Impossible de relancer le plugin apres maj en 2.x
une fois la mise a jour faite le plugin fonctionne , mais ne supporte pas d’etre relancer, maj ou autre operation qui le relance.
essai en debug
> zigbee2mqtt@2.1.0 start /opt/zigbee2mqtt
> node index.js
Starting Zigbee2MQTT without watchdog.
READ THIS CAREFULLY
Refusing to start because configuration is not valid, found the following errors:
- device_options must be object
If you don't know how to solve this, read https://www.zigbee2mqtt.io/guide/configuration
 ELIFECYCLE  Command failed with exit code 1.
#    INSTALL : Zigbee2mqtt                            #
##### apt-get update in progress
Hit:1 http://deb.debian.org/debian bullseye InRelease
Get:2 http://security.debian.org/debian-security bullseye-security InRelease [27.2 kB]
Get:3 http://deb.debian.org/debian bullseye-updates InRelease [44.1 kB]
Get:4 https://download.docker.com/linux/debian bullseye InRelease [43.3 kB]
Get:5 https://deb.nodesource.com/node_20.x nodistro InRelease [12.1 kB]
Get:6 http://security.debian.org/debian-security bullseye-security/main Sources [232 kB]
Get:7 http://security.debian.org/debian-security bullseye-security/main amd64 Packages [341 kB]
Get:8 http://security.debian.org/debian-security bullseye-security/main Translation-en [221 kB]
Get:9 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages [10.4 kB]
Get:10 https://download.docker.com/linux/debian bullseye/stable amd64 Packages [49.0 kB]
Fetched 980 kB in 2s (524 kB/s)
Reading package lists...
##### Install or update Git
Building dependency tree...
Reading state information...
g++ is already the newest version (4:10.2.1-1).
gcc is already the newest version (4:10.2.1-1).
make is already the newest version (4.3-4.1).
Suggested packages:
  git-daemon-run | git-daemon-sysvinit git-doc git-el git-email git-gui gitk
  gitweb git-cvs git-mediawiki git-svn
The following packages will be upgraded:
  git
1 upgraded, 0 newly installed, 0 to remove and 74 not upgraded.
Need to get 5566 kB of archives.
After this operation, 8192 B of additional disk space will be used.
Get:1 http://security.debian.org/debian-security bullseye-security/main amd64 git amd64 1:2.30.2-1+deb11u4 [5566 kB]
apt-listchanges: Reading changelogs...
debconf: unable to initialize frontend: Dialog
debconf: (Dialog frontend will not work on a dumb terminal, an emacs shell buffer, or without a controlling terminal.)
debconf: falling back to frontend: Readline
debconf: unable to initialize frontend: Readline
debconf: (This frontend requires a controlling tty.)
debconf: falling back to frontend: Teletype
dpkg-preconfigure: unable to re-open stdin:
Fetched 5566 kB in 4s (1484 kB/s)
(Reading database ...
(Reading database ... 5%
(Reading database ... 10%
(Reading database ... 15%
(Reading database ... 20%
(Reading database ... 25%
(Reading database ... 30%
(Reading database ... 35%
(Reading database ... 40%
(Reading database ... 45%
(Reading database ... 50%
(Reading database ... 55%
(Reading database ... 60%
(Reading database ... 65%
(Reading database ... 70%
(Reading database ... 75%
(Reading database ... 80%
(Reading database ... 85%
(Reading database ... 90%
(Reading database ... 95%
(Reading database ... 100%
(Reading database ... 73168 files and directories currently installed.)
Preparing to unpack .../git_1%3a2.30.2-1+deb11u4_amd64.deb ...
Unpacking git (1:2.30.2-1+deb11u4) over (1:2.30.2-1+deb11u3) ...
Setting up git (1:2.30.2-1+deb11u4) ...
##### Install or update NodeJs
NodeJs 20 already installed : Nothing to do !
added 1 package in 7s
1 package is looking for funding
  run `npm fund` for details
#    INSTALLING : Mosquitto for Php                   #
Mosquitto for Php is already installed, nothing to do
##### Z2M BRANCH version to install : master
##### Install Socat
Socat is already installed, nothing to do
##### Install yaml php and restart apache
Yaml is already installed, nothing to do
#####    Stopping Zigbee2mqtt deamon                  #
    ## Supprime l'installation dans /opt/zigbee2mqtt
##### Complete installation : Download Zigbee2mqtt git
Cloning into '/opt/zigbee2mqtt'...
