bonjour tous le monde
suite à ma migration avec beaucoup de difficulté, j’arrive en fin à la fin de mes soucis.
mon seul et dernier souci et le plugin googlecast qui ne fonctionne pas impossible d’arriver à la fin des dépendances.
voici le log googlecast_update on voit des erreurs à la fin mais bon pour le coup je ne sais pas les interpréter et comment les régler.
merci pour votre aide CARI
Launch install of googlecast dependancies
-- Current OS version :
Description: Debian GNU/Linux 10 (buster)
-- Updating repo...
Hit:1 http://ftp.fr.debian.org/debian buster InRelease
Hit:2 http://security.debian.org/debian-security buster/updates InRelease
Hit:3 http://ftp.fr.debian.org/debian buster-updates InRelease
Hit:4 http://phoscon.de/apt/deconz buster InRelease
Reading package lists...
-- Installation of python3 and dependancies
Building dependency tree...
Reading state information...
build-essential is already the newest version (12.6).
python-dev is already the newest version (2.7.16-1).
python3 is already the newest version (3.7.3-1).
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
-- Installed version of Python :
Python 3.7.3
Your version of python is compatible with this plugin.
-- Installation of pip for python3 and necessary libraries
python3-pip is already the newest version (18.1-5).
python3-dev is already the newest version (3.7.3-1).
python-requests is already the newest version (2.21.0-1).
-- Installation of audio sox library
sox is already the newest version (14.4.2+git20190427-1).
-- Installation of TTS libraries
libttspico-utils is already the newest version (1.0+git20130326-9).
-- Installation of libav/ffmpeg libraries
ffmpeg is already the newest version (7:4.1.9-0+deb10u1).
-- Upgrade setuptools with command pip3 if not up to date
Could not install packages due to an EnvironmentError: [Errno 2] No such file or directory: '/usr/local/lib/python3.7/dist-packages/six-1.16.0.dist-info/METADATA'
Requirement already satisfied: setuptools>=42.0.0 in /usr/local/lib/python3.7/dist-packages (62.4.0)
-- Installed version of pip :
pip 18.1 from /usr/lib/python3/dist-packages/pip (python 3.7)
-- Installation of python library 'requests' with command pip3
Requirement already satisfied: requests>=2.21.0 in /usr/lib/python3/dist-packages (2.21.0)
-- Installation of python library 'protobuf' with command pip3
Requirement already satisfied: protobuf>=3.11.0 in /usr/local/lib/python3.7/dist-packages (4.21.1)
-- Installation of python library 'zeroconf' with command pip3
Collecting zeroconf==0.31.0
Using cached https://files.pythonhosted.org/packages/36/d4/cf3952bf4ed616e0fce6864894696b367a4a984c8de9ea7ff007ee0e55ee/zeroconf-0.31.0-py3-none-any.whl
Requirement already satisfied: ifaddr>=0.1.7 in /usr/local/lib/python3.7/dist-packages (from zeroconf==0.31.0) (0.1.7)
-- Installation of python library 'click, bs4 and six' for TTS with command pip3
No metadata found in /usr/local/lib/python3.7/dist-packages
Collecting click
Using cached https://files.pythonhosted.org/packages/c2/f1/df59e28c642d583f7dacffb1e0965d0e00b218e0186d7858ac5233dce840/click-8.1.3-py3-none-any.whl
Collecting bs4
Using cached https://files.pythonhosted.org/packages/10/ed/7e8b97591f6f456174139ec089c769f89a94a1a4025fe967691de971f314/bs4-0.0.1.tar.gz
Requirement already satisfied: six in /usr/local/lib/python3.7/dist-packages (1.16.0)
-- Installation of python library 'tqdm, websocket-client, casttube' for plex/youtube with command pip3
Collecting tqdm
Using cached https://files.pythonhosted.org/packages/8a/c4/d15f1e627fff25443ded77ea70a7b5532d6371498f9285d44d62587e209c/tqdm-4.64.0-py2.py3-none-any.whl
Collecting websocket-client
Using cached https://files.pythonhosted.org/packages/a1/9e/8ddb04ef21ea3dfe3924b884dc11fa785df662af23e049ec2d62eaba707d/websocket_client-1.3.2-py3-none-any.whl
Requirement already satisfied: casttube in /usr/local/lib/python3.7/dist-packages (0.2.1)
Requirement already satisfied: requests in /usr/lib/python3/dist-packages (from casttube) (2.21.0)
-- Installation of dependencies is done !
bon j’ai réussi à lancer les dépendance mais le demon reste en nok
voici le résultat du googlcast_update si cela peut aider:
-- Updating repo...
