J’ai installé pour la première fois le plug in zwave, mais les dépendances ne s’installent pas
J’ai essayé quelques solutions proposées dans le forum sans succès :
apt update
apt upgrade
pip install --upgrade setuptools
python -m pip install --upgrade pip
python3 -m pip install --upgrade pip
La sortie de log ne m’inspire pas vraiment
Si une âme charitable pourrait me mettre sur la voie j’avoue être perdu.
DEPRECATION: Python 2.7 reached the end of its life on January 1st, 2020. Please upgrade your Python as Python 2.7 is no longer maintained. pip 21.0 will drop support for Python 2.7 in January 2021. More details about Python 2 support in pip, can be found at https://pip.pypa.io/en/latest/development/release-process/#python-2-support
Requirement already satisfied: pylint in /usr/local/lib/python2.7/dist-packages (1.9.5)
Requirement already satisfied: singledispatch; python_version < "3.4" in /usr/local/lib/python2.7/dist-packages (from pylint) (3.4.0.3)
Requirement already satisfied: backports.functools-lru-cache; python_version == "2.7" in /usr/local/lib/python2.7/dist-packages (from pylint) (1.6.1)
Requirement already satisfied: configparser; python_version == "2.7" in /usr/lib/python2.7/dist-packages (from pylint) (3.5.0b2)
Requirement already satisfied: mccabe in /usr/local/lib/python2.7/dist-packages (from pylint) (0.6.1)
Requirement already satisfied: six in /usr/lib/python2.7/dist-packages (from pylint) (1.12.0)
Requirement already satisfied: isort>=4.2.5 in /usr/local/lib/python2.7/dist-packages (from pylint) (4.3.21)
Requirement already satisfied: astroid<2.0,>=1.6 in /usr/local/lib/python2.7/dist-packages (from pylint) (1.6.6)
Requirement already satisfied: futures; python_version < "3.2" in /usr/local/lib/python2.7/dist-packages (from isort>=4.2.5->pylint) (3.3.0)
Requirement already satisfied: wrapt in /usr/local/lib/python2.7/dist-packages (from astroid<2.0,>=1.6->pylint) (1.12.1)
Requirement already satisfied: enum34>=1.1.3; python_version < "3.4" in /usr/lib/python2.7/dist-packages (from astroid<2.0,>=1.6->pylint) (1.1.6)
Requirement already satisfied: lazy-object-proxy in /usr/local/lib/python2.7/dist-packages (from astroid<2.0,>=1.6->pylint) (1.4.3)
#pip install docutils
#pip install setuptools
#The following line crashes with a core dump
#pip install "Cython==0.22"
Dependencies for users installed (python 2 7 16)
sed -i -e '253s/.*//' openzwave/cpp/src/value_classes/ValueID.h
cd openzwave && make
make[1]: Entering directory '/opt/python-openzwave/openzwave'
CPPFLAGS= make -C /opt/python-openzwave/openzwave/cpp/build/ -w
make[2]: Entering directory '/opt/python-openzwave/openzwave/cpp/build'
Building OpenZWave Version 1.4.-1
Building tinystr.o
Building tinyxmlerror.o
Building tinyxml.o
Building tinyxmlparser.o
Building hid.o
cc1: internal compiler error: Illegal instruction
Please submit a full bug report,
with preprocessed source if appropriate.
See <file:///usr/share/doc/gcc-8/README.Bugs> for instructions.
make[2]: *** [/opt/python-openzwave/openzwave/cpp/build/support.mk:142: /opt/python-openzwave/openzwave/.lib/hid.o] Error 1
make[2]: Leaving directory '/opt/python-openzwave/openzwave/cpp/build'
make[1]: *** [Makefile:20: all] Error 2
make[1]: Leaving directory '/opt/python-openzwave/openzwave'
make: *** [Makefile:273: openzwave/.lib/] Error 2
sed: can't read /boot/cmdline.txt: No such file or directory
sed: can't read /etc/inittab: No such file or directory
Everything is successfully installed!
