Est ce que cette erreur est déja arrivé a qq lors de l’install des dependances sur Jeedom V4 Buster X64 car je n’arrive pas a faire fonctionner ce plugin.
xiaomihome_dep :
Building wheels for collected packages: cryptography
Running setup.py bdist_wheel for cryptography: started
Running setup.py bdist_wheel for cryptography: finished with status 'error'
Complete output from command /usr/bin/python3 -u -c "import setuptools, tokenize;__file__='/tmp/pip-install-v0lm2l9j/cryptography/setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('
');f.close();exec(compile(code, __file__, 'exec'))" bdist_wheel -d /tmp/pip-wheel-f_3t5_bi --python-tag cp37:
running bdist_wheel
running build
running build_py
creating build
creating build/lib.linux-aarch64-3.7
creating build/lib.linux-aarch64-3.7/cryptography
copying src/cryptography/__about__.py -> build/lib.linux-aarch64-3.7/cryptography
copying src/cryptography/utils.py -> build/lib.linux-aarch64-3.7/cryptography
copying src/cryptography/exceptions.py -> build/lib.linux-aarch64-3.7/cryptography
copying src/cryptography/fernet.py -> build/lib.linux-aarch64-3.7/cryptography
copying src/cryptography/__init__.py -> build/lib.linux-aarch64-3.7/cryptography
creating build/lib.linux-aarch64-3.7/cryptography/x509
copying src/cryptography/x509/oid.py -> build/lib.linux-aarch64-3.7/cryptography/x509
copying src/cryptography/x509/name.py -> build/lib.linux-aarch64-3.7/cryptography/x509
copying src/cryptography/x509/extensions.py -> build/lib.linux-aarch64-3.7/cryptography/x509
copying src/cryptography/x509/__init__.py -> build/lib.linux-aarch64-3.7/cryptography/x509
copying src/cryptography/x509/ocsp.py -> build/lib.linux-aarch64-3.7/cryptography/x509
copying src/cryptography/x509/certificate_transparency.py -> build/lib.linux-aarch64-3.7/cryptography/x509
copying src/cryptography/x509/base.py -> build/lib.linux-aarch64-3.7/cryptography/x509
copying src/cryptography/x509/general_name.py -> build/lib.linux-aarch64-3.7/cryptography/x509
creating build/lib.linux-aarch64-3.7/cryptography/hazmat
copying src/cryptography/hazmat/_der.py -> build/lib.linux-aarch64-3.7/cryptography/hazmat
copying src/cryptography/hazmat/_oid.py -> build/lib.linux-aarch64-3.7/cryptography/hazmat
copying src/cryptography/hazmat/_types.py -> build/lib.linux-aarch64-3.7/cryptography/hazmat
copying src/cryptography/hazmat/__init__.py -> build/lib.linux-aarch64-3.7/cryptography/hazmat
creating build/lib.linux-aarch64-3.7/cryptography/hazmat/bindings
copying src/cryptography/hazmat/bindings/__init__.py -> build/lib.linux-aarch64-3.7/cryptography/hazmat/bindings
creating build/lib.linux-aarch64-3.7/cryptography/hazmat/backends
copying src/cryptography/hazmat/backends/interfaces.py -> build/lib.linux-aarch64-3.7/cryptography/hazmat/backends
copying src/cryptography/hazmat/backends/__init__.py -> build/lib.linux-aarch64-3.7/cryptography/hazmat/backends
creating build/lib.linux-aarch64-3.7/cryptography/hazmat/primitives
copying src/cryptography/hazmat/primitives/constant_time.py -> build/lib.linux-aarch64-3.7/cryptography/hazmat/primitives
copying src/cryptography/hazmat/primitives/hashes.py -> build/lib.linux-aarch64-3.7/cryptography/hazmat/primitives
copying src/cryptography/hazmat/primitives/_cipheralgorithm.py -> build/lib.linux-aarch64-3.7/cryptography/hazmat/primitives
copying src/cryptography/hazmat/primitives/_serialization.py -> build/lib.linux-aarch64-3.7/cryptography/hazmat/primitives
copying src/cryptography/hazmat/primitives/cmac.py -> build/lib.linux-aarch64-3.7/cryptography/hazmat/primitives
copying src/cryptography/hazmat/primitives/hmac.py -> build/lib.linux-aarch64-3.7/cryptography/hazmat/primitives
copying src/cryptography/hazmat/primitives/padding.py -> build/lib.linux-aarch64-3.7/cryptography/hazmat/primitives
copying src/cryptography/hazmat/primitives/_asymmetric.py -> build/lib.linux-aarch64-3.7/cryptography/hazmat/primitives
copying src/cryptography/hazmat/primitives/__init__.py -> build/lib.linux-aarch64-3.7/cryptography/hazmat/primitives
