Bonjour à tous.
Je viens de recevoir ma clé ConBee II et d’installer le plugin deconz mais je n’arrive pas a installer en local :
* Installation deconz *
Get:1 http://archive.raspberrypi.org/debian stretch InRelease [25.4 kB]
Hit:2 http://raspbian.raspberrypi.org/raspbian stretch InRelease
Hit:3 https://deb.nodesource.com/node_12.x stretch InRelease
Fetched 25.4 kB in 1s (18.0 kB/s)
Reading package lists...
Building dependency tree...
Reading state information...
libqt5serialport5 is already the newest version (5.7.1~20161021-2).
libqt5websockets5 is already the newest version (5.7.1~20161021-4).
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
sqlite3 is already the newest version (3.16.2-5+deb9u1).
It's armv7l, RPI
--2019-11-13 20:31:41-- https://www.dresden-elektronik.de/rpi/deconz/deconz-latest.deb
Resolving www.dresden-elektronik.de (www.dresden-elektronik.de)... 62.116.169.71
Connecting to www.dresden-elektronik.de (www.dresden-elektronik.de)|62.116.169.71|:443...
connected.
HTTP request sent, awaiting response... 404 Not Found
2019-11-13 20:31:43 ERROR 404: Not Found.
dpkg-deb: error: '/tmp/deconz.deb' is not a debian format archive
dpkg: error processing archive /tmp/deconz.deb (--install):
subprocess dpkg-deb --control returned error exit status 2
Errors were encountered while processing:
/tmp/deconz.deb
Hit:1 http://raspbian.raspberrypi.org/raspbian stretch InRelease
Get:2 http://archive.raspberrypi.org/debian stretch InRelease [25.4 kB]
Fetched 25.4 kB in 1s (18.6 kB/s)
* Installation terminée *
J’ai bien installé les dépendances, activé le démon et lancé l’installation.
J’ai même désinstallé et réinstallé le plugin, redémarré jeedom en ssh un update upgrade mais rien n’y fait.
Je suis sur un RPI 3b+ sous raspbian.
c’est la journée a ce que je vois
