j’essaye d’inclure ce module. il me semble que l’inclusion se passe correctement mais lors de la synchronisation, une erreur apparait. vous trouverez ci joint la log en mode debug.
Pouvez vous me dire ce qui ne fonctionne pas ?
[2021-08-14 22:37:16][DEBUG] : http://127.0.0.1:8089/application/include type : PUT
[2021-08-14 22:37:16][DEBUG] : {"duration":180}
[2021-08-14 2
2:37:16][DEBUG] : ""
[2021-08-14 22:37:37][DEBUG] : {"devices":{"80:4b:50:ff:fe:bb:d6:71":{"1":{"8":[{"value":"254","cluster_name":"Level control"}],"258":{"8":{"value":"100","cluster_name":"Window Covering"}}}}}}
[2021-08-14 22:38:06][DEBUG] : {"device_left":"80:4b:50:ff:fe:bb:d6:71"}
[2021-08-14 22:38:12][DEBUG] : {"device_joined":"80:4b:50:ff:fe:bb:d6:71"}
[2021-08-14 22:38:12][DEBUG] : {"device_initialized":"80:4b:50:ff:fe:bb:d6:71"}
[2021-08-14 22:38:15][DEBUG] : {"devices":{"80:4b:50:ff:fe:b9:64:80":{"1":{"8":[{"value":"0","cluster_name":"Level control"}],"6":[{"value":"Bool.true","cluster_name":"On\/Off"}]}}}}
[2021-08-14 22:38:19][DEBUG] : {"devices":{"80:4b:50:ff:fe:b9:64:80":{"1":{"258":{"8":{"value":"0","cluster_name":"Window Covering"}}}}}}
[2021-08-14 22:38:42][DEBUG] : http://127.0.0.1:8089/device/all?with_attributes=2 type : GET
[2021-08-14 22:38:42][DEBUG] : {"with_attributes":2}
[2021-08-14 22:38:42][DEBUG] : {"device_initialized":"80:4b:50:ff:fe:bb:d6:71"}
[2021-08-14 22:39:12][DEBUG] : http://127.0.0.1:8089/device/all?with_attributes=2 type : GET
[2021-08-14 22:39:12][DEBUG] : {"with_attributes":2}
[2021-08-14 22:39:12][DEBUG] : {"device_initialized":"80:4b:50:ff:fe:bb:d6:71"}
[2021-08-14 22:39:42][DEBUG] : http://127.0.0.1:8089/device/all?with_attributes=2 type : GET
[2021-08-14 22:39:42][DEBUG] : {"with_attributes":2}
[2021-08-14 22:40:13][DEBUG] : http://127.0.0.1:8089/device/all?with_attributes=2 type : GET
[2021-08-14 22:40:13][DEBUG] : {"with_attributes":2}
[2021-08-14 22:42:44][DEBUG] : http://127.0.0.1:8089/application/info type : GET
[2021-08-14 22:42:44][DEBUG] : null
[2021-08-14 22:42:44][DEBUG] : {"ieee":"00:15:8d:00:00:56:82:03","version":"0.36.2","nwk":0,"config":{"database_path":"\/var\/www\/html\/plugins\/zigbee\/data\/1\/network_zigate.db","device":{"path":"\/dev\/ttyS0"},"network":{"channel":15,"key":null,"update_id":0,"key_sequence_number":0,"tc_address":null,"tc_link_key":"5a:69:67:42:65:65:41:6c:6c:69:61:6e:63:65:30:39","pan_id":null,"channels":34635776,"extended_pan_id":null},"topology_scan_period":240,"topology_scan_skip_coordinator":false,"topology_scan_enabled":true,"ota":{"otau_directory":null,"ikea_provider":false,"ledvance_provider":false}},"zigate":{"version":"3.1e"}}
[2021-08-14 22:42:44][DEBUG] : http://127.0.0.1:8089/network/map type : GET
[2021-08-14 22:42:44][DEBUG] : http://127.0.0.1:8089/device/all?with_attributes=0 type : GET
[2021-08-14 22:42:44][DEBUG] : {"with_attributes":0}
[2021-08-14 22:45:55][DEBUG] : {"devices":{"80:4b:50:ff:fe:bb:d6:71":{"1":{"6":[{"value":"Bool.true","cluster_name":"On\/Off"}]}}}}
[2021-08-14 22:52:32][DEBUG] : {"devices":{"80:4b:50:ff:fe:bb:d6:71":{"1":{"8":[{"value":"254","cluster_name":"Level control"}]}}}}
[2021-08-14 22:53:07][DEBUG] : http://127.0.0.1:8089/device/all?with_attributes=2 type : GET
[2021-08-14 22:53:07][DEBUG] : {"with_attributes":2}
[2021-08-14 22:53:08][DEBUG] : {"devices":{"80:4b:50:ff:fe:bb:d6:71":{"1":{"258":{"8":{"value":"100","cluster_name":"Window Covering"}}}}}}
[2021-08-14 22:53:11][DEBUG] : {"devices":{"80:4b:50:ff:fe:b9:64:80":{"1":{"6":[{"value":"Bool.true","cluster_name":"On\/Off"}],"8":[{"value":"0","cluster_name":"Level control"}]}}}}
[2021-08-14 22:53:16][DEBUG] : {"devices":{"80:4b:50:ff:fe:b9:64:80":{"1":{"258":{"8":{"value":"0","cluster_name":"Window Covering"}}}}}}
[2021-08-14 22:59:30][INFO] : Lancement démon zigbeed : /usr/bin/python3 /var/www/html/plugins/zigbee/resources/zigbeed/zigbeed.py --device /dev/ttyS0 --loglevel debug --socketport 8089 --callback http://127.0.0.1:80/plugins/zigbee/core/php/jeeZigbee.php --apikey OeVJ47hVhvTpSxKODQPIJwds14i2XW4r --cycle 0.3 --pid /tmp/jeedom/zigbee/deamon_1.pid --data_folder /var/www/html/plugins/zigbee/data/1 --device_folder /var/www/html/plugins/zigbee/data/device --controller zigate --sub_controller auto --channel 15
[2021-08-14 22:59:31][DEBUG] : null
[2021-08-14 22:59:57][DEBUG] : http://127.0.0.1:8089/device/all?with_attributes=2 type : GET
[2021-08-14 22:59:57][DEBUG] : {"with_attributes":2}
[2021-08-14 23:00:01][DEBUG] : http://127.0.0.1:8089/device/all type : GET
[2021-08-14 23:00:01][DEBUG] : null
[2021-08-14 23:00:01][ERROR] : Erreur lors de la requete : http://127.0.0.1:8089/device/all(GET), data : null erreur : {"state":"error","result":"'NoneType' object has no attribute 'is_valid'","code":0}
[2021-08-14 23:00:51][DEBUG] : {"devices":{"80:4b:50:ff:fe:bb:d6:71":{"1":{"6":[{"value":"Bool.true","cluster_name":"On\/Off"}]}}}}
Merci par avance pour votre aide
