merci pour ton aide.
J’ai tenté la modification à cet endroit et rebooté le plugin sans succès. En le lançant en débug voici le log que cela me génère :
> zigbee2mqtt@1.30.0 start
> node index.js
Zigbee2MQTT:debug 2023-03-16 20:26:35: Loaded state from file /var/www/html/plugins/zigbee2mqtt/data/zigbee2mqtt/state.json
Zigbee2MQTT:info 2023-03-16 20:26:35: Logging to console and directory: '/var/www/html/plugins/zigbee2mqtt/data/zigbee2mqtt/log/2023-03-16.20-26-34' filename: log.txt
Zigbee2MQTT:debug 2023-03-16 20:26:35: Removing old log directory '/var/www/html/plugins/zigbee2mqtt/data/zigbee2mqtt/log/2023-03-16.18-03-29'
Zigbee2MQTT:info 2023-03-16 20:26:35: Starting Zigbee2MQTT version 1.30.0 (commit #8f781db9)
Zigbee2MQTT:info 2023-03-16 20:26:35: Starting zigbee-herdsman (0.14.89)
Zigbee2MQTT:debug 2023-03-16 20:26:35: Using zigbee-herdsman with settings: '{"adapter":{"concurrent":null,"delay":null,"disableLED":false},"backupPath":"/var/www/html/plugins/zigbee2mqtt/data/zigbee2mqtt/coordinator_backup.json","databaseBackupPath":"/var/www/html/plugins/zigbee2mqtt/data/zigbee2mqtt/database.db.backup","databasePath":"/var/www/html/plugins/zigbee2mqtt/data/zigbee2mqtt/database.db","network":{"channelList":[11],"extendedPanID":[221,221,221,221,221,221,221,221],"networkKey":"HIDDEN","panID":59534},"serialPort":{"adapter":"zstack","path":"/dev/ttyUSB1"}}'
2023-03-16T20:26:35.962Z zigbee-herdsman:controller:log Starting with options '{"network":{"networkKeyDistribute":false,"networkKey":[22,119,244,172,42,40,131,30,39,92,208,83,132,198,161,233],"panID":59534,"extendedPanID":[221,221,221,221,221,221,221,221],"channelList":[11]},"serialPort":{"path":"/dev/ttyUSB1","adapter":"zstack"},"databasePath":"/var/www/html/plugins/zigbee2mqtt/data/zigbee2mqtt/database.db","databaseBackupPath":"/var/www/html/plugins/zigbee2mqtt/data/zigbee2mqtt/database.db.backup","backupPath":"/var/www/html/plugins/zigbee2mqtt/data/zigbee2mqtt/coordinator_backup.json","adapter":{"disableLED":false,"concurrent":null,"delay":null}}'
2023-03-16T20:26:35.967Z zigbee-herdsman:adapter:zStack:znp:log Opening SerialPort with {"path":"/dev/ttyUSB1","baudRate":115200,"rtscts":false,"autoOpen":false}
2023-03-16T20:26:35.986Z zigbee-herdsman:adapter:zStack:znp:log Serialport opened
2023-03-16T20:26:35.991Z zigbee-herdsman:adapter:zStack:znp:SREQ --> SYS - ping - {"capabilities":1}
2023-03-16T20:26:35.994Z zigbee-herdsman:adapter:zStack:unpi:writer --> frame [254,0,33,1,32]
2023-03-16T20:26:36.251Z zigbee-herdsman:adapter:zStack:znp:log Writing CC2530/CC2531 skip bootloader payload
2023-03-16T20:26:36.252Z zigbee-herdsman:adapter:zStack:unpi:writer --> buffer [239]
2023-03-16T20:26:36.813Z zigbee-herdsman:adapter:zStack:unpi:parser <-- [254,2,97,1,89,6,61]
2023-03-16T20:26:36.815Z zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,2,97,1,89,6,61]
2023-03-16T20:26:36.817Z zigbee-herdsman:adapter:zStack:unpi:parser --> parsed 2 - 3 - 1 - 1 - [89,6] - 61
2023-03-16T20:26:36.820Z zigbee-herdsman:adapter:zStack:znp:SRSP <-- SYS - ping - {"capabilities":1625}
2023-03-16T20:26:36.822Z zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext []
2023-03-16T20:26:37.255Z zigbee-herdsman:adapter:zStack:znp:SREQ --> SYS - ping - {"capabilities":1}