copying src/cryptography/hazmat/primitives/poly1305.py -> build/lib.linux-aarch64-3.7/cryptography/hazmat/primitives
copying src/cryptography/hazmat/primitives/keywrap.py -> build/lib.linux-aarch64-3.7/cryptography/hazmat/primitives
creating build/lib.linux-aarch64-3.7/cryptography/hazmat/bindings/openssl
copying src/cryptography/hazmat/bindings/openssl/binding.py -> build/lib.linux-aarch64-3.7/cryptography/hazmat/bindings/openssl
copying src/cryptography/hazmat/bindings/openssl/_conditional.py -> build/lib.linux-aarch64-3.7/cryptography/hazmat/bindings/openssl
copying src/cryptography/hazmat/bindings/openssl/__init__.py -> build/lib.linux-aarch64-3.7/cryptography/hazmat/bindings/openssl
creating build/lib.linux-aarch64-3.7/cryptography/hazmat/backends/openssl
copying src/cryptography/hazmat/backends/openssl/backend.py -> build/lib.linux-aarch64-3.7/cryptography/hazmat/backends/openssl
copying src/cryptography/hazmat/backends/openssl/ed448.py -> build/lib.linux-aarch64-3.7/cryptography/hazmat/backends/openssl
copying src/cryptography/hazmat/backends/openssl/hashes.py -> build/lib.linux-aarch64-3.7/cryptography/hazmat/backends/openssl
copying src/cryptography/hazmat/backends/openssl/x448.py -> build/lib.linux-aarch64-3.7/cryptography/hazmat/backends/openssl
copying src/cryptography/hazmat/backends/openssl/aead.py -> build/lib.linux-aarch64-3.7/cryptography/hazmat/backends/openssl
copying src/cryptography/hazmat/backends/openssl/utils.py -> build/lib.linux-aarch64-3.7/cryptography/hazmat/backends/openssl
copying src/cryptography/hazmat/backends/openssl/dsa.py -> build/lib.linux-aarch64-3.7/cryptography/hazmat/backends/openssl
copying src/cryptography/hazmat/backends/openssl/cmac.py -> build/lib.linux-aarch64-3.7/cryptography/hazmat/backends/openssl
copying src/cryptography/hazmat/backends/openssl/dh.py -> build/lib.linux-aarch64-3.7/cryptography/hazmat/backends/openssl
copying src/cryptography/hazmat/backends/openssl/x25519.py -> build/lib.linux-aarch64-3.7/cryptography/hazmat/backends/openssl
copying src/cryptography/hazmat/backends/openssl/hmac.py -> build/lib.linux-aarch64-3.7/cryptography/hazmat/backends/openssl
copying src/cryptography/hazmat/backends/openssl/rsa.py -> build/lib.linux-aarch64-3.7/cryptography/hazmat/backends/openssl
copying src/cryptography/hazmat/backends/openssl/ed25519.py -> build/lib.linux-aarch64-3.7/cryptography/hazmat/backends/openssl
copying src/cryptography/hazmat/backends/openssl/ciphers.py -> build/lib.linux-aarch64-3.7/cryptography/hazmat/backends/openssl
copying src/cryptography/hazmat/backends/openssl/decode_asn1.py -> build/lib.linux-aarch64-3.7/cryptography/hazmat/backends/openssl
copying src/cryptography/hazmat/backends/openssl/x509.py -> build/lib.linux-aarch64-3.7/cryptography/hazmat/backends/openssl
copying src/cryptography/hazmat/backends/openssl/encode_asn1.py -> build/lib.linux-aarch64-3.7/cryptography/hazmat/backends/openssl
copying src/cryptography/hazmat/backends/openssl/__init__.py -> build/lib.linux-aarch64-3.7/cryptography/hazmat/backends/openssl
copying src/cryptography/hazmat/backends/openssl/ocsp.py -> build/lib.linux-aarch64-3.7/cryptography/hazmat/backends/openssl
copying src/cryptography/hazmat/backends/openssl/poly1305.py -> build/lib.linux-aarch64-3.7/cryptography/hazmat/backends/openssl
copying src/cryptography/hazmat/backends/openssl/ec.py -> build/lib.linux-aarch64-3.7/cryptography/hazmat/backends/openssl
creating build/lib.linux-aarch64-3.7/cryptography/hazmat/primitives/ciphers
copying src/cryptography/hazmat/primitives/ciphers/modes.py -> build/lib.linux-aarch64-3.7/cryptography/hazmat/primitives/ciphers
copying src/cryptography/hazmat/primitives/ciphers/aead.py -> build/lib.linux-aarch64-3.7/cryptography/hazmat/primitives/ciphers
copying src/cryptography/hazmat/primitives/ciphers/algorithms.py -> build/lib.linux-aarch64-3.7/cryptography/hazmat/primitives/ciphers
copying src/cryptography/hazmat/primitives/ciphers/__init__.py -> build/lib.linux-aarch64-3.7/cryptography/hazmat/primitives/ciphers
copying src/cryptography/hazmat/primitives/ciphers/base.py -> build/lib.linux-aarch64-3.7/cryptography/hazmat/primitives/ciphers
