Bjr,
Découvert le plugin hier , install et pas possible d’installer les dépendances. NOK après 5%
Log devolo_cpl_deamon
File "/var/www/html/plugins/devolo_cpl/resources/bin/devolo_cpld.py", line 30, in
import httpx
ModuleNotFoundError: No module named 'httpx'
+ touch /tmp/jeedom_install_in_progress_devolo_cpl
+ echo 1
+ echo 2
++ find /usr/local/lib/python2.7/dist-packages/ /usr/local/lib/python3.7/dist-packages/ -mindepth 1 -maxdepth 1 -type d -exec du -ks '{}' +
++ awk '$1 <= 4'
++ cut -f 2-
+ RESULTTODELETE=
++ echo ''
++ sed 's, ,\ ,g'
+ RESULTTODELETE2=
+ echo ''
+ xargs rm -rf
+ echo 3
+ sudo pip3 cache purge
Files removed: 35
+ echo 4
+ sudo pip3 install --upgrade pip
Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple
Requirement already satisfied: pip in /usr/local/lib/python3.7/dist-packages (23.1.2)
WARNING: Error parsing requirements for idna: [Errno 2] Aucun fichier ou dossier de ce type: '/usr/local/lib/python3.7/dist-packages/idna-3.3.dist-info/METADATA'
WARNING: Running pip as the 'root' user can result in broken permissions and conflicting behaviour with the system package manager. It is recommended to use a virtual environment instead: https://pip.pypa.io/warnings/venv
+ echo 5
+ sudo pip3 install --force-reinstall --upgrade requests
Collecting requests
Downloading https://www.piwheels.org/simple/requests/requests-2.31.0-py3-none-any.whl (62 kB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 62.6/62.6 kB 1.5 MB/s eta 0:00:00
Collecting charset-normalizer<4,>=2 (from requests)
Downloading charset_normalizer-3.1.0-py3-none-any.whl (46 kB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 46.2/46.2 kB 1.9 MB/s eta 0:00:00
Collecting idna<4,>=2.5 (from requests)
Downloading https://www.piwheels.org/simple/idna/idna-3.4-py3-none-any.whl (61 kB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 61.5/61.5 kB 1.5 MB/s eta 0:00:00
Collecting urllib3<3,>=1.21.1 (from requests)
Downloading https://www.piwheels.org/simple/urllib3/urllib3-2.0.3-py3-none-any.whl (123 kB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 123.6/123.6 kB 3.1 MB/s eta 0:00:00
Collecting certifi>=2017.4.17 (from requests)
Downloading https://www.piwheels.org/simple/certifi/certifi-2023.5.7-py3-none-any.whl (156 kB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 156.9/156.9 kB 6.6 MB/s eta 0:00:00
Installing collected packages: urllib3, idna, charset-normalizer, certifi, requests
Attempting uninstall: urllib3
Found existing installation: urllib3 2.0.3
Uninstalling urllib3-2.0.3:
Successfully uninstalled urllib3-2.0.3
Attempting uninstall: idna
WARNING: No metadata found in /usr/local/lib/python3.7/dist-packages
Found existing installation: idna 3.3
ERROR: Cannot uninstall idna 3.3, RECORD file not found. You might be able to recover from this via: 'pip install --force-reinstall --no-deps idna==3.3'.
+ echo 6
+ sudo pip3 install --force-reinstall --upgrade httpx==0.21.0
Collecting httpx==0.21.0
Downloading https://www.piwheels.org/simple/httpx/httpx-0.21.0-py3-none-any.whl (83 kB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 83.1/83.1 kB 1.5 MB/s eta 0:00:00
Collecting certifi (from httpx==0.21.0)
Using cached https://www.piwheels.org/simple/certifi/certifi-2023.5.7-py3-none-any.whl (156 kB)
Collecting charset-normalizer (from httpx==0.21.0)
Using cached charset_normalizer-3.1.0-py3-none-any.whl (46 kB)
Collecting sniffio (from httpx==0.21.0)
Downloading https://www.piwheels.org/simple/sniffio/sniffio-1.3.0-py3-none-any.whl (10 kB)
Collecting rfc3986[idna2008]<2,>=1.3 (from httpx==0.21.0)
Downloading https://www.piwheels.org/simple/rfc3986/rfc3986-1.5.0-py2.py3-none-any.whl (31 kB)
Collecting httpcore<0.15.0,>=0.14.0 (from httpx==0.21.0)
Downloading https://www.piwheels.org/simple/httpcore/httpcore-0.14.7-py3-none-any.whl (68 kB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 68.3/68.3 kB 1.7 MB/s eta 0:00:00
Collecting h11<0.13,>=0.11 (from httpcore<0.15.0,>=0.14.0->httpx==0.21.0)
Downloading https://www.piwheels.org/simple/h11/h11-0.12.0-py3-none-any.whl (54 kB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 54.9/54.9 kB 5.3 MB/s eta 0:00:00
Collecting anyio==3.* (from httpcore<0.15.0,>=0.14.0->httpx==0.21.0)
Downloading https://www.piwheels.org/simple/anyio/anyio-3.7.0-py3-none-any.whl (80 kB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 80.9/80.9 kB 6.6 MB/s eta 0:00:00
Collecting idna>=2.8 (from anyio==3.*->httpcore<0.15.0,>=0.14.0->httpx==0.21.0)
Using cached https://www.piwheels.org/simple/idna/idna-3.4-py3-none-any.whl (61 kB)
Collecting exceptiongroup (from anyio==3.*->httpcore<0.15.0,>=0.14.0->httpx==0.21.0)
Downloading https://www.piwheels.org/simple/exceptiongroup/exceptiongroup-1.1.1-py3-none-any.whl (14 kB)
Collecting typing-extensions (from anyio==3.*->httpcore<0.15.0,>=0.14.0->httpx==0.21.0)
Downloading https://www.piwheels.org/simple/typing-extensions/typing_extensions-4.6.3-py3-none-any.whl (31 kB)
Un grand merci par avance pour votre aide.
