Bon je viens d’installer le plugin sur une v4.2.7 alpha tournant sous debian 10 à jour
Launch install of noip dependencies
-- Current OS version :
Description: Debian GNU/Linux 10 (buster)
-- Updating repo...
Get:1 http://security.debian.org/debian-security buster/updates InRelease [65.4 kB]
Hit:2 http://deb.debian.org/debian buster InRelease
Hit:3 https://download.docker.com/linux/debian buster InRelease
Hit:4 https://deb.nodesource.com/node_14.x buster InRelease
Get:5 http://security.debian.org/debian-security buster/updates/main Sources [217 kB]
Get:6 http://security.debian.org/debian-security buster/updates/main amd64 Packages [314 kB]
Get:7 http://security.debian.org/debian-security buster/updates/main Translation-en [170 kB]
Fetched 766 kB in 1s (527 kB/s)
Reading package lists...
W: Target Packages (stable/binary-amd64/Packages) is configured multiple times in /etc/apt/sources.list:17 and /etc/apt/sources.list.d/docker.list:1
W: Target Packages (stable/binary-all/Packages) is configured multiple times in /etc/apt/sources.list:17 and /etc/apt/sources.list.d/docker.list:1
W: Target Translations (stable/i18n/Translation-en) is configured multiple times in /etc/apt/sources.list:17 and /etc/apt/sources.list.d/docker.list:1
W: Target Translations (stable/i18n/Translation-fr) is configured multiple times in /etc/apt/sources.list:17 and /etc/apt/sources.list.d/docker.list:1
-- Installation of python3 and dependencies
Building dependency tree...
Reading state information...
build-essential is already the newest version (12.6).
python-dev is already the newest version (2.7.16-1).
python3 is already the newest version (3.7.3-1).
0 upgraded, 0 newly installed, 0 to remove and 5 not upgraded.
-- Installed version of Python :
Python 3.7.3
Your version of python is compatible with this plugin.
-- Installation of pip for python3 and necessary libraries
python3-pip is already the newest version (18.1-5).
python3-dev is already the newest version (3.7.3-1).
python-requests is already the newest version (2.21.0-1).
-- Installation of chromium
E: Unable to locate package chromium-chromedriver
chromium-driver
0 upgraded, 1 newly installed, 0 to remove and 5 not upgraded.
Need to get 4703 kB of archives.
After this operation, 13.3 MB of additional disk space will be used.
Get:1 http://security.debian.org/debian-security buster/updates/main amd64 chromium-driver amd64 90.0.4430.212-1~deb10u1 [4703 kB]
debconf: unable to initialize frontend: Dialog
debconf: (Dialog frontend will not work on a dumb terminal, an emacs shell buffer, or without a controlling terminal.)
debconf: falling back to frontend: Readline
debconf: unable to initialize frontend: Readline
debconf: (This frontend requires a controlling tty.)
debconf: falling back to frontend: Teletype
dpkg-preconfigure: unable to re-open stdin:
Fetched 4703 kB in 4s (1082 kB/s)
Selecting previously unselected package chromium-driver.
(Reading database ...
(Reading database ... 5%
(Reading database ... 10%
(Reading database ... 15%
(Reading database ... 20%
(Reading database ... 25%
(Reading database ... 30%
(Reading database ... 35%
(Reading database ... 40%
(Reading database ... 45%
(Reading database ... 50%
(Reading database ... 55%
(Reading database ... 60%
(Reading database ... 65%
(Reading database ... 70%
(Reading database ... 75%
(Reading database ... 80%
(Reading database ... 85%
(Reading database ... 90%
(Reading database ... 95%
(Reading database ... 100%
(Reading database ... 70515 files and directories currently installed.)
Preparing to unpack .../chromium-driver_90.0.4430.212-1~deb10u1_amd64.deb ...
Unpacking chromium-driver (90.0.4430.212-1~deb10u1) ...
Setting up chromium-driver (90.0.4430.212-1~deb10u1) ...
Package chromium-browser is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
E: Package 'chromium-browser' has no installation candidate
-- Installed version of pip :
pip 21.3.1 from /usr/local/lib/python3.7/dist-packages/pip (python 3.7)
-- Installation of python library 'selenium' with command pip3.7
/usr/lib/python3/dist-packages/secretstorage/dhcrypto.py:15: CryptographyDeprecationWarning: int_from_bytes is deprecated, use int.from_bytes instead
from cryptography.utils import int_from_bytes
/usr/lib/python3/dist-packages/secretstorage/util.py:19: CryptographyDeprecationWarning: int_from_bytes is deprecated, use int.from_bytes instead
ERROR: pip's dependency resolver does not currently take into account all the packages that are installed. This behaviour is the source of the following dependency conflicts.
python-miio 0.5.6 requires cryptography<4,>=3, but you have cryptography 36.0.1 which is incompatible.
WARNING: Running pip as the 'root' user can result in broken permissions and conflicting behaviour with the system package manager. It is recommended to use a virtual environment instead: https://pip.pypa.io/warnings/venv
WARNING: You are using pip version 21.3.1; however, version 22.0.2 is available.
You should consider upgrading via the '/usr/bin/python3 -m pip install --upgrade pip' command.
cat: /tmp/jeedom/noip/dependancy_noip: No such file or directory
-- Installation of dependencies is done !
Voilà mon log.
Donc j’ai fait un
apt update
apt upgrade
J’ai upgradé mon pip comme demandé
J’ai ensuite installé chromium browser
sudo apt install snapd
sudo snap install core
sudo snap install chromium
Je relance les dépendances du plugin
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Python 3.7.3
chromium-driver is already the newest version (90.0.4430.212-1~deb10u1).
pip 22.0.2 from /usr/local/lib/python3.7/dist-packages/pip (python 3.7)
Et dans Jeedom