2023-03-16T20:26:37.256Z zigbee-herdsman:adapter:zStack:unpi:writer --> frame [254,0,33,1,32]
2023-03-16T20:26:37.260Z zigbee-herdsman:adapter:zStack:unpi:parser <-- [254,2,97,1,89,6,61]
2023-03-16T20:26:37.261Z zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,2,97,1,89,6,61]
2023-03-16T20:26:37.261Z zigbee-herdsman:adapter:zStack:unpi:parser --> parsed 2 - 3 - 1 - 1 - [89,6] - 61
2023-03-16T20:26:37.261Z zigbee-herdsman:adapter:zStack:znp:SRSP <-- SYS - ping - {"capabilities":1625}
2023-03-16T20:26:37.263Z zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext []
2023-03-16T20:26:37.263Z zigbee-herdsman:adapter:zStack:znp:SREQ --> SYS - ping - {"capabilities":1}
2023-03-16T20:26:37.264Z zigbee-herdsman:adapter:zStack:unpi:writer --> frame [254,0,33,1,32]
2023-03-16T20:26:37.268Z zigbee-herdsman:adapter:zStack:unpi:parser <-- [254,2,97,1,89,6,61]
2023-03-16T20:26:37.269Z zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,2,97,1,89,6,61]
2023-03-16T20:26:37.270Z zigbee-herdsman:adapter:zStack:unpi:parser --> parsed 2 - 3 - 1 - 1 - [89,6] - 61
2023-03-16T20:26:37.270Z zigbee-herdsman:adapter:zStack:znp:SRSP <-- SYS - ping - {"capabilities":1625}
2023-03-16T20:26:37.271Z zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext []
2023-03-16T20:26:37.271Z zigbee-herdsman:adapter:zStack:znp:SREQ --> SYS - version - {}
2023-03-16T20:26:37.272Z zigbee-herdsman:adapter:zStack:unpi:writer --> frame [254,0,33,2,35]
2023-03-16T20:26:37.276Z zigbee-herdsman:adapter:zStack:unpi:parser <-- [254,10,97,2,2,1,2,7,1,20,100,52,1,0,43]
2023-03-16T20:26:37.277Z zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,10,97,2,2,1,2,7,1,20,100,52,1,0,43]
2023-03-16T20:26:37.277Z zigbee-herdsman:adapter:zStack:unpi:parser --> parsed 10 - 3 - 1 - 2 - [2,1,2,7,1,20,100,52,1,0] - 43
2023-03-16T20:26:37.278Z zigbee-herdsman:adapter:zStack:znp:SRSP <-- SYS - version - {"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20210708}
2023-03-16T20:26:37.279Z zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext []
2023-03-16T20:26:37.279Z zigbee-herdsman:adapter:zStack:adapter Adapter concurrent: 16
2023-03-16T20:26:37.279Z zigbee-herdsman:adapter:zStack:adapter Detected znp version 'zStack3x0' ({"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20210708})
2023-03-16T20:26:37.282Z zigbee-herdsman:adapter:zStack:startup beginning znp startup
2023-03-16T20:26:37.284Z zigbee-herdsman:adapter:zStack:znp:SREQ --> SYS - getExtAddr - {}
2023-03-16T20:26:37.284Z zigbee-herdsman:adapter:zStack:unpi:writer --> frame [254,0,33,4,37]
2023-03-16T20:26:37.289Z zigbee-herdsman:adapter:zStack:unpi:parser <-- [254,8,97,4,147,136,46,42,0,75,18,0,43]
2023-03-16T20:26:37.289Z zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,8,97,4,147,136,46,42,0,75,18,0,43]
2023-03-16T20:26:37.290Z zigbee-herdsman:adapter:zStack:unpi:parser --> parsed 8 - 3 - 1 - 4 - [147,136,46,42,0,75,18,0] - 43
2023-03-16T20:26:37.291Z zigbee-herdsman:adapter:zStack:znp:SRSP <-- SYS - getExtAddr - {"extaddress":"0x00124b002a2e8893"}
2023-03-16T20:26:37.291Z zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext []
2023-03-16T20:26:37.293Z zigbee-herdsman:adapter:zStack:znp:SREQ --> SYS - osalNvLength - {"id":130}
2023-03-16T20:26:37.295Z zigbee-herdsman:adapter:zStack:unpi:writer --> frame [254,2,33,19,130,0,178]
