Impossible d'intégrer la télécommande
Merci Madcow. Non effectivement, j’étais en 9.12.0.
J’ai fait les mises à jour et la galère avec les dépendances. Puis suis tombé sur votre post Interface Zwave JS UI non accessible - error TS2345: Argument of type 'unknown' is not assignable to parameter of type 'string' de bug. Merci pour la mise à jour du plugin cette nuit à 1h03 :smiley: .
Maintenant j’ai bien de nouveau accès à Zwavejs UI.
Du coup je peux voir les logs (en verbose) directement sous Zwavejs UI :
2024-11-16 10:24:58.057 INFO MQTT: Message received on zwave/_CLIENTS/ZWAVE_GATEWAY-Jeedom/api/startInclusion/set: '{"args":[2,{"forceSecurity":false}],"type":"inclusion"}'
2024-11-16 10:24:58.059 INFO Z-WAVE: Calling api startInclusion with args: [ 2, { forceSecurity: false }, [length]: 2 ]
2024-11-16 10:24:58.126 INFO Z-WAVE: Controller status: Non-secure inclusion started
2024-11-16 10:24:58.128 INFO Z-WAVE: Success zwave api call startInclusion true
2024-11-16 10:24:58.174 INFO MQTT: Message received on zwave/_CLIENTS/ZWAVE_GATEWAY-Jeedom/api/startInclusion: '{"success":true,"message":"Success zwave api call","result":true,"args":[2,{"forceSecurity":false}],"origin":{"args":[2,{"forceSecurity":false}],"type":"inclusion"}}'
2024-11-16 10:25:58.124 INFO Z-WAVE: Controller status: Inclusion stopped
2024-11-16 10:26:01.251 INFO MQTT: Message received on zwave/_CLIENTS/ZWAVE_GATEWAY-Jeedom/api/startExclusion/set: '{"type":"inclusion"}'
2024-11-16 10:26:01.253 INFO Z-WAVE: Calling api startExclusion with args: [ [length]: 0 ]
2024-11-16 10:26:01.276 INFO Z-WAVE: Controller status: Exclusion started
2024-11-16 10:26:01.277 INFO Z-WAVE: Success zwave api call startExclusion true
2024-11-16 10:26:01.321 INFO MQTT: Message received on zwave/_CLIENTS/ZWAVE_GATEWAY-Jeedom/api/startExclusion: '{"success":true,"message":"Success zwave api call","result":true,"args":[],"origin":{"type":"inclusion"}}'
2024-11-16 10:26:08.125 INFO Z-WAVE: Controller status: Exclusion stopped
2024-11-16 10:26:25.284 INFO MQTT: Message received on zwave/_CLIENTS/ZWAVE_GATEWAY-Jeedom/api/startInclusion/set: '{"args":[2,{"forceSecurity":false}],"type":"inclusion"}'
2024-11-16 10:26:25.287 INFO Z-WAVE: Calling api startInclusion with args: [ 2, { forceSecurity: false }, [length]: 2 ]
2024-11-16 10:26:25.358 INFO Z-WAVE: Controller status: Non-secure inclusion started
2024-11-16 10:26:25.361 INFO Z-WAVE: Success zwave api call startInclusion true
2024-11-16 10:26:25.406 INFO MQTT: Message received on zwave/_CLIENTS/ZWAVE_GATEWAY-Jeedom/api/startInclusion: '{"success":true,"message":"Success zwave api call","result":true,"args":[2,{"forceSecurity":false}],"origin":{"args":[2,{"forceSecurity":false}],"type":"inclusion"}}'
2024-11-16 10:27:25.354 INFO Z-WAVE: Controller status: Inclusion stopped
On y voit que j’ai lancé une inclusion non sécurisée (depuis jeedom). Et une minute après ça s’arrête. J’ai appuyé 6 fois sur la télécommande pour lancer son inclusion, elle clignote bleue mais n’est pas détectée.
Puis j’ai lancé une exclusion. Et 7 secondes après l’exclusion s’arrête. Car j’ai appuyé 6 fois sur la télécommande, clignote bleue puis immédiatement rouge. Les devices ont certainement réussi à communiquer ensemble.
Enfin j’ai réessayé encore à l’inclure mais rien n’y fait.
Après j’ai réessayé une inclusion depuis Zwavejs ui mais ça finit en timeout.
Au final ce comportement est assez identique qu’avec l’autre télécommande (lien dans l’autre post), où « j’arrive » à l’exclure mais pas à l’inclure.
