Je viens de repartir sur une image propre de jeedom (celle du site), j’ai mis à jour les paquets, restaurer ma sauvegarde jeedom.
La console jeedom est bien accessible depuis http://maison.bebelcyl.fr.
J’ai à nouveau suivi la procédure sur youdom, j’ai à nouveau le même souci…
root@jeedom:/home/jeedom# certbot --apache
Saving debug log to /var/log/letsencrypt/letsencrypt.log
Plugins selected: Authenticator apache, Installer apache
Enter email address (used for urgent renewal and security notices) (Enter ‹ c › to
cancel): xxx
Would you be willing to share your email address with the Electronic Frontier
Foundation, a founding partner of the Let’s Encrypt project and the non-profit
organization that develops Certbot? We’d like to send you email about our work
encrypting the web, EFF news, campaigns, and ways to support digital freedom.
(Y)es/(N)o: n
No names were found in your configuration files. Please enter in your domain
name(s) (comma and/or space separated) (Enter ‹ c › to cancel): maison.bebelcyl.fr
Obtaining a new certificate
Performing the following challenges:
http-01 challenge for maison.bebelcyl.fr
Enabled Apache rewrite module
Waiting for verification…
Cleaning up challenges
Failed authorization procedure. maison.bebelcyl.fr (http-01): urn:ietf:params:acme:error:connection :: The server could not connect to the client to verify the domain :: Fetching http://maison.bebelcyl.fr/.well-known/acme-challenge/mJReeVxtyc3bo_3vJs7V3wN5BnC74cwOsakqpN3jNRM: Error getting validation data
To fix these errors, please make sure that your domain name was
entered correctly and the DNS A/AAAA record(s) for that domain
contain(s) the right IP address. Additionally, please check that
your computer has a publicly routable IP address and that no
firewalls are preventing the server from communicating with the
client. If you’re using the webroot plugin, you should also verify
that you are serving files from the webroot path you provided.
Your account credentials have been saved in your Certbot
configuration directory at /etc/letsencrypt. You should make a
secure backup of this folder now. This configuration directory will
also contain certificates and private keys obtained by Certbot so
making regular backups of this folder is ideal.
Je pense qu’il y a un problème d’accès depuis l’extérieur (hors réseau local) à ton installation.
Il est pour ma part impossible d’accéder par chrome à l’URL suivante : http://maison.bebelcyl.fr/
Ceci explique pourquoi letsencrypt n’arrive pas à valider le certificat
Je pense que tu peux supprimer l’enregistrement AAAA (maison) qui correspond à une adresse IPV6. Peu de chance que ton infrastructure de ton réseau local soit full IPV6
Au de la définition de tes DNS, je pense plutôt à un problème de configuration de ton réseau interne (routeur) pour rediriger le port 80 (et bien sur 443 une fois ton certificat validé) vers l’adresse IP de la machine qui héberge ton jeedom.
Suite à ta réinstallation, es-tu sur à 100% que l’adresse IP jest toujours celle que tu avais défini dans la configuration de ton routeur pour la redirection du port ?
Bonjour, merci de prendre le temps de m’aider
Je viens de tester plusieurs trucs :
La redirection via le nom de domaine maison.bebelcyl.fr est bien actif sur mon ip : 82.64.176.133 (tester avec mes caméras et accès sur la freebox ou mon nas).
En local, j’ai bien accès à mon raspberry qui est sur 192.168.1.44 (en http ou https)
Qd je teste depuis l’extérieur sur https://82.64.176.133:443 ou https://maison.bebelcyl.fr je tombe bien sur mon serveur (redirection port ok) -avec abs de certificat
Par contre, cela ne fonctionne pas en http. Je précise que le port 80 et bien redirigé vers le 80 du raspberry
Je pense donc que le souci vient du raspberry. Mes connaissances sont assez limités pour savoir où aller chercher… C’est étonnant que je puisse m’y connecter sur le port 80 en local mais pas en distanciel (j’ai regardé, apache écoute bien le port 80).
Par contre, il est toujours impossible de me connecter à ton serveur sur le port 80 ce qui empêche logiquement letsencrypt de valider le challenge et générer un certificat valide.
Je pense que tu devrais repartir sur une installation from scratch et vérifier avant toute chose que tu peux accéder à jeedom sur le port 80.
Une fois ceci fait, il suffit normalement d’installer les packages certbot et python-certbot-apache pour installer le certificat…
Edit :
J’ai supprimé les redirections de port sur la freebox pour les recreer… ça marche. J’ai pu valider le certificat en 2 temps 3 mouvements.
Merci à tous pour le temps pris pour m’aider. @thanaus@olive@Bison
