Bonjour @nebz , je n’arrive pas a faire fonctionner le plugin. L’installation échoue. Voici les logs :
== Jeedom 4.4.3 sur Raspbian GNU/Linux 11 (bullseye)/armhf/aarch64/32bits aka 'RPI 4 B' avec nodeJS v18.17.1 et jsonrpc:enable et aTVremote (beta) 2024-04-16 01:15:52 (avant:beta/2024-04-12 01:15:55)
== 16/04/2024 18:31:08 == Installation des dépendances de aTVremote
[ 0% ] : Vérification des droits...
[ 4% ] : Vérification des droits : [0sec] : [ OK ]
[ 5% ] : Mise à jour APT et installation des packages nécessaires...
[ 99% ] : Mise à jour APT et installation des packages nécessaires : [11sec] : ERROR
[100% ] : Terminé !
== KO == Erreur d'Installation [11sec]
== ANALYSE DES ERREURS...
== AUCUNE ERREUR CONNUE DÉTECTÉE
== Erreur à l'étape : Mise à jour APT et installation des packages nécessaires
== Ligne 220
== La commande `apt-get install -y python3 python3-pip python3-dev python3-venv' pose problème
== Le code de retour est 100
== Le message d'erreur :
Reading package lists...
Building dependency tree...
Reading state information...
python3 is already the newest version (3.9.2-3).
python3-dev is already the newest version (3.9.2-3).
python3-venv is already the newest version (3.9.2-3).
python3-pip is already the newest version (20.3.4-4+rpt1+deb11u1).
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
2 not fully installed or removed.
Need to get 0 B/51.4 kB of archives.
After this operation, 0 B of additional disk space will be used.
dpkg: error processing package libpopt-dev:armhf (--configure):
package is in a very bad inconsistent state; you should
reinstall it before attempting configuration
dpkg: dependency problems prevent configuration of librsync-dev:
librsync-dev depends on libpopt-dev; however:
Package libpopt-dev:armhf is not configured yet.
dpkg: error processing package librsync-dev (--configure):
dependency problems - leaving unconfigured
Errors were encountered while processing:
libpopt-dev:armhf
librsync-dev
E: Sub-process /usr/bin/dpkg returned an error code (1)
Informations Jeedom
Core : 4.4.3 (V4-stable)
DNS Jeedom : oui
Plugin : aTV Remote
Version : 2024-04-16 01:15:52 (beta)
Statut Démon : Stoppé - (Inconnue)
Si il y a une solution je suis preneur ![]()