##### Install/Update Zigbee2mqtt
Lockfile is up to date, resolution step is skipped
Progress: resolved 1, reused 0, downloaded 0, added 0
Packages: +366
Progress: resolved 366, reused 0, downloaded 0, added 0
Progress: resolved 366, reused 0, downloaded 37, added 32
   │                Update available! 9.15.4 → 10.2.0.                │
   │   Changelog: https://github.com/pnpm/pnpm/releases/tag/v10.2.0   │
   │                Run "pnpm add -g pnpm" to update.                 │
Progress: resolved 366, reused 0, downloaded 68, added 68
Progress: resolved 366, reused 0, downloaded 100, added 96
Progress: resolved 366, reused 0, downloaded 140, added 140
Progress: resolved 366, reused 0, downloaded 164, added 164
Progress: resolved 366, reused 0, downloaded 181, added 181
Progress: resolved 366, reused 0, downloaded 199, added 198
Progress: resolved 366, reused 0, downloaded 213, added 212
Progress: resolved 366, reused 0, downloaded 231, added 231
Progress: resolved 366, reused 0, downloaded 248, added 248
Progress: resolved 366, reused 0, downloaded 266, added 266
Progress: resolved 366, reused 0, downloaded 288, added 288
Progress: resolved 366, reused 0, downloaded 310, added 310
Progress: resolved 366, reused 0, downloaded 321, added 321
Progress: resolved 366, reused 0, downloaded 335, added 335
Progress: resolved 366, reused 0, downloaded 354, added 354
Progress: resolved 366, reused 0, downloaded 357, added 357
Progress: resolved 366, reused 0, downloaded 359, added 359
Progress: resolved 366, reused 0, downloaded 362, added 362
Progress: resolved 366, reused 0, downloaded 364, added 364
Progress: resolved 366, reused 0, downloaded 365, added 364
Progress: resolved 366, reused 0, downloaded 366, added 366, done
.../node_modules/unix-dgram install$ node-gyp rebuild
.../node_modules/sd-notify install$ node-gyp rebuild
.../@serialport/bindings-cpp install$ node-gyp-build
.../esbuild@0.24.2/node_modules/esbuild postinstall$ node install.js
.../node_modules/sd-notify install: gyp info it worked if it ends with ok
.../node_modules/sd-notify install: gyp info using node-gyp@10.3.1
.../node_modules/sd-notify install: gyp info using node@20.18.0 | linux | x64
.../node_modules/unix-dgram install: gyp info it worked if it ends with ok
.../node_modules/unix-dgram install: gyp info using node-gyp@10.3.1
.../node_modules/unix-dgram install: gyp info using node@20.18.0 | linux | x64
.../esbuild@0.24.2/node_modules/esbuild postinstall: Done
.../node_modules/sd-notify install: gyp info find Python using Python version 3.9.2 found at "/usr/bin/python3"
.../@serialport/bindings-cpp install: Done
.../node_modules/unix-dgram install: gyp info find Python using Python version 3.9.2 found at "/usr/bin/python3"
.../node_modules/sd-notify install: gyp info spawn /usr/bin/python3
.../node_modules/unix-dgram install: gyp info spawn /usr/bin/python3
.../node_modules/sd-notify install: gyp info spawn args [
.../node_modules/sd-notify install: gyp info spawn args '/root/.local/share/pnpm/.tools/pnpm/9.15.4/node_modules/.pnpm/pnpm@9.15.4/node_modules/pnpm/dist/node_modules/node-gyp/gyp/gyp_main.py',
.../node_modules/sd-notify install: gyp info spawn args 'binding.gyp',
.../node_modules/sd-notify install: gyp info spawn args '-f',
.../node_modules/sd-notify install: gyp info spawn args 'make',
.../node_modules/sd-notify install: gyp info spawn args '-I',
.../node_modules/sd-notify install: gyp info spawn args '/opt/zigbee2mqtt/node_modules/.pnpm/sd-notify@2.8.0/node_modules/sd-notify/build/config.gypi',
