Suite à un message demandant de mettre à jour les dépendances de jeeZigbee, je ne parviens plus à redémarrer le démon z2m…
La lecture des posts sur le sujet ne m’a rien donné.
J’ai tenté :
- Redémarrage de Jeedom
- Vérification générale
- Rétablissement des droits des dossiers et fichiers
Et le démon me donne l’erreur suivante :
> zigbee2mqtt@2.0.0 start
> node index.js
node:internal/modules/cjs/loader:1228
throw err;
Error: Cannot find module 'semver'
Require stack:
- /var/www/html/plugins/z2m/resources/zigbee2mqtt/index.js
at Module._resolveFilename (node:internal/modules/cjs/loader:1225:15)
at Module._load (node:internal/modules/cjs/loader:1051:27)
at Module.require (node:internal/modules/cjs/loader:1311:19)
at require (node:internal/modules/helpers:179:18)
at Object.<anonymous> (/var/www/html/plugins/z2m/resources/zigbee2mqtt/index.js:1:16)
at Module._compile (node:internal/modules/cjs/loader:1469:14)
at Module._extensions..js (node:internal/modules/cjs/loader:1548:10)
at Module.load (node:internal/modules/cjs/loader:1288:32)
at Module._load (node:internal/modules/cjs/loader:1104:12)
at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:174:12) {
code: 'MODULE_NOT_FOUND',
requireStack: [ '/var/www/html/plugins/z2m/resources/zigbee2mqtt/index.js' ]
Node.js v20.17.0
> node index.js
throw err;
Require stack:
Node.js v20.17.0
Les logs des dépendances :
+ touch /tmp/jeedom_install_in_progress_z2m
+ echo 1
+ echo 2
+ sudo chmod +x /var/www/html/core/class/../../plugins/z2m/resources/pre-install.sh
+ sudo /var/www/html/core/class/../../plugins/z2m/resources/pre-install.sh
Launch pre-install of z2m dependancy
+ echo 3
+ php /var/www/html/core/class/../php/jeecli.php plugin install mqtt2
+ echo 4
apt: no process found
apt-get: no process found
+ sudo apt update
Hit:1 http://deb.debian.org/debian bullseye InRelease
Get:2 http://deb.debian.org/debian bullseye-updates InRelease [44.1 kB]
Hit:3 http://security.debian.org bullseye-security InRelease
Get:4 https://download.docker.com/linux/debian bullseye InRelease [43.3 kB]
Get:5 http://deb.debian.org/debian bullseye-backports InRelease [49.0 kB]
Hit:6 https://deb.nodesource.com/node_20.x nodistro InRelease
Get:7 http://fi.mirror.armbian.de/apt buster InRelease [42.4 kB]
Fetched 179 kB in 3s (64.3 kB/s)
Reading package lists...
Building dependency tree...
Reading state information...
171 packages can be upgraded. Run 'apt list --upgradable' to see them.
+ echo 5
Hit:2 http://security.debian.org bullseye-security InRelease
Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
Hit:4 http://deb.debian.org/debian bullseye-backports InRelease
Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
Get:6 https://download.docker.com/linux/debian bullseye InRelease [43.3 kB]
Hit:7 http://fi.mirror.armbian.de/apt buster InRelease
Fetched 43.3 kB in 3s (16.2 kB/s)
apt-utils is already the newest version (2.2.4).
lsb-release is already the newest version (11.1.0).
git is already the newest version (1:2.30.2-1+deb11u3).
0 upgraded, 0 newly installed, 0 to remove and 171 not upgraded.
[Check Version NodeJS actuelle : v20.17.0 : [ OK ]
[Check Prefix : /usr and sudo prefix : /usr and www-data prefix : /usr : [ OK ]
Clean npm cache
npm warn using --force Recommended protections disabled.
+ echo 6
+ sudo apt install -o Dpkg::Options::=--force-confdef -y php-yaml
php-yaml is already the newest version (2.2.1+2.1.0+2.0.4+1.3.2-2).
+ echo 7
+ sudo systemctl restart apache2
+ echo 8
+ sudo chmod +x /var/www/html/core/class/../../plugins/z2m/resources/post-install.sh
+ sudo /var/www/html/core/class/../../plugins/z2m/resources/post-install.sh
+ echo Launch post-install of z2m dependancy
+ realpath /var/www/html/core/class/../../plugins/z2m/resources/post-install.sh
+ dirname /var/www/html/plugins/z2m/resources/post-install.sh
+ BASEDIR=/var/www/html/plugins/z2m/resources
+ [ -d /var/www/html/plugins/z2m/resources/zigbee2mqtt ]
+ rm -rf /var/www/html/plugins/z2m/resources/zigbee2mqtt
+ mkdir /var/www/html/plugins/z2m/resources/zigbee2mqtt
+ git clone --depth 1 https://github.com/Koenkk/zigbee2mqtt.git /var/www/html/plugins/z2m/resources/zigbee2mqtt
Cloning into '/var/www/html/plugins/z2m/resources/zigbee2mqtt'...
+ cd /var/www/html/plugins/z2m/resources/zigbee2mqtt
+ [ -f /var/www/html/plugins/z2m/resources/../data/wanted_z2m_version ]
+ npm ci
npm error code EUSAGE
npm error
npm error The `npm ci` command can only install with an existing package-lock.json or
npm error npm-shrinkwrap.json with lockfileVersion >= 1. Run an install with npm@5 or
npm error later to generate a package-lock.json file, then try again.
npm error
npm error Clean install a project
npm error
npm error Usage:
npm error npm ci
npm error
npm error Options:
npm error [--install-strategy <hoisted|nested|shallow|linked>] [--legacy-bundling]
npm error [--global-style] [--omit <dev|optional|peer> [--omit <dev|optional|peer> ...]]
npm error [--include <prod|dev|optional|peer> [--include <prod|dev|optional|peer> ...]]
npm error [--strict-peer-deps] [--foreground-scripts] [--ignore-scripts] [--no-audit]
npm error [--no-bin-links] [--no-fund] [--dry-run]
npm error [-w|--workspace <workspace-name> [-w|--workspace <workspace-name> ...]]
npm error [-ws|--workspaces] [--include-workspace-root] [--install-links]
npm error
npm error aliases: clean-install, ic, install-clean, isntall-clean
npm error
npm error Run "npm help ci" for more info
npm error A complete log of this run can be found in: /root/.npm/_logs/2025-01-04T16_25_55_660Z-debug-0.log
+ npm run build
> zigbee2mqtt@2.0.0 build
> tsc && node index.js writehash
sh: 1: tsc: not found
+ chown www-data:www-data -R /var/www/html/plugins/z2m/resources/zigbee2mqtt
+ echo 9
+ php /var/www/html/core/class/../php/jeecli.php plugin dependancy_end z2m
PHP Fatal error: Uncaught Exception: Veuillez vérifier la configuration : Le démon MQTT Manager n'est pas démarré in /var/www/html/plugins/z2m/core/class/z2m.class.php:315
Stack trace:
#0 /var/www/html/plugins/z2m/core/class/z2m.class.php(44): z2m::deamon_start()
#1 /var/www/html/core/php/jeecli.php(62): z2m::dependancy_end()
#2 {main}
thrown in /var/www/html/plugins/z2m/core/class/z2m.class.php on line 315
+ echo 10
+ rm /tmp/jeedom_install_in_progress_z2m
Merci pour votre aide ![]()
