Après relance des dépendances, voici les logs obtenus:
+ touch /tmp/jeedom_install_in_progress_openzwave
+ echo 1
+ echo 2
+ sudo pip2 install --force-reinstall --upgrade pyudev
DEPRECATION: Python 2.7 reached the end of its life on January 1st, 2020. Please upgrade your Python as Python 2.7 is no longer maintained. pip 21.0 will drop support for Python 2.7 in January 2021. More details about Python 2 support in pip can be found at https://pip.pypa.io/en/latest/development/release-process/#python-2-support pip 21.0 will remove support for this functionality.
Processing /root/.cache/pip/wheels/58/f1/de/8537c90cced7f354c81dc37594a0632b7545ed7f5c6d6add69/pyudev-0.23.2-cp27-none-any.whl
Collecting six
Using cached six-1.16.0-py2.py3-none-any.whl (11 kB)
Installing collected packages: six, pyudev
Attempting uninstall: six
Found existing installation: six 1.16.0
Uninstalling six-1.16.0:
Successfully uninstalled six-1.16.0
Attempting uninstall: pyudev
Found existing installation: pyudev 0.23.2
Uninstalling pyudev-0.23.2:
Successfully uninstalled pyudev-0.23.2
Successfully installed pyudev-0.23.2 six-1.16.0
+ echo 3
+ sudo pip2 install --force-reinstall --upgrade wheel
Collecting wheel
Using cached wheel-0.37.1-py2.py3-none-any.whl (35 kB)
Installing collected packages: wheel
Attempting uninstall: wheel
Found existing installation: wheel 0.37.1
Uninstalling wheel-0.37.1:
Successfully uninstalled wheel-0.37.1
Successfully installed wheel-0.37.1
+ echo 4
+ sudo pip2 install --force-reinstall --upgrade urwid
Processing /root/.cache/pip/wheels/6f/0b/8c/cdfc1a04f75128ffdf0e8a7a5ce63e10166d33fba5335c1810/urwid-2.1.2-cp27-cp27mu-linux_aarch64.whl
Installing collected packages: urwid
Attempting uninstall: urwid
Found existing installation: urwid 2.1.2
Uninstalling urwid-2.1.2:
Successfully uninstalled urwid-2.1.2
Successfully installed urwid-2.1.2
+ echo 5
+ sudo pip2 install --force-reinstall --upgrade louie
Collecting louie
Using cached Louie-2.0.tar.gz (13 kB)
ERROR: Command errored out with exit status 1:
command: /usr/bin/python -c 'import sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-install-G_eNZx/louie/setup.py'"'"'; __file__='"'"'/tmp/pip-install-G_eNZx/louie/setup.py'"'"';f=getattr(tokenize, '"'"'open'"'"', open)(__file__);code=f.read().replace('"'"'
'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' egg_info --egg-base /tmp/pip-pip-egg-info-eAsU8L
cwd: /tmp/pip-install-G_eNZx/louie/
Complete output (10 lines):
File "<string>", line 1, in <module>
File "/tmp/pip-install-G_eNZx/louie/setup.py", line 3, in <module>
from louie import version
File "louie/__init__.py", line 1, in <module>
from . import dispatcher, error, plugin, robustapply, saferef, sender, signal, version
File "louie/dispatcher.py", line 44
f"Louie connects: {connects}
SyntaxError: invalid syntax
ERROR: Command errored out with exit status 1: python setup.py egg_info Check the logs for full command output.
