Il s’agit de mes premiers messages donc je n’ai pas encore la capacité à envoyer des fichiers.
En texte du coup :
[2024-07-12 16:57:59] e[32minfoe[39m: z2m: Zigbee2MQTT started!
[2024-07-12 16:58:00] e[34mdebuge[39m: z2m:mqtt: Received MQTT message on 'zigbee2mqtt/bridge/request/permit_join' with data '{"value":true,"time":180}'
[2024-07-12 16:58:00] e[32minfoe[39m: z2m: Zigbee: allowing new devices to join.
[2024-07-12 16:58:00] e[34mdebuge[39m: zh:zstack:znp: SREQ: --> ZDO - mgmtPermitJoinReq - {"addrmode":15,"dstaddr":65532,"duration":254,"tcsignificance":0}
[2024-07-12 16:58:00] e[34mdebuge[39m: zh:zstack:unpi:writer: --> frame [254,5,37,54,15,252,255,254,0,228]
[2024-07-12 16:58:00] e[34mdebuge[39m: zh:zstack:unpi:parser: <-- [254,1,101,54,0,82,254,3,69,182,0,0,0,240]
[2024-07-12 16:58:00] e[34mdebuge[39m: zh:zstack:unpi:parser: --- parseNext [254,1,101,54,0,82,254,3,69,182,0,0,0,240]
[2024-07-12 16:58:00] e[34mdebuge[39m: zh:zstack:unpi:parser: --> parsed 1 - 3 - 5 - 54 - [0] - 82
[2024-07-12 16:58:00] e[34mdebuge[39m: zh:zstack:znp: SRSP: <-- ZDO - mgmtPermitJoinReq - {"status":0}
[2024-07-12 16:58:00] e[34mdebuge[39m: zh:zstack:unpi:parser: --- parseNext [254,3,69,182,0,0,0,240]
[2024-07-12 16:58:00] e[34mdebuge[39m: zh:zstack:unpi:parser: --> parsed 3 - 2 - 5 - 182 - [0,0,0] - 240
[2024-07-12 16:58:00] e[34mdebuge[39m: zh:zstack:znp: AREQ: <-- ZDO - mgmtPermitJoinRsp - {"srcaddr":0,"status":0}
[2024-07-12 16:58:00] e[34mdebuge[39m: zh:zstack:unpi:parser: --- parseNext []
[2024-07-12 16:58:00] e[34mdebuge[39m: zh:zstack:znp: SREQ: --> AF - dataRequestExt - {"dstaddrmode":2,"dstaddr":"0x000000000000fffd","destendpoint":242,"dstpanid":0,"srcendpoint":242,"clusterid":33,"transid":2,"options":0,"radius":30,"len":6,"data":{"type":"Buffer","data":[25,3,2,11,254,0]}}
[2024-07-12 16:58:00] e[34mdebuge[39m: zh:zstack:unpi:writer: --> frame [254,26,36,2,2,253,255,0,0,0,0,0,0,242,0,0,242,33,0,2,0,30,6,0,25,3,2,11,254,0,234]
[2024-07-12 16:58:00] e[34mdebuge[39m: zh:zstack:unpi:parser: <-- [254,1,100,2,0,103]
[2024-07-12 16:58:00] e[34mdebuge[39m: zh:zstack:unpi:parser: --- parseNext [254,1,100,2,0,103]
[2024-07-12 16:58:00] e[34mdebuge[39m: zh:zstack:unpi:parser: --> parsed 1 - 3 - 4 - 2 - [0] - 103
[2024-07-12 16:58:00] e[34mdebuge[39m: zh:zstack:znp: SRSP: <-- AF - dataRequestExt - {"status":0}
[2024-07-12 16:58:00] e[34mdebuge[39m: zh:zstack:unpi:parser: <-- [254,3,68,128,225,242,2,214]
[2024-07-12 16:58:00] e[34mdebuge[39m: zh:zstack:unpi:parser: --- parseNext [254,3,68,128,225,242,2,214]
[2024-07-12 16:58:00] e[34mdebuge[39m: zh:zstack:unpi:parser: --> parsed 3 - 2 - 4 - 128 - [225,242,2] - 214
[2024-07-12 16:58:00] e[34mdebuge[39m: zh:zstack:znp: AREQ: <-- AF - dataConfirm - {"status":225,"endpoint":242,"transid":2}
[2024-07-12 16:58:00] e[32minfoe[39m: z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/bridge/response/permit_join', payload '{"data":{"time":180,"value":true},"status":"ok"}'
La page Santé :
Matériel diy Système à jour OK
Etat du service fail2ban Actif Cron actif OK
Scénario actif OK Démarré OK 2024-07-12 11:25:11
Date système (dernière heure enregistrée) OK 2024-07-12 17:01:57 (2024-07-12 16:16:03) Droits sudo OK
Version Jeedom 4.4.8.1 Version OS debian 11.10
Version PHP 7.4.33 Nombre de processus Apache 12
Version OS Linux jeedom 5.10.0-30-amd64 #1 SMP Debian 5.10.218-1 (2024-06-01) x86_64 GNU/Linux [11.10] Version database 10.5.23-MariaDB-0+deb11u1
Espace disque libre 19 % Connexion active/max/autorisée 11/22/151
Espace disque libre tmp 97 % Mémoire disponible 40 % (Total 965 Mo)
Mémoire suffisante 0 Erreur I/O 0
Swap disponible 75 % (Total 975 Mo) Swapiness 10 %
Charge 1.08 - 1.09 - 0.88 Configuration réseau interne OK
Configuration réseau externe OK Node v18.20.4
Python 3 Python 3.9.2 Persistance du cache OK (2024-07-12 17:00:12)
Apache private tmp OK Plugins OK
Merci,
