Mon installation de dépendances continue à être KO et à tourner toutes les 5 minutes sur un PI installé hier avec la version de jeedom d"hier et le module … et oui d’hier !
la fin de la log dit que l’installation c’est bien passée. Mon autre rasberry avec d’anciennes versions marche très bien pourtant.
impossible d’uploader la log ici (trop nouveau) donc la voic dans le message si on peut m’aider.
Attempting uninstall: zigpy-xbee
Found existing installation: zigpy-xbee 0.14.0
Uninstalling zigpy-xbee-0.14.0:
Successfully uninstalled zigpy-xbee-0.14.0
ERROR: pip's dependency resolver does not currently take into account all the packages that are installed. This behaviour is the source of the following dependency conflicts.
requests 2.28.0 requires charset-normalizer~=2.0.0, but you have charset-normalizer 2.1.0 which is incompatible.
Successfully installed aiohttp-3.8.1 aiosignal-1.2.0 aiosqlite-0.17.0 async-timeout-4.0.2 attrs-21.4.0 cffi-1.15.0 charset-normalizer-2.1.0 crccheck-1.1 cryptography-37.0.2 frozenlist-1.3.0 idna-3.3 multidict-6.0.2 pycparser-2.21 pyserial-3.5 pyserial-asyncio-0.6 typing_extensions-4.2.0 voluptuous-0.13.1 yarl-1.7.2 zigpy-0.47.0 zigpy-xbee-0.14.0
WARNING: Running pip as the 'root' user can result in broken permissions and conflicting behaviour with the system package manager. It is recommended to use a virtual environment instead: ://pip.pypa.io/warnings/venv
+ echo 14
+ sudo pip3 install --force-reinstall --upgrade zigpy-deconz==0.16.0
Looking in indexes: ://pypi.org/simple, ://www.piwheels.org/simple
Collecting zigpy-deconz==0.16.0
Using cached ://www.piwheels.org/simple/zigpy-deconz/zigpy_deconz-0.16.0-py3-none-any.whl (30 kB)
Collecting pyserial-asyncio
Using cached ://www.piwheels.org/simple/pyserial-asyncio/pyserial_asyncio-0.6-py3-none-any.whl (7.5 kB)
Collecting zigpy>=0.40.0
Using cached ://www.piwheels.org/simple/zigpy/zigpy-0.47.0-py3-none-any.whl (137 kB)
Collecting voluptuous
Using cached ://www.piwheels.org/simple/voluptuous/voluptuous-0.13.1-py3-none-any.whl (35 kB)
Collecting aiosqlite>=0.16.0
Using cached ://www.piwheels.org/simple/aiosqlite/aiosqlite-0.17.0-py3-none-any.whl (15 kB)
Collecting aiohttp
Using cached -3.8.1-cp39-cp39-manylinux_2_17_aarch64.manylinux2014_aarch64.whl (1.2 MB)
Collecting crccheck
Using cached ://www.piwheels.org/simple/crccheck/crccheck-1.1-py3-none-any.whl (27 kB)
Collecting cryptography
Using cached cryptography-37.0.2-cp36-abi3-manylinux_2_17_aarch64.manylinux2014_aarch64.manylinux_2_24_aarch64.whl (3.6 MB)
Collecting pyserial
Using cached ://www.piwheels.org/simple/pyserial/pyserial-3.5-py2.py3-none-any.whl (90 kB)
Collecting typing_extensions>=3.7.2
Using cached ://www.piwheels.org/simple/typing-extensions/typing_extensions-4.2.0-py3-none-any.whl (24 kB)
Collecting attrs>=17.3.0
Using cached htps://www.piwheels.org/simple/attrs/attrs-21.4.0-py2.py3-none-any.whl (60 kB)
Collecting charset-normalizer<3.0,>=2.0
Using cached ://www.piwheels.org/simple/charset-normalizer/charset_normalizer-2.1.0-py3-none-any.whl (39 kB)
Collecting multidict<7.0,>=4.5
Using cached multidict-6.0.2-cp39-cp39-manylinux_2_17_aarch64.manylinux2014_aarch64.whl (116 kB)
Collecting async-timeout<5.0,>=4.0.0a3
Using cached ://www.piwheels.org/simple/async-timeout/async_timeout-4.0.2-py3-none-any.whl (5.8 kB)
Collecting yarl<2.0,>=1.0