+ echo 6
+ sudo pip2 install --force-reinstall --upgrade requests
Collecting requests
Using cached requests-2.27.1-py2.py3-none-any.whl (63 kB)
Collecting idna<3,>=2.5; python_version < "3"
Using cached idna-2.10-py2.py3-none-any.whl (58 kB)
Collecting chardet<5,>=3.0.2; python_version < "3"
Using cached chardet-4.0.0-py2.py3-none-any.whl (178 kB)
Collecting urllib3<1.27,>=1.21.1
Using cached urllib3-1.26.13-py2.py3-none-any.whl (140 kB)
Collecting certifi>=2017.4.17
Using cached certifi-2021.10.8-py2.py3-none-any.whl (149 kB)
Installing collected packages: idna, chardet, urllib3, certifi, requests
Attempting uninstall: idna
Found existing installation: idna 2.10
Uninstalling idna-2.10:
Successfully uninstalled idna-2.10
Attempting uninstall: chardet
Found existing installation: chardet 4.0.0
Uninstalling chardet-4.0.0:
Successfully uninstalled chardet-4.0.0
Attempting uninstall: urllib3
Found existing installation: urllib3 1.26.13
Uninstalling urllib3-1.26.13:
Successfully uninstalled urllib3-1.26.13
Attempting uninstall: certifi
Found existing installation: certifi 2021.10.8
Uninstalling certifi-2021.10.8:
Successfully uninstalled certifi-2021.10.8
Attempting uninstall: requests
Found existing installation: requests 2.27.1
Uninstalling requests-2.27.1:
Successfully uninstalled requests-2.27.1
Successfully installed certifi-2021.10.8 chardet-4.0.0 idna-2.10 requests-2.27.1 urllib3-1.26.13
+ echo 7
+ sudo pip2 install --force-reinstall --upgrade setuptools
Collecting setuptools
Using cached setuptools-44.1.1-py2.py3-none-any.whl (583 kB)
Installing collected packages: setuptools
Attempting uninstall: setuptools
Found existing installation: setuptools 44.1.1
Uninstalling setuptools-44.1.1:
Successfully uninstalled setuptools-44.1.1
Successfully installed setuptools-44.1.1
+ echo 8
+ sudo pip2 install --force-reinstall --upgrade pyserial
Collecting pyserial
Using cached pyserial-3.5-py2.py3-none-any.whl (90 kB)
Installing collected packages: pyserial
Attempting uninstall: pyserial
Found existing installation: pyserial 3.5
Uninstalling pyserial-3.5:
Successfully uninstalled pyserial-3.5
Successfully installed pyserial-3.5
+ echo 9
+ sudo pip2 install --force-reinstall --upgrade six
Collecting six
Successfully installed six-1.16.0
+ echo 10
+ sudo pip2 install --force-reinstall --upgrade tornado
Processing /root/.cache/pip/wheels/6d/e1/ce/f4ee2fa420cc6b940123c64992b81047816d0a9fad6b879325/tornado-5.1.1-cp27-cp27mu-linux_aarch64.whl
Collecting singledispatch
Using cached singledispatch-3.7.0-py2.py3-none-any.whl (9.2 kB)
Collecting futures
Using cached futures-3.4.0-py2-none-any.whl (16 kB)
Collecting backports-abc>=0.4
Using cached backports_abc-0.5-py2.py3-none-any.whl (5.2 kB)
Collecting six
Installing collected packages: six, singledispatch, futures, backports-abc, tornado
Attempting uninstall: singledispatch
Found existing installation: singledispatch 3.7.0
Uninstalling singledispatch-3.7.0:
Successfully uninstalled singledispatch-3.7.0
Attempting uninstall: futures
Found existing installation: futures 3.4.0
Uninstalling futures-3.4.0:
Successfully uninstalled futures-3.4.0
Attempting uninstall: backports-abc
Found existing installation: backports-abc 0.5
Uninstalling backports-abc-0.5:
Successfully uninstalled backports-abc-0.5
Attempting uninstall: tornado
Found existing installation: tornado 5.1.1
Uninstalling tornado-5.1.1:
Successfully uninstalled tornado-5.1.1
Successfully installed backports-abc-0.5 futures-3.4.0 singledispatch-3.7.0 six-1.16.0 tornado-5.1.1
+ echo 11
+ sudo chmod +x /var/www/html/core/class/../../plugins/openzwave/resources/post_install.sh
+ sudo /var/www/html/core/class/../../plugins/openzwave/resources/post_install.sh
Lancement de l'installation/mise à jour des dépendances openzwave
mkdir: cannot create directory '/opt': File exists
Désinstallation de la version précédente
Installation de Python-OpenZwave
WARNING: Skipping Cython as it is not installed.
