Je suis en V 4.4.0
L’install se passe sans soucis mais apparemment l’inscription d’origine ne fait pas
Si je tente une synchro j’ai :
Erreur lors de l'exécution de la commande : --username m.georgein@gmail.com get_master_token --password xxxxxxxxxxxxxxx
le log d’install des dépendance :
0000|********************************
0001|*Launch install of dependencies*
0002|********************************
0003|Thu Aug 31 18:34:06 CEST 2023
0004|Get:1 https://deb.nodesource.com/node_16.x buster InRelease [4584 B]
0005|Hit:2 https://download.docker.com/linux/debian buster InRelease
0006|Hit:3 http://deb.debian.org/debian buster InRelease
0007|Hit:4 http://phoscon.de/apt/deconz buster InRelease
0008|Hit:5 http://deb.debian.org/debian buster-updates InRelease
0009|Hit:6 http://security.debian.org/debian-security buster/updates InRelease
0010|Fetched 4584 B in 2s (3013 B/s)
0011|Reading package lists...
0012|*****************************
0013|Install modules using apt-get
0014|*****************************
0015|Reading package lists...
0016|Building dependency tree...
0017|Reading state information...
0018|python3-pip is already the newest version (18.1-5).
0019|python3-setuptools is already the newest version (40.8.0-1).
0020|python3 is already the newest version (3.7.3-1).
0021|python3-venv is already the newest version (3.7.3-1).
0022|python3-requests is already the newest version (2.21.0-1+deb10u1).
0023|0 upgraded, 0 newly installed, 0 to remove and 251 not upgraded.
0024|*************************************
0025|Creating python 3 virtual environment
0026|*************************************
0027|Done
0028|*************************************
0029|Install the required python libraries
0030|*************************************
0031|Requirement already satisfied: pip in /var/www/html/plugins/gkeep/resources/venv/lib/python3.7/site-packages (23.2.1)
0032|Requirement already satisfied: wheel in /var/www/html/plugins/gkeep/resources/venv/lib/python3.7/site-packages (0.41.2)
0033|Requirement already satisfied: urllib3<2 in /var/www/html/plugins/gkeep/resources/venv/lib/python3.7/site-packages (1.26.16)
0034|Requirement already satisfied: gkeepapi in /var/www/html/plugins/gkeep/resources/venv/lib/python3.7/site-packages (0.13.7)
0035|Requirement already satisfied: future>=0.16.0 in /var/www/html/plugins/gkeep/resources/venv/lib/python3.7/site-packages (from gkeepapi) (0.18.3)
0036|Requirement already satisfied: gpsoauth>=0.4.1 in /var/www/html/plugins/gkeep/resources/venv/lib/python3.7/site-packages (from gkeepapi) (0.4.3)
0037|Requirement already satisfied: six>=1.11.0 in /var/www/html/plugins/gkeep/resources/venv/lib/python3.7/site-packages (from gkeepapi) (1.16.0)
0038|Requirement already satisfied: pycryptodomex>=3.0 in /var/www/html/plugins/gkeep/resources/venv/lib/python3.7/site-packages (from gpsoauth>=0.4.1->gkeepapi) (3.18.0)
0039|Requirement already satisfied: requests in /var/www/html/plugins/gkeep/resources/venv/lib/python3.7/site-packages (from gpsoauth>=0.4.1->gkeepapi) (2.31.0)
0040|Requirement already satisfied: charset-normalizer<4,>=2 in /var/www/html/plugins/gkeep/resources/venv/lib/python3.7/site-packages (from requests->gpsoauth>=0.4.1->gkeepapi) (3.2.0)
0041|Requirement already satisfied: idna<4,>=2.5 in /var/www/html/plugins/gkeep/resources/venv/lib/python3.7/site-packages (from requests->gpsoauth>=0.4.1->gkeepapi) (3.4)
