Lors de la migration du plugin zigbee vers jeezigbee, depuis ma SMART 16Go, j’ai :
- renommé tous mes équipements zigbee
- arrêté le démon et désactivé zigbee
- téléchargé et activé le plugin jeezigbee
mais l’installation des dépendance est bloquée a 8% depuis 1h avec les log ci-dessous
+ touch /tmp/jeedom_install_in_progress_z2m
+ echo 1
+ echo 2
+ sudo chmod +x /var/www/html/core/class/../../plugins/z2m/resources/pre-install.sh
+ sudo /var/www/html/core/class/../../plugins/z2m/resources/pre-install.sh
Launch pre-install of z2m dependancy
+ echo 3
+ php /var/www/html/core/class/../php/jeecli.php plugin install mqtt2
PHP Warning: Module 'mosquitto' already loaded in Unknown on line 0
apt: no process found
apt-get: no process found
Get:1 http://security.debian.org/debian-security buster/updates InRelease [34.8 kB]
Get:2 http://www.deb-multimedia.org buster InRelease [18.1 kB]
Hit:3 https://deb.nodesource.com/node_18.x nodistro InRelease
Get:4 http://ftp.uk.debian.org/debian buster InRelease [122 kB]
Hit:5 https://oph.mdrjr.net/meveric all InRelease
Get:6 http://ftp.uk.debian.org/debian buster-updates InRelease [56.6 kB]
Hit:7 https://oph.mdrjr.net/meveric buster InRelease
Reading package lists...
E: Repository 'http://security.debian.org/debian-security buster/updates InRelease' changed its 'Suite' value from 'oldstable' to 'oldoldstable'
E: Repository 'http://www.deb-multimedia.org buster InRelease' changed its 'Suite' value from 'oldstable' to 'oldoldstable'
E: Repository 'http://ftp.uk.debian.org/debian buster InRelease' changed its 'Suite' value from 'oldstable' to 'oldoldstable'
E: Repository 'http://ftp.uk.debian.org/debian buster-updates InRelease' changed its 'Suite' value from 'oldstable-updates' to 'oldoldstable-updates'
Vérification si la source deb-multimedia existe (bug lors du apt-get update si c'est le cas)
deb-multimedia existe !
Désactivation de la source deb-multimedia !
Hit:2 https://deb.nodesource.com/node_18.x nodistro InRelease
Get:3 http://ftp.uk.debian.org/debian buster InRelease [122 kB]
Get:4 http://ftp.uk.debian.org/debian buster-updates InRelease [56.6 kB]
Hit:6 https://oph.mdrjr.net/meveric buster InRelease
Building dependency tree...
Reading state information...
apt-utils is already the newest version (1.8.2.3).
build-essential is already the newest version (12.6).
lsb-release is already the newest version (10.2019051400).
git is already the newest version (1:2.20.1-2+deb10u8).
0 upgraded, 0 newly installed, 0 to remove and 230 not upgraded.
[Check Version NodeJS actuelle : v18.19.0 : PHP Warning: Module 'mosquitto' already loaded in Unknown on line 0
[ OK ]
[Check Prefix : /usr and sudo prefix : /usr and www-data prefix : /usr : [ OK ]
Réactivation de la source deb-multimedia qu'on avait désactivé !
Hit:4 https://oph.mdrjr.net/meveric all InRelease
Hit:5 https://oph.mdrjr.net/meveric buster InRelease
[Check Version NodeJS actuelle : v18.19.0 : [ OK ]
--2024-05-14 09:03:24-- https://getcomposer.org/installer
Resolving getcomposer.org (getcomposer.org)... 2001:41d0:302:1100::8:104f, 54.36.53.46
Connecting to getcomposer.org (getcomposer.org)|2001:41d0:302:1100::8:104f|:443... connected.
HTTP request sent, awaiting response... 200 OK
Length: 58444 (57K) [application/octet-stream]
Saving to: 'composer-setup.php'
0K .......... .......... .......... .......... .......... 87% 2.26M 0s
50K ....... 100% 23.6M=0.02s
2024-05-14 09:03:25 (2.54 MB/s) - 'composer-setup.php' saved [58444/58444]
Begin installation of composer
All settings correct for using Composer
Downloading...