WARNING: Running pip as the 'root' user can result in broken permissions and conflicting behaviour with the system package manager. It is recommended to use a virtual environment instead: https://pip.pypa.io/warnings/venv
apt-get install --force-yes -y cython
W: --force-yes is deprecated, use one of the options starting with --allow instead.
E: dpkg was interrupted, you must manually run 'sudo dpkg --configure -a' to correct the problem.
make: *** [Makefile:142: cython-deps] Error 100
Installing dependencies for python : 2 7 16
apt-get install --force-yes -y python-pip python-dev python-docutils python-setuptools python-louie
make: *** [Makefile:150: common-deps] Error 100
sed -i -e '253s/.*//' openzwave/cpp/src/value_classes/ValueID.h
cd openzwave && make
make[1]: Entering directory '/opt/python-openzwave/openzwave'
CPPFLAGS= make -C /opt/python-openzwave/openzwave/cpp/build/ -w
make[2]: Entering directory '/opt/python-openzwave/openzwave/cpp/build'
Building OpenZWave Version 1.4.-1
Building tinystr.o
Building tinyxmlerror.o
Building tinyxml.o
Building tinyxmlparser.o
Building hid.o
Building aeskey.o
Building aescrypt.o
Building aestab.o
Building aes_modes.o
Building Proprietary.o
Building CRC16Encap.o
Building BarrierOperator.o
Building SensorBinary.o
Building Language.o
Building WakeUp.o
Building Color.o
Building ZWavePlusInfo.o
Building Indicator.o
Building MeterPulse.o
Building ThermostatFanMode.o
Building MultiChannelAssociation.o
Building Configuration.o
Building CommandClass.o
Building SwitchToggleBinary.o
Building ThermostatMode.o
Building SensorMultilevel.o
Building MultiInstance.o
Building UserCode.o
Building SensorAlarm.o
Building DeviceResetLocally.o
Building TimeParameters.o
Building ManufacturerSpecific.o
Building EnergyProduction.o
Building DoorLock.o
Building SoundSwitch.o
Building ApplicationStatus.o
Building ControllerReplication.o
Building CentralScene.o
Building DoorLockLogging.o
/opt/python-openzwave/openzwave/cpp/src/command_classes/DoorLockLogging.cpp: In member function 'virtual bool OpenZWave::DoorLockLogging::HandleMsg(const uint8*, uint32, uint32)':
/opt/python-openzwave/openzwave/cpp/src/command_classes/DoorLockLogging.cpp:312:15: warning: passing argument 1 to restrict-qualified parameter aliases with argument 4 [-Wrestrict]
snprintf(usercode, sizeof(usercode), "%s %d", usercode, (int)_data[12+i]);
Building ClimateControlSchedule.o
Building Protection.o
Building NodeNaming.o
Building Meter.o
Building ManufacturerProprietary.o
Building Lock.o
Building ThermostatSetpoint.o
Building Hail.o
Building MultiCmd.o
Building SceneActivation.o
Building Powerlevel.o
Building AssociationCommandConfiguration.o
Building ThermostatOperatingState.o
Building SwitchMultilevel.o
Building Battery.o
Building Association.o
Building Version.o
Building Security.o
Building Clock.o
Building Alarm.o
Building CommandClasses.o
Building ThermostatFanState.o
Building NoOperation.o
Building BasicWindowCovering.o
Building SwitchAll.o
Building Basic.o
Building SwitchToggleMultilevel.o
Building SwitchBinary.o
Building Value.o
Building ValueList.o
Building ValueButton.o
Building ValueInt.o
Building ValueStore.o
Building ValueDecimal.o