Hit:2 http://ftp.fr.debian.org/debian buster-updates InRelease
Hit:3 http://security.debian.org/debian-security buster/updates InRelease
Python 3.7.3
-- Upgrade setuptools with command pip3.7 if not up to date
WARNING: Running pip as the 'root' user can result in broken permissions and conflicting behaviour with the system package manager. It is recommended to use a virtual environment instead: https://pip.pypa.io/warnings/venv
pip 22.1.2 from /usr/local/lib/python3.7/dist-packages/pip (python 3.7)
-- Installation of python library 'requests' with command pip3.7
Requirement already satisfied: requests>=2.21.0 in /usr/local/lib/python3.7/dist-packages (2.28.0)
Requirement already satisfied: urllib3<1.27,>=1.21.1 in /usr/local/lib/python3.7/dist-packages (from requests>=2.21.0) (1.26.9)
Requirement already satisfied: charset-normalizer~=2.0.0 in /usr/local/lib/python3.7/dist-packages (from requests>=2.21.0) (2.0.12)
Requirement already satisfied: idna<4,>=2.5 in /usr/local/lib/python3.7/dist-packages (from requests>=2.21.0) (3.3)
Requirement already satisfied: certifi>=2017.4.17 in /usr/local/lib/python3.7/dist-packages (from requests>=2.21.0) (2022.6.15)
-- Installation of python library 'protobuf' with command pip3.7
-- Installation of python library 'zeroconf' with command pip3.7
Requirement already satisfied: zeroconf>=0.25.1 in /usr/local/lib/python3.7/dist-packages (0.38.7)
Requirement already satisfied: ifaddr>=0.1.7 in /usr/local/lib/python3.7/dist-packages (from zeroconf>=0.25.1) (0.2.0)
-- Installation of python library 'click, bs4 and six' for TTS with command pip3.7
Requirement already satisfied: click in /usr/local/lib/python3.7/dist-packages (8.1.3)
Requirement already satisfied: bs4 in /usr/local/lib/python3.7/dist-packages (0.0.1)
Requirement already satisfied: importlib-metadata in /usr/local/lib/python3.7/dist-packages (from click) (1.7.0)
Requirement already satisfied: beautifulsoup4 in /usr/local/lib/python3.7/dist-packages (from bs4) (4.11.1)
Requirement already satisfied: soupsieve>1.2 in /usr/local/lib/python3.7/dist-packages (from beautifulsoup4->bs4) (2.3.2.post1)
Requirement already satisfied: zipp>=0.5 in /usr/local/lib/python3.7/dist-packages (from importlib-metadata->click) (3.8.0)
-- Installation of python library 'tqdm, websocket-client, casttube' for plex/youtube with command pip3.7
Requirement already satisfied: tqdm in /usr/local/lib/python3.7/dist-packages (4.64.0)
Requirement already satisfied: websocket-client in /usr/local/lib/python3.7/dist-packages (1.3.2)
Requirement already satisfied: requests in /usr/local/lib/python3.7/dist-packages (from casttube) (2.28.0)
Requirement already satisfied: idna<4,>=2.5 in /usr/local/lib/python3.7/dist-packages (from requests->casttube) (3.3)
Requirement already satisfied: urllib3<1.27,>=1.21.1 in /usr/local/lib/python3.7/dist-packages (from requests->casttube) (1.26.9)
Requirement already satisfied: certifi>=2017.4.17 in /usr/local/lib/python3.7/dist-packages (from requests->casttube) (2022.6.15)
Requirement already satisfied: charset-normalizer~=2.0.0 in /usr/local/lib/python3.7/dist-packages (from requests->casttube) (2.0.12)
Je viens de migrer mon jeedom sur une VM dans proxmox.
Je n’ai pas rencontré de problème particulier, hormis le fait de réinstaller les dépendances de plusieurs plugin.
Mais je reste bloqué avec la même erreur pip que toi.
As tu trouvé la solution ?
Cependant y’aura t il une evolution sur le plugin ou autre car forcement des qu’on veut maj les packets python3 => googlecast est en carafe et il faut faire la manip.