Composer (version 2.7.6) successfully installed to: /var/www/html/core/ajax/composer.phar
Use it: php composer.phar
End installation of composer
npm notice
npm notice New minor version of npm available! 10.2.3 -> 10.7.0
npm notice Changelog: <https://github.com/npm/cli/releases/tag/v10.7.0>
npm notice Run `npm install -g npm@10.7.0` to update!
npm notice
added 117 packages, and audited 118 packages in 31s
19 packages are looking for funding
run `npm fund` for details
found 0 vulnerabilities
+ echo 4
+ sudo apt update
Get:7 http://ftp.uk.debian.org/debian buster-updates InRelease [56.6 kB]
+ echo 5
Get:2 http://ftp.uk.debian.org/debian buster InRelease [122 kB]
[ OK ]
+ echo 6
+ sudo apt install -o Dpkg::Options::=--force-confdef -y php-yaml
The following additional packages will be installed:
libyaml-0-2
libyaml-0-2 php-yaml
0 upgraded, 2 newly installed, 0 to remove and 230 not upgraded.
Need to get 60.0 kB of archives.
After this operation, 197 kB of additional disk space will be used.
Get:1 http://ftp.uk.debian.org/debian buster/main arm64 libyaml-0-2 arm64 0.2.1-1 [41.4 kB]
Get:2 http://ftp.uk.debian.org/debian buster/main arm64 php-yaml arm64 2.0.2+1.3.1-4 [18.6 kB]
debconf: unable to initialize frontend: Dialog
debconf: (Dialog frontend will not work on a dumb terminal, an emacs shell buffer, or without a controlling terminal.)
debconf: falling back to frontend: Readline
debconf: unable to initialize frontend: Readline
debconf: (This frontend requires a controlling tty.)
debconf: falling back to frontend: Teletype
dpkg-preconfigure: unable to re-open stdin:
Fetched 60.0 kB in 1s (118 kB/s)
Selecting previously unselected package libyaml-0-2:arm64.
(Reading database ...
(Reading database ... 5%
(Reading database ... 10%
(Reading database ... 15%
(Reading database ... 20%
(Reading database ... 25%
(Reading database ... 30%
(Reading database ... 35%
(Reading database ... 40%
(Reading database ... 45%
(Reading database ... 50%
(Reading database ... 55%
(Reading database ... 60%
(Reading database ... 65%
(Reading database ... 70%
(Reading database ... 75%
(Reading database ... 80%
(Reading database ... 85%
(Reading database ... 90%
(Reading database ... 95%
(Reading database ... 100%
(Reading database ... 83966 files and directories currently installed.)
Preparing to unpack .../libyaml-0-2_0.2.1-1_arm64.deb ...
Unpacking libyaml-0-2:arm64 (0.2.1-1) ...
Selecting previously unselected package php-yaml.
Preparing to unpack .../php-yaml_2.0.2+1.3.1-4_arm64.deb ...
Unpacking php-yaml (2.0.2+1.3.1-4) ...
Setting up libyaml-0-2:arm64 (0.2.1-1) ...
Setting up php-yaml (2.0.2+1.3.1-4) ...
Processing triggers for libc-bin (2.28-10) ...
+ echo 7
+ sudo systemctl restart apache2
Warning: The unit file, source configuration file or drop-ins of apache2.service changed on disk. Run 'systemctl daemon-reload' to reload units.
+ echo 8
+ sudo chmod +x /var/www/html/core/class/../../plugins/z2m/resources/post-install.sh
+ sudo /var/www/html/core/class/../../plugins/z2m/resources/post-install.sh
+ echo Launch post-install of z2m dependancy
+ realpath /var/www/html/core/class/../../plugins/z2m/resources/post-install.sh
+ dirname /var/www/html/plugins/z2m/resources/post-install.sh
+ BASEDIR=/var/www/html/plugins/z2m/resources
+ [ -d /var/www/html/plugins/z2m/resources/zigbee2mqtt ]
+ mkdir /var/www/html/plugins/z2m/resources/zigbee2mqtt
+ git clone --depth 1 https://github.com/Koenkk/zigbee2mqtt.git /var/www/html/plugins/z2m/resources/zigbee2mqtt
Cloning into '/var/www/html/plugins/z2m/resources/zigbee2mqtt'...
+ cd /var/www/html/plugins/z2m/resources/zigbee2mqtt
+ [ -f /var/www/html/plugins/z2m/resources/../data/wanted_z2m_version ]
+ npm ci
Que puis-je faire,
- attendre (mais jusqu’a quand)
- redemarrer jeedom et recommencer?
Informations Jeedom
Core : 4.4.5 (V4-stable)
DNS Jeedom : oui
Plugin : JeeZigbee
Version : 2024-04-24 01:01:56 (stable)
Statut Démon : Stoppé - (Inconnue)