.../node_modules/sd-notify install: gyp info spawn args '/root/.local/share/pnpm/.tools/pnpm/9.15.4/node_modules/.pnpm/pnpm@9.15.4/node_modules/pnpm/dist/node_modules/node-gyp/addon.gypi',
.../node_modules/sd-notify install: gyp info spawn args '/root/.cache/node-gyp/20.18.0/include/node/common.gypi',
.../node_modules/sd-notify install: gyp info spawn args '-Dlibrary=shared_library',
.../node_modules/sd-notify install: gyp info spawn args '-Dvisibility=default',
.../node_modules/sd-notify install: gyp info spawn args '-Dnode_root_dir=/root/.cache/node-gyp/20.18.0',
.../node_modules/sd-notify install: gyp info spawn args '-Dnode_gyp_dir=/root/.local/share/pnpm/.tools/pnpm/9.15.4/node_modules/.pnpm/pnpm@9.15.4/node_modules/pnpm/dist/node_modules/node-gyp',
.../node_modules/sd-notify install: gyp info spawn args '-Dnode_lib_file=/root/.cache/node-gyp/20.18.0/<(target_arch)/node.lib',
.../node_modules/sd-notify install: gyp info spawn args '-Dmodule_root_dir=/opt/zigbee2mqtt/node_modules/.pnpm/sd-notify@2.8.0/node_modules/sd-notify',
.../node_modules/sd-notify install: gyp info spawn args '-Dnode_engine=v8',
.../node_modules/sd-notify install: gyp info spawn args '--depth=.',
.../node_modules/sd-notify install: gyp info spawn args '--no-parallel',
.../node_modules/sd-notify install: gyp info spawn args '--generator-output',
.../node_modules/sd-notify install: gyp info spawn args 'build',
.../node_modules/sd-notify install: gyp info spawn args '-Goutput_dir=.'
.../node_modules/sd-notify install: gyp info spawn args ]
.../node_modules/unix-dgram install: gyp info spawn args [
.../node_modules/unix-dgram install: gyp info spawn args '/root/.local/share/pnpm/.tools/pnpm/9.15.4/node_modules/.pnpm/pnpm@9.15.4/node_modules/pnpm/dist/node_modules/node-gyp/gyp/gyp_main.py',
.../node_modules/unix-dgram install: gyp info spawn args 'binding.gyp',
.../node_modules/unix-dgram install: gyp info spawn args '-f',
.../node_modules/unix-dgram install: gyp info spawn args 'make',
.../node_modules/unix-dgram install: gyp info spawn args '-I',
.../node_modules/unix-dgram install: gyp info spawn args '/opt/zigbee2mqtt/node_modules/.pnpm/unix-dgram@2.0.6/node_modules/unix-dgram/build/config.gypi',
.../node_modules/unix-dgram install: gyp info spawn args '/root/.local/share/pnpm/.tools/pnpm/9.15.4/node_modules/.pnpm/pnpm@9.15.4/node_modules/pnpm/dist/node_modules/node-gyp/addon.gypi',
.../node_modules/unix-dgram install: gyp info spawn args '/root/.cache/node-gyp/20.18.0/include/node/common.gypi',
.../node_modules/unix-dgram install: gyp info spawn args '-Dlibrary=shared_library',
.../node_modules/unix-dgram install: gyp info spawn args '-Dvisibility=default',
.../node_modules/unix-dgram install: gyp info spawn args '-Dnode_root_dir=/root/.cache/node-gyp/20.18.0',
.../node_modules/unix-dgram install: gyp info spawn args '-Dnode_gyp_dir=/root/.local/share/pnpm/.tools/pnpm/9.15.4/node_modules/.pnpm/pnpm@9.15.4/node_modules/pnpm/dist/node_modules/node-gyp',
.../node_modules/unix-dgram install: gyp info spawn args '-Dnode_lib_file=/root/.cache/node-gyp/20.18.0/<(target_arch)/node.lib',
.../node_modules/unix-dgram install: gyp info spawn args '-Dmodule_root_dir=/opt/zigbee2mqtt/node_modules/.pnpm/unix-dgram@2.0.6/node_modules/unix-dgram',
.../node_modules/unix-dgram install: gyp info spawn args '-Dnode_engine=v8',
.../node_modules/unix-dgram install: gyp info spawn args '--depth=.',
.../node_modules/unix-dgram install: gyp info spawn args '--no-parallel',
.../node_modules/unix-dgram install: gyp info spawn args '--generator-output',
.../node_modules/unix-dgram install: gyp info spawn args 'build',
.../node_modules/unix-dgram install: gyp info spawn args '-Goutput_dir=.'
