Je suis en version 7 sur enphase
Je tente d’installer le module mais impossible de créer une connexion
L’installation des dépendances est OK mais je trouve des warmings
avez vous une idée ? merci
* Installation des dépendances *
Hit:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
Hit:2 http://archive.raspberrypi.org/debian buster InRelease
Hit:3 https://deb.nodesource.com/node_16.x buster InRelease
Reading package lists...
Building dependency tree...
Reading state information...
python3 is already the newest version (3.7.3-1).
0 upgraded, 0 newly installed, 0 to remove and 120 not upgraded.
python3-pip is already the newest version (18.1-5+rpt1).
Requirement already satisfied: pip in /usr/local/lib/python3.7/dist-packages (23.1.2)
WARNING: Running pip as the 'root' user can result in broken permissions and conflicting behaviour with the system package manager. It is recommended to use a virtual environment instead: https://pip.pypa.io/warnings/venv
WARNING: Skipping serial as it is not installed.
Package 'python3-serial' is not installed, so not removed
python3-setuptools is already the newest version (40.8.0-1).
python3-pyudev is already the newest version (0.21.0-1).
python3-requests is already the newest version (2.21.0-1+deb10u1).
Collecting pyjwt
Using cached PyJWT-2.7.0-py3-none-any.whl (22 kB)
Collecting html5lib
Using cached html5lib-1.1-py2.py3-none-any.whl (112 kB)
Collecting asyncio
Using cached asyncio-3.4.3-py3-none-any.whl (101 kB)
Collecting httpx
Using cached httpx-0.24.1-py3-none-any.whl (75 kB)
Collecting lxml
Using cached lxml-4.9.3.tar.gz (3.6 MB)
Preparing metadata (setup.py): started
Preparing metadata (setup.py): finished with status 'error'
error: subprocess-exited-with-error
× python setup.py egg_info did not run successfully.
│ exit code: 1
╰─> [3 lines of output]
Building lxml version 4.9.3.
Building without Cython.
Error: Please make sure the libxml2 and libxslt development packages are installed.
[end of output]
note: This error originates from a subprocess, and is likely not a problem with pip.
error: metadata-generation-failed
× Encountered error while generating package metadata.
╰─> See above for output.
note: This is an issue with the package mentioned above, not pip.
hint: See above for details.
Collecting pyserial
Using cached pyserial-3.5-py2.py3-none-any.whl (90 kB)
Installing collected packages: pyserial
Successfully installed pyserial-3.5
Requirement already satisfied: six in /usr/local/lib/python3.7/dist-packages (1.16.0)
* Installation des dépendances OK *