2023-03-16T20:26:37.303Z zigbee-herdsman:adapter:zStack:unpi:parser <-- [254,2,97,19,24,0,104]
2023-03-16T20:26:37.303Z zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,2,97,19,24,0,104]
2023-03-16T20:26:37.303Z zigbee-herdsman:adapter:zStack:unpi:parser --> parsed 2 - 3 - 1 - 19 - [24,0] - 104
2023-03-16T20:26:37.304Z zigbee-herdsman:adapter:zStack:znp:SRSP <-- SYS - osalNvLength - {"length":24}
2023-03-16T20:26:37.304Z zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext []
2023-03-16T20:26:37.305Z zigbee-herdsman:adapter:zStack:znp:SREQ --> SYS - osalNvReadExt - {"id":130,"offset":0}
2023-03-16T20:26:37.305Z zigbee-herdsman:adapter:zStack:unpi:writer --> frame [254,4,33,28,130,0,0,0,187]
2023-03-16T20:26:37.319Z zigbee-herdsman:adapter:zStack:unpi:parser <-- [254,26,97,28,0,24,0,22,119,244,172,42,40,131,30,39,92,208,83,132,198,161,233,231,1,0,0,20,4,0,221]
2023-03-16T20:26:37.319Z zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,26,97,28,0,24,0,22,119,244,172,42,40,131,30,39,92,208,83,132,198,161,233,231,1,0,0,20,4,0,221]
2023-03-16T20:26:37.320Z zigbee-herdsman:adapter:zStack:unpi:parser --> parsed 26 - 3 - 1 - 28 - [0,24,0,22,119,244,172,42,40,131,30,39,92,208,83,132,198,161,233,231,1,0,0,20,4,0] - 221
2023-03-16T20:26:37.321Z zigbee-herdsman:adapter:zStack:znp:SRSP <-- SYS - osalNvReadExt - {"status":0,"len":24,"value":{"type":"Buffer","data":[0,22,119,244,172,42,40,131,30,39,92,208,83,132,198,161,233,231,1,0,0,20,4,0]}}
2023-03-16T20:26:37.321Z zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext []
2023-03-16T20:26:37.323Z zigbee-herdsman:adapter:zStack:startup:strategy determining znp startup strategy
2023-03-16T20:26:37.325Z zigbee-herdsman:adapter:zStack:znp:SREQ --> SYS - osalNvLength - {"id":96}
2023-03-16T20:26:37.325Z zigbee-herdsman:adapter:zStack:unpi:writer --> frame [254,2,33,19,96,0,80]
2023-03-16T20:26:37.330Z zigbee-herdsman:adapter:zStack:unpi:parser <-- [254,2,97,19,1,0,113]
2023-03-16T20:26:37.331Z zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,2,97,19,1,0,113]
2023-03-16T20:26:37.331Z zigbee-herdsman:adapter:zStack:unpi:parser --> parsed 2 - 3 - 1 - 19 - [1,0] - 113
2023-03-16T20:26:37.331Z zigbee-herdsman:adapter:zStack:znp:SRSP <-- SYS - osalNvLength - {"length":1}
2023-03-16T20:26:37.332Z zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext []
2023-03-16T20:26:37.332Z zigbee-herdsman:adapter:zStack:znp:SREQ --> SYS - osalNvReadExt - {"id":96,"offset":0}
2023-03-16T20:26:37.333Z zigbee-herdsman:adapter:zStack:unpi:writer --> frame [254,4,33,28,96,0,0,0,89]
2023-03-16T20:26:37.347Z zigbee-herdsman:adapter:zStack:unpi:parser <-- [254,3,97,28,0,1,85,42]
2023-03-16T20:26:37.348Z zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,3,97,28,0,1,85,42]
2023-03-16T20:26:37.348Z zigbee-herdsman:adapter:zStack:unpi:parser --> parsed 3 - 3 - 1 - 28 - [0,1,85] - 42
2023-03-16T20:26:37.349Z zigbee-herdsman:adapter:zStack:znp:SRSP <-- SYS - osalNvReadExt - {"status":0,"len":1,"value":{"type":"Buffer","data":[85]}}
2023-03-16T20:26:37.349Z zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext []
2023-03-16T20:26:37.353Z zigbee-herdsman:adapter:zStack:znp:SREQ --> SYS - osalNvLength - {"id":33}
2023-03-16T20:26:37.354Z zigbee-herdsman:adapter:zStack:unpi:writer --> frame [254,2,33,19,33,0,17]
