Merci à @Aldarande pour ce plugin.
Je n’arrive pas à installer les dépendances.
Ci-dessous la page santé et les logs.
Log ProJote_packages (Debug)
+ touch /tmp/jeedom_install_in_progress_ProJote
+ echo 1
+ echo 2
++ find /usr/local/lib/python3.9/dist-packages/ -mindepth 1 -maxdepth 1 -type d -exec du -ks '{}' +
++ awk '$1 <= 4'
++ cut -f 2-
+ RESULTTODELETE=
++ sed 's, ,\ ,g'
++ echo ''
+ RESULTTODELETE2=
+ echo ''
+ xargs rm -rf
+ echo 3
+ sudo pip3 cache purge
Files removed: 100
+ echo 4
+ sudo pip3 install --upgrade pip
Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple
Requirement already satisfied: pip in /usr/local/lib/python3.9/dist-packages (24.2)
WARNING: Error parsing dependencies of gpg: Invalid version: '1.14.0-unknown'
WARNING: Running pip as the 'root' user can result in broken permissions and conflicting behaviour with the system package manager, possibly rendering your system unusable.It is recommended to use a virtual environment instead: https://pip.pypa.io/warnings/venv. Use the --root-user-action option if you know what you are doing and want to suppress this warning.
+ echo 5
+ sudo python3 -m pip install --force-reinstall --upgrade pronotepy
Collecting pronotepy
Downloading https://www.piwheels.org/simple/pronotepy/pronotepy-2.14.1-py3-none-any.whl (46 kB)
Collecting beautifulsoup4>=4.8.2 (from pronotepy)
Downloading https://www.piwheels.org/simple/beautifulsoup4/beautifulsoup4-4.12.3-py3-none-any.whl (147 kB)
Collecting pycryptodome>=3.9.4 (from pronotepy)
Downloading https://www.piwheels.org/simple/pycryptodome/pycryptodome-3.21.0-cp36-abi3-linux_armv7l.whl (2.1 MB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 2.1/2.1 MB 5.0 MB/s eta 0:00:00
Collecting requests>=2.22.0 (from pronotepy)
Downloading https://www.piwheels.org/simple/requests/requests-2.32.3-py3-none-any.whl (64 kB)
Collecting autoslot>=2022.12.1 (from pronotepy)
Downloading https://www.piwheels.org/simple/autoslot/autoslot-2022.12.1-py2.py3-none-any.whl (7.8 kB)
Collecting soupsieve>1.2 (from beautifulsoup4>=4.8.2->pronotepy)
Downloading https://www.piwheels.org/simple/soupsieve/soupsieve-2.6-py3-none-any.whl (36 kB)
Collecting charset-normalizer<4,>=2 (from requests>=2.22.0->pronotepy)
Downloading https://www.piwheels.org/simple/charset-normalizer/charset_normalizer-3.4.0-py3-none-any.whl (49 kB)
Collecting idna<4,>=2.5 (from requests>=2.22.0->pronotepy)
Downloading https://www.piwheels.org/simple/idna/idna-3.10-py3-none-any.whl (70 kB)
Collecting urllib3<3,>=1.21.1 (from requests>=2.22.0->pronotepy)
Downloading https://www.piwheels.org/simple/urllib3/urllib3-2.2.3-py3-none-any.whl (126 kB)
Collecting certifi>=2017.4.17 (from requests>=2.22.0->pronotepy)
Downloading https://www.piwheels.org/simple/certifi/certifi-2024.8.30-py3-none-any.whl (167 kB)
Installing collected packages: autoslot, urllib3, soupsieve, pycryptodome, idna, charset-normalizer, certifi, requests, beautifulsoup4, pronotepy
Attempting uninstall: autoslot
Found existing installation: autoslot 2022.12.1
Uninstalling autoslot-2022.12.1:
Successfully uninstalled autoslot-2022.12.1
Attempting uninstall: urllib3
Found existing installation: urllib3 2.2.3
Uninstalling urllib3-2.2.3:
Successfully uninstalled urllib3-2.2.3
Attempting uninstall: soupsieve
Found existing installation: soupsieve 2.6
Uninstalling soupsieve-2.6:
Successfully uninstalled soupsieve-2.6
Attempting uninstall: pycryptodome
Found existing installation: pycryptodome 3.21.0
Uninstalling pycryptodome-3.21.0:
Successfully uninstalled pycryptodome-3.21.0
Attempting uninstall: idna
Found existing installation: idna 3.10
Uninstalling idna-3.10:
Successfully uninstalled idna-3.10
Attempting uninstall: charset-normalizer
Found existing installation: charset-normalizer 3.4.0
Uninstalling charset-normalizer-3.4.0:
Successfully uninstalled charset-normalizer-3.4.0
Attempting uninstall: certifi
Found existing installation: certifi 2024.8.30
Uninstalling certifi-2024.8.30:
Successfully uninstalled certifi-2024.8.30