.../node_modules/unix-dgram install: gyp info spawn args ]
.../node_modules/sd-notify install: gyp info spawn make
.../node_modules/sd-notify install: gyp info spawn args [ 'BUILDTYPE=Release', '-C', 'build' ]
.../node_modules/sd-notify install: make: Entering directory '/opt/zigbee2mqtt/node_modules/.pnpm/sd-notify@2.8.0/node_modules/sd-notify/build'
.../node_modules/sd-notify install:   CXX(target) Release/obj.target/notify/notify.o
.../node_modules/unix-dgram install: gyp info spawn make
.../node_modules/unix-dgram install: gyp info spawn args [ 'BUILDTYPE=Release', '-C', 'build' ]
.../node_modules/unix-dgram install: make: Entering directory '/opt/zigbee2mqtt/node_modules/.pnpm/unix-dgram@2.0.6/node_modules/unix-dgram/build'
.../node_modules/unix-dgram install:   CXX(target) Release/obj.target/unix_dgram/src/unix_dgram.o
.../node_modules/sd-notify install: ../notify.cc:5:10: fatal error: systemd/sd-daemon.h: No such file or directory
.../node_modules/sd-notify install:     5 | #include <systemd/sd-daemon.h>
.../node_modules/sd-notify install:       |          ^~~~~~~~~~~~~~~~~~~~~
.../node_modules/sd-notify install: compilation terminated.
.../node_modules/sd-notify install: make: *** [notify.target.mk:106: Release/obj.target/notify/notify.o] Error 1
.../node_modules/sd-notify install: make: Leaving directory '/opt/zigbee2mqtt/node_modules/.pnpm/sd-notify@2.8.0/node_modules/sd-notify/build'
.../node_modules/sd-notify install: gyp ERR! build error
.../node_modules/sd-notify install: gyp ERR! stack Error: `make` failed with exit code: 2
.../node_modules/sd-notify install: gyp ERR! stack at ChildProcess.<anonymous> (/root/.local/share/pnpm/.tools/pnpm/9.15.4/node_modules/.pnpm/pnpm@9.15.4/node_modules/pnpm/dist/node_modules/node-gyp/lib/build.js:216:23)
.../node_modules/sd-notify install: gyp ERR! System Linux 5.10.0-33-amd64
.../node_modules/sd-notify install: gyp ERR! command "/usr/bin/node" "/root/.local/share/pnpm/.tools/pnpm/9.15.4/node_modules/.pnpm/pnpm@9.15.4/node_modules/pnpm/dist/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
.../node_modules/sd-notify install: gyp ERR! cwd /opt/zigbee2mqtt/node_modules/.pnpm/sd-notify@2.8.0/node_modules/sd-notify
.../node_modules/sd-notify install: gyp ERR! node -v v20.18.0
.../node_modules/sd-notify install: gyp ERR! node-gyp -v v10.3.1
.../node_modules/sd-notify install: gyp ERR! not ok
.../node_modules/sd-notify install: Failed
.../node_modules/unix-dgram install: In file included from ../../../../nan@2.22.0/node_modules/nan/nan.h:62,
.../node_modules/unix-dgram install:                  from ../src/unix_dgram.cc:5:
.../node_modules/unix-dgram install: /root/.cache/node-gyp/20.18.0/include/node/node.h:1232:7: warning: cast between incompatible function types from 'void (*)(v8::Local<v8::Object>)' to 'node::addon_register_func' {aka 'void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)'} [-Wcast-function-type]
.../node_modules/unix-dgram install:  1232 |       (node::addon_register_func) (regfunc),                          \
.../node_modules/unix-dgram install:       |       ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
.../node_modules/unix-dgram install: /root/.cache/node-gyp/20.18.0/include/node/node.h:1266:3: note: in expansion of macro 'NODE_MODULE_X'