2023-03-16T20:26:37.358Z zigbee-herdsman:adapter:zStack:unpi:parser <-- [254,2,97,19,116,0,4]
2023-03-16T20:26:37.358Z zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,2,97,19,116,0,4]
2023-03-16T20:26:37.358Z zigbee-herdsman:adapter:zStack:unpi:parser --> parsed 2 - 3 - 1 - 19 - [116,0] - 4
2023-03-16T20:26:37.359Z zigbee-herdsman:adapter:zStack:znp:SRSP <-- SYS - osalNvLength - {"length":116}
2023-03-16T20:26:37.360Z zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext []
2023-03-16T20:26:37.360Z zigbee-herdsman:adapter:zStack:znp:SREQ --> SYS - osalNvReadExt - {"id":33,"offset":0}
2023-03-16T20:26:37.361Z zigbee-herdsman:adapter:zStack:unpi:writer --> frame [254,4,33,28,33,0,0,0,24]
2023-03-16T20:26:37.377Z zigbee-herdsman:adapter:zStack:unpi:parser <-- [254,118,97,28,0,116,66,5,2,51,15,51,0,30,0,0,0,1,5,1,143,0,7,0,2,13,30,0,0,0,20,0,0,0,0,0,0,0,0,0,0,0,142,232,8,0,0,0,16,0,15,15,4,0,1,0,0,0,1,0,0,0,0,147,136,46,42,0,75,18,0,1,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,15,5,0,1,100,10,1,0,0,0,116,111,0,0,225]
2023-03-16T20:26:37.377Z zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,118,97,28,0,116,66,5,2,51,15,51,0,30,0,0,0,1,5,1,143,0,7,0,2,13,30,0,0,0,20,0,0,0,0,0,0,0,0,0,0,0,142,232,8,0,0,0,16,0,15,15,4,0,1,0,0,0,1,0,0,0,0,147,136,46,42,0,75,18,0,1,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,15,5,0,1,100,10,1,0,0,0,116,111,0,0,225]
2023-03-16T20:26:37.378Z zigbee-herdsman:adapter:zStack:unpi:parser --> parsed 118 - 3 - 1 - 28 - [0,116,66,5,2,51,15,51,0,30,0,0,0,1,5,1,143,0,7,0,2,13,30,0,0,0,20,0,0,0,0,0,0,0,0,0,0,0,142,232,8,0,0,0,16,0,15,15,4,0,1,0,0,0,1,0,0,0,0,147,136,46,42,0,75,18,0,1,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,15,5,0,1,100,10,1,0,0,0,116,111,0,0] - 225
2023-03-16T20:26:37.378Z zigbee-herdsman:adapter:zStack:znp:SRSP <-- SYS - osalNvReadExt - {"status":0,"len":116,"value":{"type":"Buffer","data":[66,5,2,51,15,51,0,30,0,0,0,1,5,1,143,0,7,0,2,13,30,0,0,0,20,0,0,0,0,0,0,0,0,0,0,0,142,232,8,0,0,0,16,0,15,15,4,0,1,0,0,0,1,0,0,0,0,147,136,46,42,0,75,18,0,1,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,15,5,0,1,100,10,1,0,0,0,116,111,0,0]}}
2023-03-16T20:26:37.378Z zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext []
2023-03-16T20:26:37.385Z zigbee-herdsman:adapter:zStack:znp:SREQ --> SYS - osalNvLength - {"id":98}
2023-03-16T20:26:37.386Z zigbee-herdsman:adapter:zStack:unpi:writer --> frame [254,2,33,19,98,0,82]
2023-03-16T20:26:37.395Z zigbee-herdsman:adapter:zStack:unpi:parser <-- [254,2,97,19,16,0,96]
2023-03-16T20:26:37.396Z zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,2,97,19,16,0,96]
2023-03-16T20:26:37.396Z zigbee-herdsman:adapter:zStack:unpi:parser --> parsed 2 - 3 - 1 - 19 - [16,0] - 96
2023-03-16T20:26:37.396Z zigbee-herdsman:adapter:zStack:znp:SRSP <-- SYS - osalNvLength - {"length":16}
2023-03-16T20:26:37.397Z zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext []
2023-03-16T20:26:37.398Z zigbee-herdsman:adapter:zStack:znp:SREQ --> SYS - osalNvReadExt - {"id":98,"offset":0}
2023-03-16T20:26:37.398Z zigbee-herdsman:adapter:zStack:unpi:writer --> frame [254,4,33,28,98,0,0,0,91]
2023-03-16T20:26:37.415Z zigbee-herdsman:adapter:zStack:unpi:parser <-- [254,18,97,28,0,16,22,119,244,172,42,40,131,30,39,92,208,83,132,198,161,233,43]