Using cached yarl-1.7.2-cp39-cp39-manylinux_2_17_aarch64.manylinux2014_aarch64.whl (321 kB)
Collecting frozenlist>=1.1.1
Using cached frozenlist-1.3.0-cp39-cp39-manylinux_2_17_aarch64.manylinux2014_aarch64.whl (156 kB)
Collecting aiosignal>=1.1.2
Using cached ://www.piwheels.org/simple/aiosignal/aiosignal-1.2.0-py3-none-any.whl (8.2 kB)
Collecting cffi>=1.12
Using cached cffi-1.15.0-cp39-cp39-manylinux_2_17_aarch64.manylinux2014_aarch64.whl (447 kB)
Collecting pycparser
Using cached ://www.piwheels.org/simple/pycparser/pycparser-2.21-py2.py3-none-any.whl (119 kB)
Collecting idna>=2.0
Using cached ://www.piwheels.org/simple/idna/idna-3.3-py3-none-any.whl (64 kB)
Installing collected packages: voluptuous, pyserial, crccheck, typing_extensions, pyserial-asyncio, pycparser, multidict, idna, frozenlist, charset-normalizer, attrs, async-timeout, yarl, cffi, aiosqlite, aiosignal, cryptography, , zigpy, zigpy-deconz
Attempting uninstall: voluptuous
Found existing installation: voluptuous 0.13.1
Uninstalling voluptuous-0.13.1:
Successfully uninstalled voluptuous-0.13.1
Attempting uninstall: pyserial
Found existing installation: pyserial 3.5
Uninstalling pyserial-3.5:
Successfully uninstalled pyserial-3.5
Attempting uninstall: crccheck
Found existing installation: crccheck 1.1
Uninstalling crccheck-1.1:
Successfully uninstalled crccheck-1.1
Attempting uninstall: typing_extensions
Found existing installation: typing_extensions 4.2.0
Uninstalling typing_extensions-4.2.0:
Successfully uninstalled typing_extensions-4.2.0
Attempting uninstall: pyserial-asyncio
Found existing installation: pyserial-asyncio 0.6
Uninstalling pyserial-asyncio-0.6:
Successfully uninstalled pyserial-asyncio-0.6
Attempting uninstall: pycparser
Found existing installation: pycparser 2.21
Uninstalling pycparser-2.21:
Successfully uninstalled pycparser-2.21
Attempting uninstall: multidict
Found existing installation: multidict 6.0.2
Uninstalling multidict-6.0.2:
Successfully uninstalled multidict-6.0.2
Attempting uninstall: idna
Found existing installation: idna 3.3
Uninstalling idna-3.3:
Successfully uninstalled idna-3.3
Attempting uninstall: frozenlist
Found existing installation: frozenlist 1.3.0
Uninstalling frozenlist-1.3.0:
Successfully uninstalled frozenlist-1.3.0
Attempting uninstall: charset-normalizer
Found existing installation: charset-normalizer 2.1.0
Uninstalling charset-normalizer-2.1.0:
Successfully uninstalled charset-normalizer-2.1.0
Attempting uninstall: attrs
Found existing installation: attrs 21.4.0
Uninstalling attrs-21.4.0:
Successfully uninstalled attrs-21.4.0
Attempting uninstall: async-timeout
Found existing installation: async-timeout 4.0.2
Uninstalling async-timeout-4.0.2:
Successfully uninstalled async-timeout-4.0.2
Attempting uninstall: yarl
Found existing installation: yarl 1.7.2
Uninstalling yarl-1.7.2:
Successfully uninstalled yarl-1.7.2
Attempting uninstall: cffi
Found existing installation: cffi 1.15.0
Uninstalling cffi-1.15.0:
Successfully uninstalled cffi-1.15.0
Attempting uninstall: aiosqlite
Found existing installation: aiosqlite 0.17.0
Uninstalling aiosqlite-0.17.0:
Successfully uninstalled aiosqlite-0.17.0
Attempting uninstall: aiosignal
Found existing installation: aiosignal 1.2.0
Uninstalling aiosignal-1.2.0:
Successfully uninstalled aiosignal-1.2.0
Attempting uninstall: cryptography
