Depuis plusieurs mois, les dépendances de mon ESP Easy sont mortes. Voici le log à l’installation:
Début de l'installation
--2022-02-02 08:10:35-- https://raw.githubusercontent.com/lunarok/jeedom_nodejs/master/nodejs.sh
Resolving raw.githubusercontent.com (raw.githubusercontent.com)... 185.199.108.133, 185.199.109.133, 185.199.110.133, ...
Connecting to raw.githubusercontent.com (raw.githubusercontent.com)|185.199.108.133|:443... connected.
HTTP request sent, awaiting response... 200 OK
Length: 1552 (1.5K) [text/plain]
Saving to: 'dependencies.sh'
0K . 100% 2.39M=0.001s
2022-02-02 08:10:35 (2.39 MB/s) - 'dependencies.sh' saved [1552/1552]
dependencies.sh: 3: [: espeasy: unexpected operator
Version actuelle : 12
Hit:1 http://archive.raspberrypi.org/debian stretch InRelease
Hit:2 http://raspbian.raspberrypi.org/raspbian stretch InRelease
Hit:3 https://deb.nodesource.com/node_12.x stretch InRelease
Reading package lists...
Building dependency tree...
Reading state information...
lsb-release is already the newest version (9.20161125+rpi1).
0 upgraded, 0 newly installed, 0 to remove and 23 not upgraded.
dependencies.sh: 29: dependencies.sh: [[: not found
KO, version obsolète à upgrader
Suppression du Nodejs existant et installation du paquet recommandé
Package 'npm' is not installed, so not removed
The following packages will be REMOVED:
nodejs*
0 upgraded, 0 newly installed, 1 to remove and 23 not upgraded.
After this operation, 85.8 MB disk space will be freed.
(Reading database ...
(Reading database ... 5%
(Reading database ... 10%
(Reading database ... 15%
(Reading database ... 20%
(Reading database ... 25%
(Reading database ... 30%
(Reading database ... 35%
(Reading database ... 40%
(Reading database ... 45%
(Reading database ... 50%
(Reading database ... 55%
(Reading database ... 60%
(Reading database ... 65%
(Reading database ... 70%
(Reading database ... 75%
(Reading database ... 80%
(Reading database ... 85%
(Reading database ... 90%
(Reading database ... 95%
(Reading database ... 100%
(Reading database ... 66194 files and directories currently installed.)
Removing nodejs (12.22.10-1nodesource1) ...
Processing triggers for man-db (2.7.6.1-2) ...
dependencies.sh: 38: [: armv7l: unexpected operator
Utilisation du dépot officiel
## Installing the NodeSource Node.js 14.x repo...
## Populating apt-get cache...
+ apt-get update
Hit:1 http://raspbian.raspberrypi.org/raspbian stretch InRelease
Hit:2 http://archive.raspberrypi.org/debian stretch InRelease
## Confirming "stretch" is supported...
+ curl -sLf -o /dev/null 'https://deb.nodesource.com/node_14.x/dists/stretch/Release'
## Adding the NodeSource signing key to your keyring...
+ curl -s https://deb.nodesource.com/gpgkey/nodesource.gpg.key | gpg --dearmor | tee /usr/share/keyrings/nodesource.gpg >/dev/null
## Creating apt sources list file for the NodeSource Node.js 14.x repo...
+ echo 'deb [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_14.x stretch main' > /etc/apt/sources.list.d/nodesource.list
+ echo 'deb-src [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_14.x stretch main' >> /etc/apt/sources.list.d/nodesource.list