Building ValueRaw.o
Building ValueString.o
Building ValueByte.o
Building ValueBool.o
Building ValueSchedule.o
Building ValueShort.o
Building Wait.o
Building Thread.o
Building Controller.o
Building Stream.o
Building Log.o
Building HidController.o
Building Mutex.o
Building SerialController.o
Building Event.o
Building FileOps.o
Building TimeStamp.o
Building FileOpsImpl.o
Building TimeStampImpl.o
Building WaitImpl.o
Building ThreadImpl.o
Building LogImpl.o
Building MutexImpl.o
Building SerialControllerImpl.o
Building EventImpl.o
Building Options.o
Building Scene.o
Building Utils.o
Building Driver.o
Building ZWSecurity.o
Building Group.o
Building Node.o
Building Manager.o
Building Msg.o
Building Notification.o
Creating vers.cpp
Building vers.o
Linking Static Library
Linking Shared Library
Making ozw_config file
make[2]: Leaving directory '/opt/python-openzwave/openzwave/cpp/build'
CPPFLAGS= make -C /opt/python-openzwave/openzwave/cpp/examples/MinOZW/ -w
make[2]: Entering directory '/opt/python-openzwave/openzwave/cpp/examples/MinOZW'
Building Main.o
Linking /opt/python-openzwave/openzwave/.lib/MinOZW
g++ -o /opt/python-openzwave/openzwave/.lib/MinOZW /opt/python-openzwave/openzwave/.lib/Main.o /opt/python-openzwave/openzwave/libopenzwave.so -pthread
Creating Temporary Shell Launch Script
make[2]: Leaving directory '/opt/python-openzwave/openzwave/cpp/examples/MinOZW'
make[1]: Leaving directory '/opt/python-openzwave/openzwave'
python setup-lib.py build
running build
running build_ext
cythoning src-lib/libopenzwave/libopenzwave.pyx to src-lib/libopenzwave/libopenzwave.cpp
/usr/lib/python2.7/dist-packages/Cython/Compiler/Main.py:367: FutureWarning: Cython directive 'language_level' not set, using 2 for now (Py2). This will change in a later release! File: /opt/python-openzwave/src-lib/libopenzwave/libopenzwave.pyx
tree = Parsing.p_module(s, pxd, full_module_name)
building 'libopenzwave' extension
creating build
creating build/temp.linux-aarch64-2.7
creating build/temp.linux-aarch64-2.7/src-lib
creating build/temp.linux-aarch64-2.7/src-lib/libopenzwave
aarch64-linux-gnu-gcc -pthread -DNDEBUG -g -fwrapv -O2 -Wall -Wstrict-prototypes -fno-strict-aliasing -Wdate-time -D_FORTIFY_SOURCE=2 -g -fdebug-prefix-map=/build/python2.7-QCkEc0/python2.7-2.7.16=. -fstack-protector-strong -Wformat -Werror=format-security -fPIC -DPY_SSIZE_T_CLEAN=1 -Iopenzwave/cpp/src/ -Iopenzwave/cpp/src/value_classes/ -Iopenzwave/cpp/src/platform/ -Iopenzwave/cpp/build/linux/ -I/usr/include/python2.7 -c src-lib/libopenzwave/libopenzwave.cpp -o build/temp.linux-aarch64-2.7/src-lib/libopenzwave/libopenzwave.o
cc1plus: warning: command line option '-Wstrict-prototypes' is valid for C/ObjC but not for C++
src-lib/libopenzwave/libopenzwave.cpp:3: warning: "PY_SSIZE_T_CLEAN" redefined
#define PY_SSIZE_T_CLEAN
<command-line>: note: this is the location of the previous definition
In file included from openzwave/cpp/src/aes/aescpp.h:26,
from openzwave/cpp/src/Driver.h:42,
from src-lib/libopenzwave/libopenzwave.cpp:638:
openzwave/cpp/src/aes/aes.h:75: warning: ignoring #pragma warning [-Wunknown-pragmas]
#pragma warning( disable : 4324 )