Found existing installation: cryptography 37.0.2
Uninstalling cryptography-37.0.2:
Successfully uninstalled cryptography-37.0.2
Attempting uninstall: aiohttp
Found existing installation: aiohttp 3.8.1
Uninstalling aiohttp-3.8.1:
Successfully uninstalled aiohttp-3.8.1
Found existing installation: zigpy 0.47.0
Uninstalling zigpy-0.47.0:
Successfully uninstalled zigpy-0.47.0
Attempting uninstall: zigpy-deconz
Found existing installation: zigpy-deconz 0.16.0
Uninstalling zigpy-deconz-0.16.0:
Successfully uninstalled zigpy-deconz-0.16.0
Successfully installed aiohttp-3.8.1 aiosignal-1.2.0 aiosqlite-0.17.0 async-timeout-4.0.2 attrs-21.4.0 cffi-1.15.0 charset-normalizer-2.1.0 crccheck-1.1 cryptography-37.0.2 frozenlist-1.3.0 idna-3.3 multidict-6.0.2 pycparser-2.21 pyserial-3.5 pyserial-asyncio-0.6 typing_extensions-4.2.0 voluptuous-0.13.1 yarl-1.7.2 zigpy-0.47.0 zigpy-deconz-0.16.0
+ echo 15
+ sudo pip3 install --force-reinstall --upgrade zigpy-zigate==0.7.4
Collecting zigpy-zigate==0.7.4
Using cached ://www.piwheels.org/simple/zigpy-zigate/zigpy_zigate-0.7.4-py3-none-any.whl (27 kB)
Collecting zigpy>=0.22.2
Collecting RPi.GPIO
Using cached RPi.GPIO-0.7.1-cp39-cp39-linux_aarch64.whl
Collecting pyusb
Using cached ://www.piwheels.org/simple/pyusb/pyusb-1.2.1-py3-none-any.whl (58 kB)
Collecting aiohttp
Using cached aiohttp-3.8.1-cp39-cp39-manylinux_2_17_aarch64.manylinux2014_aarch64.whl (1.2 MB)
Collecting crccheck
Collecting pyserial
Using cached ://www.piwheels.org/simple/attrs/attrs-21.4.0-py2.py3-none-any.whl (60 kB)
Installing collected packages: voluptuous, RPi.GPIO, pyserial, crccheck, typing_extensions, pyusb, pyserial-asyncio, pycparser, multidict, idna, frozenlist, charset-normalizer, attrs, async-timeout, yarl, cffi, aiosqlite, aiosignal, cryptography, aiohttp, zigpy, zigpy-zigate
Attempting uninstall: RPi.GPIO
Found existing installation: RPi.GPIO 0.7.0
ERROR: Cannot uninstall 'RPi.GPIO'. It is a distutils installed project and thus we cannot accurately determine which files belong to it which would lead to only a partial uninstall.
+ echo 16
+ sudo pip3 install --force-reinstall --upgrade bellows==0.30.0
Collecting bellows==0.30.0
Using cached ://www.piwheels.org/simple/bellows/bellows-0.30.0-py3-none-any.whl (158 kB)
Collecting pyserial
Collecting pure-pcapy3==1.0.1
Using cached ://www.piwheels.org/simple/pure-pcapy3/pure_pcapy3-1.0.1-py3-none-any.whl (6.1 kB)
Collecting click-log>=0.2.1
Using cached ://www.piwheels.org/simple/click-log/click_log-0.4.0-py2.py3-none-any.whl (4.5 kB)
Collecting zigpy>=0.37.0
Collecting click
Using cached ://www.piwheels.org/simple/click/click-8.1.3-py3-none-any.whl (96 kB)
Collecting setuptools
Using cached ://www.piwheels.org/simple/setuptools/setuptools-62.6.0-py3-none-any.whl (1.2 MB)
Collecting crccheck
Collecting aiohttp
Installing collected packages: voluptuous, pyserial, crccheck, typing_extensions, setuptools, pyserial-asyncio, pycparser, multidict, idna, frozenlist, click, charset-normalizer, attrs, async-timeout, yarl, pure-pcapy3, click-log, cffi, aiosqlite, aiosignal, cryptography, aiohttp, zigpy, bellows
Attempting uninstall: setuptools
Found existing installation: setuptools 62.6.0
Uninstalling setuptools-62.6.0:
Successfully uninstalled setuptools-62.6.0
Attempting uninstall: click
Found existing installation: click 8.1.3
