je viens de passe ma smart en buster et je rencontre un problème avec le plug in Xiaomi. L’installation des dépendace tourne en boucle.
* Installation des dépendances *
Hit:2 http://security.debian.org/debian-security buster/updates InRelease
Hit:3 http://www.deb-multimedia.org buster InRelease
Hit:4 http://ftp.uk.debian.org/debian buster InRelease
Hit:5 http://ftp.uk.debian.org/debian buster-updates InRelease
Hit:6 https://oph.mdrjr.net/meveric all InRelease
Hit:7 https://oph.mdrjr.net/meveric buster InRelease
Err:1 https://repo.jeedom.com/odroid stable InRelease
502 Bad Gateway [IP: 51.210.253.116 443]
Reading package lists...
W: Failed to fetch http://repo.jeedom.com/odroid/dists/stable/InRelease 502 Bad Gateway [IP: 51.210.253.116 443]
W: Some index files failed to download. They have been ignored, or old ones used instead.
Installation des dépendances apt
Building dependency tree...
Reading state information...
libffi-dev is already the newest version (3.2.1-9).
python3-cryptography is already the newest version (2.6.1-3+deb10u2).
python3-pip is already the newest version (18.1-5).
python3-dev is already the newest version (3.7.3-1).
libssl-dev is already the newest version (1.1.1d-0+deb10u6).
0 upgraded, 0 newly installed, 0 to remove and 137 not upgraded.
Installation du module construct pour python
Collecting construct
Using cached https://files.pythonhosted.org/packages/39/2b/c68eaf8294f01ea534f39b8b4ec1d7308b5195e08570c276b104bccd24ff/construct-2.10.67.tar.gz
Complete output from command python setup.py egg_info:
File "<string>", line 1, in <module>
ModuleNotFoundError: No module named 'setuptools'
Command "python setup.py egg_info" failed with error code 1 in /tmp/pip-install-87yrmx0m/construct/
Installation du module pyudev pour python
Collecting pyudev
Using cached https://files.pythonhosted.org/packages/72/c8/4660d815a79b1d42c409012aaa10ebd6b07a47529b4cb6880f27a24bd646/pyudev-0.22.0.tar.gz
Command "python setup.py egg_info" failed with error code 1 in /tmp/pip-install-2xfn1a7v/pyudev/
Installation du module future pour python
Collecting future
Using cached https://files.pythonhosted.org/packages/45/0b/38b06fd9b92dc2b68d58b75f900e97884c45bedd2ff83203d933cf5851c9/future-0.18.2.tar.gz
Command "python setup.py egg_info" failed with error code 1 in /tmp/pip-install-lo9h8r0u/future/
Installation du module pycrypto pour python
Collecting pycrypto
Using cached https://files.pythonhosted.org/packages/60/db/645aa9af249f059cc3a368b118de33889219e0362141e75d4eaf6f80f163/pycrypto-2.6.1.tar.gz
Command "python setup.py egg_info" failed with error code 1 in /tmp/pip-install-73o2dqyr/pycrypto/
Installation du module yeelight pour python
Collecting yeelight
Using cached https://files.pythonhosted.org/packages/e3/fd/142e3084cb6827de8e486216d7703a6d7acd420704f02d1e86035c60c74e/yeelight-0.6.3-py3-none-any.whl
Collecting future (from yeelight)
Command "python setup.py egg_info" failed with error code 1 in /tmp/pip-install-q9t336ju/future/
Installation du module miio pour python
Collecting python-miio
Using cached https://files.pythonhosted.org/packages/25/0d/c64cd4c85e27eed0bfd950dee8f5c0fc1b0627750b78f447f4c75efc08d1/python_miio-0.5.6-py3-none-any.whl
Collecting click<8,>=7 (from python-miio)
Using cached https://files.pythonhosted.org/packages/d2/3d/fa76db83bf75c4f8d338c2fd15c8d33fdd7ad23a9b5e57eb6c5de26b430e/click-7.1.2-py2.py3-none-any.whl
Collecting croniter<1,>=0 (from python-miio)