openzwave/cpp/src/aes/aes.h:93: warning: ignoring #pragma warning [-Wunknown-pragmas]
#pragma warning( default : 4324 )
src-lib/libopenzwave/libopenzwave.cpp: In function 'PyObject* __pyx_pf_12libopenzwave_9PyManager_268beginControllerCommand(__pyx_obj_12libopenzwave_PyManager*, PyObject*, PyObject*, PyObject*, PyObject*, PyObject*, PyObject*)':
src-lib/libopenzwave/libopenzwave.cpp:30325:204: warning: 'bool OpenZWave::Manager::BeginControllerCommand(uint32, OpenZWave::Driver::ControllerCommand, OpenZWave::Driver::pfnControllerCallback_t, void*, bool, uint8, uint8)' is deprecated [-Wdeprecated-declarations]
__pyx_t_6 = __Pyx_PyBool_FromLong(__pyx_v_self->manager->BeginControllerCommand(__pyx_t_1, __pyx_t_2, __pyx_f_12libopenzwave_ctrl_callback, ((void *)__pyx_v_pythonfunc), __pyx_t_3, __pyx_t_4, __pyx_t_5)); if (unlikely(!__pyx_t_6)) __PYX_ERR(0, 4120, __pyx_L1_error)
In file included from src-lib/libopenzwave/libopenzwave.cpp:643:
openzwave/cpp/src/Manager.h:1731:19: note: declared here
DEPRECATED bool BeginControllerCommand( uint32 const _homeId, Driver::ControllerCommand _command, Driver::pfnControllerCallback_t _callback = NULL, void* _context = NULL, bool _highPower = false, uint8 _nodeId = 0xff, uint8 _arg = 0 );
creating build/lib.linux-aarch64-2.7
aarch64-linux-gnu-g++ -pthread -shared -Wl,-O1 -Wl,-Bsymbolic-functions -Wl,-z,relro -fno-strict-aliasing -DNDEBUG -g -fwrapv -O2 -Wall -Wstrict-prototypes -Wdate-time -D_FORTIFY_SOURCE=2 -g -fdebug-prefix-map=/build/python2.7-QCkEc0/python2.7-2.7.16=. -fstack-protector-strong -Wformat -Werror=format-security -Wl,-z,relro -Wdate-time -D_FORTIFY_SOURCE=2 -g -fdebug-prefix-map=/build/python2.7-QCkEc0/python2.7-2.7.16=. -fstack-protector-strong -Wformat -Werror=format-security build/temp.linux-aarch64-2.7/src-lib/libopenzwave/libopenzwave.o openzwave/libopenzwave.a -ludev -lstdc++ -o build/lib.linux-aarch64-2.7/libopenzwave.so
python setup-lib.py install
running install
running bdist_egg
running egg_info
creating src-lib/libopenzwave.egg-info
writing requirements to src-lib/libopenzwave.egg-info/requires.txt
writing src-lib/libopenzwave.egg-info/PKG-INFO
writing top-level names to src-lib/libopenzwave.egg-info/top_level.txt
writing dependency_links to src-lib/libopenzwave.egg-info/dependency_links.txt
writing manifest file 'src-lib/libopenzwave.egg-info/SOURCES.txt'
reading manifest file 'src-lib/libopenzwave.egg-info/SOURCES.txt'
installing library code to build/bdist.linux-aarch64/egg
running install_lib
running build_ext
skipping 'src-lib/libopenzwave/libopenzwave.cpp' Cython extension (up-to-date)
creating build/bdist.linux-aarch64
creating build/bdist.linux-aarch64/egg
copying build/lib.linux-aarch64-2.7/libopenzwave.so -> build/bdist.linux-aarch64/egg
creating stub loader for libopenzwave.so
byte-compiling build/bdist.linux-aarch64/egg/libopenzwave.py to libopenzwave.pyc
installing package data to build/bdist.linux-aarch64/egg
running install_data
creating build/bdist.linux-aarch64/egg/config
creating build/bdist.linux-aarch64/egg/EGG-INFO
copying src-lib/libopenzwave.egg-info/PKG-INFO -> build/bdist.linux-aarch64/egg/EGG-INFO
copying src-lib/libopenzwave.egg-info/SOURCES.txt -> build/bdist.linux-aarch64/egg/EGG-INFO