2023-03-16T20:26:37.416Z zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,18,97,28,0,16,22,119,244,172,42,40,131,30,39,92,208,83,132,198,161,233,43]
2023-03-16T20:26:37.416Z zigbee-herdsman:adapter:zStack:unpi:parser --> parsed 18 - 3 - 1 - 28 - [0,16,22,119,244,172,42,40,131,30,39,92,208,83,132,198,161,233] - 43
2023-03-16T20:26:37.417Z zigbee-herdsman:adapter:zStack:znp:SRSP <-- SYS - osalNvReadExt - {"status":0,"len":16,"value":{"type":"Buffer","data":[22,119,244,172,42,40,131,30,39,92,208,83,132,198,161,233]}}
2023-03-16T20:26:37.417Z zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext []
2023-03-16T20:26:37.420Z zigbee-herdsman:adapter:zStack:znp:SREQ --> SYS - osalNvLength - {"id":58}
2023-03-16T20:26:37.420Z zigbee-herdsman:adapter:zStack:unpi:writer --> frame [254,2,33,19,58,0,10]
2023-03-16T20:26:37.425Z zigbee-herdsman:adapter:zStack:unpi:parser <-- [254,2,97,19,17,0,97]
2023-03-16T20:26:37.426Z zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,2,97,19,17,0,97]
2023-03-16T20:26:37.426Z zigbee-herdsman:adapter:zStack:unpi:parser --> parsed 2 - 3 - 1 - 19 - [17,0] - 97
2023-03-16T20:26:37.426Z zigbee-herdsman:adapter:zStack:znp:SRSP <-- SYS - osalNvLength - {"length":17}
2023-03-16T20:26:37.427Z zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext []
2023-03-16T20:26:37.427Z zigbee-herdsman:adapter:zStack:znp:SREQ --> SYS - osalNvReadExt - {"id":58,"offset":0}
2023-03-16T20:26:37.428Z zigbee-herdsman:adapter:zStack:unpi:writer --> frame [254,4,33,28,58,0,0,0,3]
2023-03-16T20:26:37.437Z zigbee-herdsman:adapter:zStack:unpi:parser <-- [254,19,97,28,0,17,0,22,119,244,172,42,40,131,30,39,92,208,83,132,198,161,233,43]
2023-03-16T20:26:37.437Z zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,19,97,28,0,17,0,22,119,244,172,42,40,131,30,39,92,208,83,132,198,161,233,43]
2023-03-16T20:26:37.438Z zigbee-herdsman:adapter:zStack:unpi:parser --> parsed 19 - 3 - 1 - 28 - [0,17,0,22,119,244,172,42,40,131,30,39,92,208,83,132,198,161,233] - 43
2023-03-16T20:26:37.438Z zigbee-herdsman:adapter:zStack:znp:SRSP <-- SYS - osalNvReadExt - {"status":0,"len":17,"value":{"type":"Buffer","data":[0,22,119,244,172,42,40,131,30,39,92,208,83,132,198,161,233]}}
2023-03-16T20:26:37.438Z zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext []
2023-03-16T20:26:37.439Z zigbee-herdsman:adapter:zStack:znp:SREQ --> SYS - osalNvLength - {"id":59}
2023-03-16T20:26:37.439Z zigbee-herdsman:adapter:zStack:unpi:writer --> frame [254,2,33,19,59,0,11]
2023-03-16T20:26:37.444Z zigbee-herdsman:adapter:zStack:unpi:parser <-- [254,2,97,19,17,0,97]
2023-03-16T20:26:37.444Z zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,2,97,19,17,0,97]
2023-03-16T20:26:37.445Z zigbee-herdsman:adapter:zStack:unpi:parser --> parsed 2 - 3 - 1 - 19 - [17,0] - 97
2023-03-16T20:26:37.446Z zigbee-herdsman:adapter:zStack:znp:SRSP <-- SYS - osalNvLength - {"length":17}
2023-03-16T20:26:37.446Z zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext []
2023-03-16T20:26:37.447Z zigbee-herdsman:adapter:zStack:znp:SREQ --> SYS - osalNvReadExt - {"id":59,"offset":0}
2023-03-16T20:26:37.447Z zigbee-herdsman:adapter:zStack:unpi:writer --> frame [254,4,33,28,59,0,0,0,2]
2023-03-16T20:26:37.455Z zigbee-herdsman:adapter:zStack:unpi:parser <-- [254,19,97,28,0,17,0,22,119,244,172,42,40,131,30,39,92,208,83,132,198,161,233,43]
