u1
Err:8 http://raspbian.raspberrypi.org/raspbian buster/main armhf mariadb-client all 1:10.3.22-0+deb10u1
Err:9 http://raspbian.raspberrypi.org/raspbian buster/main armhf mariadb-server all 1:10.3.22-0+deb10u1
E: Failed to fetch http://raspbian.raspberrypi.org/raspbian/pool/main/m/mariadb-10.3/mariadb-common_10.3.22-0+deb10u1_all.deb 404 Not Found [IP: 93.93.128.193 80]
E: Failed to fetch http://raspbian.raspberrypi.org/raspbian/pool/main/libd/libdbi-perl/libdbi-perl_1.642-1+b1_armhf.deb 404 Not Found [IP: 93.93.128.193 80]
E: Failed to fetch http://raspbian.raspberrypi.org/raspbian/pool/main/m/mariadb-10.3/mariadb-client-core-10.3_10.3.22-0+deb10u1_armhf.deb 404 Not Found [IP: 93.93.128.193 80]
E: Failed to fetch http://raspbian.raspberrypi.org/raspbian/pool/main/m/mariadb-10.3/mariadb-client-10.3_10.3.22-0+deb10u1_armhf.deb 404 Not Found [IP: 93.93.128.193 80]
E: Failed to fetch http://raspbian.raspberrypi.org/raspbian/pool/main/m/mariadb-10.3/mariadb-server-core-10.3_10.3.22-0+deb10u1_armhf.deb 404 Not Found [IP: 93.93.128.193 80]
E: Failed to fetch http://raspbian.raspberrypi.org/raspbian/pool/main/m/mariadb-10.3/mariadb-server-10.3_10.3.22-0+deb10u1_armhf.deb 404 Not Found [IP: 93.93.128.193 80]
E: Failed to fetch http://raspbian.raspberrypi.org/raspbian/pool/main/m/mariadb-10.3/libmariadb3_10.3.22-0+deb10u1_armhf.deb 404 Not Found [IP: 93.93.128.193 80]
E: Failed to fetch http://raspbian.raspberrypi.org/raspbian/pool/main/m/mariadb-10.3/mariadb-client_10.3.22-0+deb10u1_all.deb 404 Not Found [IP: 93.93.128.193 80]
E: Failed to fetch http://raspbian.raspberrypi.org/raspbian/pool/main/m/mariadb-10.3/mariadb-server_10.3.22-0+deb10u1_all.deb 404 Not Found [IP: 93.93.128.193 80]
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
\033[1;31mNe peut installer mariadb-client mariadb-common mariadb-server - Annulation\033[0;39m
Comment passer au travers de ce problème ?
Merci d’avance
