J’ai un soucis avec ZigbeeLinker, qui fonctionne correctement depuis plus d’un an mais, tout à coup, refuse de démarrer les dépendances…
Voici l’état du plugin :
Impossible donc d’aller dans la section « Expert ».
Voici les logs en DEBUG:
[2024-01-06 20:35:09]INFO : ##### Synchronisation du temps avant l'installation des dépendances...
[2024-01-06 20:35:24]INFO : ##### Synchronisation du temps terminée, lancement des dépendances.
# INSTALL : Zigbee2mqtt #
##### apt-get update in progress
Hit:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
Hit:2 http://archive.raspberrypi.org/debian buster InRelease
Hit:3 https://deb.nodesource.com/node_18.x nodistro InRelease
Hit:4 https://packagecloud.io/ookla/speedtest-cli/debian buster InRelease
Reading package lists...
##### Install or update Git
Building dependency tree...
Reading state information...
g++ is already the newest version (4:8.3.0-1+rpi2).
gcc is already the newest version (4:8.3.0-1+rpi2).
git is already the newest version (1:2.20.1-2+deb10u8).
make is already the newest version (4.2.1-1.2).
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
##### Install or update NodeJs
NodeJs 18 already installed : Nothing to do !
# INSTALLING : Mosquitto (server) #
mosquitto is already the newest version (1.5.7-1+deb10u1).
# INSTALLING : Mosquitto for Php #
Mosquitto for Php is already installed, nothing to do
##### Install Socat
Socat is already installed, nothing to do
##### Install yaml php and restart apache
Yaml is already installed, nothing to do
##### Stopping Zigbee2mqtt deamon #
Removed /etc/systemd/system/multi-user.target.wants/zigbee2mqtt.service.
##### Update : Download update from Zigbee2mqtt git
##### up to date
##### Configure deamon and start it
Created symlink /etc/systemd/system/multi-user.target.wants/zigbee2mqtt.service → /etc/systemd/system/zigbee2mqtt.service.
# END #
et
[2024-01-06 20:34:21]DEBUG : [Light][0x680ae2fffe0caa19] : Erreur Jeedom-->MQTT. Impossible de trouver le client MQTT à contacter pour envoyer la demande (essayez de réveiller l'équipement pour que l'interview soit complet)
[2024-01-06 20:35:25]DEBUG : [Light][0x680ae2fffe0caa19] : Erreur Jeedom-->MQTT. Impossible de trouver le client MQTT à contacter pour envoyer la demande (essayez de réveiller l'équipement pour que l'interview soit complet)
[2024-01-06 20:35:25]DEBUG : [Light][0xec1bbdfffe94a0f1] : Ping de réveil de l'équipement
[2024-01-06 20:35:25]DEBUG : [Light][0xec1bbdfffe94a0f1] : Jeedom-->MQTT, topic=zigbee2mqtt/0xec1bbdfffe94a0f1/get, json={"state":""}
[2024-01-06 20:35:25]DEBUG : [Light][Light - Road] : Ping de réveil de l'équipement
[2024-01-06 20:35:25]DEBUG : [Light][Light - Road] : Jeedom-->MQTT, topic=zigbee2mqtt/Light - Road/get, json={"state":""}
[2024-01-06 20:35:25]DEBUG : [Switch][Plug - Living Room] : Ping de réveil de l'équipement
[2024-01-06 20:35:25]DEBUG : [Switch][Plug - Living Room] : Jeedom-->MQTT, topic=zigbee2mqtt/Plug - Living Room/get, json={"state":""}
[2024-01-06 20:36:21]DEBUG : [Light][0x680ae2fffe0caa19] : Erreur Jeedom-->MQTT. Impossible de trouver le client MQTT à contacter pour envoyer la demande (essayez de réveiller l'équipement pour que l'interview soit complet)
[2024-01-06 20:37:21]DEBUG : [Light][0x680ae2fffe0caa19] : Erreur Jeedom-->MQTT. Impossible de trouver le client MQTT à contacter pour envoyer la demande (essayez de réveiller l'équipement pour que l'interview soit complet)
[2024-01-06 20:37:21]DEBUG : [Light][0xec1bbdfffe94a0f1] : Ping de réveil de l'équipement
[2024-01-06 20:37:21]DEBUG : [Light][0xec1bbdfffe94a0f1] : Jeedom-->MQTT, topic=zigbee2mqtt/0xec1bbdfffe94a0f1/get, json={"state":""}
[2024-01-06 20:37:21]DEBUG : [Light][Light - Road] : Ping de réveil de l'équipement
[2024-01-06 20:37:21]DEBUG : [Light][Light - Road] : Jeedom-->MQTT, topic=zigbee2mqtt/Light - Road/get, json={"state":""}
[2024-01-06 20:37:21]DEBUG : [Switch][Plug - Living Room] : Ping de réveil de l'équipement
[2024-01-06 20:37:21]DEBUG : [Switch][Plug - Living Room] : Jeedom-->MQTT, topic=zigbee2mqtt/Plug - Living Room/get, json={"state":""}
[2024-01-06 20:38:21]DEBUG : [Light][0x680ae2fffe0caa19] : Erreur Jeedom-->MQTT. Impossible de trouver le client MQTT à contacter pour envoyer la demande (essayez de réveiller l'équipement pour que l'interview soit complet)
[2024-01-06 20:39:21]DEBUG : [Light][0x680ae2fffe0caa19] : Erreur Jeedom-->MQTT. Impossible de trouver le client MQTT à contacter pour envoyer la demande (essayez de réveiller l'équipement pour que l'interview soit complet)
[2024-01-06 20:39:21]DEBUG : [Light][0xec1bbdfffe94a0f1] : Ping de réveil de l'équipement
[2024-01-06 20:39:21]DEBUG : [Light][0xec1bbdfffe94a0f1] : Jeedom-->MQTT, topic=zigbee2mqtt/0xec1bbdfffe94a0f1/get, json={"state":""}
[2024-01-06 20:39:21]DEBUG : [Light][Light - Road] : Ping de réveil de l'équipement
[2024-01-06 20:39:21]DEBUG : [Light][Light - Road] : Jeedom-->MQTT, topic=zigbee2mqtt/Light - Road/get, json={"state":""}
[2024-01-06 20:39:21]DEBUG : [Switch][Plug - Living Room] : Ping de réveil de l'équipement
[2024-01-06 20:39:21]DEBUG : [Switch][Plug - Living Room] : Jeedom-->MQTT, topic=zigbee2mqtt/Plug - Living Room/get, json={"state":""}
J’ai donc l’erreur : Erreur Jeedom–>MQTT. Impossible de trouver le client MQTT à contacter pour envoyer la demande (essayez de réveiller l’équipement pour que l’interview soit complet)
J’ai vérifié que :
- jeedom et tous les plugins sont à jour
- la version php est correcte - 7.3.31-1~deb10u1
- la commande « dpkg --configure -a » a été exécutée (c’était demandé dans les logs auparavant)
Auriez-vous la moindre suggestion ?
Merci !