Using cached https://files.pythonhosted.org/packages/05/e5/1d2b7e3c36c444e78a31d7f0b8a1799acf4f8d869693f2232a3555a5dc6f/croniter-0.3.37-py2.py3-none-any.whl
Collecting defusedxml<0.7,>=0.6 (from python-miio)
Using cached https://files.pythonhosted.org/packages/06/74/9b387472866358ebc08732de3da6dc48e44b0aacd2ddaa5cb85ab7e986a2/defusedxml-0.6.0-py2.py3-none-any.whl
Collecting tqdm<5,>=4 (from python-miio)
Using cached https://files.pythonhosted.org/packages/b4/20/9f1e974bb4761128fc0d0a32813eaa92827309b1756c4b892d28adfb4415/tqdm-4.61.1-py2.py3-none-any.whl
Collecting zeroconf<1,>=0 (from python-miio)
Using cached https://files.pythonhosted.org/packages/36/d4/cf3952bf4ed616e0fce6864894696b367a4a984c8de9ea7ff007ee0e55ee/zeroconf-0.31.0-py3-none-any.whl
Collecting PyYAML<6,>=5 (from python-miio)
Using cached https://files.pythonhosted.org/packages/a0/a4/d63f2d7597e1a4b55aa3b4d6c5b029991d3b824b5bd331af8d4ab1ed687d/PyYAML-5.4.1.tar.gz
Installing build dependencies: started
Installing build dependencies: finished with status 'done'
Collecting netifaces<1,>=0 (from python-miio)
Using cached https://files.pythonhosted.org/packages/a6/91/86a6eac449ddfae239e93ffc1918cf33fd9bab35c04d1e963b311e347a73/netifaces-0.11.0.tar.gz
Command "python setup.py egg_info" failed with error code 1 in /tmp/pip-install-6asqkyzk/netifaces/
Installation du module thread pour python
Invalid requirement: '_thread'
File "/usr/share/python-wheels/packaging-19.0-py2.py3-none-any.whl/packaging/requirements.py", line 93, in __init__
req = REQUIREMENT.parseString(requirement_string)
File "/usr/share/python-wheels/pyparsing-2.2.0-py2.py3-none-any.whl/pyparsing.py", line 1632, in parseString
raise exc
File "/usr/share/python-wheels/pyparsing-2.2.0-py2.py3-none-any.whl/pyparsing.py", line 1622, in parseString
loc, tokens = self._parse( instring, 0 )
File "/usr/share/python-wheels/pyparsing-2.2.0-py2.py3-none-any.whl/pyparsing.py", line 1379, in _parseNoCache
loc,tokens = self.parseImpl( instring, preloc, doActions )
File "/usr/share/python-wheels/pyparsing-2.2.0-py2.py3-none-any.whl/pyparsing.py", line 3395, in parseImpl
loc, exprtokens = e._parse( instring, loc, doActions )
File "/usr/share/python-wheels/pyparsing-2.2.0-py2.py3-none-any.whl/pyparsing.py", line 3717, in parseImpl
return self.expr._parse( instring, loc, doActions, callPreParse=False )
File "/usr/share/python-wheels/pyparsing-2.2.0-py2.py3-none-any.whl/pyparsing.py", line 3378, in parseImpl
loc, resultlist = self.exprs[0]._parse( instring, loc, doActions, callPreParse=False )
File "/usr/share/python-wheels/pyparsing-2.2.0-py2.py3-none-any.whl/pyparsing.py", line 1383, in _parseNoCache
File "/usr/share/python-wheels/pyparsing-2.2.0-py2.py3-none-any.whl/pyparsing.py", line 2689, in parseImpl
raise ParseException(instring, loc, self.errmsg, self)
pyparsing.ParseException: Expected W:(abcd...) (at char 0), (line:1, col:1)
During handling of the above exception, another exception occurred:
File "/usr/lib/python3/dist-packages/pip/_internal/req/constructors.py", line 253, in install_req_from_line
req = Requirement(req)
File "/usr/share/python-wheels/packaging-19.0-py2.py3-none-any.whl/packaging/requirements.py", line 97, in __init__
requirement_string[e.loc : e.loc + 8], e.msg
pip._vendor.packaging.requirements.InvalidRequirement: Parse error at "'_thread'": Expected W:(abcd...)
* Installation terminée *
merci pour votre aide