creating build/lib.linux-aarch64-3.7/cryptography/hazmat/primitives/asymmetric
copying src/cryptography/hazmat/primitives/asymmetric/ed448.py -> build/lib.linux-aarch64-3.7/cryptography/hazmat/primitives/asymmetric
copying src/cryptography/hazmat/primitives/asymmetric/x448.py -> build/lib.linux-aarch64-3.7/cryptography/hazmat/primitives/asymmetric
copying src/cryptography/hazmat/primitives/asymmetric/utils.py -> build/lib.linux-aarch64-3.7/cryptography/hazmat/primitives/asymmetric
copying src/cryptography/hazmat/primitives/asymmetric/dsa.py -> build/lib.linux-aarch64-3.7/cryptography/hazmat/primitives/asymmetric
copying src/cryptography/hazmat/primitives/asymmetric/dh.py -> build/lib.linux-aarch64-3.7/cryptography/hazmat/primitives/asymmetric
copying src/cryptography/hazmat/primitives/asymmetric/x25519.py -> build/lib.linux-aarch64-3.7/cryptography/hazmat/primitives/asymmetric
copying src/cryptography/hazmat/primitives/asymmetric/rsa.py -> build/lib.linux-aarch64-3.7/cryptography/hazmat/primitives/asymmetric
copying src/cryptography/hazmat/primitives/asymmetric/padding.py -> build/lib.linux-aarch64-3.7/cryptography/hazmat/primitives/asymmetric
copying src/cryptography/hazmat/primitives/asymmetric/ed25519.py -> build/lib.linux-aarch64-3.7/cryptography/hazmat/primitives/asymmetric
copying src/cryptography/hazmat/primitives/asymmetric/__init__.py -> build/lib.linux-aarch64-3.7/cryptography/hazmat/primitives/asymmetric
copying src/cryptography/hazmat/primitives/asymmetric/ec.py -> build/lib.linux-aarch64-3.7/cryptography/hazmat/primitives/asymmetric
creating build/lib.linux-aarch64-3.7/cryptography/hazmat/primitives/twofactor
copying src/cryptography/hazmat/primitives/twofactor/totp.py -> build/lib.linux-aarch64-3.7/cryptography/hazmat/primitives/twofactor
copying src/cryptography/hazmat/primitives/twofactor/utils.py -> build/lib.linux-aarch64-3.7/cryptography/hazmat/primitives/twofactor
copying src/cryptography/hazmat/primitives/twofactor/hotp.py -> build/lib.linux-aarch64-3.7/cryptography/hazmat/primitives/twofactor
copying src/cryptography/hazmat/primitives/twofactor/__init__.py -> build/lib.linux-aarch64-3.7/cryptography/hazmat/primitives/twofactor
creating build/lib.linux-aarch64-3.7/cryptography/hazmat/primitives/serialization
copying src/cryptography/hazmat/primitives/serialization/pkcs12.py -> build/lib.linux-aarch64-3.7/cryptography/hazmat/primitives/serialization
copying src/cryptography/hazmat/primitives/serialization/pkcs7.py -> build/lib.linux-aarch64-3.7/cryptography/hazmat/primitives/serialization
copying src/cryptography/hazmat/primitives/serialization/ssh.py -> build/lib.linux-aarch64-3.7/cryptography/hazmat/primitives/serialization
copying src/cryptography/hazmat/primitives/serialization/__init__.py -> build/lib.linux-aarch64-3.7/cryptography/hazmat/primitives/serialization
copying src/cryptography/hazmat/primitives/serialization/base.py -> build/lib.linux-aarch64-3.7/cryptography/hazmat/primitives/serialization
creating build/lib.linux-aarch64-3.7/cryptography/hazmat/primitives/kdf
copying src/cryptography/hazmat/primitives/kdf/scrypt.py -> build/lib.linux-aarch64-3.7/cryptography/hazmat/primitives/kdf
copying src/cryptography/hazmat/primitives/kdf/kbkdf.py -> build/lib.linux-aarch64-3.7/cryptography/hazmat/primitives/kdf
copying src/cryptography/hazmat/primitives/kdf/hkdf.py -> build/lib.linux-aarch64-3.7/cryptography/hazmat/primitives/kdf
copying src/cryptography/hazmat/primitives/kdf/concatkdf.py -> build/lib.linux-aarch64-3.7/cryptography/hazmat/primitives/kdf
copying src/cryptography/hazmat/primitives/kdf/x963kdf.py -> build/lib.linux-aarch64-3.7/cryptography/hazmat/primitives/kdf
copying src/cryptography/hazmat/primitives/kdf/pbkdf2.py -> build/lib.linux-aarch64-3.7/cryptography/hazmat/primitives/kdf
copying src/cryptography/hazmat/primitives/kdf/__init__.py -> build/lib.linux-aarch64-3.7/cryptography/hazmat/primitives/kdf
running egg_info
writing src/cryptography.egg-info/PKG-INFO