copying src-lib/libopenzwave.egg-info/dependency_links.txt -> build/bdist.linux-aarch64/egg/EGG-INFO
copying src-lib/libopenzwave.egg-info/not-zip-safe -> build/bdist.linux-aarch64/egg/EGG-INFO
copying src-lib/libopenzwave.egg-info/requires.txt -> build/bdist.linux-aarch64/egg/EGG-INFO
copying src-lib/libopenzwave.egg-info/top_level.txt -> build/bdist.linux-aarch64/egg/EGG-INFO
writing build/bdist.linux-aarch64/egg/EGG-INFO/native_libs.txt
creating dist
creating 'dist/libopenzwave-0.3.1-py2.7-linux-aarch64.egg' and adding 'build/bdist.linux-aarch64/egg' to it
removing 'build/bdist.linux-aarch64/egg' (and everything under it)
Processing libopenzwave-0.3.1-py2.7-linux-aarch64.egg
creating /usr/local/lib/python2.7/dist-packages/libopenzwave-0.3.1-py2.7-linux-aarch64.egg
Extracting libopenzwave-0.3.1-py2.7-linux-aarch64.egg to /usr/local/lib/python2.7/dist-packages
Adding libopenzwave 0.3.1 to easy-install.pth file
Installed /usr/local/lib/python2.7/dist-packages/libopenzwave-0.3.1-py2.7-linux-aarch64.egg
Processing dependencies for libopenzwave==0.3.1
Searching for six==1.16.0
Best match: six 1.16.0
Adding six 1.16.0 to easy-install.pth file
Using /usr/local/lib/python2.7/dist-packages
Finished processing dependencies for libopenzwave==0.3.1
Installation of lib finished.
python setup-api.py install
running install
running bdist_egg
running egg_info
creating src-api/openzwave.egg-info
writing requirements to src-api/openzwave.egg-info/requires.txt
writing src-api/openzwave.egg-info/PKG-INFO
writing top-level names to src-api/openzwave.egg-info/top_level.txt
writing dependency_links to src-api/openzwave.egg-info/dependency_links.txt
writing manifest file 'src-api/openzwave.egg-info/SOURCES.txt'
reading manifest file 'src-api/openzwave.egg-info/SOURCES.txt'
running install_lib
running build_py
creating build/lib.linux-aarch64-2.7/openzwave
copying src-api/openzwave/value.py -> build/lib.linux-aarch64-2.7/openzwave
copying src-api/openzwave/object.py -> build/lib.linux-aarch64-2.7/openzwave
copying src-api/openzwave/network.py -> build/lib.linux-aarch64-2.7/openzwave
copying src-api/openzwave/node.py -> build/lib.linux-aarch64-2.7/openzwave
copying src-api/openzwave/controller.py -> build/lib.linux-aarch64-2.7/openzwave
copying src-api/openzwave/command.py -> build/lib.linux-aarch64-2.7/openzwave
copying src-api/openzwave/__init__.py -> build/lib.linux-aarch64-2.7/openzwave
copying src-api/openzwave/singleton.py -> build/lib.linux-aarch64-2.7/openzwave
copying src-api/openzwave/scene.py -> build/lib.linux-aarch64-2.7/openzwave
copying src-api/openzwave/group.py -> build/lib.linux-aarch64-2.7/openzwave
copying src-api/openzwave/option.py -> build/lib.linux-aarch64-2.7/openzwave
creating build/bdist.linux-aarch64/egg/openzwave
copying build/lib.linux-aarch64-2.7/openzwave/value.py -> build/bdist.linux-aarch64/egg/openzwave
copying build/lib.linux-aarch64-2.7/openzwave/object.py -> build/bdist.linux-aarch64/egg/openzwave
copying build/lib.linux-aarch64-2.7/openzwave/network.py -> build/bdist.linux-aarch64/egg/openzwave
copying build/lib.linux-aarch64-2.7/openzwave/node.py -> build/bdist.linux-aarch64/egg/openzwave
