Depuis la mise à jour des dépendances, le démon refuse de redémarrer. je précise que je suis une la version Stable, et que même en basculant sur Beta, le probleme persiste.
Le mdp comprend un caractère spéciaux du type « @ »
voici le log merossync_update
Installation des dépendances
Hit:1 http://security.debian.org/debian-security buster/updates InRelease
Hit:2 http://ftp.fr.debian.org/debian buster InRelease
Hit:3 http://ftp.fr.debian.org/debian buster-updates InRelease
Get:4 https://deb.nodesource.com/node_16.x buster InRelease [4584 B]
Fetched 4584 B in 3s (1484 B/s)
Reading package lists...
Building dependency tree...
Reading state information...
libffi-dev is already the newest version (3.2.1-9).
0 upgraded, 0 newly installed, 0 to remove and 1 not upgraded.
python3 is already the newest version (3.7.3-1).
python3-pip is already the newest version (18.1-5).
python3-requests is already the newest version (2.21.0-1+deb10u1).
python3-setuptools is already the newest version (40.8.0-1).
python3-dev is already the newest version (3.7.3-1).
Requirement already satisfied: pip in /usr/local/lib/python3.7/dist-packages (23.2.1)
WARNING: Running pip as the 'root' user can result in broken permissions and conflicting behaviour with the system package manager. It is recommended to use a virtual environment instead: https://pip.pypa.io/warnings/venv
Requirement already satisfied: meross_iot==0.4.5.9 in /usr/local/lib/python3.7/dist-packages (0.4.5.9)
Requirement already satisfied: paho-mqtt>=1.5.0 in /usr/local/lib/python3.7/dist-packages (from meross_iot==0.4.5.9) (1.6.1)
Requirement already satisfied: requests>=2.19.1 in /usr/lib/python3/dist-packages (from meross_iot==0.4.5.9) (2.21.0)
Requirement already satisfied: aiohttp[speedups]>=3.7.4.post0 in /usr/local/lib/python3.7/dist-packages (from meross_iot==0.4.5.9) (3.8.3)
Requirement already satisfied: attrs>=17.3.0 in /usr/local/lib/python3.7/dist-packages (from aiohttp[speedups]>=3.7.4.post0->meross_iot==0.4.5.9) (21.4.0)
Requirement already satisfied: charset-normalizer<3.0,>=2.0 in /usr/local/lib/python3.7/dist-packages (from aiohttp[speedups]>=3.7.4.post0->meross_iot==0.4.5.9) (2.1.1)
Requirement already satisfied: multidict<7.0,>=4.5 in /usr/local/lib/python3.7/dist-packages (from aiohttp[speedups]>=3.7.4.post0->meross_iot==0.4.5.9) (6.0.2)
Requirement already satisfied: async-timeout<5.0,>=4.0.0a3 in /usr/local/lib/python3.7/dist-packages (from aiohttp[speedups]>=3.7.4.post0->meross_iot==0.4.5.9) (4.0.2)
Requirement already satisfied: yarl<2.0,>=1.0 in /usr/local/lib/python3.7/dist-packages (from aiohttp[speedups]>=3.7.4.post0->meross_iot==0.4.5.9) (1.8.1)
Requirement already satisfied: frozenlist>=1.1.1 in /usr/local/lib/python3.7/dist-packages (from aiohttp[speedups]>=3.7.4.post0->meross_iot==0.4.5.9) (1.3.3)
Requirement already satisfied: aiosignal>=1.1.2 in /usr/local/lib/python3.7/dist-packages (from aiohttp[speedups]>=3.7.4.post0->meross_iot==0.4.5.9) (1.3.1)
Requirement already satisfied: asynctest==0.13.0 in /usr/local/lib/python3.7/dist-packages (from aiohttp[speedups]>=3.7.4.post0->meross_iot==0.4.5.9) (0.13.0)
Requirement already satisfied: typing-extensions>=3.7.4 in /usr/local/lib/python3.7/dist-packages (from aiohttp[speedups]>=3.7.4.post0->meross_iot==0.4.5.9) (4.4.0)
Requirement already satisfied: aiodns in /usr/local/lib/python3.7/dist-packages (from aiohttp[speedups]>=3.7.4.post0->meross_iot==0.4.5.9) (3.0.0)
Requirement already satisfied: Brotli in /usr/local/lib/python3.7/dist-packages (from aiohttp[speedups]>=3.7.4.post0->meross_iot==0.4.5.9) (1.0.9)
Requirement already satisfied: cchardet in /usr/local/lib/python3.7/dist-packages (from aiohttp[speedups]>=3.7.4.post0->meross_iot==0.4.5.9) (2.1.7)
Requirement already satisfied: idna>=2.0 in /usr/lib/python3/dist-packages (from yarl<2.0,>=1.0->aiohttp[speedups]>=3.7.4.post0->meross_iot==0.4.5.9) (2.6)
Requirement already satisfied: pycares>=4.0.0 in /usr/local/lib/python3.7/dist-packages (from aiodns->aiohttp[speedups]>=3.7.4.post0->meross_iot==0.4.5.9) (4.2.2)
Requirement already satisfied: cffi>=1.5.0 in /usr/local/lib/python3.7/dist-packages (from pycares>=4.0.0->aiodns->aiohttp[speedups]>=3.7.4.post0->meross_iot==0.4.5.9) (1.15.1)
Requirement already satisfied: pycparser in /usr/local/lib/python3.7/dist-packages (from cffi>=1.5.0->pycares>=4.0.0->aiodns->aiohttp[speedups]>=3.7.4.post0->meross_iot==0.4.5.9) (2.21)
Installation des dépendances terminée !
et pour ce qui concerne le log MerosSync
[2023-09-04 16:08:01][ERROR] : Impossible de lancer le démon meross, vérifiez la log
[2023-09-04 16:10:05][ERROR] : Merci de démarrer le démon !
[2023-09-04 16:10:06][ERROR] : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consécutivement
/usr/lib/python3/dist-packages/requests/__init__.py:91: RequestsDependencyWarning: urllib3 (1.26.8) or chardet (3.0.4) doesn't match a supported version!
RequestsDependencyWarning)
File "/var/www/html/plugins/MerosSync/resources/MerossIOTd/MerossIOTd.py", line 9, in <module>
import requests
File "/usr/lib/python3/dist-packages/requests/__init__.py", line 95, in <module>
from urllib3.contrib import pyopenssl
File "/usr/local/lib/python3.7/dist-packages/urllib3/contrib/pyopenssl.py", line 50, in <module>
import OpenSSL.SSL
File "/usr/local/lib/python3.7/dist-packages/OpenSSL/__init__.py", line 8, in <module>
from OpenSSL import crypto, SSL
File "/usr/local/lib/python3.7/dist-packages/OpenSSL/crypto.py", line 3279, in <module>
_lib.OpenSSL_add_all_algorithms()
AttributeError: module 'lib' has no attribute 'OpenSSL_add_all_algorithms'
[2023-09-04 16:11:06][ERROR] : Impossible de lancer le démon meross, vérifiez la log
[2023-09-04 16:15:06][ERROR] : Attention je pense qu'il y a un soucis avec le démon que j'ai relancé plus de 3 fois consécutivement
import requests
import OpenSSL.SSL
Si quelqu’un a une idée ? @jercle ?
merci ![]()