Attempting uninstall: requests
Found existing installation: requests 2.32.3
Uninstalling requests-2.32.3:
Successfully uninstalled requests-2.32.3
Attempting uninstall: beautifulsoup4
Found existing installation: beautifulsoup4 4.12.3
Uninstalling beautifulsoup4-4.12.3:
Successfully uninstalled beautifulsoup4-4.12.3
Attempting uninstall: pronotepy
Found existing installation: pronotepy 2.14.1
Uninstalling pronotepy-2.14.1:
Successfully uninstalled pronotepy-2.14.1
Successfully installed autoslot-2022.12.1 beautifulsoup4-4.12.3 certifi-2024.8.30 charset-normalizer-3.4.0 idna-3.10 pronotepy-2.14.1 pycryptodome-3.21.0 requests-2.32.3 soupsieve-2.6 urllib3-2.2.3
+ echo 6
+ sudo python3 -m pip install --force-reinstall --upgrade cryptography
Collecting cryptography
Downloading cryptography-43.0.3.tar.gz (686 kB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 687.0/687.0 kB 4.0 MB/s eta 0:00:00
Installing build dependencies: started
Installing build dependencies: finished with status 'done'
Getting requirements to build wheel: started
Getting requirements to build wheel: finished with status 'done'
Preparing metadata (pyproject.toml): started
Preparing metadata (pyproject.toml): finished with status 'error'
error: subprocess-exited-with-error
× Preparing metadata (pyproject.toml) did not run successfully.
│ exit code: 1
╰─> [6 lines of output]
Cargo, the Rust package manager, is not installed or is not on PATH.
This package requires Rust and Cargo to compile extensions. Install it through
the system's package manager or via https://rustup.rs/
Checking for Rust toolchain....
[end of output]
note: This error originates from a subprocess, and is likely not a problem with pip.
error: metadata-generation-failed
× Encountered error while generating package metadata.
╰─> See above for output.
note: This is an issue with the package mentioned above, not pip.
hint: See above for details.
+ echo 7
+ sudo python3 -m pip install --force-reinstall --upgrade pycryptodome
Using cached https://www.piwheels.org/simple/pycryptodome/pycryptodome-3.21.0-cp36-abi3-linux_armv7l.whl (2.1 MB)
Installing collected packages: pycryptodome
Successfully installed pycryptodome-3.21.0
+ echo 8
+ sudo python3 -m pip install --force-reinstall --upgrade requests
Collecting requests
Using cached https://www.piwheels.org/simple/requests/requests-2.32.3-py3-none-any.whl (64 kB)
Collecting charset-normalizer<4,>=2 (from requests)
Using cached https://www.piwheels.org/simple/charset-normalizer/charset_normalizer-3.4.0-py3-none-any.whl (49 kB)
Collecting idna<4,>=2.5 (from requests)
Using cached https://www.piwheels.org/simple/idna/idna-3.10-py3-none-any.whl (70 kB)
Collecting urllib3<3,>=1.21.1 (from requests)
Using cached https://www.piwheels.org/simple/urllib3/urllib3-2.2.3-py3-none-any.whl (126 kB)
Collecting certifi>=2017.4.17 (from requests)
Using cached https://www.piwheels.org/simple/certifi/certifi-2024.8.30-py3-none-any.whl (167 kB)
Installing collected packages: urllib3, idna, charset-normalizer, certifi, requests
Successfully installed certifi-2024.8.30 charset-normalizer-3.4.0 idna-3.10 requests-2.32.3 urllib3-2.2.3
+ echo 9
+ sudo python3 -m pip install --force-reinstall --upgrade beautifulsoup4
Using cached https://www.piwheels.org/simple/beautifulsoup4/beautifulsoup4-4.12.3-py3-none-any.whl (147 kB)
Collecting soupsieve>1.2 (from beautifulsoup4)
Using cached https://www.piwheels.org/simple/soupsieve/soupsieve-2.6-py3-none-any.whl (36 kB)
Installing collected packages: soupsieve, beautifulsoup4
Successfully installed beautifulsoup4-4.12.3 soupsieve-2.6
+ echo 10
+ php /var/www/html/core/class/../php/jeecli.php plugin dependancy_end ProJote
+ echo 11
+ rm /tmp/jeedom_install_in_progress_ProJote
P.S. : L’accès a la documentation et au changelog est inaccessible.
Merci d’avance.
Informations Jeedom
Core : 4.4.18 (master)
DNS Jeedom : oui
Plugin : Plugin Pronote
Version : 2024-10-18 23:32:34 (beta)
Statut Démon : Stoppé - (2024-10-19 00:20:28)