Uninstalling click-8.1.3:
Successfully uninstalled click-8.1.3
Attempting uninstall: pure-pcapy3
Found existing installation: pure-pcapy3 1.0.1
Uninstalling pure-pcapy3-1.0.1:
Successfully uninstalled pure-pcapy3-1.0.1
Attempting uninstall: click-log
Found existing installation: click-log 0.4.0
Uninstalling click-log-0.4.0:
Successfully uninstalled click-log-0.4.0
Attempting uninstall: bellows
Found existing installation: bellows 0.30.0
Uninstalling bellows-0.30.0:
Successfully uninstalled bellows-0.30.0
Successfully installed aiohttp-3.8.1 aiosignal-1.2.0 aiosqlite-0.17.0 async-timeout-4.0.2 attrs-21.4.0 bellows-0.30.0 cffi-1.15.0 charset-normalizer-2.1.0 click-8.1.3 click-log-0.4.0 crccheck-1.1 cryptography-37.0.2 frozenlist-1.3.0 idna-3.3 multidict-6.0.2 pure-pcapy3-1.0.1 pycparser-2.21 pyserial-3.5 pyserial-asyncio-0.6 setuptools-62.6.0 typing_extensions-4.2.0 voluptuous-0.13.1 yarl-1.7.2 zigpy-0.47.0
+ echo 17
+ sudo pip3 install --force-reinstall --upgrade zigpy==0.46.0
Collecting zigpy==0.46.0
Using cached ://www.piwheels.org/simple/zigpy/zigpy-0.46.0-py3-none-any.whl (133 kB)
Collecting crccheck
Collecting aiohttp
Installing collected packages: voluptuous, crccheck, typing_extensions, pycparser, multidict, idna, frozenlist, charset-normalizer, attrs, async-timeout, yarl, cffi, aiosqlite, aiosignal, cryptography, aiohttp, zigpy
Successfully installed aiohttp-3.8.1 aiosignal-1.2.0 aiosqlite-0.17.0 async-timeout-4.0.2 attrs-21.4.0 cffi-1.15.0 charset-normalizer-2.1.0 crccheck-1.1 cryptography-37.0.2 frozenlist-1.3.0 idna-3.3 multidict-6.0.2 pycparser-2.21 typing_extensions-4.2.0 voluptuous-0.13.1 yarl-1.7.2 zigpy-0.46.0
+ echo 18
+ sudo pip3 install --force-reinstall --upgrade xmodem
Collecting xmodem
Using cached ://www.piwheels.org/simple/xmodem/xmodem-0.4.6-py3-none-any.whl (34 kB)
Installing collected packages: xmodem
Attempting uninstall: xmodem
Found existing installation: xmodem 0.4.6
Uninstalling xmodem-0.4.6:
Successfully uninstalled xmodem-0.4.6
Successfully installed xmodem-0.4.6
+ echo 19
+ sudo pip3 install --force-reinstall --upgrade pycrypto
Collecting pycrypto
Using cached pycrypto-2.6.1-cp39-cp39-linux_aarch64.whl
Installing collected packages: pycrypto
Attempting uninstall: pycrypto
Found existing installation: pycrypto 2.6.1
Uninstalling pycrypto-2.6.1:
Successfully uninstalled pycrypto-2.6.1
Successfully installed pycrypto-2.6.1
+ echo 20
+ sudo pip3 install --force-reinstall --upgrade charset-normalizer==2.0.12
Collecting charset-normalizer==2.0.12
Using cached ://www.piwheels.org/simple/charset-normalizer/charset_normalizer-2.0.12-py3-none-any.whl (44 kB)
Installing collected packages: charset-normalizer
Successfully installed charset-normalizer-2.0.12
+ echo 21
+ sudo chmod +x /var/www/html/core/class/../../plugins/zigbee/resources/post-install.sh
+ sudo /var/www/html/core/class/../../plugins/zigbee/resources/post-install.sh
Launch post-install of zigbee dependancy
grep: /usr/local/lib/python3.7/dist-packages/bellows/zigbee/application.py: No such file or directory
/var/www/html/core/class/../../plugins/zigbee/resources/post-install.sh: line 24: [: -eq: unary operator expected
Everything is successfully installed!
+ echo 22
+ php /var/www/html/core/class/../php/jeecli.php plugin dependancy_end zigbee
+ rm /tmp/jeedom_install_in_progress_zigbee