## Running `apt-get update` for you...
+ apt-get update
Get:3 https://deb.nodesource.com/node_14.x stretch InRelease [4585 B]
Get:4 https://deb.nodesource.com/node_14.x stretch/main armhf Packages [780 B]
Fetched 5365 B in 3s (1590 B/s)
## Run `sudo apt-get install -y nodejs` to install Node.js 14.x and npm
## You may also need development tools to build native addons:
sudo apt-get install gcc g++ make
## To install the Yarn package manager, run:
curl -sL https://dl.yarnpkg.com/debian/pubkey.gpg | gpg --dearmor | sudo tee /usr/share/keyrings/yarnkey.gpg >/dev/null
echo "deb [signed-by=/usr/share/keyrings/yarnkey.gpg] https://dl.yarnpkg.com/debian stable main" | sudo tee /etc/apt/sources.list.d/yarn.list
sudo apt-get update && sudo apt-get install yarn
nodejs
0 upgraded, 1 newly installed, 0 to remove and 23 not upgraded.
Need to get 23.4 MB of archives.
After this operation, 117 MB of additional disk space will be used.
Get:1 https://deb.nodesource.com/node_14.x stretch/main armhf nodejs armhf 14.19.0-1nodesource1 [23.4 MB]
debconf: unable to initialize frontend: Dialog
debconf: (Dialog frontend will not work on a dumb terminal, an emacs shell buffer, or without a controlling terminal.)
debconf: falling back to frontend: Readline
debconf: unable to initialize frontend: Readline
debconf: (This frontend requires a controlling tty.)
debconf: falling back to frontend: Teletype
dpkg-preconfigure: unable to re-open stdin:
Fetched 23.4 MB in 9s (2361 kB/s)
Selecting previously unselected package nodejs.
(Reading database ... 61330 files and directories currently installed.)
Preparing to unpack .../nodejs_14.19.0-1nodesource1_armhf.deb ...
Unpacking nodejs (14.19.0-1nodesource1) ...
Setting up nodejs (14.19.0-1nodesource1) ...
ln: failed to create symbolic link '/usr/bin/nodejs': File exists
Version actuelle : v14.19.0
npm WARN registry Unexpected warning for https://registry.npmjs.org/: Miscellaneous Warning EINTEGRITY: sha512-OvNTHeHlQ0BJFyQnUquSMwp0FrkrHD5HpxXMr9Q/5/dPVA9ArajgORbw2bUQTWuQzvmb2KWT2Wm/PcOAIM50Wg== integrity checksum failed when using sha512: wanted sha512-OvNTHeHlQ0BJFyQnUquSMwp0FrkrHD5HpxXMr9Q/5/dPVA9ArajgORbw2bUQTWuQzvmb2KWT2Wm/PcOAIM50Wg== but got sha512-z4PhNX7vuL3xVChQ1m2AB9Yg5AULVxXcg/SpIdNs6c5H0NE8XYXysP+DGNKHfuwvY7kxvUdBeoGlODJ6+SfaPg==. (0 bytes)
npm WARN registry Using stale data from https://registry.npmjs.org/ due to a request error during revalidation.
npm ERR! code EINTEGRITY
npm ERR! errno EINTEGRITY
npm ERR! Invalid response body while trying to fetch https://registry.npmjs.org/request: Integrity verification failed for sha512-OvNTHeHlQ0BJFyQnUquSMwp0FrkrHD5HpxXMr9Q/5/dPVA9ArajgORbw2bUQTWuQzvmb2KWT2Wm/PcOAIM50Wg== (/var/www/.npm/_cacache/content-v2/sha512/3a/f3/531de1e543404917242752ab92330a7416b92b1c3e47a715ccafd43fe7f74f540f40ada8e03916f0d9b5104d6b90cef99bd8a593d969bf3dc38020ce745a)
npm ERR! A complete log of this run can be found in:
npm ERR! /var/www/.npm/_logs/2022-02-02T07_13_17_947Z-debug.log
chown: cannot access 'node_modules': No such file or directory
Fin de l'installation
Je suis sous Jeedom 3.3.59 et EspEasy est en dernière version (2021-11-29 01:00:39).
Pouvez-vous s’il vous plait m’aider ?
Merci beaucoup d’avance…
Romain.