copying build/lib.linux-aarch64-2.7/openzwave/controller.py -> build/bdist.linux-aarch64/egg/openzwave
copying build/lib.linux-aarch64-2.7/openzwave/command.py -> build/bdist.linux-aarch64/egg/openzwave
copying build/lib.linux-aarch64-2.7/openzwave/__init__.py -> build/bdist.linux-aarch64/egg/openzwave
copying build/lib.linux-aarch64-2.7/openzwave/singleton.py -> build/bdist.linux-aarch64/egg/openzwave
copying build/lib.linux-aarch64-2.7/openzwave/scene.py -> build/bdist.linux-aarch64/egg/openzwave
copying build/lib.linux-aarch64-2.7/openzwave/group.py -> build/bdist.linux-aarch64/egg/openzwave
copying build/lib.linux-aarch64-2.7/openzwave/option.py -> build/bdist.linux-aarch64/egg/openzwave
byte-compiling build/bdist.linux-aarch64/egg/openzwave/value.py to value.pyc
byte-compiling build/bdist.linux-aarch64/egg/openzwave/object.py to object.pyc
byte-compiling build/bdist.linux-aarch64/egg/openzwave/network.py to network.pyc
byte-compiling build/bdist.linux-aarch64/egg/openzwave/node.py to node.pyc
byte-compiling build/bdist.linux-aarch64/egg/openzwave/controller.py to controller.pyc
byte-compiling build/bdist.linux-aarch64/egg/openzwave/command.py to command.pyc
byte-compiling build/bdist.linux-aarch64/egg/openzwave/__init__.py to __init__.pyc
byte-compiling build/bdist.linux-aarch64/egg/openzwave/singleton.py to singleton.pyc
byte-compiling build/bdist.linux-aarch64/egg/openzwave/scene.py to scene.pyc
byte-compiling build/bdist.linux-aarch64/egg/openzwave/group.py to group.pyc
byte-compiling build/bdist.linux-aarch64/egg/openzwave/option.py to option.pyc
copying src-api/openzwave.egg-info/PKG-INFO -> build/bdist.linux-aarch64/egg/EGG-INFO
copying src-api/openzwave.egg-info/SOURCES.txt -> build/bdist.linux-aarch64/egg/EGG-INFO
copying src-api/openzwave.egg-info/dependency_links.txt -> build/bdist.linux-aarch64/egg/EGG-INFO
copying src-api/openzwave.egg-info/not-zip-safe -> build/bdist.linux-aarch64/egg/EGG-INFO
copying src-api/openzwave.egg-info/requires.txt -> build/bdist.linux-aarch64/egg/EGG-INFO
copying src-api/openzwave.egg-info/top_level.txt -> build/bdist.linux-aarch64/egg/EGG-INFO
creating 'dist/openzwave-0.3.1-py2.7.egg' and adding 'build/bdist.linux-aarch64/egg' to it
Processing openzwave-0.3.1-py2.7.egg
creating /usr/local/lib/python2.7/dist-packages/openzwave-0.3.1-py2.7.egg
Extracting openzwave-0.3.1-py2.7.egg to /usr/local/lib/python2.7/dist-packages
Adding openzwave 0.3.1 to easy-install.pth file
Installed /usr/local/lib/python2.7/dist-packages/openzwave-0.3.1-py2.7.egg
Processing dependencies for openzwave==0.3.1
Searching for libopenzwave==0.3.1
Best match: libopenzwave 0.3.1
libopenzwave 0.3.1 is already the active version in easy-install.pth
Using /usr/local/lib/python2.7/dist-packages/libopenzwave-0.3.1-py2.7-linux-aarch64.egg
Searching for Louie==1.1
Best match: Louie 1.1
Adding Louie 1.1 to easy-install.pth file
Using /usr/lib/python2.7/dist-packages
Finished processing dependencies for openzwave==0.3.1
Installation of API finished.
Everything is successfully installed!
+ echo 12
+ php /var/www/html/core/class/../php/jeecli.php plugin dependancy_end openzwave
+ rm /tmp/jeedom_install_in_progress_openzwave