writing dependency_links to src/cryptography.egg-info/dependency_links.txt
writing requirements to src/cryptography.egg-info/requires.txt
writing top-level names to src/cryptography.egg-info/top_level.txt
adding license file 'LICENSE' (matched pattern 'LICEN[CS]E*')
adding license file 'LICENSE.PSF' (matched pattern 'LICEN[CS]E*')
adding license file 'LICENSE.APACHE' (matched pattern 'LICEN[CS]E*')
adding license file 'LICENSE.BSD' (matched pattern 'LICEN[CS]E*')
reading manifest file 'src/cryptography.egg-info/SOURCES.txt'
reading manifest template 'MANIFEST.in'
no previously-included directories found matching 'docs/_build'
warning: no previously-included files found matching 'vectors'
warning: no previously-included files matching '*' found under directory 'vectors'
warning: no previously-included files matching '*' found under directory '.github'
warning: no previously-included files found matching 'release.py'
warning: no previously-included files found matching '.coveragerc'
warning: no previously-included files found matching 'codecov.yml'
warning: no previously-included files found matching '.readthedocs.yml'
warning: no previously-included files found matching 'dev-requirements.txt'
warning: no previously-included files found matching 'tox.ini'
warning: no previously-included files found matching 'mypy.ini'
warning: no previously-included files matching '*' found under directory '.zuul.d'
warning: no previously-included files matching '*' found under directory '.zuul.playbooks'
writing manifest file 'src/cryptography.egg-info/SOURCES.txt'
copying src/cryptography/py.typed -> build/lib.linux-aarch64-3.7/cryptography
running build_ext
generating cffi module 'build/temp.linux-aarch64-3.7/_padding.c'
creating build/temp.linux-aarch64-3.7
generating cffi module 'build/temp.linux-aarch64-3.7/_openssl.c'
running build_rust
=============================DEBUG ASSISTANCE=============================
If you are seeing a compilation error please try the following steps to
successfully install cryptography:
1) Upgrade to the latest pip and try again. This will fix errors for most
users. See: https://pip.pypa.io/en/stable/installing/#upgrading-pip
2) Read https://cryptography.io/en/latest/installation.html for specific
instructions for your platform.
3) Check our frequently asked questions for more information:
https://cryptography.io/en/latest/faq.html
4) Ensure you have a recent Rust toolchain installed:
https://cryptography.io/en/latest/installation.html#rust
5) If you are experiencing issues with Rust for *this release only* you may
set the environment variable `CRYPTOGRAPHY_DONT_BUILD_RUST=1`.
error: can't find Rust compiler
If you are using an outdated pip version, it is possible a prebuilt wheel is available for this package but pip is not able to install from it. Installing from the wheel would avoid the need for a Rust compiler.
To update pip, run:
pip install --upgrade pip
and then retry package installation.
If you did intend to build this package from source, try installing a Rust compiler from your system package manager and ensure it is on the PATH during installation. Alternatively, rustup (available at https://rustup.rs) is the recommended way to download and update the Rust compiler toolchain.
This package requires Rust >=1.41.0.
Failed building wheel for cryptography
Running setup.py clean for cryptography
');f.close();exec(compile(code, __file__, 'exec'))" clean --all:
running clean
removing 'build/temp.linux-aarch64-3.7' (and everything under it)
removing 'build/lib.linux-aarch64-3.7' (and everything under it)
'build/bdist.linux-aarch64' does not exist -- can't clean it
'build/scripts-3.7' does not exist -- can't clean it
removing 'build'
running clean_rust
To update pip, run:
Failed cleaning build dir for cryptography
Failed to build cryptography
PIP upgrade = Idem KO
PIP upgrade Crypto = Idem KO
Install manuel de rust = Idem KO
cargo --version --verbose
cargo 1.51.0 (43b129a20 2021-03-16)
release: 1.51.0
commit-hash: 43b129a20fbf1ede0df411396ccf0c024bf34134
commit-date: 2021-03-16
Merci de votre aide