.../node_modules/unix-dgram install:  1266 |   NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)
.../node_modules/unix-dgram install: ../src/unix_dgram.cc:404:1: note: in expansion of macro 'NODE_MODULE'
.../node_modules/unix-dgram install:   404 | NODE_MODULE(unix_dgram, Initialize)
.../node_modules/unix-dgram install:   SOLINK_MODULE(target) Release/obj.target/unix_dgram.node
.../node_modules/unix-dgram install:   COPY Release/unix_dgram.node
.../node_modules/unix-dgram install: make: Leaving directory '/opt/zigbee2mqtt/node_modules/.pnpm/unix-dgram@2.0.6/node_modules/unix-dgram/build'
.../node_modules/unix-dgram install: gyp info ok
.../node_modules/unix-dgram install: Done
dependencies:
+ ajv 8.17.1
+ bind-decorator 1.0.11
+ debounce 2.2.0
+ express-static-gzip 2.2.0
+ fast-deep-equal 3.1.3
+ finalhandler 1.3.1
+ git-last-commit 1.0.1
+ humanize-duration 3.32.1
+ js-yaml 4.1.0
+ json-stable-stringify-without-jsonify 1.0.1
+ jszip 3.10.1
+ moment 2.30.1
+ mqtt 5.10.3
+ object-assign-deep 0.4.0
+ rimraf 6.0.1
+ semver 7.6.3
+ source-map-support 0.5.21
+ throttleit 2.1.0
+ winston 3.17.0
+ winston-syslog 2.7.1
+ winston-transport 4.9.0
+ ws 8.18.0
+ zigbee-herdsman 3.2.5
+ zigbee-herdsman-converters 21.27.1
+ zigbee2mqtt-frontend 0.9.4
optionalDependencies:
+ sd-notify 2.8.0
devDependencies:
+ @eslint/core 0.10.0
+ @eslint/js 9.19.0
+ @ianvs/prettier-plugin-sort-imports 4.4.1
+ @types/eslint__js 8.42.3
+ @types/finalhandler 1.2.3
+ @types/humanize-duration 3.27.4
+ @types/js-yaml 4.0.9
+ @types/node 22.10.10
+ @types/object-assign-deep 0.4.3
+ @types/readable-stream 4.0.18
+ @types/sd-notify 2.8.2
+ @types/serve-static 1.15.7
+ @types/ws 8.5.14
+ @vitest/coverage-v8 3.0.4
+ eslint 9.19.0
+ eslint-config-prettier 10.0.1
+ prettier 3.4.2
+ tmp 0.2.3
+ typescript 5.7.3
+ typescript-eslint 8.21.0
+ vitest 3.0.4
Done in 38.7s
> zigbee2mqtt@2.1.0 build /opt/zigbee2mqtt
> tsc && node index.js writehash
##### Configure deamon and start it
#                         END                         #
meme avec une réparation cela ne fonctionne plus…
donc le plugins ne fonctione temps que je ne l’arrete pas , une fois arreter il ne redemarre jamais
correction faite
j’ai éditer le fichier config
j’en profite pour le remettre en forme
en bas du fichier
- "0x00124b00234ccc48"
device_options: []
version: 4
le soucis etant device_options: [] qu’il faut supprimer
je sup tout,
les blocklist ne sont plus d’actualités
et je remonte tout en haut
version: 4
sauvegarde et relance, tout fonctionne de nouveau, je peux relancer et arrêter le service sans soucis
Lorsque tu supprimes device_option, ets ce que tu es sur la vesrion 1.42.0 ou 2.0.0 ?
c’est le passage de la v1 à la v2 qui créé ce problème dans le fichier de configuration.
Tant que le fichier n’est pas corrigé manuellement, tu ne pourras plus démarrer la v1 ou la v2
ok je te remercie
il faut le sup quand tu passe en V2, et si tu veux revenir en 1.42.0… car il reste dans le fichier config
cette ligne ce crée a la migration pour passer en 2.x.x .
depuis zero soucis, je viens meme de faire la maj en 2.1.1
OK merci. Si je passe en V2 je le supprime aussi puis relance des demons. Ca roule
