Commenter cette ligne en mettant un # devant ou ajouter {} après les :
Il y a encore un espoir ? ![]()
> zigbee2mqtt@2.1.3 start /opt/zigbee2mqtt
> node index.js
Starting Zigbee2MQTT without watchdog.
/opt/zigbee2mqtt/node_modules/.pnpm/js-yaml@4.1.0/node_modules/js-yaml/lib/loader.js:183
return new YAMLException(message, mark);
YAMLException: can not read a block mapping entry; a multiline key may not be an implicit key (40:8)
37 | host: 192.168.50.148
38 | port: 8080
39 | device_options:{} ~
40 | devices:
41 | "0x540f57fffe2fe781":
42 | friendly_name: BP tuya 2
at generateError (/opt/zigbee2mqtt/node_modules/.pnpm/js-yaml@4.1.0/node_modules/js-yaml/lib/loader.js:183:10)
at throwError (/opt/zigbee2mqtt/node_modules/.pnpm/js-yaml@4.1.0/node_modules/js-yaml/lib/loader.js:187:9)
at readBlockMapping (/opt/zigbee2mqtt/node_modules/.pnpm/js-yaml@4.1.0/node_modules/js-yaml/lib/loader.js:1145:9)
at composeNode (/opt/zigbee2mqtt/node_modules/.pnpm/js-yaml@4.1.0/node_modules/js-yaml/lib/loader.js:1441:12)
at readDocument (/opt/zigbee2mqtt/node_modules/.pnpm/js-yaml@4.1.0/node_modules/js-yaml/lib/loader.js:1625:3)
at loadDocuments (/opt/zigbee2mqtt/node_modules/.pnpm/js-yaml@4.1.0/node_modules/js-yaml/lib/loader.js:1688:5)
at Object.load (/opt/zigbee2mqtt/node_modules/.pnpm/js-yaml@4.1.0/node_modules/js-yaml/lib/loader.js:1714:19)
at Object.read (/opt/zigbee2mqtt/lib/util/yaml.ts:23:29)
at read (/opt/zigbee2mqtt/lib/util/settings.ts:279:20)
at getPersistedSettings (/opt/zigbee2mqtt/lib/util/settings.ts:395:21)
ELIFECYCLE Command failed with exit code 1.
il y a aussi une ~
supprimes cette ligne…