0042|Requirement already satisfied: urllib3<3,>=1.21.1 in /var/www/html/plugins/gkeep/resources/venv/lib/python3.7/site-packages (from requests->gpsoauth>=0.4.1->gkeepapi) (1.26.16)
0043|Requirement already satisfied: certifi>=2017.4.17 in /var/www/html/plugins/gkeep/resources/venv/lib/python3.7/site-packages (from requests->gpsoauth>=0.4.1->gkeepapi) (2023.7.22)
0044|*********************************
0045|Get version of installed packages
0046|*********************************
0047|Python 3.7.3
0048|Package Version
0049|------------------ ---------
0050|certifi 2023.7.22
0051|charset-normalizer 3.2.0
0052|future 0.18.3
0053|gkeepapi 0.13.7
0054|gpsoauth 0.4.3
0055|idna 3.4
0056|pip 23.2.1
0057|pkg_resources 0.0.0
0058|pycryptodomex 3.18.0
0059|requests 2.31.0
0060|setuptools 40.8.0
0061|six 1.16.0
0062|urllib3 1.26.16
0063|wheel 0.41.2
0064|Thu Aug 31 18:34:17 CEST 2023
0065|***************
0066|*Install ended*
0067|***************
le log après appui sur première connexion :
0023|[2023-08-31 18:40:34]DEBUG : Commande envoyée : sudo /var/www/html/plugins/gkeep/core/class/../../resources/venv/bin/python3 /var/www/html/plugins/gkeep/core/class/../../resources/gkeepmanager.py --username m.georgein@gmail.com get_master_token --password xxxxxxxxxxxxxxxxx
0024|[2023-08-31 18:40:35]DEBUG : Résultat brut Traceback (most recent call last): File "/var/www/html/plugins/gkeep/core/class/../../resources/gkeepmanager.py", line 902, in <module> main() File "/var/www/html/plugins/gkeep/core/class/../../resources/gkeepmanager.py", line 786, in main manager.get_master_token(args.username, args.password) File "/var/www/html/plugins/gkeep/core/class/../../resources/gkeepmanager.py", line 61, in get_master_token success = keep.login(self.username, password) File "/var/www/html/plugins/gkeep/resources/venv/lib/python3.7/site-packages/gkeepapi/__init__.py", line 695, in login ret = auth.login(username, password, device_id) File "/var/www/html/plugins/gkeep/resources/venv/lib/python3.7/site-packages/gkeepapi/__init__.py", line 60, in login res.get('Error'), res.get('ErrorDetail') gkeepapi.exception.LoginException: ('NeedsBrowser', 'To access your account, you must sign in on the web. Touch Next to start browser sign-in.')
0025|[2023-08-31 18:40:35]DEBUG : sendCmdAndFormatResult : Résultat brut Traceback (most recent call last): File "/var/www/html/plugins/gkeep/core/class/../../resources/gkeepmanager.py", line 902, in <module> main() File "/var/www/html/plugins/gkeep/core/class/../../resources/gkeepmanager.py", line 786, in main manager.get_master_token(args.username, args.password) File "/var/www/html/plugins/gkeep/core/class/../../resources/gkeepmanager.py", line 61, in get_master_token success = keep.login(self.username, password) File "/var/www/html/plugins/gkeep/resources/venv/lib/python3.7/site-packages/gkeepapi/__init__.py", line 695, in login ret = auth.login(username, password, device_id) File "/var/www/html/plugins/gkeep/resources/venv/lib/python3.7/site-packages/gkeepapi/__init__.py", line 60, in login res.get('Error'), res.get('ErrorDetail') gkeepapi.exception.LoginException: ('NeedsBrowser', 'To access your account, you must sign in on the web. Touch Next to start browser sign-in.')
0026|[2023-08-31 18:40:35]INFO : sendCmdAndFormatResult : Résultat array null
0027|[2023-08-31 18:40:35]WARNING : Erreur lors de l'exécution de la commande : --username m.georgein@gmail.com get_master_token --password xxxxxxxxxxxxxxx
test refait après re régénération du mot de passe par ggogle.