2023-03-16T20:26:37.456Z zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,19,97,28,0,17,0,22,119,244,172,42,40,131,30,39,92,208,83,132,198,161,233,43]
2023-03-16T20:26:37.456Z zigbee-herdsman:adapter:zStack:unpi:parser --> parsed 19 - 3 - 1 - 28 - [0,17,0,22,119,244,172,42,40,131,30,39,92,208,83,132,198,161,233] - 43
2023-03-16T20:26:37.457Z zigbee-herdsman:adapter:zStack:znp:SRSP <-- SYS - osalNvReadExt - {"status":0,"len":17,"value":{"type":"Buffer","data":[0,22,119,244,172,42,40,131,30,39,92,208,83,132,198,161,233]}}
2023-03-16T20:26:37.458Z zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext []
2023-03-16T20:26:37.471Z zigbee-herdsman:adapter:zStack:startup:strategy (stage-1) adapter is configured
2023-03-16T20:26:37.472Z zigbee-herdsman:adapter:zStack:startup:strategy (stage-2) adapter state does not match configuration
2023-03-16T20:26:37.472Z zigbee-herdsman:adapter:zStack:startup:strategy (stage-3) got adapter backup
2023-03-16T20:26:37.472Z zigbee-herdsman:adapter:zStack:startup:strategy (stage-4) adapter state matches backup
Zigbee2MQTT:error 2023-03-16 20:26:37: Configuration is not consistent with adapter state/backup!
Zigbee2MQTT:error 2023-03-16 20:26:37: - PAN ID: configured=59534, adapter=59534
Zigbee2MQTT:error 2023-03-16 20:26:37: - Extended PAN ID: configured=00124b002a2e8893, adapter=00124b002a2e8893
Zigbee2MQTT:error 2023-03-16 20:26:37: - Network Key: configured=1677f4ac2a28831e275cd05384c6a1e9, adapter=1677f4ac2a28831e275cd05384c6a1e9
Zigbee2MQTT:error 2023-03-16 20:26:37: - Channel List: configured=11, adapter=20
Zigbee2MQTT:error 2023-03-16 20:26:37: Please update configuration to prevent further issues.
Zigbee2MQTT:error 2023-03-16 20:26:37: If you wish to re-commission your network, please remove coordinator backup at /var/www/html/plugins/zigbee2mqtt/data/zigbee2mqtt/coordinator_backup.json.
Zigbee2MQTT:error 2023-03-16 20:26:37: Re-commissioning your network will require re-pairing of all devices!
Zigbee2MQTT:error 2023-03-16 20:26:37: Error while starting zigbee-herdsman
Zigbee2MQTT:error 2023-03-16 20:26:37: Failed to start zigbee
Zigbee2MQTT:error 2023-03-16 20:26:37: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start.html for possible solutions
Zigbee2MQTT:error 2023-03-16 20:26:37: Exiting...
Zigbee2MQTT:error 2023-03-16 20:26:37: Error: startup failed - configuration-adapter mismatch - see logs above for more information
at ZnpAdapterManager.determineStrategy (/opt/zigbee2mqtt/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/manager.ts:229:35)
at ZnpAdapterManager.start (/opt/zigbee2mqtt/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/manager.ts:63:26)
at Controller.start (/opt/zigbee2mqtt/node_modules/zigbee-herdsman/src/controller/controller.ts:132:29)
at Zigbee.start (/opt/zigbee2mqtt/lib/zigbee.ts:58:27)
at Controller.start (/opt/zigbee2mqtt/lib/controller.ts:101:27)
at start (/opt/zigbee2mqtt/index.js:107:5)
Etrangement tout va bien quand je suis sur le canal par défaut (20) mais dès que j’en change ça pète.
Les messages en fin de log semblent indiquer un soucis avec le dongle.
En remettant le 20 tout repart bien.
J’ai pensé à un conflit de canal avec Deconz qui est aussi sur le canal 11 mais même en tentant le canal 15 ça ne passe pas.
